T0905
T0905
    ATMEL(爱特梅尔)
    T0905 - General- purpose VHF/UHF Power Amplifier (135 to 600 MHz) - ATMEL Corporation
T0905 数据手册
Features • • • • • • 35 dBm Output Power in CW Mode High Power Added Efficiency (PAE) Single Supply Operation (No Negative Rail) Simple Analog Power Ramp Control Low Current Consumption in Power-down Mode (Typically ≤15 µA) Small SMD Package (PSSOP28 with Heat Slug) Applications • • • • Professional Phones Hands-free Sets ISM Band Application Wireless Infrastructure Preamplifiers Description The T0905 is a monolithic integrated power amplifier IC manufactured with Atmel’s Silicon-Germanium (SiGe) process. Due to its open architecture, the device can be used either as a two or three-stage amplifier. Every stage can be matched individually, thus allowing applications in a wide frequency range. The T0905 can be used from 135 MHz up to 600 MHz in both linear and non-linear (saturated) mode. The power gain can be set dynamically by means of an analog control input optionally for each single stage or for the entire power amplifier. Constant gain mode is also possible. The T0905 is suited for CW mode up to 35 dBm. These features, including wide power ramp control, make the T0905 a very flexible power amplifier for many different applications. Apart from telephone applications, the T0905 can also be used for car identification systems and several other wireless communication systems. The single supply voltage operation at +3.5 V and a negligible leakage current in power-down mode enable a remarkable simplification of the application’s power management. Figure 1. Block Diagram VCTL1 Generalpurpose VHF/UHF Power Amplifier (135 to 600 MHz) T0905 Preliminary GAIN1 16 VCTL2 GAIN2 VCTL3 GAIN3 15 Buf3 13 14 Buf2 17 18 19 VBIAS3 11 BGOUT VCTL VCC_CTL 12 10 BG Buf1 9 8 20 VBIAS2 VB2_DC VB3_DC RFOUT/VCC3 7 RFIN1 21 GND3 Match RF1 Match RF2 Match RF3 22-25 6 5 4 3 28 27 VB3 26 GND3 GND1 VCC1 GND2 VCC2 RFIN2 Rev. 4751D–SIGE–05/04 Pin Configuration Figure 2. Pinning PSSOP28 NC GND2 GND2 RFin2 VCC1 GND1 RFIN1 VB2_DC VBIAS2 VCC_CTL BGOUT VCTL VCTL1 VCTL2 1 2 3 4 5 6 7 8 9 10 11 12 13 14 28 27 26 25 24 23 22 21 20 19 18 17 16 15 VCC2 VB3 GND3 RFOUT/VCC3 RFOUT/VCC3 RFOUT/VCC3 RFOUT/VCC3 GND3 VB3_DC VBIAS3 GAIN3 GAIN2 GAIN1 VCTL3 Pin Description Pin 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 Symbol NC GND2 GND2 RFIN2 VCC1 GND1 RFIN1 VB2_DC VBIAS2 VCC_CTL BGOUT VCTL VCTL1 VCTL2 VCTL3 GAIN1 GAIN2 GAIN3 VBIAS3 VB3_DC GND3 RFOUT/VCC3 RFOUT/VCC3 RFOUT/VCC3 Function Not connected Ground Ground RF input (2-stage operation) Supply voltage, first stage Ground RF input (3-stage operation) Input for gain setting, second stage Output Buf2 Supply voltage control block Output band gap Control voltage input Control voltage input, first stage Control voltage input, second stage Control voltage input, third stage Gain setting Buf1 Gain setting Buf2 Gain setting Buf3 Output Buf3 Input for gain setting, third stage Ground RF output/supply voltage, third stage RF output/supply voltage, third stage RF output/supply voltage, third stage 2 T0905 [Preliminary] 4751D–SIGE–05/04 T0905 [Preliminary] Pin Description (Continued) Pin 25 26 27 28 Symbol RFOUT/VCC3 GND3 VB3 VCC2 Function RF output/supply voltage, third stage Ground Pin to extend the input capacity of stage 3 Supply voltage second stage Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Parameters Supply voltage VCC, no RF Input power Gain control voltage(1) Operating case temperature Storage temperature Maximum output power Note: Symbol VCC1, VCC2, VCC3 PRFin Vctl Tc Tstg PRFout Value 0 to +5.5 10 0 to +2.5 -40 to 100 -40 to +150 36 Unit V dBm V °C °C dBm 1. The part may not survive all maximums applied simultaneously Thermal Resistance