T496
T496
    KEMET(基美)
    T496 - SOLID TANTALUM CHIP CAPACITORS - Kemet Corporation
T496 数据手册
SOLID TANTALUM CHIP CAPACITORS T496 SERIES—Fail-Safe Fused FEATURES • • • • • • • • Built-in fuse protects against damaging short circuit failure mode Precision-molded, laser-marked case Symmetrical, compliant terminations Taped and reeled per EIA 481-1 Case geometry and footprints equivalent to Industrial Grade T491 Series. (Case sizes B, C, D and X only) 100% Surge Current test on C, D, X sizes Patented fuse assembly Operating Temperature: -55˚C to +125˚C CATHODE (-) END VIEW W SIDE VIEW B Test Tab 0.15(0.006) Max. • • • • • Fuse actuation, 25 C: within 1 second at fault currents of 4 amps and higher. Continuous current capability: 0.75 amps Post-actuation resistance, 25 C: 10 megohms minimum Test tabs on the sides of the case bypass the capacitor element to allow direct testing of the fuse assembly. RoHS Compliant & Leadfree Terminations (See www.kemet.com for lead transition) OUTLINE DRAWINGS ANODE (+) END VIEW BOTTOM VIEW B E P G S R Termination cutout at KEMET’s Option, either end H K X S T F A L DIMENSIONS — Millimeters (Inches) CASE SIZE KEMET B C D X EIA 3528-21 6032-28 7343-31 H ± 10 ± ± ± 0.20 K ± (.008) 1.1 (.043) 1.4 (.055) 1.5 (.059) 2.3 (.091) ± 0.1 2.2 (.087) 2.2 (.087) 2.4 (.094) 2.4 (.094) S ± 0.3 0.8 (.031) 1.3 (.051) 1.3 (.051) 1.3 (.051) (Ref) ± B ± 0.15 (.1 7343-43 (.287 ± .012) (.169 ± ± .012) (.016) 0.5 (.020) 0.5 (.020) 0.5 (.020) X (Ref) ± (.004 P (Ref) R 1.0 1.0 1.0 1.0 A G E T (Ref) (Min) (Ref) (Ref) 2.1 1.8 2.2 (.083) (.071) (.087) 2.8 (.1 (.094) 3.5 (.138) (.005) (.150) (.138) (.138) (.004 ± (.067) Notes: 1. Metric dimensions govern. 2. (Ref) - Dimensions provided for reference only. * Round glue pad: 2.9 ± 0.1mm (.114" ± .004") in diameter at KEMET’s option. T496 Series – ORDERING INFORMATION T 496 B 105 M 025 A S Tantalum Series T496 - P r ecision Molded, Fail-safe Lead Material T - 100% Sn (Tin) Plated H - Tin/Lead (SnPb - 5% Pb minimum) **S - = Not Recommended new designs “S” Not recommended for Case Size B, C, D, X Failure Rate A - Not Applicable Capacitance Picofarad Code First two digits represent significant figures. Third digit specifies number of zeros to follow. termination codes do not quarantee Pb-free product. Voltage Capacitance Tolerance M - ± 20% K - ± 10% *Part Number Example: T496B105M025AS spaces). See www.kemet.com for Pb Free transition. 