HMC-T2270
Synthesized Signal Generator, 10 MHz to 70 GHz
2 Elizabeth Drive • Chelmsford, MA 01824
Phone:
978-250-3343
Fax:
Information furnished by Analog Devices
is believed
to be accurate
and 978-250-3373
reliable. However, no
responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other
Order
Onlinesubject
at www.tm-hittite.com
rights of third parties that may result from its use.
Specifications
to change without notice. No
license is granted by implication or otherwise under any patent or patent rights of Analog Devices.
Trademarks and registered trademarks are the property of their respective owners.
Instrumentation Product Support at TE@hittite.com
HMC-T2270* PRODUCT PAGE QUICK LINKS
Last Content Update: 02/23/2017
COMPARABLE PARTS
DESIGN RESOURCES
View a parametric search of comparable parts.
• HMC-T2270 Material Declaration
• PCN-PDN Information
DOCUMENTATION
• Quality And Reliability
Application Notes
• Symbols and Footprints
• Pulsed Modulation
Data Sheet
DISCUSSIONS
• HMC-T2270: Synthesized Signal Generator, 10 MHz to 70
GHz Data Sheet
View all HMC-T2270 EngineerZone Discussions.
User Guides
SAMPLE AND BUY
• Programmer’s Manual Installation, Operation &
Maintenance Guide for HMC-T2220, HMC-T2220B, HMCT2240, and HMC-T2270
Visit the product page to see pricing options.
• User Manual - Synthesized Signal Generator Family - HMCT2220/40/70, HMC-T2220B
TECHNICAL SUPPORT
Submit a technical question or find your regional support
number.
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not
trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
HMC-T2270
SYNTHESIZED SIGNAL GENERATOR, 10 MHz to 70 GHz
v05.0216
Wide Frequency Range, 10 MHz to 70 GHz Signal Generator!
The HMC-T2270 is an easy to implement test equipment solution designed to fulfill your signal
generation needs. Built on a foundation of high quality and market leading Hittite MMICs, the
HMC-T2270 provides high output power, low harmonic levels and broad frequency range.
This compact and light weight signal generator also features USB, GPIB and Ethernet
interfaces ensuring carefree integration within various test environments while improving overall
productivity and equipment utilization.
Applications
ATE
Test & Measurement
SYNthesized Signal Generator
R&D Laboratories
2
Advantages
Versatile: Simplifies Test Set-Ups
Efficient: 500 µs Frequency Switching
Reliable: Incorporates Hittite MMICs
Flexible: Manual or Software Control
Via USB, GPIB or Ethernet
Performance
High Output Power:
+26 dBm @ 1 GHz
+3.0 dBm @ 70 GHz
Wide Frequency Range:
10 MHz to 70 GHz
Excellent Phase Noise Performance:
-118 dBc/Hz @ 10 kHz Offset @ 1 GHz
-79 dBc/Hz @ 100 kHz Offset @ 67 GHz
Integer Spurious:
< -65 dBc
Power Resolution: 0.1 dB
Frequency Resolution: 1 Hz
For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
Phone: 781-329-4700 • Order online at www.analog.com
Application Support: Phone: 1-800-ANALOG-D
HMC-T2270
Output Power Range
Harmonics
Frequency
(GHz)
30
OUTPUT POWER (dBm)
0.5
1
2
5
10
15
25
30
40
50
60
70
10
-20
-30
-40
-50
-60
-70
10
40
50
60
70
FREQUENCY (GHz)
Max. Pout
Min. Pout
Dynamic Range:
> 60 dB
Resolution:
0.1 dB
Power Accuracy:
± 1 dB > 500 MHz
± 2 dB ≤ 500 MHz
± 2 dB < -20 dBm (All Frequencies)
RF OFF
3rd
Harmonics
(dBc)
-44
-55
-50
-40
-59
-64
-60
Output Power = +10 dBm
Output Power:
+10 dBm at or below 40 GHz
See Max. Power above 40 GHz
SSB Phase Noise (dBc/Hz)
RESIDUAL PHASE NOISE (dBc/Hz)
2nd
Harmonics
(dBc)
-38
-34
-39
-32
-37
-33
-40
-29
-40
< -90 dBm
SSB Phase Noise vs. Frequency
-20
-40
-60
-80
-100
-120
-140
-160 2
10
SubHarmonics
(dBc)
-77
-78
-78
-78
-74
-58
-41
-71
-70
-50
-46
-50
-58
3
10
4
5
10
10
OFFSET FREQUENCY (Hz)
6
10
10 MHz
40 GHz
1 GHz
10 GHz
50 GHz
60 GHz
20 GHz
30 GHz
67 GHz
7
10
Spurious
< -65 dBc @ Integer Frequencies (See Table)
< -63 dBc @ Fractional Frequencies 40 GHz
Offset From Carrier
Frequency
(GHz)
10 Hz
100 Hz
1 kHz
0.01
1
10
40
50
60
67
-86
-80
-63
-62
-54
-51
-45
-41
-46
-95
-90
-72
-66
-62
-60
-55
-54
-51
-104
-111
-90
-85
-80
-78
-75
-76
-74
10 kHz 100 kHz 1 MHz 10 MHz
-112
-118
-97
-90
-87
-84
-81
-81
-79
-107
-118
-98
-92
-87
-87
-80
-81
-79
-126
-134
-117
-111
-105
-105
-96
-98
-96
-140
-143
-141
-136
-127
-129
-120
-121
-120
Integer Frequencies *
Frequency Band
(MHz)
25 - 450
450 - 625
625 - 1250
1250 - 2500
2500 - 5000
5000 - 10000
10000 - 20000
20000 - 40000
40000 - 70000
Frequency Step Size (MHz)
25
6.25
12.5
25
50
100
200
400
800
* All other frequencies are fractional.
40
v05.0216
Above data is typical performance at +25°C after 30 minutes of warm-up time unless otherwise stated.
3
HMC-T2270
General Specifications
Frequency:
Accuracy:
For < 2.5 GHz, Reference +0/-90 nHz
For > 2.5 GHz, Reference +0/-2.88 uHz
Internal Reference: ±1.5 ppm
Resolution: 1 Hz
Aging Rate:
很抱歉,暂时无法提供与“HMC-T2270”相匹配的价格&库存,您可以联系我们找货
