T
PL
IA
N
M
CO
Features
■ Push switch option
*R
oH
S
■ Compact, rugged design
■ High reliability
■ Metal bushing/shaft
PEC09 Series - 9 mm Incremental Encoder
Electrical Characteristics
Output....................................................................................................................................................................................................2-bit quadrature code
Closed Circuit Resistance ...........................................................................................................................................................................3 ohms maximum
Contact Rating.............................................................................................................................................................................................. 10 mA @ 5 VDC
Insulation Resistance ...................................................................................................................................................................100 megohms @ 250 VDC
Dielectric Withstanding Voltage
Sea Level............................................................................................................................................................................................... 300 VAC minimum
Electrical Travel .....................................................................................................................................................................................................Continuous
Contact Bounce (15 RPM).........................................................................................................................................................................5.0 ms maximum**
RPM (Operating) ..............................................................................................................................................................................................60 maximum**
Environmental Characteristics
Operating Temperature Range ......................................................................................................................................-10 °C to +70 °C (+14 °F to +158 °F)
Storage Temperature Range ..........................................................................................................................................-40 °C to +85 °C (-40 °F to +185 °F)
Humidity................................................................................................................................................................. MIL-STD-202, Method 103B, Condition B
Rotational Life.................................................................................................................................................................................... 30,000 cycles minimum
IP Rating..........................................................................................................................................................................................................................IP 40
Mechanical Characteristics
Mechanical Angle ......................................................................................................................................................................................... 360 ° continuous
Torque
Running/Detent............................................................................................................................................................ 30 to 200 gf.cm (0.42 to 2.7 oz.-in.)
Mounting.......................................................................................................................................................................10.0 kgf.cm (8.67 lb.-in.) maximum
Terminal Bend Strength .................................................................................................................................................................................300 gf (10.6 ozf)
Shaft Push-Pull Strength ................................................................................................................................................................................... 10 kgf (22 lbf)
Weight ............................................................................................................................................................................................ 5 gm (0.17 oz.) maximum
Terminals ................................................................................................................................................................................. Printed circuit board terminals
Soldering Condition
Wave Soldering ...................................................................................... Sn95.5/Ag2.8/Cu0.7 solder with no-clean flux: 260 °C max. for 3-5 seconds
Hand Soldering................................................................................................................................................................................. Not recommended
Hardware ....................................................................................................................... One flat washer and one mounting nut supplied with each encoder
Switch Characteristics
Switch Type ....................................................................................................................................................................Contact Push ON Momentary SPST
Switch Life ......................................................................................................................................................................................... 20,000 cycles minimum
Power Rating (Resistive Load) ..................................................................................................................................................................... 10 mA at 5 V DC
Switch Travel .............................................................................................................................................................................................. See How to Order
Switch Actuation Force ...............................................................................................................................................................300 ± 200 gf (10.6 ± 7.0 ozf)
How To Order
Quadrature Output Table
PEC09 - 2 0 20 F - S 0012
Model
Terminal Configuration
2 = PC Pin Vertical/Side Exit
Detent Option
0 = No Detents (12, 15 pulses)
1 = 12 Detents (12 pulses)
2 = 24 Detents (12 pulses)
3 = 30 Detents (15 pulses)
Standard Shaft Length
15 = 15.0 mm
20 = 20.0 mm
25 = 25.0 mm
Shaft Style
F = Metal Flatted Shaft
K = Metal Knurled Shaft
Switch Configuration
N = No Switch
S = Push Momentary (0.5 mm stroke)
T = Push Momentary (1.5 mm stroke)
Resolution
0012 = 12 Pulses per 360 ° Rotation
0015 = 15 Pulses per 360 ° Rotation
CW
OFF
A Signal
ON
B Signal
D
Suggested Filter Circuit
5 VDC
10K OHMS
10K OHMS
10K OHMS
10K OHMS
TERMINAL A
TERMINAL B
0.01 μF
0.01 μF
ENCODER
TERMINAL C
WARNING Cancer and Reproductive Harm - www.P65Warnings.ca.gov
Switch Circuit
*RoHS Directive 2015/863, Mar 31, 2015 and Annex.
**Devices are tested using standard noise reduction filters.
D
E
For optimum performance, designers should use noise reduction filters in their circuits.
Specifications are subject to change without notice.
CIRCUIT DIAGRAM
Users should verify actual device performance in their specific applications.
The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
Applications
Level control, tuning and timer settings in:
■ Audio-visual equipment
■ Consumer electric appliances
■ Environmental controls
■ Musical instrumentation
■ Communications equipment
Product Dimensions
PEC09-2xxxF-Nxxxx
7.05
(.278)
9.7
(.382)
4.85
(.191)
2.5 ± 0.1
(.098 ± .004)
SHAFT
FLAT IS
OPTIONAL
ANGLE
Y
X
5.0 ± 0.1
(.197 ± .004)
5.0 ± 0.1
(.197 ± .004)
B
C
X
6.5
(.256)
A
(SW01)
3.5
(.138)
2.5 ± 0.1
(.098 ± .004)
0.8 ± 0.2
(.031 ± .008)
A C
Y
0.2
(.008)
0.74
(.029)
B
0.9 ± 0.1
(.035 ± .004)
Locating Lug Detail
13.3
(.524)
SWITCH STROKE
0.5 +0.4/-0.3
(.020 +.016/-.012)
6.5
(.256)
0.2
(.008)
6.25
(.246)
0.74
(.029)
6.25 ± 0.1
(.246 ± .004)
5.0 ± 0.1
(.197 ± .004)
2.5 ± 0.1
(.098 ± .004)
5.0 ± 0.1
(.197 ± .004)
2.5 ± 0.1
(.098 ± .004)
0.8 ± 0.2
(.031 ± .008)
(SW) (ENCODER)
3.5
(.138)
E
B
C
MOUNTING
SURFACE
6.0 ± 0.2
(.236 ± .008)
X
X
0.8 ± 0.2
(.031 ± .008)
Y
1.0 +0.2/-0
5 PLCS.
(.039 +.008/-0)
2.0 ± 0.1
(.079 ± .004)
Hardware
0.2
(.008)
M7 x 0.75
(.030)
DIA.
