BD2041AFJ-E2
BD2041AFJ-E2
    ROHM(罗姆)
    SOIC8
    IC PWR SWITCH N-CHAN 1:1 SOP-J8
BD2041AFJ-E2 数据手册
Datasheet 1ch High Side Switch ICs 1.0A Current Limit High Side Switch ICs BD2041AFJ BD2051AFJ General Description BD2041AFJ and BD2051AFJ are single channel high side switch ICs with over-current protection for Universal Serial Bus (USB) power supply line. These ICs have low ON-Resistance N-Channel power MOSFETs with low supply current, built-in over-current protection circuit, thermal shutdown circuit, under voltage lockout and soft-start circuit. Key Specifications        Input Voltage Range: 2.7V to 5.5V ON-Resistance: 80mΩ(Typ) Continuous Current Load: 0.5A Over-Current Threshold: 0.7A (Min), 1.6A (Max) Standby Current: 0.01μA (Typ) Output Rise Time: 1.2ms(Typ) Operating Temperature Range: -40°C to +85°C W(Typ) Package Features  Built-In Low ON-Resistance Nch MOSFET ( Typ=80mΩ )  Control Input Logic  Active-Low: BD2041AFJ  Active-High: BD2051AFJ  Soft-Start Circuit  Over-Current Protection  Thermal Shutdown  Under Voltage Lockout Function  Open Drain Error Flag Output  Reverse-Current Protection when Switch Off  Flag Output Delay D(Typ) H (Max) SOP-J8 4.90mm x 6.00mm x 1.65mm Applications USB Hub in Consumer Appliances, PC, PC Peripheral Equipment, and so forth Typical Application Circuit 5V(Typ) C IN GND OUT IN OUT IN OUT VBUS D+ + CL - DGND EN( /EN ) /OC Lineup Min 0.7A 0.7A Over-Current Threshold Typ Max 1.0A 1.6A 1.0A 1.6A Control Input Logic Low SOP-J8 Reel of 2500 BD2041AFJ-E2 High SOP-J8 Reel of 2500 BD2051AFJ-E2 Package Orderable Part Number ○Product structure:Silicon monolithic integrated circuit ○This product has not designed protection against radioactive rays www.rohm.com TSZ02201-0E3E0H300290-1-2 © 2013 ROHM Co., Ltd. All rights reserved. 1/22 TSZ22111・14・001 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Block Diagram GND OUT IN UVLO IN EN(/EN) Charge pump OUT OCD Gate logic OUT TSD /OC Pin Configurations BD2051AFJ TOP VIEW BD2041AFJ TOP VIEW 1 GND OUT 8 1 GND OUT 8 2 IN OUT 7 2 IN OUT 7 3 IN OUT 6 3 IN OUT 6 4 /EN /OC 5 4 EN /OC 5 Pin Description Pin No. Symbol I/O 1 GND I 2, 3 IN I 4 EN, /EN I 5 /OC O 6, 7, 8 OUT O Pin Function Ground. Power supply input. Input terminal to the power switch and power supply input terminal of the internal circuit. When used, connect each pin outside. Enable input. /EN: Power switch on at low level. (BD2041AFJ) EN: Power switch on at high level. (BD2051AFJ) High level input > 2.0V, low level input < 0.8V. Error flag output. Low at over current, thermal shutdown. Open drain output. Power switch output. When used, connect each pin outside. