4
THIS DRAWING IS UNPUBLISHED.
C
COPYRIGHT
3
1
RELEASED FOR PUBLICATION
REVISIONS
ALL RIGHTS RESERVED.
BY -
P
A
A1
D
DATE
DWN
APVD
INITIAL RELEASE
23JUN2015
DL
CW
ECR-17-001721
14FEB2017
YC
CW
ECR-20-008190
10OCT2020
WQR
CW
NOTES:
1. TECHNICAL CHARACTERISTICS:
HOUSING MATERIAL: DIE CAST ALUMINIUM ALLOY
SURFACE TREATMENT: POWDER COATED,GREY
DEGREE OF PROTECTION: IP65 (MATED)
4-M3
77.5
93.5
1.
113.1
HOUSING
IG2
: IP65(
C
26.1
26.1
( 134.2 )
C
IG1
117
B
105
5.5
45
57
( 98.5 )
4-
THIS DRAWING IS A CONTROLLED DOCUMENT.
TOLERANCES UNLESS
OTHERWISE SPECIFIED:
DIMENSIONS:
mm
A
TYPE 1: T1660163XXX-100 H16B-SDRHM-LB-PG/M
1: T1660163XXX-100 H16B ,
PG/M,
MATERIAL
1470-19 (3/13)
D
27
43
B
B
DESCRIPTION
LTR
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
23JUN2015
CHK
23JUN2015
APVD
23JUN2015
DAVID LI
CHRIS WANG
XIANG XU
PRODUCT SPEC
TE Connectivity
NAME
H16B-SDRHM-LB-PG/M
A
108-137013
APPLICATION SPEC
114-137013
WEIGHT
Customer Drawing
SIZE
A3
CAGE CODE
DRAWING NO
RESTRICTED TO
T166016XXXXX00
SCALE
1:2
SHEET
1
OF
3
REV
B
4
C
COPYRIGHT
3
1
REVISIONS
BY -
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
( 94.9 )
D
HOUSING
SCALE
3:10
109.2
C
C
( 134.5 )
IG1
B
IG3
IG1
IG2
HOUSING
TYPE 2: T1660163XXX-000 H16B-SDRH-LB-PG/M
OTHER SPEC REFER TO TYPE 1
2: T1660163XXX-000H16B ,
,PG/M,
1
B
3:10
TYPE 3: T1660160932-000 H16B-SDRH-LB-M32/PG9
OTHER SPEC REFER TO TYPE 2
3: T1660160932-000 H16B ,
, PG9,
M32,
2
TOLERANCES UNLESS
DIMENSIONS:
mm
A
MATERIAL
1470-19 (3/13)
SCALE
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
23JUN2015
CHK
23JUN2015
APVD
23JUN2015
DAVID LI
CHRIS WANG
XIANG XU
PRODUCT SPEC
TE Connectivity
NAME
H16B-SDRHM-LB-PG/M
A
108-137013
APPLICATION SPEC
114-137013
WEIGHT
Customer Drawing
SIZE
A3
CAGE CODE
DRAWING NO
RESTRICTED TO
T166016XXXXX00
SCALE
1:2
SHEET
2
OF
3
REV
B
4
C
COPYRIGHT
BY -
2
3
REVISIONS
P
DESCRIPTION
LTR
DATE
SEE SHEET 1
DWN
APVD
D
D
NOTES:
SEE SHEET 1
SHEET 1
C
B
T1660163121-100
H16B-SDRHM-LB-PG21
T1660163129-100
H16B-SDRHM-LB-PG29
T1660163132-100
H16B-SDRHM-LB-M32
T1660163221-100
H16B-SDRHM-LB-2PG21
T1660163229-100
H16B-SDRHM-LB-2PG29
T1660163232-100
H16B-SDRHM-LB-2M32
T1660163121-000
H16B-SDRH-LB-PG21
T1660163129-000
H16B-SDRH-LB-PG29
T1660163125-000
H16B-SDRH-LB-M25
T1660163132-000
H16B-SDRH-LB-M32
T1660163221-000
H16B-SDRH-LB-2PG21
T1660163229-000
H16B-SDRH-LB-2PG29
T1660163232-000
H16B-SDRH-LB-2M32
T1660160932-000
PART NUMBER
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,PG21,HIGH CONSTRUCTION,METAL
H16B ,
,PG21, ,
PROTECTION COVER,POWDER COATED,GREY
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,PG29,HIGH CONSTRUCTION,METAL
H16B ,
,PG29, ,
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,M32,HIGH CONSTRUCTION,METAL
H16B ,
,M32, ,
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2PG21,HIGH CONSTRUCTION,METAL
H16B ,
,2PG21, ,
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2PG29,HIGH CONSTRUCTION,METAL
H16B ,
,2PG29, ,
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,2M32,HIGH CONSTRUCTION,METAL
H16B ,
,2M32, ,
H16B ,
,PG21, ,
H16B ,
,PG29, ,
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,M25
H16B ,
,M25, ,
CONSTRUCTION,PLASTIC PROTECTION COVER,POWDER COATED,GREY
,HIGH CONSTRUCTION,PLASTIC PROTECTION COVER,POWDER COATED,GREY
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,M32,HIGH CONSTRUCTION,PLASTIC
H16B ,
,M32, ,
H16B ,
,2PG21, ,
H16B ,
,2PG29, ,
H16B ,
,2M32, ,
H16B HOUSING,SURFACE MOUNTED,METAL SINGLE LOCKING,SIDE ENTRY PG9,BOTTOM ENTRY
COVER,POWDER COATED,GREY / H16B ,
, PG9, M32, ,
M32,HIGH CONSTRUCTION,PLASTIC PROTECTION
PART DESCRIPTION
TOLERANCES UNLESS
DIMENSIONS:
mm
A
MATERIAL
1470-19 (3/13)
2
3
4
PLC
PLC
PLC
PLC
PLC
ANGLES
FINISH
DWN
23JUN2015
CHK
23JUN2015
APVD
23JUN2015
DAVID LI
CHRIS WANG
XIANG XU
PRODUCT SPEC
PG21
PG29
M32
PG21
PG21
PG29
PG29
M32
M32
PG21
PG29
M25
M32
PG21
PG21
PG29
PG29
M32
M32
PG9
M32
IG1
IG2
IG3
C
TYPE 1
1
TYPE 2
2
TYPE 3
3
TYPE
TE Connectivity
NAME
H16B-SDRHM-LB-PG/M
A
108-137013
APPLICATION SPEC
114-137013
WEIGHT
CUSTOMER DRAWING
B
SIZE
A3
CAGE CODE
DRAWING NO
RESTRICTED TO
T166016XXXXX00
SCALE
1:2
SHEET
3
OF
3
REV
B
