WRD_S-1W & WRD_S-2W Series
1W & 2W, WIDE INPUT, ISOLATED & REGULATED TWIN OUTPUT SIP DC-DC CONVERTER
m ulti-country patent protection RoHS
FEATURES
Wide (2:1) Input Range Miniature SIP Package I/0 Isolation 1000VDC Short Circuit Protection(automatic recovery) External On/Off control Internal SMD construction Operating Temperature: -40°C to +85°C RoHS Compliance
PRODUCT PROGRAM
Input Part Number W RD050505S-1W W RD050909S-1W W RD051212S-1W W RD051515S-1W W RD050505S-2W W RD050909S-2W W RD051212S-2W W RD051515S-2W W RD120505S-1W W RD120909S-1W W RD121212S-1W W RD121515S-1W W RD120505S-2W W RD120909S-2W W RD121212S-2W W RD121515S-2W W RD240505S-1W W RD240909S-1W W RD241212S-1W W RD241515S-1W W RD240505S-2W W RD240909S-2W W RD241212S-2W W RD241515S-2W W RD480505S-1W W RD480909S-1W 24 18-36 40 10 12 9.0-18 22 20 5 4.5-9.0 11 40 Voltage (VDC) Nominal R ange N o-load Voltage Max* (mA)(Typ) (VDC) 5 9 12 15 5 9 12 15 5 9 12 15 5 9 12 15 5 9 12 15 5 9 12 15 5 9 12 48 36-72 80 5 15 5 9 12 15 Output Current (mA) Max 100 55 42 33 200 111 83 67 100 55 42 33 200 111 83 67 100 55 42 33 200 111 83 67 100 55 42 33 200 111 83 67 Min 10 5 4 3 20 11 8 7 10 5 4 3 20 11 8 7 10 5 4 3 20 11 8 7 10 5 4 3 20 11 8 7 70 71 73 72 67 71 72 73 73 76 78 78 75 77 80 79 76 77 78 77 76 78 80 79 73 75 77 77 75 78 79 78 Efficiency (%, Typ)
APPLICATIONS
The WRD_S-1W Series are specially designed for applications where a wide range input voltage power supplies are isolated from the input power supply in a distributed power supply system on a circuit board. These products apply to: 1) Where the voltage of the input power supply is wide range (voltage range ≤2:1); 2) Where isolation is necessary between input and output & Vout1 and Vout2 (Isolation Voltage ≤1000VDC); 3) Where the regulation of the output voltage and the output ripple noise are demanded.
MODEL SELECTION
WRD051212S-1W
Rated Power Package Style 2nd Output Voltage 1st Output Voltage Input Voltage
W RD481212S-1W W RD481515S-1W W RD480505S-2W W RD480909S-2W W RD481212S-2W W RD481515S-2W
*Input voltage can’t exceed this value, or will cause the permanent damage. Note: The load shouldn't be less than 10%, otherwise ripple will increase dramatically. Operation under 10% load will not damage the converter; However, they may not meet all specification listed .
OUTPUT SPECIFICAT IONS
Item M ORNSUN Science & Technology co.,Ltd.
Address: 2th floor 6th building, Huangzhou Industrial District, Guangzhou, China Tel: 86-20-38601850 Fax:86-20-38601272 Http://www.mornsun-power.com
Test Conditions R efer to recommended circuit 10% to 100% load Input voltage from low to high Refer to recommended circuit 20MHz Bandwidth Input voltage range 100% load
Min
Typ ±1 ±3 ±0.5 ±0.2 50 300
Max ±3 ±5 ±1* ±0.5 ±0.03 100
Units
Positive voltage accuracy Load regulation Line regulation Temperature drift (Vout) Ripple & Noise** Switching frequency
N egative voltage accuracy R efer to recommended circuit
%/°C mVp-p kHz
*Dual output models unbalanced load: ±5%. **Test ripple and noise by “parallel cable” method. See detailed operation instructions at Testing of Power Converter section, application notes.
MORNSUN reserves the copyright
Specifications subject to change without notice.
WRD_S-1W & WRD_S-2W
A/1-2008
Page 1 of 2
COMMON SPECIFICATION
Item Storage humidity Operating temperature Storage temperature Temp. rise at full load Lead temperature Isolation voltage Isolation resistance Isolation Capacitance N o-load power consumption C ooling Short circuit protection C ase material MTBF Weight 1000 5.8 1.5mm from case for 10 seconds Tested for 1 minute and 1mA max Test at 500VDC 100KHz,1V 1000 1000 80 0.1 Free Air Convection Continuous Plastic(UL94-V0) K hours g -40 -55 15 300 VDC MΩ pF W Test Conditions Min Typ. Max 95 85 125 °C Units %
APPLICATION NOTE
CS Pin By connecting a low ESR capacitor between this terminal and the pin-7(Figure 1), the output ripple and noise may be further improved. Generally, the capacitance is no greater than 47uF. Requirement on Output Load To ensure this module can operate efficiently and reliably, During operation, the minimum output load is not less than 10% of the full load, If the actual load is less than the specified minimum load, the output ripple may increase sharply. If the actual output power is very small, please add an appropriate resistor as extra loading, or contact our company for other lower output power products. Recommended Circuit If you want to further input/output ripple, you
Note: 1. All specifications measured at TA=25°C, humidity
很抱歉,暂时无法提供与“WRD050909S-2W”相匹配的价格&库存,您可以联系我们找货
