T1073
T1073
    PULSECORE(普思)
    TRANSFORMER
T1073 数据手册
Telecommunications Products 现货库存、技术资料、百科信息、热点资讯,精彩尽在鼎好! TELECOMMUNICATIONS PRODUCTS Pulse is a leading provider of magnetics for telecom infrastructure equipment, customer premises equipment, audio interface applications, and emerging applications such as VoIP. Our broad portfolio of transformers and integrated transformer modules support T1/E1/ISDN-PRI, T3/E3/STS-1, ISDN-S, ISDN-U, Digital Audio, and DDS. Package options include surface mount, through hole, single, dual, quad and octal covering standard and extended temperature ranges. Many parts meet ANSI, ITU and ETSI requirements, and many are recognized by UL, TUV, Austel and/or CSA. Numerous models incorporate our patented “Interlock Base” construction, ensuring high reliability. Please see our “Telecom IC Cross Reference” section that begins on page 18. TRANSFORMERS T1/E1/CEPT/ISDN-Pri—SINGLE, DUAL Part Number RoHS-6 Part Number Turns Ratio Package L/W/H (in.)* Data Sheet SINGLE TRANSFORMERS 1.5 kV Isolation, Standard Temperature Range, THT PE-64931 PE-64931NL 1:1:1 (1:2CS) .350 / .500 / .250 PE-64933 PE-64933NL 1CT:3CT .350 / .500 / .250 PE-64934 PE-64934NL 1:1 .350 / .500 / .250 PE-64936 PE-64936NL 1CT:1 .350 / .500 / .250 PE-64937 PE-64937NL 1:1.36 .350 / .500 / .250 PE-64940 PE-64940NL 1:1:1.58 .350 / .500 / .250 PE-64941 PE-64941NL 1:1:2 .350 / .500 / .250 PE-64942 PE-64942NL 1:1:2.62 .350 / .500 / .250 PE-64943 PE-64943NL 1CT:2CT .350 / .500 / .250 PE-65351 PE-65351NL 1:2CT .350 / .500 / .250 PE-65363 PE-65363NL 1:4CT .350 / .500 / .250 PE-65379 PE-65379NL 1:1.14CT .350 / .500 / .250 PE-65388 PE-65388NL 1:1.15CT .350 / .500 / .250 PE-65389 PE-65389NL 1:1:1.266 .350 / .500 / .250 PE-65415 PE-65415NL 1CT:2CT .350 / .500 / .250 PE-65558 PE-65558NL 1:2.3CT .350 / .500 / .250 PE-65586 PE-65586NL 1:1.36CT .350 / .500 / .250 PE-65755 PE-65755NL 1CT:1CT .350 / .500 / .250 PE-68644 PE-68644NL 1CT:1 .350 / .500 / .250 PE-68645 PE-68645NL 1:1.36CT .350 / .500 / .250 T1054 T1054NL 1:1.5CT .350 / .500 / .250 T1249 T1249NL 1:1.26CT .350 / .500 / .250 1.5 kV Isolation, Extended Temperature Range, THT PE-68664 PE-68664NL 1:1/1.26 .350 / .500 / .250 PE-65340 PE-65340NL 1:1.36 .350 / .500 / .250 PE-65770 PE-65770NL 1:1.15CT .350 / .500 / .250 PE-65771 PE-65771NL 1CT:2CT .350 / .500 / .250 PE-65778 PE-65778NL 1CT:1CT .350 / .500 / .250 PE-68600 PE-68600NL 1CT:3CT .350 / .500 / .250 TX1252 TX1252NL 1CT:1 .350 / .500 / .250 T1229 T1229NL 1:1.583CT .350 / .500 / .250 1.5 kV Isolation, Extended Temperature Range, SMT TX1281 ⎯ 1CT:1 .220 / .305 / .200 TX1282 ⎯ 1.14CT:1 .220 / .305 / .200 TX1283 ⎯ 1.35CT:1 .220 / .305 / .200 TX1284 ⎯ 1.26CT:1 .220 / .305 / .200 TX1491 ⎯ 1CT:1 .220 / .305 / .200 TX1492 ⎯ 2CT:1 .220 / .305 / .200 TX1314 ⎯ 1:1/1.26 .300 / .390 / .250 TX1315 ⎯ 1CT:1CT .300 / .390 / .250 TX1320 ⎯ 1CT:1.36CT .300 / .390 / .250 3.0 kV – Reinforced Insulation per IEC 950, THT PE-65830 PE-65830NL 1:1:1.58 .558 / .558 / .400 PE-65831 PE-65831NL 1:1:2 .558 / .558 / .400 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T659 T669 T669 T669 T669 T669 T669 T678 T678 T678 T608 T608 Part Number Turns Ratio Package L/W/H (in.)* Data Sheet 3.0 kV – Reinforced Insulation per IEC 950, THT (continued) PE-65832 PE-65832NL 1:1.36CT .558 / .558 / .400 T608 PE-65833 PE-65833NL 1CT:2CT .558 / .558 / .400 T608 PE-65834 PE-65834NL 1:1 .558 / .558 / .400 T608 1 PE-65835 PE-65835NL 1CT:2CT .558 / .558 / .400 T608 PE-65836 PE-65836NL 1CT:3CT:1 .558 / .558 / .400 T608 PE-65837 PE-65837NL 1:1.08:1.36 .558 / .558 / .400 T608 PE-65838 PE-65838NL 1:1.14 .558 / .558 / .400 T608 PE-65839 PE-65839NL 1:1:1.266 .558 / .558 / .400 T608 PE-68646 PE-68646NL 1:1.58:2 .558 / .558 / .400 T608 PE-68788 PE-68788NL 1CT:1.41CT .558 / .558 / .400 T608 DUAL TRANSFORMERS 1.5 kV Isolation, Extended Temperature Range, THT PE-68618 PE-686 18NL 1CT:1CT & 1CT:3CT:0.25 1.000 / .390 / .290 T608 PE-64950 PE-64950NL 1CT:1CT & 1CT:3CT:1 1.000 / .390 / .290 T608 PE-65567 PE-65567NL 1:1.15CT & 1:2CT .800 / .390 / .290 T608 PE-65568 PE-65568NL 1:1:1.266 & 1:2CT .800 / .390 / .290 T608 PE-65774 PE-65774NL 1CT:2CT & 1:1.36CT .800 / .390 / .290 T608 1.5 kV Isolation, Standard Temperature Range, THT PE-64951 PE-64951NL 1:2CT & 1:2CT .800 / .390 / .250 T608 PE-64952 PE-64952NL 1:2CT & 1:1.36CT .800 / .390 / .250 T608 PE-64953 PE-64953NL 1:2CT & 1:2CT .800 / .390 / .250 T608 PE-64954 PE-64954NL 1CT:2CT & 1:1 .800 / .390 / .250 T608 PE-64955 PE-64955NL 1.58:2CT & 1.58:1 .800 / .390 / .250 T608 PE-64956 PE-64956NL 2:2CT & 2:1 .800 / .390 / .250 T608 PE-64957 PE-64957NL 2.62:2CT & 2.62:1 .800 / .390 / .250 T608 PE-65565 PE-65565NL 1:1.15CT & 1:2CT .800 / .390 / .290 T608 PE-65566 PE-65566NL 1:1:1.266 & 1:2CT .800 / .390 / .290 T608 1.5 kV Isolation, Standard Temperature Range, BH Package, SMT T1136 T1136NL 1CT:1CT & 1CT:1.36CT .505 / .375 / .245 T608 T1022 T1022NL 1CT:1CT & 1CT:1.5CT .505 / .375 / .245 T608 T1190 T1190NL 1CT:1.36CT & 1CT:1CT .505 / .375 / .245 T654 PE-65861 PE-65861NL 1CT:2CT & 1CT:2CT .505 / .375 / .245 T608 PE-65862 PE-65862NL 1CT:2CT & 1:1.36CT .505 / .375 / .245 T608 PE-65865 PE-65865NL 1:1.15CT & 1CT:2CT .505 / .375 / .245 T608 PE-65866 PE-65866NL 1:1/1.26 & 1CT:2CT .505 / .375 / .245 T608 PE-65870 PE-65870NL 1CT:1.15CT & 1CT:1.15CT .505 / .375 / .245 T608 PE-68678 PE-68678NL 1CT:1CT & 1CT:2CT .505 / .375 / .245 T608 PE-68786 PE-68786NL 1CT:1.41CT & 1CT:1.41CT .505 / .375 / .245 T608 T1023 T1023NL 1CT:1.41CT & 1CT:1.41CT .505 / .375 / .245 T608 T1137 T1137NL 1CT:2.42CT & 1CT: 2.42CT .505 / .375 / .245 T651 T1021 T1021NL 2CT:1/1.26 & 2CT:1/1.26 .505 / .375 / .245 T637 T1075 T1075NL 2CS:1.57/2 & 2CS:1.57/2 .505 / .375 / .245 T637 T1122 T1122NL 1CT:2CT & 1CT:2.3CT .505 / .375 / .245 T608 T1121 T1121NL 1CT:1.5CT & 1CT:1.5CT .505 / .375 / .245 T608 T1286 T1286NL 1CT:2.4CT & 1CT: 2.4CT .505 / .375 / .245 T608 1. To make a 1CT:1 ratio from a 1CT:2CT ratio, use only one-half the 2CT winding. *L/W/H is measured on surface mount parts tip to tip (height includes wash area). 