T6801
T6801
    ATMEL(爱特梅尔)
    T6801 - Single-channel Driver IC with Thermal Monitoring - ATMEL Corporation
T6801 数据手册
Features • • • • • • Input Comparator with Schmitt-trigger Characteristic Input Clamping Current Capability of ±10 mA Integrated Protection Cells (EMC, ESD, RF) Dedicated to All Input Stages Shutdown by Junction-temperature Monitor Reset with Hysteresis at Low Voltage ESD Protection According to Human Body Model: ±2000V (C = 100 pF, R = 1.5 kΩ) • Output Stage: – Short-circuit Protected – Load-dump Protected at 1 kΩ – Jump Start Possible Single-channel Driver IC with Thermal Monitoring T6801 1. Description The single-channel driver IC includes one non-inverted and current-limited output stage with an open collector. Thermal shutdown protects the output against critical junction temperatures. The output can sink a current of 20 mA. The digital input has Schmitt-trigger function with pull-up resistors to 5V. Figure 1-1. Block Diagram NC 1 3 NC VO 4 VS 7 Thermal shutdown 2 GND Undervoltage detection 5 NC NC VI VS Rev. 4761B–AUTO–09/05 2. Pin Configuration Figure 2-1. Pinning SO8 NC 1 8 NC GND 2 7 VS NC 3 6 NC VO 4 5 VI Table 2-1. Pin 1 2 3 4 5 6 7 8 Pin Description Symbol NC GND NC VO VI NC VS NC Function Not connected Ground Not connected Output Input Not connected Supply voltage 5V Not connected 3. Basic Circuitry The integrated circuit T6801 requires a stabilized supply voltage (VS = 5V ±5%) to comply with its electrical characteristics. An external buffer capacitor of C = 100 nF is recommended. An integrated 14V Zener diode between VS and ground protects the supply pin. The input stage is provided with an integrated 250 kΩ pull-up resistor and can be directly connected to a microcontroller. The output stage is an open collector, capable of sinking 20 mA. Recommended external components: • Pull-up resistor, R = 1 kΩ • Capacitor to GND, C = 470 pF, see Figure 4-1 on page 3 2 T6801 4761B–AUTO–09/05 T6801 4. Functional Description 4.1 General ON state: Low level at the input stage activates the output stage. OFF state: The internal pull-up resistor provides high level to the input comparator and deactivates the output stage. A 7V Zener diode between input pin and GND is capable of ±10 mA clamping current. 4.2 Current Limitation of the Output Stages and Overtemperature Shutdown A temperature-dependent current limitation in the range of 25 to 100 mA protects the stage in case of a short circuit. Additionally, the chip temperature is monitored. For TChip > 148°C, the output is disabled and automatically enabled with a hysteresis of TChip > 5°C. 4.3 Transients and Load Dump An integrated 28V Zener diode protects the output stage against transients and load-dump (Schaffner pulses). With the help of an external 1 kΩ resistor, the output transistor is capable of handling the corresponding current which flows during each of these conditions. Apart from that, the output is short-circuit and overload protected. 4.4 Low-voltage Detection When the supply voltage is switched on, a power-on reset pulse is generated internally which disables the output stage until a defined supply-voltage level is reached. The low-voltage detection is provided with a hysteresis of Vhyst = 0.5V typically. Figure 4-1. Application Schematic VS = 5 V VBatt Load 100 nF R 1 kΩ VO Microcontroller VI T6801 C 470 pF 3 4761B–AUTO–09/05 5. Absolute Maximum Ratings Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Parameters Supply voltage Ambient temperature range Storage temperature range Maximum junction temperature Symbol VS Tamb Tstg Tj Value 7.0 –40 to +125 –50 to +150 +150 Unit V °C °C °C 6. Thermal Resistance Parameters Junction ambient Symbol RthJA Value 160 Unit K/W 7. Electrical Characteristics VS = 5V ±5%, Tamb = 27°C, reference point pin 2 (GND), unless otherwise specified, see Figure 1-1 on page 1 and Figure 4-1 on page 3. Parameters Supply, Pin 7 Supply voltage Supply current Low-voltage detection threshold Low-voltage hysteresis Temperature shutdown Temperature shutdown hysteresis Input, Pin 5 Zener-diode protection voltage Zener-diode clamping current Pull-up resistor Switching threshold Hysteresis Output, Pin 4 Zener-diode protection voltage Integrated capacitor Leakage current Saturation voltage Current limitation Propagation delay (470 pF, 1 kΩ, 20V) (IO = 20 mA) ILeak VSat Ilimit td 25 IO = 10 mA VO 26.5 5 2.5 0.7 100 