96B105M025AT (14 Part number example: T4are converting from digits - no(14 digits finishes. Orders including “S” suffix no spa es) ** “S” Termination codes 90Sn/10 Pb to 100% tin Current (Amps) TYPICAL FUSE ACTUATION PROFILE *Pb-free supply is not guaranteed with the ‘S’ termination code. This termination code not available effective 15 July 2007. 10 1 .0001 .001 .01 .1 1 10 Time (Seconds) 36 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 SOLID TANTALUM CHIP CAPACITORS T496 SERIES—Fail-Safe Fused T496 RATINGS & PART NUMBER REFERENCE Capaci- Case tance µF Size KEMET Part Number DCL µA @ 25°C Max. DF% @ +25°C 120 Hz. Max. ESR Ω @ +25°C 100 kHz Max. 1.6 0.4 1.2 0.8 1.2 0.7 0.4 0.7 0.4 0.7 0.5 3.5 3.5 3.5 2.0 3.5 1.5 2.0 2.0 0.6 1.6 0.6 1.0 1.2 1.0 0.9 0.3 0.8 0.4 0.4 0.3 0.7 0.3 0.7 0.3 0.7 0.3 0.5 0.3 3.5 3.5 3.5 2.0 3.5 2.0 0.6 2.0 0.5 1.0 0.4 1.6 0.4 Capaci- Case tance µF Size KEMET Part Number DCL µA @ 25°C Max. DF% @ +25°C 120 Hz. Max. ESR Ω @ +25°C 100 kHz Max. 1.0 0.4 1.2 0.4 0.9 0.8 0.4 0.4 0.7 0.4 0.7 0.4 0.7 0.4 0.5 0.3 0.3 3.5 3.5 2.1 3.5 1.6 2.0 0.6 3.5 2.0 0.7 2.0 0.6 1.0 0.5 1.6 1.0 1.0 0.4 0.9 0.4 0.8 0.4 0.7 68.0 68.0 100.0 150.0 150.0 220.0 220.0 #330.0 #330.0 330.0 #470.0 4.7 6.8 10.0 15.0 22.0 22.0 22.0 33.0 33.0 47.0 47.0 47.0 #68.0 68.0 100.0 100.0 100.0 100.0 #100 150.0 150.0 150.0 220.0 220.0 #220.0 #220.0 #330.0 #330.0 3.3 4.7 6.8 10.0 15.0 15.0 15.0 22.0 22.0 33.0 33.0 33.0 33.0 C C C D C D D D D X X B B B C B B C C C C C D C D X X D D C X D D X X D D X X B B B C B C C C C D D C C 4 Volt Rating at +85°C (2.7 Volt Rating at +125°C) 2.7 6.0 T496C686(1)004A(2) E1K6 T496C686(1)004A(2) E400 2.7 6.0 T496C107(1)004A(2) E1K2 4.0 8.0 T496D157(1)004A(2) E800 6.0 8.0 T496C157(1)004A(2) E1K2 6.0 8.0 T496D227(1)004A(2) E700 8.8 8.0 T496D227(1)004A(2) E400 8.8 8.0 T496D337(1)004A(2) E700 13.2 8.0 T496D337(1)004A(2) E400 13.2 8.0 T496X337(1)004A(2) E700 13.2 8.0 T496X477(1)004A(2) E500 18.8 8.0 **6 Volt Rating at +85°C (4 Volt Rating at +125°C) T496B475(1)006A(2) E3K5 0.5 6.0 T496B685(1)006A(2) E3K5 0.5 6.0 T496B106(1)006A(2) E3K5 0.6 6.0 T496C156(1)006A(2) E2K0 0.9 6.0 T496B226(1)006A(2) E3K5 1.3 6.0 T496B226(1)006A(2) E1K5 1.3 6.0 T496C226(1)006A(2) E2K0 1.4 6.0 T496C336(1)006A(2) E2K0 2.0 6.0 T496C336(1)006A(2) E600 2.0 6.0 T496C476(1)006A(2) E1K6 2.9 6.0 T496C476(1)006A(2) E600 2.9 6.0 T496D476(1)006A(2) E1K0 2.9 6.0 T496C686(1)006A(2) E1K2 4.1 6.0 T496D686(1)006A(2) E1K0 4.1 6.0 T496X107(1)006A(2) E900 6.0 8.0 T496X107(1)006A(2) E300 6.0 8.0 T496D107(1)006A(2) E800 6.0 8.0 T496D107(1)006A(2) E400 6.0 8.0 T496C107(1)006A(2) E400 6.0 8.0 T496X157(1)006A(2) E300 9.0 8.0 T496D157(1)006A(2) E700 9.0 8.0 T496D157(1)006A(2) E300 9.0 8.0 T496X227(1)006A(2) E700 