12.05
(.474)
SWITCH STROKE
1.5 ± 0.5
(.059 +.020)
6.5
(.256)
3.5
(.138)
Y
A
D
PEC09-2xxxF-Txxxx
4.85
(.191)
1.0 +0.2/-0
3 PLCS.
(.039 +.008/-0)
3.5
(.138)
PEC09-2xxxF-Sxxxx
4.85
(.191)
MOUNTING
SURFACE
2.5 ± 0.1
(.098 ± .004)
5.0 ± 0.1
(.197 ± .004)
2.5 ± 0.1
(.098 ± .004)
(SW) (ENCODER)
0.8 ± 0.2
(.031 ± .008)
DIMENSIONS:
E
D
5.0 ± 0.1
(.197 ± .004)
5.0 ± 0.1
(.197 ± .004)
B
C
MOUNTING
SURFACE
A
12.7
(.500)
2.0
(.079)
11.0
(.433)
DIA.
NUT
DIA.
12.0
(.472)
7.2
DIA.
(.283)
1.0 +0.2/-0
5 PLCS.
(.039 +.008/-0)
0.5
(.020)
MM
(INCHES)
WASHER
The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of thisdocument, and at www.bourns.com/docs/legal/disclaimer.pdf.
Shaft Options
PEC09-2xxxx-Nxxxx
Knurled Type
L1
LB
PEC09-2xxxx-Sxxxx
(0.5 mm Switch Stroke)
PEC09-2xxxx-Txxxx
(1.5 mm Switch Stroke)
Knurled Type
Knurled Type
L1
1.0
(.039)
L2
LB
18 TEETH
0.75
M7x
(.030)
L1
15
(.591)
25
(.984)
LB
5.0
(.197)
7.0
(.276)
10.0
(.394)
L2
6.0
(.236)
10.0
(.394)
10.0
(.394)
L3
7.0
(.276)
11.0
(.433)
11.0
(.433)
L1
15
(.591)
25
(.984)
LB
5.0
(.197)
7.0
(.276)
10.0
(.394)
Flat Type
L1
L1
0.75
M7x
(.030)
L1
15
(.591)
25
(.984)
4.5
(.177)
L2
0.5
1.0
C
OR
(.020)
(.039)
LB
5.0
(.197)
7.0
(.276)
10.0
(.394)
L2
7.0
(.276)
12.0
(.472)
12.0
(.472)
LB
6.0
(.236)
DIA.
1.0
(.039)
L2
L2
6.0
(.236)
9.0
(.354)
9.0
(.354)
L3
7.0
(.276)
10.0
(.394)
10.0
(.394)
L1
15
(.591)
25
(.984)
0.75
M7x
(.030)
L1
15
(.591)
25
(.984)
6.0
(.236)
DIA.
L3
0.5
1.0
C
OR
(.020)
(.039)
LB
5.0
(.197)
7.0
(.276)
10.0
(.394)
L2
5.0
(.197)
8.0
(.315)
8.0
(.315)
L3
6.0
(.236)
9.0
(.354)
9.0
(.354)
Flat Type
0.5
1.0
C
OR
(.020)
(.039)
LB
5.0
(.197)
7.0
(.276)
10.0
(.394)
DIMENSIONS:
L1
4.5
(.177)
L2
0.75
M7x
(.030)
18 TEETH
6.0
(.236)
DIA.
L3
0.5
1.0
C
OR
(.020)
(.039)
0.75
M7x
(.030)
Flat Type
LB
LB
18 TEETH
6.0
(.236)
DIA.
L3
0.5
1.0
C
OR
(.020)
(.039)
L1
1.0
(.039)
L2
L2
7.0
(.276)
10.0
(.394)
10.0
(.394)
LB
6.0
(.236)
DIA.
0.75
M7x
(.030)
L1
15
(.591)
25
(.984)
4.5
(.177)
L2
C
0.5
1.0
OR
(.020)
(.039)
LB
5.0
(.197)
7.0
(.276)
10.0
(.394)
6.0
(.236)
DIA.
L2
7.0
(.276)
10.0
(.394)
10.0
(.394)
MM
(INCHES)
Asia-Pacific: Tel: +886-2 2562-4117 • Email: asiacus@bourns.com
EMEA: Tel: +36 88 885 877 • Email: eurocus@bourns.com
The Americas: Tel: +1-951 781-5500 • Email: americus@bourns.com
www.bourns.com
REV. 09/19
Legal Disclaimer Notice
This legal disclaimer applies to purchasers and users of Bourns® products manufactured by or on behalf of Bourns, Inc. and
P[ZHɉSPH[LZJVSSLJ[P]LS`¸)V\YUZ¹
Unless otherwise expressly indicated in writing, Bourns® products and data sheets relating thereto are subject to change
^P[OV\[UV[PJL
很抱歉,暂时无法提供与“PEC09-2215K-T0012”相匹配的价格&库存,您可以联系我们找货