14 RoHS-6 Part Number www.pulseeng.com SMT - Surface Mount Package THT - Through Hole Package G003.U (2/07) Telecommunications Products TELECOMMUNICATIONS PRODUCTS TRANSFORMERS, TRANSFORMER/CHOKE INTERFACE MODULES T1/E1/CEPT/ISDN-Pri—SINGLE, DUAL, Quad Part Number RoHS-6 Part Number Turns Ratio Package L/W/H (in.)* DUAL TRANSFORMERS (continued) 1.5 kV Isolation, Extended Temperature Range, BH Package, SMT T1090 T1090NL 1CT:2CT & 1CT:2CT .505 / .375 / .245 1CT:2CT & 1:1.36CT T1091 T1091NL .505 / .375 / .245 T1076 T1076NL 1:1.15CT & 1CT:2CT .505 / .375 / .245 1:1/1.26 & 1CT:2CT .505 / .375 / .245 T1092 T1092NL 1CT:1.15CT & 1CT:1.15CT .505 / .375 / .245 T1093 T1093NL 1CT:1CT & 1CT:1.5CT T1077 T1077NL .505 / .375 / .245 1CT:1CT & 1CT:2CT .505 / .375 / .245 T1094 T1094NL T1144 T1144NL 1CT:1CT & 1CT:2.4CT .505 / .375 / .245 1CT:1.41CT & 1CT:1.41CT .505 / .375 / .245 T1095 T1095NL T1096 T1096NL 1CT:1.41CT & 1CT:1.41CT .505 / .375 / .245 T1097 T1097NL 1CT:1CT & 1CT:1.67CT .505 / .375 / .245 T1146 T1146NL 1:2/2.4 & 1:0.79/1 .505 / .375 / .245 TX1088 TX1088NL 1CT:2CT & 1CT:2.42CT .505 / .375 / .245 TX1089 TX1089NL 1CT:1CT & 1CT:1CT .505 / .375 / .245 TX1099 TX1099NL 1CT:1:0.8 & 1CT:1:0.8 .505 / .375 / .245 TX1287 TX1287NL 1CT:2.42CT & 1CT: 2.42CT .505 / .375 / .245 TX1317 TX1317NL 1:2CT & 1:2CS .505 / .375 / .245 TX1186 TX1186NL 1CT:1.58:2 & 1:1.65:2 .505 / .375 / .245 TX1187 TX1187NL 1CT:2CT & 1:1 .505 / .375 / .245 TX1188 TX1188NL 1CT:2CT & 1CT:2CT .505 / .375 / .245 TX1189 TX1189NL 1:1.36CT & 1:2CT .505 / .375 / .245 TX1467 TX1467NL 1CT:1:1 & 1CT:1:1 .505 / .375 / .245 1.5 kV Isolation, Standard Temperature Range, ANTE Package, SMT T1131 T1131NL 1CT:1 & 1:1.36CT .675 / .600 / .340 PE-68861 PE-68861NL 1CT:2CT & 1CT:2CT .675 / .600 / .340 PE-68862 PE-68862NL 1CT:2CT & 1:1.36CT .675 / .600 / .340 PE-68863 PE-68863NL 1:2CT & 1:1.14CT .675 / .600 / .340 PE-68864 PE-68864NL 1CT:2CT & 1:1 .675 / .600 / .340 PE-68865 PE-68865NL 1:1.15CT & 1CT:2CT .675 / .600 / .340 PE-68866 PE-68866NL 1:1/1.26 & 1:2CT .675 / .600 / .340 PE-68869 PE-68869NL 1CT:2CT & 1:1.08CT .675 / .600 / .340 PE-68836 PE-68836NL 1:1/1.26 & 1:1/1.26 .675 / .600 / .340 1.5 kV Isolation, Extended Temperature Range, ANTE Package, SMT PE-68822 PE-68822NL 1CT:2CT & 1:1.36CT .675 / .600 / .340 PE-68825 PE-68825NL 1:1.15CT & 1CT:2CT .675 / .600 / .340 PE-68826 PE-68826NL 1:1/1.26 & 1:2CT .675 / .600 / .340 PE-68827 PE-68827NL 1:1CT & 2:1 .675 / .600 / .340 PE-68828 PE-68828NL 1CT:1CT & 1CT:1CT .675 / .600 / .340 PE-68841 PE-68841NL 1CT:2CT & 1CT:2CT .675 / .600 / .340 PE-68874 PE-68874NL 1CT:1.15CT & 1CT:1.15CT .675 / .600 / .340 PE-68877 PE-68877NL 1CT:1CT & 1CT:2CT .675 / .600 / .340 PE-68881 PE-68881NL 1CT:2.3CT & 1CT:2CT .675 / .600 / .340 PE-68882 PE-68882NL 1:1.15CT: & 1CT:1CT .675 / .600 / .340 PE-68884 PE-68884NL 1CT:1.36CT & 1CT:1.36CT .675 / .600 / .340 PE-68887 PE-68887NL 1CT:1.41CT & 1CT:1.41CT .675 / .600 / .340 TX1277 TX1277NL 1CT:1CT & 1CT:2CT .675 / .600 / .340 3.0 kV Isolation – Standard Temperature Range, SMT T1030 ⎯ 1CT:1CT & 1CT:1CT .950 / .745 / .395 T1081 ⎯ 1CT:1CT & 1CT:1.5CT .950 / .745 / .395 T1031 ⎯ 1CT:1CT & 1CT:2CT .950 / .745 / .395 T1032 ⎯ 1CT:1.15CT & 1CT:1CT .950 / .745 / .395 T1033 ⎯ 1CT:1.15CT & 1CT:1.15CT .950 / .745 / .395 T1034 ⎯ 1CT:1.15CT & 1CT:2CT .950 / .745 / .395 T1035 ⎯ 1CS:1CS & 1CS:1.36CS .950 / .745 / .395 1CT:1CT & 1CT:1.36CT T1038 ⎯ .950 / .745 / .395 1CT:1.36CT & 1CT:1.36CT .950 / .745 / .395 T1036 ⎯ 1CT:1.41CT & 1CT:1.41CT .950 / .745 / .395 T1037 ⎯ 1CT:1.41CT & 1CT:1.41CT .950 / .745 / .395 T1080 ⎯ 1CT:2CT & 1CT:1.08CT T1039 ⎯ .950 / .745 / .395 T1043 ⎯ 1CT:2CT & 1CT:1.14CT .950 / .745 / .395 Data Sheet T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T608 T617 T617 T617 T617 T617 T617 T617 T617 T617 T617 T617 T617 T617 Part Number Turns Ratio Package L/W/H (in.)* 3.0 kV Isolation – Standard Temperature Range, SMT (continued) T1044 ⎯ 1CT:2CT & 1CT:1.36CT .950 / .745 / .395 T1045 ⎯ 1CT:2CT & 1CT:2CT .950 / .745 / .395 1CT:2.3CT & 1CT:2CT .950 / .745 / .395 T1047 ⎯ 1CT:1/1.26 & 1CT:2CT .950 / .745 / .395 T1049 ⎯ 1CT:2.42CT & 1CT:2.42CT .950 / .745 / .395 T1082 ⎯ 1CT:2.4CT & 1CT:1CT .675 / .600 / .340 T1308 ⎯ DUAL TRANSFORMER/CHOKE INTERFACE MODULES 1.5 kV Isolation, Extended Temperature Range, SMT T1207 T1207NL 1CT:2CT & 1CT:2CT .675 / .600 / .340 1CT:2CT & 1CT:1.36CT .675 / .600 / .340 T1208 T1208NL T1209 T1209NL 1CT:1.15CT & 1CT:2CT .675 / .600 / .340 T1210 T1210NL 1CT:1.26CT & 1CT:2CT .675 / .600 / .340 T1211 T1211NL 1CT:1.15CT & 1CT:1.15CT .675 / .600 / .340 T1212 T1212NL 1CT:1CT & 1CT:2CT .675 / .600 / .340 T1213 T1213NL 1CT:1.15CT & 1CT:1CT .675 / .600 / .340 T1214 T1214NL 1CT:1.36CT & 1CT:1.36CT .675 / .600 / .340 T1215 T1215NL 1CT:1.41CT & 1CT:1.41CT .675 / .600 / .340 T1216 T1216NL 1CT:2.3CT & 1CT:2CT .675 / .600 / .340 T1217 T1217NL 1CT:2.42CT & 1CT:2.42CT .675 / .600 / .340 T1218 T1218NL 1CT:1CT & 1CT:1.36CT .675 / .600 / .340 T1219 T1219NL 1CT:2.4CT & 1CT:1CT .675 / .600 / .340 T1220 T1220NL 1CT:1CT & 1CT:1CT .675 / .600 / .340 QUAD TRANSFORMER/CHOKE INTERFACE MODULES 1.5 kV Isolation, Extended Temperature Range, SMT T1176 T1176NL 1CT:2.4CT & 1CT:1CT .690 / .630 / .225 1CT:2.42CT & 1CT:2.42CT .690 / .630 / .225 TX1192 TX1192NL TX1193 