Test Procedure for the NCP382LMN20AGEVB Evaluation Board
Equipment Needed:
1. Power Supply (5V, 3A)
2. Potentiometer/Load (100Ω, 10W)
3. Multimeter
Note: Cables should be as short as possible to lower their inductance value – otherwise you
may harm either the input or output pins of the device
Set-up & Test:
1.
2.
3.
4.
5.
6.
Apply Vin = 4V dc (Over Current Limit = 2.0A) on IN test point.
Connect a 100Ω, 10W load between Output1 test point and GND strap.
Toggle EN1 strap between Low and High sides.
Output1 must change from 0 to 4V by toggling the EN1 switch.
Disconnect load from Output1 and connect it to Output2 test point.
Toggle EN2 strap between Low and High sides.
7. Output2 must change from 0 to 4V by toggling the EN2 switch.
7/30/2012
-1-
www.onsemi.com
很抱歉,暂时无法提供与“NCP382LMN20AGEVB”相匹配的价格&库存,您可以联系我们找货
