T1220240116-000
T1220240116-000
    HUMIREL(泰科)
    防护罩 连接器 顶端插入 PG16 H24B IP65 - 防尘,耐水
T1220240116-000 数据手册
T1220240116-000 Heavy Duty Connector Hood, Bottom Entry, Locking, Sealable T1220240116-000  ACTIVE HDC TE Internal #: T1220240116-000 Heavy Duty Connector Hood, Bottom Entry, Locking, Sealable View on TE.com > Connectors > Rectangular Connectors > Rectangular Connector Hoods & Bases Hood & Base Connector Product Type: Hood Cable Entry Location: Bottom Hood & Base Locking Device Type: Locking Sealable: Yes Circuit Application: Power & Signal Features Product Type Features Hood & Base Connector Product Type Hood Sealable Yes Body Features Primary Product Color Gray Cable Entry Location Bottom Mechanical Attachment Locking Device Location Housing Thread Size PG16 Hood & Base Locking Device Type Locking Housing Features Housing Material Die Cast Aluminum Dimensions  Product Width 56.4 mm[2.221 in] Product Length 120 mm[4.724 in] Product Height 60 mm[2.363 in] For support call+1 800 522 6752 01/03/2024 12:29AM | Page 1 T1220240116-000 Heavy Duty Connector Hood, Bottom Entry, Locking, Sealable Product Height 60 mm[2.363 in] Usage Conditions Corrosion Protected Yes Operation/Application Circuit Application Power & Signal Packaging Features Packaging Quantity 1 Packaging Method Bag Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant EU ELV Directive 2000/53/EC Compliant China RoHS 2 Directive MIIT Order No 32, 2016 No Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) Does not contain REACH SVHC Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not reviewed for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts  For support call+1 800 522 6752 01/03/2024 12:29AM | Page 2 T1220240116-000 Heavy Duty Connector Hood, Bottom Entry, Locking, Sealable TE Part # T1410242000-000 TE Part # T2040242101-000 TE Part # T3609160101-000 TE Part # T1010241200-000 H24B-AG HE-024-M DLX-16-MS H24B-KDTP Customers Also Bought TE Part #T1320060116-000 TE Part #T2040062201-000 TE Part #T2040243201-000 H6B-TG-PG16 HE-006-F HE-024-FS Documents Product Drawings H24B-TG-PG16 English CAD Files 3D PDF 3D Customer View Model ENG_CVM_CVM_T1220240116-000_A.2d_dxf.zip English Customer View Model ENG_CVM_CVM_T1220240116-000_A.3d_igs.zip English Customer View Model ENG_CVM_CVM_T1220240116-000_A.3d_stp.zip English By downloading the CAD file I accept and agree to the Terms and Conditions of use. Product Specifications Application Specification English  For support call+1 800 522 6752 01/03/2024 12:29AM | Page 3
T1220240116-000 价格&库存
很抱歉,暂时无法提供与“T1220240116-000”相匹配的价格&库存,您可以联系我们找货