TX1193NL 1CT:2CT & 1CT:1CT .690 / .630 / .225 TX1194 TX1194NL 1CT:1.15CT & 1CT:1.15CT .690 / .630 / .225 TX1195 TX1195NL 1CT:1.41CT & 1CT:1.41CT .690 / .630 / .225 TX1196 TX1196NL 1CT:2CT & 1CT:2CT .690 / .630 / .225 TX1197 TX1197NL 1CT:2CT & 1CT:2CT .690 / .630 / .225 TX1198 TX1198NL 1CT:2.3CT & 1CT:1CT .690 / .630 / .225 TX1199 TX1199NL 1CT:1.36CT & 1CT:2CT .690 / .630 / .225 TX1300 TX1300NL 1CT:1.36CT & 1CT:1CT .690 / .630 / .225 TX1301 TX1301NL 1CT:1.15CT & 1CT:2CT .690 / .630 / .225 T1337 ⎯ 1CT:1CT & 1CT:1CT .537 / .590 / .245 QUAD TRANSFORMERS (four transformers per package) 1.5 kV Isolation, Extended Temperature Range, SMT TX1321 TX1321NL 1CT:2.4CT & 1CT:1CT .690 / .630 / .225 TX1322 TX1322NL 1CT:2.42CT & 1CT:2.42CT .690 / .630 / .225 TX1323 TX1323NL 1CT:2CT & 1CT:1CT .690 / .630 / .225 1CT:1.15CT & 1CT:1.15CT .690 / .630 / .225 TX1324 TX1324NL TX1325 TX1325NL 1CT:1.41CT & 1CT:1.41CT .690 / .630 / .225 TX1326 TX1326NL 1CT:2CT & 1CT:2CT .690 / .630 / .225 TX1327 TX1327NL 1CT:2CT & 1CT:2CT .690 / .630 / .225 TX1328 TX1328NL 1CT:2.3CT & 1CT:1CT .690 / .630 / .225 TX1329 TX1329NL 1CT:1.36CT & 1CT:2CT .690 / .630 / .225 TX1330 TX1330NL 1CT:1.36CT & 1CT:1CT .690 / .630 / .225 TX1331 TX1331NL 1CT:1.15CT & 1CT:2CT .690 / .630 / .225 QUAD TRANSFORMERS (four transformers per package) 1.5 kV Isolation, Standard Temperature Range, SMT T1001 T1001NL 1:1 & 1:1.36 1.000 / .425 / .295 T1005 T1005NL 1:1.267 & 1:1.58 1.000 / .425 / .295 T1006 T1006NL 1:1 & 1:2CT 1.000 / .425 / .295 T1007 T1007NL 1:1.15 1.000 / .425 / .295 T1008 T1008NL 1:1.364 & 1:2 1.000 / .425 / .295 T1009 T1009NL 1:1 & 1:1.265 1.000 / .425 / .295 T1010 T1010NL 1:1.36CT 1.000 / .425 / .295 T1016 T1016NL 1:1.15 & 1:2 1.000 / .425 / .295 T1017 T1017NL 1:2.3 & 1:2 1.000 / .425 / .295 *L/W/H is measured on surface mount parts tip to tip (height includes wash area). G003.U (2/07) RoHS-6 Part Number www.pulseeng.com SMT - Surface Mount Package Data Sheet T617 T617 T617 T617 T617 T666 T660 T660 T660 T660 T660 T660 T660 T660 T660 T660 T660 T660 T660 T660 T662 T662 T662 T662 T662 T662 T662 T662 T662 T662 T662 T665 T662 T662 T662 T662 T662 T662 T662 T662 T662 T662 T662 T615 T615 T615 T615 T615 T615 T615 T615 T615 THT - Through Hole Package 15 Telecommunications Products TELECOMMUNICATIONS PRODUCTS TRANSFORMERS, TRANSFORMER MODULES T1/E1 Protection Modules T1/E1/CEPT/ISDN-Pri—Octal Part Number RoHS-6 Part Number Turns Ratio TX RX Package L/W/H (in.)* Data Sheet OCTAL TRANSFORMERS (eight transformers per package) 1.5 kV Isolation, Standard Temperature Range, SMT T1063 T1063NL 1:1.36 1:1.36CT 1.125 / .640 / .230 T1064 T1064NL 1:1.14 1:1.14CT 1.125 / .640 / .230 T1065 T1065NL 1:2CT 1:2CT 1.125 / .640 / .230 T1066 T1066NL 1:2 1:2CT 1.125 / .640 / .230 T1067 T1067NL 1:1.36CT 1:2CT 1.125 / .640 / .230 T1068 T1068NL 1:2CT 1:1CT 1.125 / .640 / .230 T1069 T1069NL 1CT:1.41 1CT:1.41 1.125 / .640 / .230 T1070 T1070NL 1:1.15 1:2CT 1.125 / .640 / .230 T1071 T1071NL 1:1/1.26 1:2CT 1.125 / .640 / .230 T1072 T1072NL 1:1.15 1:1.15 1.125 / .640 / .230 T1073 T1073NL 1:2 1:2 1.125 / .640 / .230 T1124 T1124NL 1:2CT 1CT:2 1.125 / .640 / .230 T1125 T1125NL 1:1.70 1:1.36CT 1.125 / .640 / .230 T1129 T1129NL 1:1.36CT 1:1CT 1.125 / .640 / .230 T1142 T1142NL 1:2.4 1:1 1.125 / .640 / .230 T1145 T1145NL 1:2/2.4 1:0.79/1 1.125 / .640 / .230 T1180 T1180NL 1:2.42 1:2.42 1.125 / .640 / .230 T1181 T1181NL 1:2.1CT 1:2.1CT 1.125 / .640 / .230 T1182 T1182NL 1:2.45CT 1:2.45CT 1.125 / .640 / .230 T1078 T1078NL 1:1.08 1.08CT:1 1.125 / .640 / .230 1.5 kV Isolation, Extended Temperature Range, SMT T1103 T1103NL 1:1.36 1:1.36CT 1.125 / .640 / .230 T1104 T1104NL 1:1.14 1:1.14CT 1.125 / .640 / .230 T1105 T1105NL 1:2CT 1:2CT 1.125 / .640 / .230 T1106 T1106NL 1:2 1:2CT 1.125 / .640 / .230 T1107 T1107NL 1:1.36CT 1:2CT 1.125 / .640 / .230 T1108 T1108NL 1:2CT 1:1CT 1.125 / .640 / .230 T1109 T1109NL 1CT:1.41 1CT:1.41 1.125 / .640 / .230 T1110 T1110NL 1:1.15 1:2CT 1.125 / .640 / .230 T1111 T1111NL 1:1/1.26 1:2CT 1.125 / .640 / .230 1.5 kV Isolation, Standard Temperature Range, SMT T1112 T1112NL 1:1.15 1:1.15 1.125 / .640 / .230 T1113 T1113NL 1:2 1:2 1.125 / .640 / .230 T1114 T1114NL 1:2CT 1CT:2 1.125 / .640 / .230 T1226 T1226NL 1:1.5 1.41:1 1.125 / .640 / .230 T1231 T1231NL 1:2.4 1:1 1.125 / .640 / .230 TX1262 TX1262NL 1:2 1:2 1.125 / .640 / .230 TX1264 TX1264NL 1:2CT 1CT:1.41 1.125 / .640 / .230 TX1266 TX1266NL 1:2 1:1 1.125 / .640 / .230 TX1292 TX1292NL 1:1.36 1:1 1.125 / .640 / .230 TX1294 TX1294NL 1:1CT 1:1CT 1.125 / .640 / .230 TX1295 TX1295NL 1:1.26CT 1:1.26CT 1.125 / .640 / .230 TX1298 TX1298NL 1:1 1:1 1.125 / .640 / .230 TX1299 TX1299NL 1:2.42 1:2.42 1.125 / .640 / .230 TX1341 TX1341NL 1:2 1:2 1.000 / .425 / .295 TX1342 TX1342NL 1:1.15 1:1.15 1.000 / .425 / .295 T1343 T1343NL 1:1.266 1:1.266 1.000 / .425 / .295 TX1344 TX1344NL 1:1 1:2 1.000 / .425 / .295 TX1470 TX1470NL 1:1.41 1:1.41 1.000 / .425 / .295 TX1472 TX1472NL 1: 2.4 1:1 1.000 / .425 / .295 TX1473 TX1473NL 1:2 1:1 1.000 / .425 / .295 TX1474 TX1474NL 1:2.42 1:2.42 1.000 / .425 / .295 TX1471 TX1471NL 1:1 1:1 1.000 / .425 / .295 OCTAL TRANSFORMER/CHOKE INTERFACE MODULES 1.5 kV Isolation, Extended Temperature Range, SMT TX1263 TX1263NL 1:2 1:2 1.125 / .640 / .285 TX1267 TX1267NL 1:2 1:1 1.125 / .640 / .285 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T622 T671 T671 T671 T671 T671 T671 T671 T671 T671 T682 T682 SONET/SDH (STM-1/E4/CMI) Part Number DUAL, SMT A7802 ST6200QNL Turns Ratio Primary Inductance OCL (µH MIN) 1:1 1CT:1CT 42 28 Package L/W/H (in.) ¹ Data Sheet .500 / .295 / .220 .455 / .375 / .225 A103 T692 Part Number Turns Ratio Primary Inductance OCL (µH MIN) Package L/W/H (in.)