ADL945HD-T2500
ADL945HD-T2500
    ADL
    ADL945HD-T2500 - Intel Celeron M / Core Duo / Core 2 Duo: 1.07GHz - 2.16GHz - Advanced Digital Logic...
ADL945HD-T2500 数据手册
3.5-inch ADL945HD Intel Celeron M / Core Duo / Core 2 Duo: 1.07GHz - 2.16GHz Features • • • • • • • • • • • • • Intel Celeron M / Core Duo / Core 2 Duo 1.07GHz to 2.16GHz 945GME / ICH7R Chipset Up to 4GB DDR2 - 667MHz SDRAM Hardware Monitoring Power Management 8x USB 2.0 Onboard Digital Video Interface (DVI) Gigabit Ethernet LAN Controller Mini-PCI socket 3.5-inch form factor 2x SATA 300 ATX Power Control Ordering Guide Item Code ADL945HD-423CM ADL945HD-440CM ADL945HD-U2500 ADL945HD-L2400 ADL945HD-T2500 ADL945HD-T7400 ADL945HD-L7400 Standard DDR2 RAM DDR2-DRAM512 DDR2-DRAM1024 DDR2-DRAM2048 996925 512MB 667MHz 200-pin SODIMM 996025 1024MB 667MHz 200-pin SODIMM 996125 2048MB 667MHz 200-pin SODIMM Description Description Part # 294110 SingleCore 1.07GHz, 1M cache 294111 SingleCore 1.86GHz, 1M cache 294112 DualCore 1.2GHz, 2M cache 294113 DualCore 1.66GHz, 2M cache 294114 DualCore 2GHz, 2M cache 294115 DualCore 2.16GHz, 4M cache 294116 DualCore 1.5GHz, 4M cache The ADL945HD is based on the Intel® Core™2 Duo / Core™Duo / Core™Solo Processors, with clock speeds up to 2.16GHz, and the Intel® 945GME / ICH7R chipset. The Intel® Generation 3.5 graphics engine is integrated into the chipset, along with the Intel® Graphics Media Accelerator 950 (Intel® GMA 950), and can drive either a CRT/DVI and/or LVDS LCD. The memory is added by way of a SODIMM200 socket and can accept up to four Gigabytes of DDR2 DRAM. The ADL945HD power management incorporates ACPI/APM functions. The standard ADL945HD also incorporates EIDE, SATA, 4x Onboard External USB 2.0, 4x Internal USB 2.0, 4x RS232 COM ports, PS/2 Keyboard and Mouse, AC97 Sound, separate 10/100Mbit and Gigabit Ethernet LAN, and more. ADL offers highly effective active and passive cooling solutions based on proven thermal data and mounting techniques; resulting in the least possible mechanical board stress. Please contact your Sales Engineer for detailed information on cooling solutions to fit your needs. Extended Temperature DDR2 RAM DDR2-DRAM512-EX 996927 915/945DDR2 512MB 667MHz 200pin -40°C-+85°C DDR2-DRAM1024-EX 996027 915/945DDR2 1GB 667MHz 200pin -40°C-+85°C DDR2-DRAM2048-EX 996127 915/945DDR2 2GB 667MHz 200pin -40°C- +85°C Data subject to change without notice Advanced Digital Logic, Inc.; 4411 Morena Blvd., Suite 101; San Diego, CA 92117-4345 Ph. 858 490-0597 F. 858 490-0599; e-mail: sales@adl-usa.com; web: www.adl-usa.com 3.5-inch Technical Specifications FEATURE Processor/CPU: L2-Cache: Front Side Bus: CPU-Clock: Memory 200pin DDR2 SODIMM: Video Controller: Video Memory: Video Interfaces: Video Channel 1: Video Channel 2: Real Time Clock: LAN-Controller: AC97-Controller: SMBus-Controller: USB2-Controller: Resistive Touchscreen Flash BIOS: BIOS: Power Management Control: EIDE-Controller: FUNCTION Intel® Celeron M Core™2 Duo / Core™Duo / 2MB / 4MB 533/667 MHz 1.07GHz - 2.16GHz 512MB - 4096MB 945GME integrated Gen 3.5 engine 8MB UMA / 224MB DVMT VGA-Analog, CRT, LVDS 2048 x 1536 1600 x 1200 Yes INTEL – ICH7R – ext. PHY 82562GZ INTEL – ICH7R – AC97 V2.3 INTEL – ICH7R – SMBus 8 Ports V2.0 Dedicated connector 512KB Award ACPI / APM PIO 1-4, UDMA 100*/66*/33 REMARKS CPU dependent CPU dependent OPTIONS U2500 - 533FSB / L2400, L7400, T7400 667FSB Intel® Graphics Media Accelerator 950 (Intel® GMA 950) External Battery Required for RTC Intel 573E for 10/100/1000 ALC655 Codec 5.1 Sound Does not occupy existing COM or USB ports. Primary Master/Slave *requires 80 conductor cable SATA Controller HW-Monitor: Audio Output: Audio Input: Keyboard / Mouse COM1 - COM4 Ports 1 and 2 Winbond W83627HG Stereo Output and SPDif Stereo-Line, Mic and SPDif PS/2-USB RS232 1.5Gb/3.0Gb supported 5.1 Support 1x onboard, 3x internal connector I2C Bus SMBus GPIO PCI-Bus: Power Supply: Power consumption: Operating Temperature: (typ. ambient) Dimensions: Weight: (gr) Winbond 83627HG ICH7R Winbond 83627HG Mini-PCI interface 100W ATX Interface +5, +12 (recommended) 2.5 Amps - 11 Amps max @ +5V -25°C to +60°C 147mm x 20mm x 102mm TBD x16 lines suported CPU dependent -40°C to +85°C available upon request Provided CPU die is kept below 100°C at all times with sufficient thermal path to dissipate 3.5-inch form Factor Data subject to change without notice Advanced Digital Logic, Inc.; 4411 Morena Blvd., Suite 101; San Diego, CA 92117-4345 Ph. 858 490-0597 F. 858 490-0599; e-mail: sales@adl-usa.com; web: www.adl-usa.com
ADL945HD-T2500 价格&库存
很抱歉,暂时无法提供与“ADL945HD-T2500”相匹配的价格&库存,您可以联系我们找货