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 2/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Absolute Maximum Ratings Parameter Symbol Rating Unit Supply Voltage V IN -0.3 to +6.0 V Enable Voltage V EN , V /EN -0.3 to +6.0 V V /OC -0.3 to +6.0 V /OC Voltage /OC Current I /OC 10 mA OUT Voltage V OUT -0.3 to +6.0 V Storage Temperature Tstg -55 to +150 °C Power Dissipation Pd 0.67 (Note 1) W (Note 1) Derating in done 5.4 mW/°C for operating above Ta≧25°C (Mount on 1-layer 70.0mm x 70.0mm x 1.6mm board) Caution: Operating the IC over the absolute maximum ratings may damage the IC. The damage can either be a short circuit between pins or an open circuit between pins and the internal circuitry. Therefore, it is important to consider circuit protection measures, such as adding a fuse, in case the IC is operated over the absolute maximum ratings. Recommended Operating Conditions Parameter Symbol Rating Min Typ Max Unit Operating Voltage V IN 2.7 - 5.5 V Operating Temperature Topr -40 - +85 °C I LO 0 - 500 mA Continuous Output Current Electrical Characteristics BD2041AFJ (Unless otherwise specified, V IN = 5.0V, Ta = 25°C) Limit Parameter Symbol Min Typ Operating Current Standby Current /EN Input Voltage I DD Max Unit Conditions - 90 120 μA I STB - 0.01 1 μA V /EN = 5V, OUT = OPEN V /ENH 2.0 - - V High Input V /ENL V /EN = 0V, OUT = OPEN - - 0.8 V Low Input - - 0.4 V Low Input 2.7V≤ V IN ≤4.5V +0.01 +1.0 μA V /EN = 0V or V /EN = 5V /EN Input Current I /EN -1.0 /OC Output Low Voltage V /OC - - 0.5 V I /OC = 5mA /OC Output Leak Current I L/OC - 0.01 1 μA V /OC = 5V /OC Delay Time t /OC - 2.5 8 ms ON-Resistance R ON - 80 100 mΩ Over-Current Threshold I TH 0.7 1.0 1.6 A Output Current at Short I SC 0.7 1.0 1.3 A Output Rise Time t ON1 - 1.2 10 ms Output Turn ON Time t ON2 - 1.5 20 ms Output Fall Time t OFF1 - 1 20 μs Output Turn OFF Time UVLO Threshold www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 I OUT = 500mA V IN = 5V, V OUT = 0V, C L = 100μF (RMS) R L = 10Ω, C L = OPEN t OFF2 - 3 40 μs V TUVH 2.1 2.3 2.5 V Increasing V IN V TUVL 2.0 2.2 2.4 V Decreasing V IN 3/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Electrical Characteristics - continued BD2051AFJ (Unless otherwise specified, V IN = 5.0V, Ta = 25°C) Limit Parameter Symbol Min Typ Operating Current I DD Standby Current EN Input Voltage Max Unit Conditions - 90 120 μA V EN = 5V, OUT = OPEN I STB - 0.01 1 μA V EN = 0V, OUT = OPEN V ENH 2.0 - - V High Input - - 0.8 V Low Input V ENL - - 0.4 V Low Input 2.7V≤ V IN ≤4.5V I EN -1.0 +0.01 +1.0 μA V EN = 0V or V EN = 5V /OC Output Low Voltage V /OC - - 0.5 V I /OC = 5mA /OC Output Leak Current I L/OC - 0.01 1 μA V /OC = 5V /OC Delay Time t /OC - 2.5 8 ms ON-Resistance R ON - 80 100 mΩ Over-Current Threshold I TH 0.7 1.0 1.6 A Output Current at Short I SC 0.7 1.0 1.3 A Output Rise Time t ON1 - 1.2 10 ms Output Turn ON Time t ON2 - 1.5 20 ms Output Fall Time t OFF1 - 1 20 μs Output Turn OFF Time t OFF2 - 3 40 μs V TUVH 2.1 2.3 2.5 V Increasing V IN V TUVL 2.0 2.2 2.4 V Decreasing V IN EN Input Current UVLO Threshold www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 4/22 I OUT = 500mA V IN = 5V, V OUT = 0V, C L = 100μF (RMS) R L = 10Ω, C L = OPEN TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Measurement Circuit VIN VIN A 1uF 1uF GND OUT GND OUT IN OUT IN OUT IN OUT IN OUT EN(/EN) /OC EN(/EN) /OC VEN (V/EN ) A. RL CL VEN (V/EN ) Operating