13.2 8.0 T496X227(1)006A(2) E300 13.2 8.0 T496D227(1)006A(2) E700 13.2 8.0 T496D227(1)006A(2) E300 13.2 8.0 T496X337(1)006A(2) E500 19.8 8.0 T496X337(1)006A(2) E300 19.8 8.0 10 Volt Rating at +85°C (7 Volt Rating at + 125°C) 0.5 6.0 T496B335(1)010A(2) E3K5 T496B475(1)010A(2) E3K5 0.5 6.0 T496B685(1)010A(2) E3K5 0.7 6.0 T496C106(1)010A(2) E2K0 1.0 6.0 T496B156(1)010A(2) E3K5 1.5 6.0 T496C156(1)010A(2) E2K0 1.5 6.0 T496C156(1)010A(2) E600 1.5 6.0 T496C226(1)010A(2) E2K0 2.2 6.0 T496C226(1)010A(2) E500 2.2 6.0 T496D336(1)010A(2) E1K0 3.3 6.0 T496D336(1)010A(2) E400 3.3 6.0 T496C336(1)010A(2) E1K6 3.3 6.0 T496C336(1)010A(2) E400 3.3 6.0 47.0 47.0 #47.0 #47.0 68.0 68.0 68.0 100.0 100.0 100.0 150.0 150.0 #150.0 #150.0 #220.0 #220.0 #220.0 2.2 3.3 3.3 4.7 4.7 6.8 6.8 10.0 10.0 10.0 15.0 15.0 22.0 22.0 22.0 22.0 33.0 33.0 47.0 47.0 47.0 47.0 100.0 10 Volt Rating at +85°C (7 Volt Rating at +125°C) cont. 4.7 6.0 D T496D476(1)010A(2) E1K0 D T496D476(1)010A(2) E400 4.7 6.0 C T496C476(1)010A(2) E1K2 4.7 6.0 C T496C476(1)010A(2) E400 4.7 6.0 X T496X686(1)010A(2) E900 6.8 6.0 D T496D686(1)010A(2) E800 6.8 6.0 D T496D686(1)010A(2) E400 6.8 6.0 X T496X107(1)010A(2) E400 10.0 8.0 D T496D107(1)010A(2) E700 10.0 8.0 D T496D107(1)010A(2) E400 10.0 8.0 X T496X157(1)010A(2) E700 15.0 8.0 X T496X157(1)010A(2) E400 15.0 8.0 D T496D157(1)010A(2) E700 15.0 8.0 D T496D157(1)010A(2) E400 15.0 8.0 X T496X227(1)010A(2) E500 22.0 8.0 X T496X227(1)010A(2) E300 22.0 8.0 D T496D227(1)010A(2) E300 22.0 8.0 16 Volt Rating at +85°C (10 Volt Rating at +125°C) B T496B225(1)016A(2) E3K5 0.5 6.0 B T496B335(1)016A(2) E3K5 0.5 6.0 B T496B335(1)016A(2) E2K1 0.5 6.0 B T496B475(1)016A(2) E3K5 0.8 6.0 B T496B475(1)016A(2) E1K6 0.8 6.0 C T496C685(1)016A(2) E2K0 1.1 6.0 C T496C685(1)016A(2) E600 1.1 6.0 B T496B106(1)016A(2) E3K5 1.6 6.0 C T496C106(1)016A(2) E2K0 1.6 6.0 C T496C106(1)016A(2) E700 1.6 6.0 C T496C156(1)016A(2) E2K0 2.4 6.0 C T496C156(1)016A(2) E600 2.4 6.0 D T496D226(1)016A(2) E1K0 3.6 6.0 D T496D226(1)016A(2) E500 3.6 6.0 C T496C226(1)016A(2) E1K6 3.6 6.0 C T496C226(1)016A(2) E1K0 3.6 6.0 D T496D336(1)016A(2) E1K0 5.3 6.0 D T496D336(1)016A(2) E400 5.3 6.0 X T496X476(1)016A(2) E900 7.5 6.0 X T496X476(1)016A(2) E400 7.5 6.0 D T496D476(1)016A(2) E800 7.5 6.0 7.5 6.0 D T496D476(1)016A(2) E400 X T496X107(1)016A(2) E700 16.0 8.0 (1) To complete KEMET Part Number, insert M for ±20% tolerance or K for ±10% tolerance. (2) To complete KEMET Part Number, insert lead material designation for Ordering Information on page 36. Higher voltage ratings and tighter capacitance tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. T496 SERIES CONSTRUCTION Negative Termination* CAPACITOR MARKINGS T496 Series — All Case Sizes Fused Fail-Safe Device Silver Adhesive Washer Molded Case Polarity Stripe (+) Polarity Bevel (+) F+ 227 20K 542 Print Week Code: 1st Digit = Year 2nd & 3rd Digits = Week "542" = T he 42nd week of 2005 Polarity Indicator (+) (Solid Stripe) Fuse Picofarad Code KEMET I. D. Symbol Rated Voltage Tantalum (Ta2O5) Weld Mn02 Coat (First Layer) (Second Layer) Carbon Positive Termination* Silver Paint (Third Layer) 10 Volt Rating at +85°C (7 Volt Rating at + 125°C) Tantalum Wire *100% Tin ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 37 Solid Tantalum Surface Mount SOLID TANTALUM CHIP CAPACITORS T496 SERIES—Fail-Safe Fused T496 RATINGS & PART NUMBER REFERENCE Capaci- Case tance µF Size KEMET Part Number DCL µA @ 25°C Max. DF% @ +25°C 120 Hz. Max. ESR Ω @ +25°C 100 kHz Max. 5.0 3.5 1.6 3.5 2.0 2.0 0.6 2.0 0.8 1.0 0.5 0.5 1.0 0.5 0.9 0.4 0.4 0.3 0.3 6.5 5.0 3.5 5.0 1.6 3.5 2.5 2.1 2.5 1.3 2.0 0.6 0.6 1.2 0.6 1.0 0.5 0.9 0.4 0.8 0.4 Capaci- Case tance µF Size KEMET Part Number DCL µA @ 25°C Max. DF% @ +25°C 120 Hz. Max. ESR Ω @ +25°C 100 kHz Max. 8.0 2.6 6.5 5.0 3.1 4.5 2.6 3.5 1.6 2.5 0.9 1.5 0.7 1.3 0.75 1.0 0.5 0.5 0.9 0.5 0.5 0.3 16.0 14.0 10.0 10.0 2.6 8.0 1.9 7.0 1.7 5.5 2.7 5.0 2.0 2.5 0.9 2.0 1.0 1.5 0.4 0.4 1.5 2.2 2.2 3.3 4.7 6.8 6.8 10.0 10.0 15.0 15.0 15.0 22.0 22.0 33.0 33.0 33.0 47.0 47.0 0.68 1.0 1.0 1.5 1.5 2.2 3.3 3.3 4.7 4.7 6.8 6.8 10.0 10.0 10.0 15.0 15.0 22.0 22.0 22.0 22.0 B B B B C C C C C D D C D D X X D X D B B B B B C C C C C C C C D D D D X X D D 20 Volt Rating at +85°C (13 Volt Rating at +125°C) 0.5 6.0 T496B155(1)020A(2) E5K0 T496B225(1)020A(2) E3K5 0.5 6.0 T496B225(1)020A(2) E1K6 0.5 6.0 T496B335(1)020A(2) E3K5 0.7 6.0 T496C475(1)020A(2) E2K0 1.0 6.0 T496C685(1)020A(2) E2K0 1.4 6.0 T496C685(1)020A(2) E600 1.4 6.0 T496C106(1)020A(2) E2K0 2.0 6.0 T496C106(1)020A(2) E800 2.0 6.0 T496D156(1)020A(2) E1K0 3.0 6.0 T496D156(1)020A(2) E500 3.0 6.0 T496C156(1)020A(2) E500 3.0 6.0 T496D226(1)020A(2) E1K0 4.4 6.0 T496D226(1)020A(2) E500 4.4 6.0 T496X336(1)020A(2) E900 6.6 6.0 T496X336(1)020A(2) E400 6.6 6.0 T496D336(1)020A(2) E400 6.6 6.0 T496X476(1)020A(2) E300 9.4 6.0 T496D476(1)020A(2) E300 9.4 6.0 25 Volt Rating at +85°C (17 Volt Rating at +125°C) T496B684(1)025A(2) E6K5 0.5 4.0 T496B105(1)025A(2) E5K0 0.5 4.0 T496B105(1)025A(2) E3K5 0.5 4.0 T496B155(1)025A(2) E5K0 0.5 6.0 T496B155(1)025A(2) E1K6 0.5 6.0 T496C225(1)025A(2) E3K5 0.6 6.0 T496C335(1)025A(2) E2K5 0.9 