* OCTAL TRANSFORMER MODULES, 1.5 kV Isolation Extended Temperature Range, Line Side Protection, SMT TX RX T9030 1CT:2 1CT:1 1.2 1.255 / .852 / .305 TX9031 1CT:2.4 1:1CT 1.2 1.255 / .852 / .305 TX9032 1CT:1 1:1CT 1.2 1.255 / .852 / .305 TX9033 1CT:1.14 1.14:1CT 1.2 1.255 / .852 / .305 IC Side Protection, SMT T9021 1:2.42 1:2.42 .6 1.125 / .640 / .285 TX9020 1:2.42 1:2.42 1.2 1.125 / .640 / .285 TX9022 1:2.42 1:2.42 1.2 1.125 / .640 / .285 TX9023 1:2 1:2 1.2 1.125 / .640 / .285 TX9025 1:2CT 1:2 1.2 1.125 / .640 / .285 TX9027 1:2 1:2 1.2 1.125 / .640 / .285 T3/DS3/E3/STS-1—Single, Dual, Six Octal, Twelve SINGLE TRANSFORMERS THT PE-68629 1:1 40 .350 / .500 / .250 PE-65966 1:1 40 .300 / .280 / .250 PE-65663 1:1 40 .300 / .400 / .250 PE-65969 1:2CT 19 .300 / .280 / .250 PE-65664 1:2CT 35 .300 / .400 / .250 PE-68630 1:2CT 19 .350 / .500 / .250 PE-65779 1:4CT 200 .300 / .400 / .250 PE-65856 1:1.73CT 50 .300 / .280 / .250 SMT PE-65967 1:1 40 .300 / .390 / .250 PE-65662 1:1 45 .300 / .420 / .200 PE-65968 1:2CT 19 .300 / .390 / .250 PE-65661 1:2CT 35 .300 / .420 / .200 SMT, Extended Temperature Range T3001 1:1 100 .300 / .390 / .250 T3002 1:2CT 40 .300 / .390 / .250 T3011 1:1 100 .300 / .390 / .250 T3012 1:2CT 40 .300 / .390 / .250 T3027 1CT:1CT 40 .300 / .390 / .250 T3029 1:1.15CT 40 .300 / .390 / .250 DUAL TRANSFORMERS, SMT, Extended Temperature Range T3020 1:2CT & 1:1 40 & 100 .505 / .375 / .245 T3021 1:2CT & 1:2CT 100 & 100 .505 / .375 / .245 T3023 1:1 & 1:1 40 & 40 .505 / .375 / .245 TX3025 1CT:1CT & 1:1 100 & 100 .505 / .375 / .245 TX3026 1:2CT & 1:1 100 & 100 .505 / .375 / .245 SIX TRANSFORMERS (Triple Port) SMT, Extended Temperature Range TX3036 1:1 100 .537 / .510 / .226 OCTAL TRANSFORMERS (Quad Port) SMT TX3042 1:1 & 1:2CT 40 1.125 / .640 / .230 TX3045 1:1 & 1:2 40 1.000 / .425 / .295 TX3047 1:1 40 1.000 / .425 / .295 T3048 1:1 40 1.000 / .425 / .295 T3049 1:2 19 1.000 / .425 / .295 TWELVE TRANSFORMERS (Six Port) SMT, Extended Temperature Range TX3051 1:1 60 1.120 / .630 / .280 TX3052 1:2 40 1.120 / .630 / .280 1. SOIC = 50 mil pitch leads. Length and width are MAX package dimensions. Height dimensions include the wash area. SMT - Surface Mount Package Data Sheet T656 T670 T680 T680 T657 T677 T677 T674 T686 T691 T606 T606 T606 T606 T606 T606 T606 T606 T606 T606 T606 T606 T619 T619 T619 T619 T619 T619 T655 T655 T655 T655 T655 T672 T690 T663 T663 T663 T663 T668 T668 THT - Through Hole Package *L/W/H is measured on surface mount parts tip to tip (height includes wash area). 16 www.pulseeng.com G003.U (2/07) Telecommunications Products TELECOMMUNICATIONS PRODUCTS TRANSFORMERS, TRANSFORMER MODULES ISDN U-Interface Part Number 1.5-2.0 kV 2.5 kV 3 kV Turns Ratio 1 OCL Line Side (mH MIN) ISDN S-Interface — Single, Dual (continued) Package Data L/W/H (in.)* Sheet THT PE-65575 — PE-68669 1.65:1 13.0 -18.0 1.100/ .750 / .430 T603 PE-65578 — — 1.32:1 7.0 - 8.3 1.100/ .750 / .430 T603 PE-65579 — — 2.00:1 25.5 - 28.5 1.100/ .950 / .450 T603 PE-65581 — — 1.50:1 14.2-15.8 1.100/ .950 / .450 T603 PE-65583 PE-68631 — 1.50:1 25.6-28.4 1.100/ .950 / .450 T603 PE-65584 PE-68681 — 1.50:1 25.6-28.4 1.100/ .950 / .450 T603 PE-68628 PE-68668 — 1.25:1 26.5-29.5 1.100/ .950 / .450 T603 T4008 — — 1.50:1 73.0-98.0 1.050/ .900/1.050 T616 PT4084 — — 1:0.75:0.75 85.0 .800 /1.020/ .675 PT4084 PT5031 — — 1:1.25 14.5 .800 /1.020/ .675 PT5031 PT5062 — — 1:1.6CT 27.0 .800 /1.020/ .675 PT5062 PT5065 — — 1:1.33CT 27.0 .800 /1.020/ .675 PT5065 T4022 — — 1.6CS:1CT 8.41-2.60 .760 / .870 / .450 T625 1. Echo Cancellation Hybrid units PE-36005 and PE-36005W are also available. Part Number Turns Ratio Primary Inductance OCL (mH MIN) Package L/W/H (in.)* Data Sheet SMT T4001 1.25:1 26.5 - 30.0 .760 / .870 / .500 T614 T4002 1.65:1 15.0 - 18.0 .760 / .870 / .500 T614 T4004 1.50:1 25.6 - 28.4 .760 / .870 / .500 T614 T4006 1.50:1 14.2 - 15.8 .760 / .870 / .500 T614 T4031 1.65CS:1CT 13.0 - 18.0 .695 / .530 / .485 T624 T4032 1.25CS:1CT 11.9 - 16.1 .695 / .530 / .485 T624 T4033 1.25CS:1CT 26.6 - 29.4 .695 / .530 / .485 T624 T4043 2CS:1CS 13.5 -16.5 .695 / .530 / .485 T624 T4067 1.32CS:1 7.5 - 8.3 .695 / .530 / .485 T624 1. Echo Cancellation Hybrid units PE-36005 and PE-36005W are also available. ISDN S-Interface — Single, Dual Part Number Turns Ratio Primary Inductance OCL (mH MIN) Package L/W/H (in.)* SINGLE TRANSFORMERS, 1.5 kV ISOLATION PCMCIA Type 2, SMT T5002 1:1 22 .492 / .670 / .167 T5003 1:2 22 .492 / .670 / .167 T5004 1:2.5 22 .492 / .670 / .167 SINGLE TRANSFORMERS, 2.0 kV ISOLATION THT PE-64993 1:1 22 .560 / .560 / .400 PE-64994 1:1.8 22 .560 / .560 / .400 PE-64995 1:2 22 .560 / .560 / .400 PE-64996 1:2.5 22 .560 / .560 / .400 PE-64998 1:2.5 22 .560 / .560 / .400 PE-64999 1:2 22 .560 / .560 / .400 DUAL TRANSFORMERS, 2.0 kV ISOLATION THT PE-65492 1:1 & 1:2 22 .920 / .560 / .400 PE-65493 1:1 & 1:1 22 .920 / .560 / .400 PE-65495 1:2 & 1:2 22 .920 / .560 / .400 PE-65498 1:2.5 & 1:2.5 22 .920 / .560 / .400 PE-65499 1:2 & 1:2 22 .920 / .560 / .400 SMT PE-65792 1:1 & 1:2 22 .950 / .720 / .390 PE-65793 1:1 & 1:1 22 .950 / .720 / .390 PE-65795 1:2 & 1:2 22 .950 / .720 / .390 PE-65798 1:2.5 & 1:2.5 22 .950 / .720 / .390 PE-65799 1:2 & 1:2 22 .950 / .720 / .390 ST5048 1CS:2.5CS & 1CS:2.5CS 22 .987 / .575 / .340 ST5069 1CS:2CS & 1CS:2CS 22 .987 / .575 / .340 Data Sheet T631 T631 T631 Part Number T604 T604 T604 T604 T604 T604 T604 T604 T604 T604 ST5048 ST5069 Primary Inductance OCL (mH MIN) Package L/W/H (in.)