NPR NPS 2-T220 T221 NHR NHS 2-T220 T221
Power Resistors • • • • • • • Resistances from 0.02Ohm to 100kOhms Power Rating to 50Watt Resistance Tolerances to ±1% TCR to ±50ppm/K Load Stability to 0.5% TO-220 Housing Convenient SMD D2Pak Available
SPECIFICATIONS
Type
Resistance Range Power rating free air 70°C with heatsink Thermal Resistance Rthj-c Tolerances from 0.02 Ohms from 1.0 Ohms Stability Temperature Coefficient 0.02 to 0.049 Ohms 0.05 to 0.099 Ohms 0.1 Ohms to 100 kOhms Voltage Proof Max. Voltage depending on resistance value 2.0 kVDC 2% / 5% 1% / 2% / 5% 0.5% ±600 ppm/K ±300 ppm/K ±100 ppm/K upon request ±50 ppm/K 1.5 kVDC
NPR / NPS
0.02 Ohms to 100kOhms 1.5 W 30 W 3.5 K/W
NHR / NHS
0.02 Ohms to 15kOhms 1.5 W 50 W 2.1 K/W
10000
max. working voltage (VDC)
1000
100
10
1 2 Ohm
Operating Temperature Range Resistor Material Substrate Housing Connector Material Terminals Max. Torque
10 Ohm
100 Ohm
1 kOhm
5 kOhm
10 kOhm 100 kOhm
-40 to 155°C Thick Film Al2O3 Epoxy or PPS Cu tinned 2 T220: 1 Nm T221: 0.8 Nm
Ordering Information
Part Number - Resistance - Contact - Tolerance NHR 2-T221 C 1.1 kOhms 1%
Riedon Inc. 300 Cypress Avenue Alhambra CA 91801 www.riedon.com (626) 284-9901 (626) 284-1704 Page 80
rev. 03/2006A
Power Resistors SPECIFICATIONS (continued) Temperature Coefficient
100ppm/K
7000
∆R/R (ppm)
50ppm/K
2000 -3000 -8000 -50
-25
Temperature (°C)
25
50
75
100
125
120
Derating
Power Rating Notes -
Power ( % from nominal power)
100 80 60 40 20 0 25 50 85 100 115 130 145 155 Temperature of the backplate (°C)
The NPR / NHR Series Resistors must be attached to a suitable heatsink. The maximum internal resistor temperature is 155°C. To specify an appropriate heatsink use the following formula :
RqH = TMAX - ( P x RqR ) - TA P
Where: RqH = Thermal Resistance of Heatsink ( K/W ) RqR = Thermal Resistance of Resistor ( K/W ) TMAX = Maximum Temperature of Resistor TA = Ambient Temperature of Heatsink ( °C ) P = Power Through Resistor ( W )
Dimensions
NPS / NHS 2-T220
Dimension A B C D E F G H I J K
mm 12.70 10.16 0.76 5.08 4.00 1.20 14.60 15.00 17.33 0.40 1.85
tol. (±mm) 0.2 0.2 0.1 0.1 0.1 0.1 0.2 0.2 0.2 0.1 0.1
inches 0.50 0.40 0.03 0.20 0.16 0.05 0.57 0.59 0.68 0.02 0.07
tol. (±inches) 0.008 0.008 0.004 0.004 0.004 0.004 0.008 0.008 0.008 0.004 0.004 Dimension A B C D E F mm 12.10 11.16 18.33 5.08 1.76 3.20 inches 0.476 0.439 0.722 0.200 0.069 0.126
Riedon Inc.
300 Cypress Avenue
(626) 284-9901
(626) 284-1704 Page 81
rev. 03/2006A
NPR / NHR 2-T220
Dimension A B C D E F G H I J K L M N O
mm 17.30 10.16 6.00 Ø3.7 16.40 5.08 0.76 1.30 13.80 2.00 1.20 4.00 2.90 0.40 1.85
tol. (±mm) 0.2 0.2 0.1 0.1 0.2 0.1 0.1 0.1 0.2 0.1 0.1 0.1 0.1 0.1 0.1
inches 0.68 0.40 0.24 Ø0.146 0.65 0.20 0.03 0.05 0.54 0.08 0.05 0.16 0.11 0.02 0.07
tol. (±inches) 0.008 0.008 0.004 0.004 0.008 0.004 0.004 0.004 0.008 0.004 0.004 0.004 0.004 0.004 0.004
NPR / NHR 2-T221
tol. (±mm) 0.2 0.2 0.1 0.1 0.2 0.1 0.1 0.1 0.2 0.1 0.1 0.1 0.1 0.1 0.1 tol. (±inches) 0.008 0.008 0.004 0.004 0.008 0.004 0.004 0.004 0.008 0.004 0.004 0.004 0.004 0.004 0.004
mm 18.30 10.16 3.70 Ø3.2 16.40 5.08 0.76 1.30 13.80 2.00 1.20 4.00 3.90 0.40 1.85
inches 0.72 0.40 0.15 Ø0.126 0.65 0.20 0.03 0.05 0.54 0.08 0.05 0.16 0.15 0.02 0.07
Riedon Inc.
300 Cypress Avenue
(626) 284-9901
(626) 284-1704 Page 82
rev. 03/2006A
很抱歉,暂时无法提供与“NHR2-T220”相匹配的价格&库存,您可以联系我们找货