6.0 T496C335(1)025A(2) E2K1 0.9 6.0 T496C475(1)025A(2) E2K5 1.2 6.0 T496C475(1)025A(2) E1K3 1.2 6.0 T496C685(1)025A(2) E2K0 1.7 6.0 T496C685(1)025A(2) E600 1.7 6.0 T496C106(1)025A(2) E600 2.5 6.0 T496D106(1)025A(2) E1K2 2.5 6.0 T496D106(1)025A(2) E600 2.5 6.0 T496D156(1)025A(2) E1K0 3.8 6.0 T496D156(1)025A(2) E500 3.8 6.0 T496X226(1)025A(2) E900 5.5 6.0 T496X226(1)025A(2) E400 5.5 6.0 T496D226(1)025A(2) E800 5.5 6.0 T496D226(1)025A(2) E400 5.5 6.0 0.47 0.47 0.68 1.0 1.0 1.5 1.5 2.2 2.2 3.3 3.3 4.7 4.7 6.8 6.8 10.0 10.0 10.0 15.0 15.0 15.0 22.0 0.15 0.22 0.22 0.33 0.33 0.47 0.47 0.68 0.68 1.0 1.0 1.5 1.5 2.2 2.2 3.3 3.3 4.7 4.7 4.7 B B B B B C C C C C C D D D D X X D X X D X B B B B B C C C C C C C C D D D D X X D 35 Volt Rating at +85°C (23 Volt Rating at +125°C) 0.5 4.0 T496B474(1)035A(2)E8K0 T496B474(1)035A(2)E2K6 0.5 4.0 T496B684(1)035A(2) E6K5 0.5 4.0 T496B105(1)035A(2) E5K0 0.5 4.0 T496B105(1)035A(2) E3K1 0.5 4.0 T496C155(1)035A(2) E4K5 0.5 6.0 T496C155(1)035A(2) E2K6 0.5 6.0 T496C225(1)035A(2) E3K5 0.8 6.0 T496C225(1)035A(2) E1K6 0.8 6.0 T496C335(1)035A(2) E2K5 1.2 6.0 T496C335(1)035A(2) E900 1.2 6.0 T496D475(1)035A(2) E1K5 1.7 6.0 T496D475(1)035A(2) E700 1.7 6.0 T496D685(1)035A(2) E1K3 2.4 6.0 T496D685(1)035A(2) E750 2.4 6.0 T496X106(1)035A(2) E1K0 3.5 6.0 T496X106(1)035A(2) E500 3.5 6.0 T496D106(1)035A(2) E400 3.5 6.0 T496X156(1)035A(2) E900 5.3 6.0 T496X156(1)035A(2) E500 5.3 6.0 T496D156(1)035A(2) E500 5.3 6.0 T496X226(1)035A(2) E300 7.7 6.0 50 Volt Rating at +85°C (33 Volt Rating at +125°C) T496B154(1)050A(2) E16K 0.5 4.0 T496B224(1)050A(2) E14K 0.5 4.0 T496B224(1)050A(2) E10K 0.5 4.0 T496B334(1)050A(2) E10K 0.5 4.0 T496B334(1)050A(2) E2K6 0.5 4.0 T496C474(1)050A(2) E8K0 0.5 4.0 T496C474(1)050A(2) E1K9 0.5 4.0 T496C684(1)050A(2) E7K0 0.5 4.0 T496C684(1)050A(2) E1K7 0.5 4.0 T496C105(1)050A(2) E5K5 0.5 4.0 T496C105(1)050A(2) E2K7 0.5 4.0 T496C155(1)050A(2) E5K0 0.8 6.0 T496C155(1)050A(2) E2K0 0.8 6.0 T496D225(1)050A(2) E2K5 1.1 6.0 T496D225(1)050A(2) E900 1.1 6.0 T496D335(1)050A(2) E2K0 1.7 6.0 T496D335(1)050A(2) E1K0 1.7 6.0 T496X475(1)050A(2) E1K5 2.4 6.0 T496X475(1)050A(2) E400 2.4 6.0 T496D475(1)050A(2) E400 2.4 6.0 (1) To complete KEMET Part Number, insert M for ±20% tolerance or K for ±10% tolerance. (2) To complete KEMET Part Number, insert lead material designation for Ordering Information on page 36. Higher voltage ratings and tighter capacitance tolerance product may be substituted within the same size at KEMET’s option. Voltage substitutions will be marked with the higher voltage rating. T496 SERIES