* DUAL TRANSFORMERS, 2.0 kV ISOLATION (continued) Low Profile, SMT T5005 1:2.5 & 1:2.5 22 .950 / .720 / .295 T5006 1:2 & 1:2 22 .950 / .720 / .295 T5007 1:2 & 1:2 22 .950 / .720 / .295 T5008 1:1 & 1:1 22 .950 / .720 / .295 T5009 1:1 & 1:2 22 .950 / .720 / .295 T5010 1:1.8 & 1:1.8 22 .950 / .720 / .295 SINGLE TRANFORMERS, 3.0 kV ISOLATION Reinforced Insulation per IEC 950, THT PE-68992 1:2CT 22 .750 / .750 / .500 PE-68993 1:1 22 .750 / .750 / .500 PE-68995 1:2 22 .750 / .750 / .500 PE-68998 1:2.5 22 .750 / .750 / .500 PE-68999 1:2 22 .750 / .750 / .500 T5035 1CT:2CT 30 .578 / .648 / .565 DUAL TRANSFORMERS, 3.0 kV ISOLATION SMT T5042 1:2 & 1:2 22 1.092 / .726 / .430 T5043 1:2.5 & 1:2.5 22 1.092 / .726 / .430 Data Sheet T613 T613 T613 T613 T613 T613 T604 T604 T604 T604 T604 T636 T638 T638 ISDN S-Interface Modules, Transformer & Choke Part Number THT T5011 T5012 T5013 T5015 SMT T5034 T5037 T5038 T5039 ST5201 T5049 Turns Ratio Pri. Inductance OCL Package OCL (mH MIN) (mH MIN) L/W/H (in.)* Data Sheet Transformer Choke 1CT:1CT & 1CT:1CT 1CT:2CT & 1CT:2CT 1CT:2.5CT & 1CT:2.5CT 1:2CT & 1:2CT 30 30 30 30 4.70 4.70 4.70 4.70 1.150 / .420 / .590 1.150 / .420 / .590 1.150 / .420 / .590 1.150 / .420 / .590 T632 T632 T632 T632 1CT:2CT & 1CT:2CT 1CT:2.5CT & 1CT:2.5CT 1CT:2CT & 1CT:2CT 1CT:2.5CT & 1CT:2.5CT 1CS:2CS & 1CS:2CS 1CT:1CT & 1CT:1CT 30 30 30 30 22 30 4.70 4.70 0.47 0.47 0.42 4.70 1.170 / .660 / .320 1.170 / .660 / .320 1.170 / .660 / .320 1.170 / .660 / .320 .987 / .575 / .340 1.170 / .660 / .320 T635 T635 T635 T635 ST5201 T635 Echelon® & Digital Audio, Single Part Number T604 T604 T604 T604 T604 T604 Turns Ratio Turns Ratio THT T6074 1 1:1 T6075 1:1 PE-65948 1CT:1CT PE-65612 1:1 SMT PE-65848 1CS:1CS PE-65812 1:1 1. With shield Primary Inductance OCL (mH MIN) Package L/W/H (in.)* Data Sheet .225 .225 3.5 - 6.5 2.5 .350 / .500 / .250 .350 / .500 / .250 .350 / .500 / .250 .350 / .500 / .250 T688 T688 T602 T601 3.5 - 6.5 2.5 .480 / .600 / .340 .480 / .600 / .340 T602 T601 .530 / .695 / .485 .410 / .525 / .365 T629 T629 DDS / Switched 56 SMT T7002 T7006 1CT:1CT 1CT:1CT 40 40 Audio / Voice Band SMT T6003 Isolation Voltage 1:1 1500 SMT - Surface Mount Package .530 / .695 / .485 T628 THT - Through Hole Package *L/W/H is measured on surface mount parts tip to tip (height includes wash area). G003.U (2/07) www.pulseeng.com 17 Telecom IC Cross Reference TELECOM IC CROSS REFERENCE IC CROSS REFERENCE Echelon® & Digital Audio ISDN U-Interface Recommended Transformer 1.5 kV 2 kV 2.5 kV THT SMT THT SMT Alcatel (Microelectronics) MTC20276 — T4043 — — — AKM AK5204 T4022 — — — — Infineon Technologies (Siemens) PEB 2091 PT5031 T4031 PE-65575 T4002 — PEB 8091/8191 — T4031 PE-65575 T4002 — PEB 2090/20901 — T4067 PE-65578 — — PEB 24902/11 — T4031 PE-65575 T4002 — PSB 21910/11 — T4031 PE-65575 T4002 — PEB 2491 — T4032 — — — PEB 20901 — T4067 PE-65578 — — PEB 2095 — — — — — PSB 2196 — — — — — Lucent Technologies T7234 PT4084 — T4008 — — Motorola MC145472 — — PE-65579 — — MC145572 PT5062 T4033 PE-68628 1 T4001 2 PE-68668 National Semiconductor TP3410 PT5065 — PE-65583 — PE-68631 — — PE-65584 T4004 — Thomson SD 5411 — — PE-65581 T4006 PE-68631 1. Small package for North American applications available. See T618 data sheet. 2. Suitable for use in North America only. IC Manufacturer/ IC Part Number 3 kV IC Manufacturer Echelon ® — AKM — Cirrus Logic PE-68669 PE-68669 — PE-68669 PE-68669 — — — — — Realtek — 3120™ 1.25 Mbps 3150™ 1.25 Mbps AK4101 AK4102 AK4103 CS8401/2/3/4 CS8405/8415 CS8413/14/27 CS8406/8416 ALS300+ SMT THT PE-65848 PE-65848 PE-65812 PE-65812 PE-65812 PE-65812 PE-65812 PE-65812 — PE-65812 PE-65948 PE-65948 PE-65612 PE-65612 PE-65612 PE-65612 PE-65612 PE-65612 T6074/T6075 PE-65612 DDS/Switched 56 IC Manufacturer IC Part Number Recommended Transformer Dual SMT Intel Intel LXT 441 LXT 441 T7002 T7006 — — — — Single IC Part Number SONET/SDH (STM-1/E4/CMI) DUAL TRANSFORMERS IC Manufacturer AMCC Intel IC Part Number Recommended Transformer Single SMT S3015, S3016, S3031B LXT6155 A7802 ST6200QNL ISDN S-Interface IC Manufacturer/ Part Number Dual SMT TX & RX Alcatel (Microelectronics) MTC2072, MTC20172 PE-65795/T5007 LP/ST5069 MTC20276/77 PE-65795/T5007 LP/ST5069 AMD AM79C30/32 PE-65799/T5006 L P Cologne Chip Design HFC-SXX PE-65795/T5007 LP/ST5069 Infineon Technologies (Siemens) PEB2080/81/84/85/86 PE-65795/T5007 LP/ST5069 PSB2115/86 PE-65795/T5007 LP/ST5069 PSB21381/82/83/84 PE-65793/T5008 LP/ST5048 PEB3018/86,PSB3186 PE-65793/T5008 LP/ST5048 PEB8090/91, PEB8190/91 — Intel 29C53 PE-65795/T5010 LP/ST5069 Lucent Technologies T7234, T7254 PE-65798/T5005 LP T7250/56/59 PE-65798/T5005 LP T7901/03 PE-65795/T5007 LP/ST5069 Mitel MT8930/31 PE-65795/T5007 LP/ST5069 Motorola MC145474/475 PE-65793/T5008 LP/ST5048 MC145574 PE-65798/T5005 LP National Semiconductor TP3420/21 PE-65795/T5007 LP/ST5069 SGS Thomson ST5420/21 PE-65795/T5007 LP/ST5069 Yamaha 7405B, YTD421 PE-65795/T5007 LP/ST5069 NOTE: LP = Low Profile TX & RX Dual SMT Module 1.5kVRMS TX & RX THT Module w/ Choke 1.5kVRMS TX & RX Single THT 3kVRMS TX & RX Dual SMT 3kVRMS TX & RX TX & RX PE-64995 PE-64995 PE-65495 PE-65495 T5034/T5038/ST5201 T5034/T5038/ST5201 T5015/T5012 T5015/T5012 PE-68995/T5035 PE-68995/T5035 T5042 T5042 T5003 T5003 PE-64999 PE-65499 T5034/T5038/ST5201 T5015/T5012 PE-68995/T5035 T5042 T5003 PE-64995 PE-65495 T5034/T5038/ST5201 T5015/T5012 PE-68999/T5035 T5042 T5003 PE-64995 PE-64995 PE-64993 PE-64993 — PE-65495 PE-65495 PE-65493 PE-65493 — T5034/T5038/ST5201 T5034/T5038/ST5201 T5049 T5049 T5034/T5038/ST5201 T5015/T5012 T5015/T5012 T5011 T5011 T5015/T5012 PE-68995/T5035 PE-68995/T5035 PE-68993 PE-68993 PE-68995/T5035 T5042 T5042 — — T5042 T5003 T5003 T5002 T5002 — PE-64995 PE-65495 T5034/T5038/ST5201 T5015/T5012 PE-68995/T5035 T5042 T5003 PE-64998 PE-64998 PE-64995 PE-65498 PE-65498 PE-65495 T5037/T5039 T5037/T5039 T5034/T5038/ST5201 T5013 T5013 T5015/T5012 PE-68998 PE-68998 PE-68995/T5035 T5043 T5043 T5042 T5004 T5004 T5003 PE-64995 PE-65495 T5034/T5038/ST5201 T5015/T5012 PE-68995/T5035 T5042 T5003 PE-64993 PE-64998 PE-65493 PE-65498 T5049 T5037/T5039 T5011 T5013 PE-68993 PE-68998 — T5043 T5002 T5004 PE-64995 PE-65495 T5034/T5038/ST5201 T5015/T5012 PE-68995/T5035 T5042 T5003 PE-64995 PE-65495 T5034/T5038/ST5201 T5015/T5012 PE-68995/T5035 T5042 T5003 PE-64995 PE-65495 T5034/T5038/ST5201 T5015/T5012 PE-68995/T5035 T5042 T5003 Single THT Dual THT TX & RX *L/W/H is measured on surface mount parts tip to tip (height includes wash area). 