64 KBPS INTERFACE
TRANSFORMERS
Designed for G.703 Codirectional Interface
Single and dual transformer modules for
ITU G.703 codirectional applications
Transformers matched to the integrated circuit
Provide 1500 Vrms minimum isolation
Electrical Specifications @ 25°C — Operating Temperature 0°C to 70°C
Part Number
Turns
Ratio
(± 3%)
OCL
(mH MIN)
LL
(µH MAX)
CW/W
(pF MAX)
DCR
pri
(Ω MAX)
DCR
sec
(Ω MAX)
Package/
Schematic
Matched
To
PE-65535
1:2CT
20.0
5.0
130
2.65
5.0
IS/5
EXAR XR6164
XR-T6165, XR-T6166
PE-65540
1CT:1
10.0
5.0
100
2.60
2.6
IS/6
1:2CT & 1:2CT
20.0
5.0
130
2.80
5.6
AN/1
T7015
Mechanicals
IS
AN
.558 MAX
14,20
1
6
2 PE-655XX
5
.558
14,20
MAX
1
CL
Pri
3
6
1
5
2
4
3
Pri
Sec
.400
10,16
.500
12,70
6
.100
TYP
2,54
SUGGESTED PAD LAYOUT
.340
MAX
8,64
1
9
8
7
6
4
1
The CCITT recommendations G.703 describe the physical and
electrical characteristics of digital interfaces at 64 Kbps.
PE-65535 listed above has been designed for the codirectional
interface and matches the driver/receiver chips from EXAR
3
4
0°-8°
.010 / .020
0,25 / 0,51
.004/0,10 MAX
IS-6
Sec
.640
16,26
.100
2,54
12 11 10
IS-5
1
DATE CODE
.085
2,16
Note: Unused pins not provided.
.400 Leads are 22 AWG solderable.
10,20
MAX
Weight . . . . . . . . . .4 grams
Tube . . . . . . . . . . . . .35/tube
Dimensions: Inches
mm
.130
Unless otherwise specified,
3,30
all tolerances are ± .010
0,25
.456
MAX
11,58
T7015
.050
TYP
1,27
.030
0,76
7
.600
MAX
15,24
3 DATE CODE 4
Schematics
12X
12
.200
5,08
.400
10,20
.120
3,05
.675
MAX
17,15
.400
10,20
6
.040 / .050
1,02 / 1,27
Weight . . . . . . . . .4.0 grams
Tape & Reel . . . . . .250/reel
Tube . . . . . . . . . . . .30/tube
Dimensions: Inches
mm
0,25
(XR6164, XR-T6165, and XR-T6166). The characteristics of
these transformers allow the pulse to comply with the pulse
masks in the 120 Ω system.
For More Information :
UNITED STATES
(Worldwide)
UNITED KINGDOM
(Northern Europe)
FRANCE
(Southern Europe)
SINGAPORE
(Southern Asia)
TAIWAN, R.O.C.
(Northern Asia)
HONG KONG
(China/Hong Kong)
12220 World Trade Drive
San Diego, CA 92128
U.S.A.
http://www.pulseeng.com
TEL: 858 674 8100
FAX: 858 674 8262
1 & 2 Huxley Road
The Surrey Research Park
Guildford, Surrey GU2 5RE
United Kingdom
TEL: 44 1483 401700
FAX: 44 1483 401701
Zone Industrielle
F-39270
Orgelet
France
TEL: 33 3 84 35 04 04
FAX: 33 3 84 25 46 41
150 Kampong Ampat
#07-01/02
KA Centre
Singapore 368324
TEL: 65 6287 8998
FAX: 65 6280 0080
3F-4, No. 81, Sec. 1
HsinTai Wu Road
Hsi-Chih, Taipei Hsien
Taiwan, R.O.C.
Tel: 886 2 2698 0228
FAX: 886 2 2698 0948
9/F, Phase 2, Tai Sang
Shatin Warehouse Centre
6 Wong Chuk Yeung Street
Fotan, Shatin, Hong Kong
TEL: 852 2788 6588
FAX: 852 2776 1055
DISTRIBUTOR
Performance warranty of products offered on this data sheet is limited to the parameters specified. Data is subject to change without notice. Other brand and product
names mentioned herein may be trademarks or registered trademarks of their respective owners.
Printed on recycled paper. ©2003, Pulse Engineering, Inc.
T611.C (1/03)
很抱歉,暂时无法提供与“T7015”相匹配的价格&库存,您可以联系我们找货