Parameters Junction case Symbol RthJC Value 19 Unit K/W Operating Range All voltages are referred to GND Parameters Supply voltage Ambient temperature Input frequency Symbol VCC Tamb fRfin Value 2.7 to 5.0 -40 to +85 135 to 600 Unit V °C MHz 3 4751D–SIGE–05/04 Electrical Characteristics Test conditions (if not otherwise specified): VCC = +3.5 V, Tamb = +25°C, 50 Ω input and 50 Ω output match No. 1 1.1 2 2.1 Parameters Power Supply Current consumption power down mode (leakage current) Frequency range Output power normal conditions VCC = 3.5 V Tamb = +25°C PRFin = 3 dBm RL = RG = 50 Ω VCC = 2.4 V Tamb = +85°C PRFin = 3 dBm RL = RG = 50 Ω VCC = 3.5 V PRFout = 35.0 dBm PRFout = 35 dBm PRFin = 0 to 8 dBm PRFout = 31.0 dBm PRFout = 31.0 dBm VCC = 4.6 V Vctlx ≤0.2 V 10, 22 25, 28 I 15 25 µA A Test Conditions Pin Symbol Min. Typ. Max. Unit Type* 150-MHz Amplifier Mode fRfin150 22 - 25 PRFout150 135 178 MHz C 2.2 34.0 35.0 dBm C 2.3 Extreme conditions 22 - 25 PRFout150 PRFin150 PAE150 I150 VSWR150 VSWR150 2fo150 3fo150 4fo..8fo150 PRFout150 32.0 33.0 dBm C 2.4 2.5 2.6 2.7 2.8 2.9 2.10 2.11 Input power Power added efficiency Current consumption active mode Input VSWR Stability/load mismatch 2nd harmonic distortion 3rd harmonic distortion 4th to 8th harmonic distortion Isolation between input and output PRfin150 = 8 dBm Vctl ≤0.2 V (power down) 4 10, 22 25, 28 10, 22 25, 28 4 22 - 25 22 - 25 22 - 25 22 - 25 4, 22 - 25 3 50 55 1.64 10 dBm % A C C C C C 2:1 8:1 -35 -35 -35 dBc dBc dBc C C C 2.12 3 3.1 -30 dBm C 450-MHz Amplifier Mode Frequency range Output power normal conditions VCC = 3.5 V Tamb = +25°C PRFin = 3 dBm RL = RG = 50 Ω VCC = 2.4 V Tamb = +85°C PRFin = 3 dBm RL = RG = 50 Ω fRfin450 22 - 25 PRFout450 380 520 MHz A 3.2 34.0 35.0 dBm A 3.3 Extreme conditions 22 - 25 PRFout450 PRFin450 32.0 33.0 dBm C 3.4 Input power 4 3 10 dBm A *) Type means: A = 100% tested, B = 100% correlation tested, C = Characterized on samples, D = Design parameter 4 T0905 [Preliminary] 4751D–SIGE–05/04 T0905 [Preliminary] Electrical Characteristics (Continued) Test conditions (if not otherwise specified): VCC = +3.5 V, Tamb = +25°C, 50 Ω input and 50 Ω output match No. 3.5 3.6 3.7 3.8 3.9 3.10 3.11 Parameters Power added efficiency Current consumption active mode Input VSWR Stability/load mismatch 2nd harmonic distortion 3rd harmonic distortion 4th to 8th harmonic distortion Isolation between input and output Power Control Control curve slope Power control range Control voltage range Control current PRFin = 0 to 8 dBm Vctl = 0 to 2.0 V PRFout ≥ 5 dBm PRFout ≥ 25 dBm Vctl = 0 to 2.5 V 22 - 25 22 - 25 12 - 14 12 - 14 Sctl Gctl Vctl Ictll 60 0.5 2.0 200 300 120 350 150 dB/V dB/V dB V µA C C C A PRfin150 = 8 dBm Vctl ≤0.2 V (power down) Test Conditions VCC = 3.5 V PRFout = 35.0 dBm PRFout = 35 dBm PAE = 55% PRfin450 = 0 to 8 dBm PRFout = 31.0 dBm PRFout450 = 31.0 dBm VCC = 4.6 V Pin 10, 22 25, 28 10, 22 25, 28 4 22 - 25 22 - 25 22 - 25 22 - 25 4, 22 - 25 Symbol PAE450 I450 VSWR450 VSWR450 2fo450 3fo450 4fo..8fo450 PRFout450 Min. 50 Typ. 55 1.64 2:1 8:1 -35 -35 -35 dBc dBc dBc Max. Unit % A Type* A A C C A A C 3.12 4 4.1 4.2 4.3 4.4 -30 dBm A *) Type means: A = 100% tested, B = 100% correlation tested, C = Characterized on samples, D = Design parameter 5 4751D–SIGE–05/04 Figure 3. Application Example for 450-MHz PA with Variable Gain VCTL R3 VCTL1 13 GAIN1 VCTL2 16 14 R7 GAIN2 VCTL3 17 15 R11 GAIN3 18 19 Buf3 9 BG 8 20 7 22-25 Match RF1 Match RF2 28 VCC2 MS6 R14 BGOUT C4 11 Buf1 Buf2 VBIAS3 VCTL 12 VBIAS2 VB2_DC L1 VB3_DC MS3 RFOUT/ VCC3 L3 C24 R13 L5 L13 L8 MS4 C20 C21 C8 RFOUT C7 C19 C1 L2 C2 C5 VCC_CTL 10 VCC_CTL C18 L9 RFIN L4 21 GND3 C3 MS5 RFIN1 Match RF3 27 VB3 26 GND3 6 GND1 5 4 3 GND2 VCC1 RFin2 MS7 MS1 Micro strip lines