CONSTRUCTION 38 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 Solid Tantalum Surface Mount TANTALUM AND ALUMINUM CHIP CAPACITORS Packaging Information Tape & Reel Packaging KEMET’s Molded Tantalum and Aluminum Chip Capacitor families are packaged in 8 mm and 12 mm plastic tape on 7" and 13" reels, in accordance with EIA Standard 481-1: Taping of Surface Mount Components for Automatic Handling. This packaging system is compatible with all tape fed automatic pick and place systems. Right Hand Orientation Only Embossed Carrier (+) (–) Embossment Top Tape Thickness .10mm (.004") Max Thickness 8mm ±.30 8mm (0.315") (.315 ±.012") or or 12mm (0.472") 12mm ±.30 (.472 ±.012") 178mm (7.00") 180mm (7.0") oror 330mm (13.00") 330mm (13.0") Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA-556. QUANTITIES PACKAGED PER REEL Case Code KEMET EIA R 2012-12 S 3216-12 T 3528-12 U 6032-15 W 7343-15 V 7343-20 A 3216-18 B 3528-21 C 6032-28 D 7343-31 Y 7343-40 X 7343-43 E 7260-38 Tape Width-mm 8 8 8 12 12 12 8 8 12 12 12 12 12 7" Reel* 2,500 2,500 2,500 1,000 1,000 1,000 2,000 2,000 500 500 500 500 500 13" Reel* 10,000 10,000 10,000 5,000 3,000 3,000 9,000 8,000 3,000 2,500 2,000 2,000 2,000 * No c-spec required for 7" reel packaging. C-7280 required for 13" reel packaging. * Standard reel packaging is not mandatory. * Bulk packaging also available using C-7610. 92 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 Packaging TANTALUM, CERAMIC AND ALUMINUM CHIP CAPACITORS Packaging Information Performance Notes 1. Cover Tape Break Force: 1.0 Kg Minimum. 2. Cover Tape Peel Strength: The total peel strength of the cover tape from the carrier tape shall be: Tape Width Peel Strength 8 mm 0.1 Newton to 1.0 Newton (10g to 100g) 12 mm 0.1 Newton to 1.3 Newton (10g to 130g) The direction of the pull shall be opposite the direction of the carrier tape travel. The pull angle of the carrier tape shall be 165 to 180 from the plane of the carrier tape. During peeling, the carrier and/or cover tape shall be pulled at a velocity of 300 ±10 mm/minute. 3. Reel Sizes: Molded tantalum capacitors are available on either 180 mm (7") reels (standard) or 330 mm (13") reels (with C-7280). Note that 13” reels are preferred. 