18 www.pulseeng.com SMT - Surface Mount Package PCMCIA THT - Through Hole Package G003.U (2/07) Telecom IC Cross Reference TELECOM IC CROSS REFERENCE IC CROSS REFERENCE T3/DS3/E3/STS-1 IC Manufacturer/ IC Part Number Exar XRT75xxx XRT73L00/2/3/4/6/12 XRT73LC03A/04A,R12 XRT7300/7302 Infineon Technologies PEB3452/3460 Maxim (Dallas Semi) DS3181/2/3/4 DS3150/1/2/3/4 Mindspeed CN28333/332/331 M28335/M28356 M28354/3/2 TDK Semiconductor 78P2342/43/44 78P2241B 78P7200/7200L 78P7203L/7204L 78P2362/2361 Transwitch MRT TXC-02050 ART TXC-02020 ARTE TXC-02021 DART TXC-2030, DS3 DART TXC-2030, E3 DS3LIM-SN, TXC20153G E3LIM TXC-20163 Octal Xfmrs TX & RX 6 Xfmrs Ext. Temp. TX & RX TX3051 TX3051 TX3051 TX3051 T3048 T3048 T3048 T3048 TX3036 TX3036 TX3036 TX3036 TX3025 TX3025 TX3025 TX3025 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 T3001 T3001 T3001 T3001 T3001 T3001 T3001 T3001 — — — — — — T3027 T3011/01 TX3052 TX3052 T3049 T3049 — — — — PE-65968 PE-65968 PE-65968 PE-65968 T3002 T3002 T3002 T3002 PE-65969 PE-65969 PE-68630 PE-68630 PE-65969 PE-65969 PE-68630 PE-68630 TX3051 TX3051 TX3051 T3048 T3048 T3048 TX3036 TX3036 TX3036 TX3025 TX3025 TX3025 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 T3001 T3001 T3001 T3001 T3001 T3001 PE-65966 PE-65966 PE-68629 PE-68629 PE-65966 PE-65966 PE-68629 PE-68629 PE-65966 PE-65966 PE-68629 PE-68629 TX3051/TX3052 TX3051/TX3052 TX3051/TX3052 TX3051/TX3052 TX3051/TX3052 TX3045 TX3045 TX3045 TX3045 TX3045 T3020 or TX3026 T3020 or TX3026 T3020 or TX3026 T3020 or TX3026 T3020 or TX3026 PE-65968 PE-65968 PE-65968 PE-65968 PE-65968 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 T3002 T3002 T3002 T3002 T3002 T3001 T3001 T3001 T3001 T3001 PE-65969 PE-65969 PE-65969 PE-65969 PE-65969 PE-65966 PE-65966 PE-65966 PE-65966 PE-65966 PE-68630 PE-68630 PE-68630 PE-68630 PE-68630 PE-68629 PE-68629 PE-68629 PE-68629 PE-68629 — — — — — T3020 or TX3026 TX3025 TX3025 TX3025 T3020 or TX3026 TX3025 T3020 or TX3026 PE-65968 PE-65967 PE-65967 PE-65967 PE-65968 PE-65967 PE-65968 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 PE-65967 T3002 T3001 T3001 T3001 T3002 T3001 T3002 T3001 T3001 T3001 T3001 T3001 T3001 T3001 PE-65969 PE-65966 PE-65966 PE-65966 PE-65969 PE-65966 PE-65969 PE-65966 PE-65966 PE-65966 PE-65966 PE-65966 PE-65966 PE-65966 PE-68630 PE-68629 PE-68629 PE-68629 PE-68630 PE-68629 PE-68630 PE-68629 PE-68629 PE-68629 PE-68629 PE-68629 PE-68629 PE-68629 TX3051/TX3052 TX3045 TX3051 T3048 TX3051 T3048 TX3051 T3048 TX3051/TX3052 T3049/T3048 TX3051 T3048 TX3051/TX3052 T3049/T3048 — — — — — — — Dual SMT Ext. Temp. TX & RX Single SMT Standard Temp. Extended Temp. TX RX TX RX 12 Xfmrs Ext. Temp. TX & RX *L/W/H is measured on surface mount parts tip to tip (height includes wash area). G003.U (2/07) www.pulseeng.com Single THT Single THT 3 kVRMS TX RX TX RX PE-65966 PE-65966 PE-65966 PE-65966 PE-65966 PE-65966 PE-65966 PE-65966 PE-68629 PE-68629 PE-68629 PE-68629 PE-68629 PE-68629 PE-68629 PE-68629 — — — — SMT - Surface Mount Package THT - Through Hole Package 19 Telecom IC Cross Reference TELECOM IC CROSS REFERENCE IC CROSS REFERENCE: T1/E1/CEPT/ISDN-Pri FOR SINGLE & MULTIPORT PORT ICs IC MFR. Cirrus Logic (Crystal) Exar IDT Infineon Technologies (Siemens) Intel Agere (Lucent) Maxim (Dallas) Mindspeed PMC-Sierra Zarlink (Mitel) IC PART NO. / COMMENT 61577 T1 & E1 61304A/5A/535A/574A,/75 T1 61304A/5A/535A/574A,/75 75 E1 61304A/5A/535A/574A,/75 120 E1 61884 T1/E1/J1 61582, 61583 61310, 61581 61310, 61581 Host 61880, 61881 61584/84A IQ3 61584/82/83/A IQ5 XRT5683A, XRT59L91 XRT5894/5897/5997 XRTT5793/94 XRT81L27,82L24,82D20 XRT83L30/4/8/314,86L38 XRT83SL30/4/8/314 XRT86L30/32/34/38 T5684,XRT7288,82D20 82V2048, 82V2058 82V2044/48/48L/54/58 82V2041E/2E/4E/8E 82V2081/2/4/8 82P2281/2/4/8 PEB 2254/55 E1/T1 & J1 PEB 2254/55 E1/T1 & J1 PEB 22504, 22554, 2256 3.3V PEB22554 75 E1 LXT 300/301 LXT 304/305/307 T1,E1 LXT 304/305/307 T1 LXT 304/305/307 75E1,120E1 LX T 304/305/307 DSX-1, D4 LXT 310/317/318 LXT 312/ 313/ 315 LXT 331 T1,E1 LXT 331, LXT 332 LXT 331, LXT 332 LXT 331, LXT 332 LXT 334, LXT 335 T1/E1 LXT 334, LXT 335 120/75 E1 LXT 334, LXT 335 75 E1 LXT 334, LXT 335 LXT 336 LXT 350, LXT 351, LXT 359 T1,E1 LXT 350, LXT 351 LXT 350, LXT 351 120 E1 LXT 360/361/362/363 T1,E1 LXT 360/361/362/363 LXT 360, LXT361 120 E1 LXT 380/381/384/386/388 T1/E1 LXT 380/381/384/386/388 T1/E1 LXT 3104, LXT 3108 LXT 3104, LXT 3108 T7288, T290A CEPT T7289A DS1 T7630,T7688, T7690, T7698 CEPT T7630,T7689, T7690, T7698 DS1 T7693,T7697 CEPT TLIU04C1 DS1 TLIU04C1 CEPT DS2196,2155,2149,21448 DS2151/2152/2153/2154 DS2151/2152/2153/2154 DS2148/Q48/Q348/349/Q59 3V DS2148/Q48 5V DS21352/Q352, DS21354/Q354 DS21552/Q552, DS21554/Q554 DS21552/Q552, DS21554/Q554 DS26502/3 DS21455/8 DS26528 BT8510 T1/E1 BT8510 T1/E1 CN8380/28380 BT8370/5/6 Better Rl BT8370/5/6 Low Power PM4341/6341/4314 PM4318/4319 PM4323/4325 PM4329 PM4351/4354 COMET MT9071, MT9076 MT9076, MT9075 MT9074, MT9075 DUAL