5 V pF µA V mA µs OFF ON II = 10 mA VI II RI VI VI Vhyst 170 250 3.3 1.8 1.5 6.7 8.5 ±10 305 V mA kΩ V V V Input open Input closed to GND ON OFF VS IS IS VTH(ON) VTH(OFF) Vhyst TChip Thyst 4.75 0.8 7 3.7 3.0 0.55 140 5 5.25 3.2 13 4.6 3.8 1.05 149 V mA mA V V V °C °C Test Conditions Symbol Min. Typ. Max. Unit 4 T6801 4761B–AUTO–09/05 T6801 8. Ordering Information Extended Type Number T6801-TAQY Package SO8 Remarks Taped and reeled, Pb-free 9. Package Information Package SO8 Dimensions in mm 5.00 4.85 1.4 0.4 1.27 3.81 8 5 0.25 0.10 0.2 3.8 6.15 5.85 5.2 4.8 3.7 technical drawings according to DIN specifications 1 4 10. Revision History Please note that the following page numbers referred to in this section refer to the specific revision mentioned, not to this document. Revision No. 4761B-AUTO-09/05 History • Put datasheet in a new template • Pb-free logo on page 1 added • Ordering Information on page 5 changed 5 4761B–AUTO–09/05 Atmel Corporation 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 487-2600 Atmel Operations Memory 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 436-4314 RF/Automotive Theresienstrasse 2 Postfach 3535 74025 Heilbronn, Germany Tel: (49) 71-31-67-0 Fax: (49) 71-31-67-2340 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906, USA Tel: 1(719) 576-3300 Fax: 1(719) 540-1759 Regional Headquarters Europe Atmel Sarl Route des Arsenaux 41 Case Postale 80 CH-1705 Fribourg Switzerland Tel: (41) 26-426-5555 Fax: (41) 26-426-5500 Microcontrollers 2325 Orchard Parkway San Jose, CA 95131, USA Tel: 1(408) 441-0311 Fax: 1(408) 436-4314 La Chantrerie BP 70602 44306 Nantes Cedex 3, France Tel: (33) 2-40-18-18-18 Fax: (33) 2-40-18-19-60 Biometrics/Imaging/Hi-Rel MPU/ High Speed Converters/RF Datacom Avenue de Rochepleine BP 123 38521 Saint-Egreve Cedex, France Tel: (33) 4-76-58-30-00 Fax: (33) 4-76-58-34-80 Asia Room 1219 Chinachem Golden Plaza 77 Mody Road Tsimshatsui East Kowloon Hong Kong Tel: (852) 2721-9778 Fax: (852) 2722-1369 ASIC/ASSP/Smart Cards Zone Industrielle 13106 Rousset Cedex, France Tel: (33) 4-42-53-60-00 Fax: (33) 4-42-53-60-01 1150 East Cheyenne Mtn. Blvd. Colorado Springs, CO 80906, USA Tel: 1(719) 576-3300 Fax: 1(719) 540-1759 Scottish Enterprise Technology Park Maxwell Building East Kilbride G75 0QR, Scotland Tel: (44) 1355-803-000 Fax: (44) 1355-242-743 Japan 9F, Tonetsu Shinkawa Bldg. 1-24-8 Shinkawa Chuo-ku, Tokyo 104-0033 Japan Tel: (81) 3-3523-3551 Fax: (81) 3-3523-7581 Literature Requests www.atmel.com/literature Disclaimer: T he information in this document is provided in connection with Atmel products. No license, express or implied, by estoppel or otherwise, to any intellectual property right is granted by this document or in connection with the sale of Atmel products. EXCEPT AS SET FORTH IN ATMEL’S TERMS AND CONDITIONS OF SALE LOCATED ON ATMEL’S WEB SITE, ATMEL ASSUMES NO LIABILITY WHATSOEVER AND DISCLAIMS ANY EXPRESS, IMPLIED OR STATUTORY WARRANTY RELATING TO ITS PRODUCTS INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTY OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR NON-INFRINGEMENT. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, CONSEQUENTIAL, PUNITIVE, SPECIAL OR INCIDENTAL DAMAGES (INCLUDING, WITHOUT LIMITATION, DAMAGES FOR LOSS OF PROFITS, BUSINESS INTERRUPTION, OR LOSS OF INFORMATION) ARISING OUT OF THE USE OR INABILITY TO USE THIS DOCUMENT, EVEN IF ATMEL HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. A tmel makes no representations or warranties with respect to the accuracy or completeness of the contents of this document and reserves the right to make changes to specifications and product descriptions at any time without notice. Atmel does not make any commitment to update the information contained herein. Unless specifically provided otherwise, Atmel products are not suitable for, and shall not be used in, automotive applications. Atmel’s products are not intended, authorized, or warranted for use as components in applications intended to support or sustain life. © Atmel Corporation 2005 . A ll rights reserved. A tmel ®, logo and combinations thereof, Everywhere You Are ® a nd others, are registered trademarks or trademarks of Atmel Corporation or its subsidiaries. Other terms and product names may be trademarks of others. Printed on recycled paper. 4761B–AUTO–09/05
T6801 价格&库存
很抱歉,暂时无法提供与“T6801”相匹配的价格&库存,您可以联系我们找货