4. Labeling: Bar code labeling (standard or custom) shall be on the side of the reel opposite the sprocket holes. Refer to EIA-556. Embossed Carrier Tape Configuration: Figure 1 Table 1 — EMBOSSED TAPE DIMENSIONS (Metric will govern) Constant Dimensions — Millimeters (Inches) Tape Size 8 mm and 12 mm D0 E P0 4.0 ±0.10 (0.157 ±0.004) P2 2.0 ±0.05 (0.079 ±0.002) T Max 0.600 (0.024) T1 Max 0.100 (0.004) 1.5 1.75 ±0.10 +0.10 -0.0 (0.059 (0.069 ±0.004) +0.004, -0.0) Pitch Single (4 mm) B1 Max. Note 1 4.4 (0.173) 12 mm Double (8 mm) 8.2 (0.323) D1 Min. Note 2 1.0 Variable Dimensions — Millimeters (Inches) Tape Size 8 mm F 3.5 ±0.05 P1 4.0 ±0.10 R Min. Note 3 25.0 T2 Max 2.5 (0.098) W 8.0 ±0.30 (.315 ±0.012) A0B0K0 Note 4 (0.039) (0.138 ±0.002) 1.5 5.5 ±0.05 (0.059) (0.217 ±0.002) (0.157 ±0.004) (0.984) 8.0 ±0.10 30.0 (0.315 ±0.004) (1.181) 4.6 12.0 ±0.30 (0.181) (0.472 ±0.012) NOTES 1. B1 dimension is a reference dimension for tape feeder clearance only. 2. The embossment hole location shall be measured from the sprocket hole controlling the location of the embossment. Dimensions of embossment location and hole location shall be applied independent of each other. 3. Tape with components shall pass around radius “R” without damage (see sketch A). The minimum trailer length (Fig. 2) may require additional length to provide R min. for 12 mm embossed tape for reels with hub diameters approaching N min. (Table 2) 4. The cavity defined by A0, B0, and K0 shall be configured to surround the part with sufficient clearance such that the chip does not protrude beyond the sealing plane of the cover tape, the chip can be removed from the cavity in a vertical direction without mechanical restriction, rotation of the chip is limited to 20 degrees maximum in all 3 planes, and lateral movement of the chip is restricted to 0.5 mm maximum in the pocket (not applicable to vertical clearance.) 94 ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 TANTALUM, CERAMIC AND ALUMINUM CHIP CAPACITORS Packaging Information Embossed Carrier Tape Configuration (cont.) 20° Sketch D: Tape Camber (Top View) 1mm (0.039) Max. 250mm (9.843) Allowable camber to be 1 mm/250 mm. 1mm (0.039) Max. 400mm (15.75) Min. Figure 2: Tape Leader & Trailer Dimensions (Metric Dimensions Will Govern) Figure 3: Reel Dimensions (Metric Dimensions will govern) Table 2 – REEL DIMENSIONS (Metric will govern) Tape Size 8 mm A Max 330.0 (12.992) B* Min 1.5 (0.059) C 13.0 ± 0.20 (0.512 ± 0.008) D* Min 20.2 (0.795) N Min 50.0 (1.969) See Note 3 Table 1 W1 8.4 +1.5, -0.0 (0.331 +0.059, -0.0) 12.4 +2.0, -0.0 (0.488 +0.078, -0.0) W2 Max 14.4 (0.567) W3 7.9 Min (0.311) 10.9 Max (0.429) 11.9 Min (0.469) 15.4 Max (0.606) 12 mm 330.0 (12.992) 1.5 (0.059) 13.0 ± 0.20 (0.512 ± 0.008) 20.2 (0.795) 18.4 (0.724) ©KEMET Electronics Corporation, P.O. Box 5928, Greenville, S.C. 29606, (864) 963-6300 95 Packaging
很抱歉,暂时无法提供与“T496”相匹配的价格&库存,您可以联系我们找货