SMT (BH) STD TEMP EXT TEMP DUAL SMT (AN) STD TEMP EXT TEMP DUAL SMT XFMR/CHOKE EXT TEMP SINGLE THT STANDARD TEMP TX & RX TX & RX TX & RX TX & RX TX & RX TX RX PE-65861 PE-65865 PE-65866 PE-65866 PE-65861 PE-65870 PE-68678 T1022 PE-65865 PE-65861 PE-65870 PE-65861 PE-65861 PE-65866 PE-65861 PE-68678 PE-68678 PE-68678 PE-65862 TX1188 TX1188 PE-68678 PE-68678 PE-68678 PE-68786 T1023 T1144 T1146 PE-65861 PE-65861 PE-65865 PE-65866 T1122 PE-68678 — PE-68678 PE-65861 T1122 PE-65865 PE-65861 PE-65862 PE-65866 T1022 PE-65861 PE-68678 PE-65865 T1122 PE-68678 PE-65865 T1122 PE-68678 PE-65861 PE-65861 TX1099 PE-65862 PE-65865 — PE-65870 T1137 PE-65870 — PE-68678 PE-65865 T1136 PE-68678 T1136 PE-68678 PE-65865 T1136 PE-68678 PE-68678 PE-68678 PE-65866 T1021 — T1190 PE-65865 PE-65862 PE-65861 PE-65861 — T1137 T1137 T1144 PE-68678 T1090 T1076 T1092 T1092 TX1188 T1093 T1094 T1077 T1076 T1090 T1093 T1090 T1090 T1092 T1090 T1094 T1094 T1094 T1091 TX1188 TX1188 T1094 T1094 T1094 T1095 T1096 T1144 T1146 T1090 T1090 T1076 T1092 PE-68861 PE-68865 PE-65866 PE-65866 PE-68861 PE-68874 PE-68877 T1022 PE-68865 PE-68861 PE-68874 PE-68861 PE-65861 PE-68866 PE-68861 PE-68877 PE-68877 PE-68877 PE-68862 PE-68861 PE-68861 PE-68877 PE-68877 PE-68877 PE-68887 PE-68887 — — PE-68861 PE-68861 PE-68865 PE-68866 PE-68881 PE-68877 — PE-68877 PE-68861 — PE-68865 PE-68861 PE-68862 PE-68866 — PE-68828 PE-68877 PE-68865 — PE-68877 PE-68865 — PE-68877 PE-68861 PE-68861 — PE-68862 PE-68865 PE-68884 PE-68874 — PE-68874 PE-68884 TX1277 PE-68865 PE-68862 TX1277 PE-68862 TX1277 PE-68865 PE-68862 TX1277 TX1277 TX1277 PE-68866 T1021 — PE-68862 — PE-68862 PE-68861 PE-68861 — — — — PE-68877 PE-68841 PE-68825 PE-68826 PE-68826 PE-68841 PE-68874 PE-68877 — PE-68825 PE-68841 PE-68874 PE-68841 PE-68841 PE-68826 PE-68841 PE-68877 PE-68877 PE-68877 PE-68822 PE-68841 PE-68841 PE-68877 PE-68877 PE-68877 PE-68887 PE-68887 — — PE-68841 PE-68841 PE-68825 PE-68826 PE-68881 PE-68877 — PE-68877 PE-68841 PE-68881 PE-68825 PE-68841 PE-68822 PE-68826 — PE-68828 PE-68877 PE-68825 PE-68881 PE-68877 PE-68825 PE-68881 PE-68877 PE-68841 PE-68841 — PE-68822 PE-68825 PE-68884 PE-68874 — PE-68874 PE-68884 TX1277 PE-68825 PE-68822 TX1277 PE-68822 TX1277 PE-68825 PE-68822 TX1277 TX1277 TX1277 PE-68826 PE-68826 — PE-68822 PE-68825 PE-68822 PE-68841 PE-68841 — — — — PE-68877 T1207 T1209 T1212 T1210 T1207 T1211 T1212 — T1209 T1207 T1211 T1207 T1207 T1220 T1207 T1212 T1212 T1212 T1208 T1207 T1207 T1212 T1212 T1212 T1215 T1215 T1219 — T1207 T1207 T1209 T1212 T1216 T1212 — T1212 T1207 T1216 T1209 T1207 T1218 — — T1220 T1212 T1209 T1216 T1212 T1209 T1216 T1212 — T1220 — T1208 T1209 T1214 T1211 T1217 T1211 T1214 T1212 T1213 T1218 T1212 T1218 T1212 T1213 T1218 T1212 T1212 T1212 T1212/T1210 T1212/T1210 — T1218 T1213 T1208 T1207 T1207 — T1217 T1217 T1219 T1212 PE-65351 PE-65388 PE-65389 PE-65389 PE-65351 PE-65388 PE-65351 PE-65351 PE-65388 PE-65351 PE-65388 PE-65415 PE-65415 PE-65389 PE-65415 PE-65415 PE-65415 PE-65415 PE-64937 PE-65415 PE-65415 PE-65415 PE-65415 PE-65415 — — — — PE-65351 PE-65351 PE-65388 PE-65389 PE-65558 PE-65351 PE-64933 PE-65351 PE-65351 PE-65558 PE-65388 PE-65351 PE-65586 PE-65389 T1054 — PE-65351 PE-65388 PE-65558 PE-65351 PE-65388 PE-65558 PE-65351 PE-65351 PE-64936 — PE-65586 PE-65379 PE-65586 PE-65379 — PE-65379 PE-65586 PE-65351 PE-65388 PE-65586 PE-65351 PE-65586 PE-65351 PE-65388 PE-65586 PE-65351 PE-65351 PE-65351 PE-65389 PE-65389 — PE-64937 PE-65388 PE-64937 PE-65351 PE-65351 — — — — PE-65351 PE-65351 PE-65351 PE-65351 PE-65351 PE-65351 PE-65388 PE-64936 PE-65351 PE-65351 PE-65351 PE-65388 PE-65415 PE-65415 PE-64934 PE-65415 PE-64934 PE-64934 PE-64934 PE-65351 PE-65415 PE-65415 PE-64934 PE-64934 PE-64934 — — — — PE-65351 PE-65351 PE-65351 PE-65351 PE-65351 PE-64936 PE-64936 PE-64936 PE-65351 PE-65351 PE-65351 PE-65351 PE-65351 PE-65351 PE-64936 PE-65351 PE-64936 PE-65351 PE-65351 PE-64936 PE-65351 PE-65351 PE-64936 PE-65351 PE-64936 — PE-65415 PE-65351 PE-65586 PE-65379 — PE-65379 PE-65586 PE-64936 PE-64936 PE-64936 PE-64936 PE-64936 PE-64936 PE-64936 PE-64936 PE-64936 PE-64936 PE-64936 PE-65351 PE-65351 — PE-64936 PE-64936 PE-65351 PE-65351 PE-65351 — — — — PE-64934 T1094 — T1094 T1090 — T1076 T1090 T1091 T1092 T1077 T1090 T1094 T1076 — T1094 T1076 — T1094 T1090 T1090 TX1099 T1091 T1076 — T1093 TX1287 T1093 — T1094 T1076 T1091 T1094 T1091 T1094 T1076 T1091 T1094 T1094 T1094 T1092 T1092 — T1091 T1076 T1091 T1090 T1090 — TX1287 TX1287 T1144 T1094 Read across ➙ 20 www.pulseeng.com G003.U (2/07) Telecom IC Cross Reference TELECOM IC CROSS REFERENCE IC CROSS REFERENCE: T1/E1/CEPT/ISDN-Pri FOR SINGLE & MULTIPORT PORT ICs SINGLE THT EXTENDED TEMP DUAL THT STD TEMP EXT TEMP REINFORCED 3 kVRMS STANDARD TEMP DUAL SMT QUAD SMT STANDARD TEMP OCTAL SMT STD TEMP PROTECTION MODULES EXT TEMP STD TEMP EXT TEMP TX RX TX RX TX RX TX & RX TX RX TX & RX TX &RX TX & RX TX & RX PE-65771 PE-65770 PE-68664 PE-68664 PE-65771 PE-65770 PE-65771 PE-65771 PE-65770 PE-65771 PE-65770 PE-65771 PE-65771 PE-68664 PE-65771 PE-65771 PE-65771 PE-65771 PE-65340 PE-65771 PE-65771 PE-65771 PE-65771 PE-65771 — — — — PE-65771 PE-65771 PE-65770 PE-68664 — PE-65771 PE-68600 PE-65771 PE-65771 — PE-65770 PE-65771 PE-65340 PE-68664 — — PE-65771 PE-65770 — PE-65771 PE-65770 — PE-65771 PE-65771 PE-65778 — PE-65340 PE-65770 PE-65340 PE-65770 — PE-65770 PE-65340 PE-65771 PE-65770 PE-65340 PE-65771 PE-65340 PE-65771 PE-65770 PE-65340 PE-65771 PE-65771 PE-65771 PE-68664 PE-68664 — PE-65340 PE-65770 PE-65340 PE-65771 PE-65771 — — — — PE-65771 PE-65771 PE-65771 PE-65771 PE-65771 PE-65771 PE-65770 — PE-65771 PE-65771 PE-65771 PE-65770 PE-65771 