length/mm width/mm MS1 2.5 1 MS2 2 1 MS3 2.5 1.6 MS4 5 0.43 MS5 4 0.43 MS6 3 0.63 MS7 2 0.3 MS8 2 0.3 MS9 4 0.63 Board material: Epsilon(r): 4.3; metal Cu: 35 µm; distance 1. layer - RF ground: 240 µm MS8 C28 MS9 C26 MS2 R15 L7 C27 C14 L10 C11 L11 C17 C12 C16 C13 C9 C10 C15 VCC1 VCC2 VCC3 6 T0905 [Preliminary] 4751D–SIGE–05/04 T0905 [Preliminary] Figure 4. Recommended Package Footprint Extract from the PCB Showing a Part of the Core Application (Without Components) • • • • Only ground signal traces are recommended directly under the package. Maximum density of ground vias guarantees an optimum connection of the ground layers and the best diversion of the heat. Heat slug must be soldered to GND. Plugging of the ground vias under the heat slug is recommended to avoid soldering problems. 7 4751D–SIGE–05/04 Ordering Information Extended Type Number T0905-TSPH Package PSSOP28 Remarks Lead-free Package Information Package PSSOP28 Dimensions in mm 9.98 9.80 1.60 1.45 0.25 0.64 8.32 28 15 0.10 0.00 3.91 6.02 0.2 2.21 1.80 technical drawings according to DIN specifications 1 7.29 6.88 14 8 T0905 [Preliminary] 4751D–SIGE–05/04 Atmel Corporation 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 487-2600 Atmel Operations Memory 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 436-4314 RF/Automotive Theresienstrasse 2 Postfach 3535 74025 Heilbronn, Germany Tel: (49) 71-31-67-0 Fax: (49) 71-31-67-2340 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906, USA Tel: 1(719) 576-3300 Fax: 1(719) 540-1759 Regional Headquarters Europe Atmel Sarl Route des Arsenaux 41 Case Postale 80 CH-1705 Fribourg Switzerland Tel: (41) 26-426-5555 Fax: (41) 26-426-5500 Microcontrollers 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 436-4314 La Chantrerie BP 70602 44306 Nantes Cedex 3, France Tel: (33) 2-40-18-18-18 Fax: (33) 2-40-18-19-60 Biometrics/Imaging/Hi-Rel MPU/ High Speed Converters/RF Datacom Avenue de Rochepleine BP 123 38521 Saint-Egreve Cedex, France Tel: (33) 4-76-58-30-00 Fax: (33) 4-76-58-34-80 Asia Room 1219 Chinachem Golden Plaza 77 Mody Road Tsimshatsui East Kowloon Hong Kong Tel: (852) 2721-9778 Fax: (852) 2722-1369 ASIC/ASSP/Smart Cards Zone Industrielle 13106 Rousset Cedex, France Tel: (33) 4-42-53-60-00 Fax: (33) 4-42-53-60-01 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906, USA Tel: 1(719) 576-3300 Fax: 1(719) 540-1759 Scottish Enterprise Technology Park Maxwell Building East Kilbride G75 0QR, Scotland Tel: (44) 1355-803-000 Fax: (44) 1355-242-743 Japan 9F, Tonetsu Shinkawa Bldg. 1-24-8 Shinkawa Chuo-ku, Tokyo 104-0033 Japan Tel: (81) 3-3523-3551 Fax: (81) 3-3523-7581 Literature Requests www.atmel.com/literature Disclaimer: A tmel Corporation makes no warranty for the use of its products, other than those expressly contained in the Company’s standard warranty which is detailed in Atmel’s Terms and Conditions located on the Company’s web site. The Company assumes no responsibility for any errors which may appear in this document, reserves the right to change devices or specifications detailed herein at any time without notice, and does not make any commitment to update the information contained herein. No licenses to patents or other intellectual property of Atmel are granted by the Company in connection with the sale of Atmel products, expressly or by implication. Atmel’s products are not authorized for use as critical components in life support devices or systems. © Atmel Corporation 2004 . A ll rights reserved. A tmel ® a nd combinations thereof are the registered trademarks of Atmel Corporation or its subsidiaries. Other terms and product names may be the trademarks of others. Printed on recycled paper. 4751D–SIGE–05/04
T0905 价格&库存
很抱歉,暂时无法提供与“T0905”相匹配的价格&库存,您可以联系我们找货
