T4113511041-000
T4113511041-000
    HUMIREL(泰科)
    4 针位圆形连接器 插座,公形引脚 螺钉
T4113511041-000 数据手册
T4113511041-000 Standard Circular Connectors, Wire-to-Wire, 4 Position, Sealable, Wire & Cable, Signal, Nickel, Brass, D Polarization Code, M12 Connector T4113511041-000  ACTIVE M12 Connector TE Internal #: T4113511041-000 Standard Circular Connectors, Wire-to-Wire, 4 Position, Sealable, Wire & Cable, Signal, Nickel, Brass, D Polarization Code, M12 Connector View on TE.com > Connectors > Circular Connectors > Standard Circular Connectors Connector System: Wire-to-Wire Number of Positions: 4 Sealable: Yes Connector & Contact Terminates To: Wire & Cable Contact Current Rating (Max): 4 A Features Product Type Features Prewired No Product Type Connector Assembly Accessory Color Black Assembly Type Electrical Connector Connector System Wire-to-Wire Sealable Yes Connector & Contact Terminates To Wire & Cable Circular Connector Type Plug Shell Type Metal Configuration Features  Keying & Polarized Position Locations D Factory Installed Backshell With Keying D Number of Positions 4 Number of Power Positions 0 For support call+1 800 522 6752 01/03/2024 12:33AM | Page 1 T4113511041-000 Standard Circular Connectors, Wire-to-Wire, 4 Position, Sealable, Wire & Cable, Signal, Nickel, Brass, D Polarization Code, M12 Connector Number of Power Positions 0 Number of Signal Positions 4 Contacts Preloaded Yes Electrical Characteristics Operating Voltage 250 VAC Voltage 250 Vrms Body Features Peripheral Seal Material Silicone Environmental Protection IP67 O-Ring Material Silicone Environmental Protection Type Elastomer Sealed Shell Plating Material Nickel Shell Base Material Brass Circular Connector Insulation Material Type Polyamide 66 GF25 Contact Features Contact Current Rating (Max) 4A Reverse Gender No Circular Connector Contact Type Pin Mechanical Attachment Mating Retention Type Threaded Coupling Mating Alignment With Polarization Code D Mating Alignment Type Keyed Housing Features Circular Connector Shell Size 20 Dimensions Wire Size .82 – .2 mm² Usage Conditions IP Dust Sealing Level 6 IP Water Sealing Level IP67 Operating Temperature Range -40 – 85 °C[-40 – 185 °F] Operation/Application  Durability Rating For support call+1 800 522 6752 100 Cycles 01/03/2024 12:33AM | Page 2 T4113511041-000 Standard Circular Connectors, Wire-to-Wire, 4 Position, Sealable, Wire & Cable, Signal, Nickel, Brass, D Polarization Code, M12 Connector Operation/Application Durability Rating 100 Cycles Circuit Application Signal Shielded Yes Industry Standards UL Flammability Rating UL 94HB Other Position Locations Omitted 0 Field Serviceable Yes Product Compliance For compliance documentation, visit the product page on TE.com> EU RoHS Directive 2011/65/EU Compliant with Exemptions EU ELV Directive 2000/53/EC Compliant with Exemptions China RoHS 2 Directive MIIT Order No 32, 2016 Restricted Materials Above Threshold EU REACH Regulation (EC) No. 1907/2006 Current ECHA Candidate List: JUNE 2023 (235) Candidate List Declared Against: JUNE 2023 (235) SVHC > Threshold: Pb (3.7% in Component Part) Article Safe Usage Statements: Do not eat, drink or smoke when using this product. Wash thoroughly after handling. Recycle if possible and dispose of the article by following all applicable governmental regulations relevant to your geographic location. Halogen Content Low Halogen - Br, Cl, F, I < 900 ppm per homogenous material. Also BFR/CFR/PVC Free Solder Process Capability Not applicable for solder process capability Product Compliance Disclaimer This information is provided based on reasonable inquiry of our suppliers and represents our current actual knowledge based on the information they provided. This information is subject to change. The part numbers that TE has identified as EU RoHS compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, mercury, PBB, PBDE, DBP, BBP, DEHP, DIBP, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2011/65/EU (RoHS2). Finished electrical and electronic equipment products will be CE marked as required by Directive 2011/65/EU. Components may not be CE marked. Additionally, the part numbers that TE has identified as EU ELV compliant have a maximum concentration of 0.1% by weight in homogenous materials for lead, hexavalent chromium, and mercury, and 0.01% for cadmium, or qualify for an exemption to these limits as defined in the Annexes of Directive 2000/53/EC (ELV). Regarding the REACH Regulation, the information TE provides on SVHC in articles for this part number is based on the latest European Chemicals Agency (ECHA) ‘Guidance on requirements for substances in articles’ posted at this URL: https://echa.europa.eu/guidance-documents/guidance-onreach Compatible Parts  For support call+1 800 522 6752 01/03/2024 12:33AM | Page 3 T4113511041-000 Standard Circular Connectors, Wire-to-Wire, 4 Position, Sealable, Wire & Cable, Signal, Nickel, Brass, D Polarization Code, M12 Connector Compatible Parts TE Part # T4112511041-000 M12 F, 4P GOLD D_CODE RA SHIELDED PG7 Also in the Series M12 Connector Connector Caps & Covers(5) Connector Hardware(12) M8/M12 Cable Assemblies(230) Standard Circular Connectors(801) Customers Also Bought  TE Part #1630019-1 TE Part #T4013019041-000 TE Part #T4111512041-000 TE Part #926299-3 HSC200 100R 5% M8,SCREW, MALE,R/A,SHIELD,4P, GOLD M12 M, 4P GOLD D_CODE S SHIELDED PG9 5P UN-MNL STECKGEH TE Part #1-770904-1 TE Part #5-2176331-4 TE Part #A70754-000 TE Part #160859-2 MINI UMNL SOK 22-18AWG AU LF CRGP 2512 270K 1% B-155-03 FF 250 TAB 0.5-1.0MM2 TPBR TE Part #5-104655-7 TE Part #936263-2 60 50/50 HDR DRST SFMNT TIN BULB 2P CAP(AMBER) ASSY BLACK Documents For support call+1 800 522 6752 01/03/2024 12:33AM | Page 4 T4113511041-000 Standard Circular Connectors, Wire-to-Wire, 4 Position, Sealable, Wire & Cable, Signal, Nickel, Brass, D Polarization Code, M12 Connector Documents Product Drawings M12 M, 4P GOLD D_CODE RA SHIELDED PG7 English CAD Files Customer View Model ENG_CVM_CVM_T4113511041-000_B.3d_igs.zip English Customer View Model ENG_CVM_CVM_T4113511041-000_B.3d_stp.zip English Customer View Model ENG_CVM_CVM_T4113511041-000_B.2d_dxf.zip English 3D PDF 3D By downloading the CAD file I accept and agree to the Terms and Conditions of use. Product Specifications English  For support call+1 800 522 6752 01/03/2024 12:33AM | Page 5
T4113511041-000 价格&库存
很抱歉,暂时无法提供与“T4113511041-000”相匹配的价格&库存,您可以联系我们找货