PE-65771 PE-65778 PE-65771 PE-65778 PE-65778 PE-65778 PE-65771 PE-65771 PE-65771 PE-65778 PE-65778 PE-65778 — — — — PE-65771 PE-65771 PE-65771 PE-65771 — PE-65778 PE-65778 PE-65778 PE-65771 — PE-65771 PE-65771 PE-65771 PE-65771 — PE-65778 PE-65778 PE-65771 — PE-65778 PE-65771 — PE-65778 PE-65771 PE-65778 — PE-65771 PE-65771 PE-65340 PE-65770 — PE-65770 PE-65340 PE-65778 PE-65778 PE-65778 PE-65778 PE-65778 PE-65778 PE-65778 PE-65778 PE-65778 PE-65778 PE-65778 PE-65771 PE-65771 — PE-65771 PE-65771 PE-65771 PE-65771 PE-65771 — — — — PE-65778 PE-64951 PE-65565 PE-65566 PE-65566 PE-64951 — PE-64951 PE-64951 PE-65565 PE-64951 — PE-64951 PE-64951 PE-65566 PE-64951 PE-64951 PE-64951 PE-64951 PE-64952 PE-64951 PE-64951 PE-64951 PE-64951 PE-64951 — — — — PE-64951 PE-64951 PE-65565 PE-65566 — PE-64954 — PE-64954 PE-64951 — PE-65565 PE-64951 PE-64952 PE-65566 — PE-64951 PE-64954 PE-65565 — PE-64954 PE-65565 PE-65565 PE-64954 PE-64951 PE-64951 — PE-64952 PE-65565 — — — — — PE-64951 PE-65565 PE-64952 PE-64951 PE-64952 PE-64951 PE-65565 PE-64952 PE-64951 PE-64951 PE-64951 PE-65566 PE-65566 — PE-64952 PE-65565 PE-64952 PE-64951 PE-64951 — — — — PE-64954 — PE-65567 PE-65568 PE-65568 — — PE-65568 — PE-65567 — — — — PE-65568 — — — — PE-65774 — — — — — — — — — — — PE-65567 PE-65568 — — PE-64950 — — — PE-65567 — PE-65771 PE-65568 — — — PE-65567 — — PE-65567 — — — — — PE-65774 PE-65567 — — — — — PE-65568 PE-65567 PE-65774 PE-65568 PE-65774 PE-65568 PE-65567 PE-65774 PE-65568 PE-65568 PE-65568 PE-65568 PE-65568 — PE-65774 PE-65567 PE-65774 — — — — — — PE-65568 PE-65835 PE-65838 PE-65839 PE-65839 PE-65838 PE-65838 PE-65835 PE-65835 PE-65838 PE-65835 PE-65838 PE-65835 PE-65835 PE-65839 PE-65835 PE-65835 PE-65835 PE-65835 PE-65837 PE-65835 PE-65835 PE-65835 PE-65835 PE-65835 — — — — PE-65835 PE-65835 PE-65838 PE-65839 — PE-65835 PE-65836 PE-65835 PE-65835 — PE-65838 PE-65835 PE-65832 PE-65839 — — PE-65835 PE-65838 — PE-65835 PE-65838 — PE-65835 PE-65835 PE-65835 — PE-65832 PE-65838 PE-65832 PE-65838 — PE-65838 PE-65832 PE-65838 PE-65838 PE-65832 PE-65838 PE-65832 PE-65838 PE-65838 PE-65832 PE-65838 PE-65838 PE-65838 PE-65839 PE-65839 — PE-65832 PE-65838 PE-65832 PE-65835 PE-65835 — — — — PE-65835 PE-65835 PE-65835 PE-65835 PE-65835 PE-65835 PE-65838 PE-65835 PE-65835 PE-65835 PE-65835 PE-65838 PE-65835 PE-65835 PE-65834 PE-65835 PE-65834 PE-65834 PE-65834 PE-65835 PE-65835 PE-65835 PE-65834 PE-65834 PE-65834 PE-68788 PE-68788 — — PE-65835 PE-65835 PE-65835 PE-65835 — PE-65834 PE-65834 PE-65834 PE-65835 — PE-65835 PE-65835 PE-65835 PE-65835 — PE-65835 PE-65834 PE-65835 — PE-65834 PE-65835 — PE-65834 PE-65835 PE-65835 — PE-65835 PE-65835 PE-65832 PE-65838 — PE-65838 PE-65832 PE-65838 PE-65834 PE-65834 PE-65838 PE-65834 PE-65838 PE-65834 PE-65834 PE-65838 PE-65838 PE-65838 PE-65835 PE-65835 — PE-65834 PE-65834 PE-65835 PE-65835 PE-65835 — — — — PE-65834 T1045 T1034 T1049 T1049 T1045 T1033 T1031 T1081 T1034 T1045 T1033 T1045 T1045 T1049 T1045 T1031 T1031 T1031 T1044 T1045 T1045 T1031 T1031 T1031 PE-68788 PE-68788 — — T1045 T1045 T1034 T1049 T1047 T1031 — T1031 T1045 T1047 T1034 T1045 T1035 T1049 — T1030 T1031 T1034 T1047 T1031 T1034 T1047 T1031 T1045 T1030 — T1044 T1034 T1036 T1033 — T1033 T1036 T1031 T1032 T1038 T1031 T1038 T1031 T1032 T1038 T1031 T1031 T1031 T1049 T1049 — T1038 T1032 T1044 T1045 T1045 — T1082 — — T1031 T1006 T1007 T1009 T1009 T1006 T1007 T1006 — T1007 T1006 T1007 T1006 T1006 T1009 T1006 T1006 T1006 T1006 T1008 T1006 T1006 T1006 T1006 T1006 T1037 T1080 — — T1006 T1006 T1016 T1009 T1017 T1006 — T1006 T1006 T1017 T1016 T1006 T1001 T1009 — — T1006 T1016 T1017 T1006 T1016 T1017 T1006 T1006 T1006 — T1008 T1007 T1010 T1007 — T1007 T1010 T1006 T1007 T1001 T1006 T1001 T1006 T1007 T1001 T1006 T1006 T1006 T1009 T1009 T1006 T1006 T1006 T1008 T1006 T1006 — — — — — T1006 T1006 T1006 T1006 T1006 T1007 T1006 — T1006 T1006 T1007 T1006 T1006 T1009 T1006 T1006 T1006 T1006 T1008 T1006 T1006 T1006 T1006 T1006 — — — — T1006 T1006 T1016 T1009 T1017 T1006 — T1006 T1006 T1017 T1016 T1006 T1001 T1009 — T1006 T1006 T1016 T1017 T1006 T1016 T1017 T1006 T1006 T1006 — T1008 T1006 T1010 T1007 — T1007 T1010 T1006 T1006 T1001 T1006 T1001 T1006 T1006 T1001 T1006 T1006 T1006 T1006 T1006 T1006 T1001 T1007 T1008 T1006 T1006 — — — — — T1065 T1070 T1068 T1071 T1073 T1064 T1068 — T1070 T1065 T1064 T1065 T1065 T1071 T1065 T1068 T1068 T1068 T1067 T1124 T1124 T1068 T1068 T1068 T1069 T1069 T1142 — T1065 T1065 T1070 T1071 — T1068 — T1068 T1065 — T1070 T1065 T1067 T1071 — T1065 T1068 T1070 — T1068 T1070 — T1068 T1124 T1068 — T1067 T1070 T1063 T1064 — T1064 T1063 T1068 T1070 TX1292 T1068 TX1292 T1068 T1070 TX1292 T1068 T1068 T1068 T1071 T1071 T1124 T1067 T1070 T1067 T1073 T1073 — T1180 T1180 T1142 T1068 T1105 T1110 T1108 T1111 T1113 T1104 T1108 — T1110 T1105 T1104 T1105 T1105 T1111 T1105 T1108 T1108 T1108 T1107 T1114 T1114 T1108 T1108 T1108 T1109 T1109 T1231 — T1105 T1105 T1110 T1111 — T1108 — T1108 T1105 — T1110 T1105 T1107 T1111 — T1105 T1108 T1110 — T1108 T1110 — T1108 T1114 T1108 — T1107 T1110 T1103 T1104 T1180 T1104 T1103 T1108 T1110 TX1292 T1108 TX1292 T1108 T1110 TX1292 T1108 T1108 T1108 T1111 T1111 T1114 T1107 T1110 T1107 T1113 T1113 — TX1299 — T1231 T1108 — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — — T9030 T9030 — — — — — — — — — — — — — — — — — — — — — — — — — — — — — T9021 — — — — — — — — — — — — — — — — — — — — — — — — — — — — — TX9031 — — — — — — — — — — — — — — — — — — — — — — — T9030 T9030 — — — — — — — — — — — — — — — — — — — — — — — — — — TX9023 TX9023 TX9027 TX9020 — — — ➙ Continued G003.U (2/07) www.pulseeng.com 21
T1073 价格&库存
很抱歉,暂时无法提供与“T1073”相匹配的价格&库存,您可以联系我们找货