Current B. EN, /EN Input Voltage, Output Rise / Fall Time VIN VIN VIN 10k 1uF VIN 1uF I/OC GND OUT GND OUT IN OUT IN OUT IN OUT IN OUT EN(/EN) /OC EN(/EN) /OC IOUT CL VEN (V/EN ) VEN (V/EN ) C. ON-Resistance, Over Current Detection D. /OC Output Low Voltage Figure 1. Measurement Circuit Timing Diagram tOFF1 tOFF1 tON1 tON1 90% 90% 90% VOUT 90% VOUT 10% 10% 10% 10% tOFF2 tOFF2 tON2 tON2 V/EN VEN V/ENL V/ENH VENH Figure 2. Timing Diagram(BD2041AFJ) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 VENL Figure 3. Timing Diagram (BD2051AFJ) 5/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Performance Curves 120 100 Ta=25°C Operating Current : IDD [μA] Operating Current : IDD[μA] 120 80 60 40 20 100 VIN=5.0V 80 60 40 20 0 0 2 3 4 5 Supply Voltage : VIN [V] -50 6 50 100 Figure 5. Operating Current vs Ambient Temperature (EN, /EN Enable) Figure 4. Operating Current vs Supply Voltage (EN, /EN Enable) 1.0 1.0 Ta=25°C VIN=5.0V 0.8 Standby Current : ISTB[μA] Standby Current : ISTB[μA] 0 Ambient Temperature : Ta[°C] 0.6 0.4 0.2 0.8 0.6 0.4 0.2 0.0 0.0 2 3 4 5 Supply Voltage : VIN [V] -50 6 50 100 Ambient Temperature : Ta[°C] Figure 6. Standby Current vs Supply Voltage (EN, /EN Disable) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 0 Figure 7. Standby Current vs Ambient Temperature (EN, /EN Disable) 6/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Performance Curves – continued 2.0 ENABLE : Enable Input INPUT VoltageVOLTAGE : VEN, V/EN[V] Ta=25°C Ta=25°C Low LowtotoHigh High High HightotoLow Low 1.0 VIN=5.0V 1.5 Low to High VEN , V /EN [V] 1.5 VEN, V /EN [V] 0 Enable Input Voltage : VEN, V/EN ENABLE INPUT VOLTAGE : [V] 2.0 0.5 High to Low 1.0 0.5 0.0 0.0 2 3 4 5 SUPPLY VOLTAGE VIN [V] Supply Voltage : VIN: [V] -50 6 Figure 8. EN, /EN Input Voltage vs Supply Voltage 0.5 Ta=25°C /OC LOW VOLTAGE /OCOUTPUT Output Low Voltage : V/OC[V]: /OC V [V] V/OC [V] 100 Figure 9. EN, /EN Input Voltage vs Ambient Temperature 0.5 OUTPUT VOLTAGE /OC Output LowLOW Voltage : V/OC[V]: 0 50 Ambient Temperature: :Ta[°C] Ta[° C]℃] AMBIENT TEMPERATURE : Ta[ Ambient Temperature 0.4 0.3 0.2 0.1 0.0 2 3 4 5 Supply Voltage [V] SUPPLY VOLTAGE : IN V [V] Supply Voltage :: V V [V] ININ 0.3 0.2 0.1 0.0 6 -50 Figure 10. /OC Output Low Voltage vs Supply Voltage www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 VIN=5.0V 0.4 0 50 Ambient Temperature :: Ta[°C] Ta[°: C] Ambient Temperature AMBIENT TEMPERATURE Ta[℃] 100 Figure 11. /OC Output Low Voltage vs Ambient Temperature 7/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Performance Curves – continued 200 200 VIN=5.0V ON-Resistance : RON[mΩ] ON RESISTANCE : 150 150 RON [mΩ] ON-Resistance : RON[mΩ] Ta=25°C 100 50 0 2 3 4 5 100 50 0 -50 6 Supply Voltage : VIN [V] Figure 13. ON-Resistance vs Ambient Temperature Figure 12. ON-Resistance vs Supply Voltage 5.0 5.0 VIN=5.0V 4.0 /OC DELAY TIME : TD/OC[mS] /OC Delay Time: t/OC [ms] /OC DELAY TIME : /OC Delay Time: t/OC [ms] TD/OC[mS] Ta=25°C 3.0 2.0 1.0 0.0 0 50 100 AMBIENT : Ta[℃] AmbientTEMPERATURE Temperature : Ta[°C] 4.0 3.0 2.0 1.0 2 3 4 5 Supply Voltage: V [V] ININ[V] SUPPLY VOLTAGE: V 0.0 6 Figure 14. /OC Delay Time vs Supply Voltage www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 -50 50 0 Ambient TEMPERATURE: Temperature: Ta [°C] AMBIENT Ta[℃] 100 Figure 15. /OC Delay Time vs Ambient Temperature 8/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Performance Curves – continued 2.0 VIN=5.0V Ta=25°C SHORT OutputCIRCUIT Current atCURRENT Short : ISC[A]: ISC [A] Output Current at Short : ISC[A] 2.0 1.5 1.5 1.0 1.0 0.5 0.5 0.0 2 Figure 16. 3 4 5 Supply Voltage : VIN [V] 0.0 6 -50 Output Current at Short vs Supply Voltage Figure 17. Output Current at Short vs Ambient Temperature 5.0 5.0 VIN=5.0V Ta=25°C 4.0 Output Rise Time : tON1[ms] Output Rise Time : tON1[ms] 0 50 100 AMBIENT TEMPERATURE : Ta[ ] Ambient Temperature : Ta[°C] ℃ 3.0 2.0 1.0 4.0 3.0 2.0 1.0 0.0 0.0 2 3 4 5 Supply Voltage : VIN [V] -50 6 Figure 18. Output Rise Time vs Supply Voltage www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 0 50 Ambient Temperature : Ta[°C] 100 Figure 19. Output Rise Time vs Ambient Temperature 9/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Performance Curves – continued 5.0 Ta=25°C Output Turn ON Time : tON2[ms] Output Turn ON Time : tON2[ms] 5.0 4.0 3.0 2.0 1.0 VIN=5.0V 4.0 3.0 2.0 1.0 0.0 0.0 2 3 4 5 Supply Voltage : VIN [V] -50 6 50 100 Ambient Temperature : Ta[°C] Figure 20. Output Turn ON Time vs Supply Voltage Figure 21. Output Turn ON Time vs Ambient Temperature 5.0 5.0 VIN=5.0V Ta=25°C 4.0 Output Fall Time : tOFF1[μs] Output Fall Time : tOFF1[μs] 0 3.0 2.0 1.0 0.0 4.0 3.0 2.0 1.0 0.0 2 3 4 5 Supply Voltage : VIN [V] 6 -50 Figure 22. Output Fall Time vs Supply Voltage www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 0 50 Ambient Temperature : Ta[°C] 100 Figure 23. Output Fall Time vs Ambient Temperature 10/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Performance Curves – continued 5.0 5.0 VIN=5.0V Output Turn OFF Time : tOFF2[μs] Output Turn OFF Time : tOFF2[μs] Ta=25°C 4.0 3.0 2.0 1.0 4.0 3.0 2.0 1.0 0.0 0.0 2 3 4 5 Supply Voltage : VIN [V] -50 6 50 100 Figure 25. Output Turn OFF Time vs Ambient Temperature Figure 24. Output Turn OFF Time vs Supply Voltage 1.0 UVLO Hysteresis Voltage :VHYS[V] 2.5 UVLO Threshold : VTUVH, VTUVL[V] 0 Ambient Temperature : Ta[°C] 2.4 VTUVH 2.3 VTUVL 2.2 2.1 2.0 -50 0 50 100 Ambient Temperature : Ta[°C] Figure 26. UVLO Threshold Voltage vs Ambient Temperature www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 0.8 0.6 0.4 0.2 0.0 -50 0 50 Ambient Temperature : Ta[°C] 100 Figure 27. UVLO Hysteresis Voltage vs Ambient Temperature 11/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Wave Forms V/EN (5V/div.) V/EN (5V/div.) V/OC (5V/div.) V/OC (5V/div.) VOUT (5V/div.) VOUT (5V/div.) IOUT (0.5A/div. VIN=5V RL=10Ω VIN=5V RL=10Ω IOUT (0.5A/div.) TIME(1ms/div.) TIME(1ms/div.) Figure 28. Output Rise Characteristic (BD2041AFJ) Figure 29. Output Fall Characteristic (BD2041AFJ) V/OC (5V/div.) V/EN (1V/div.) VOUT (5V/div.) IOUT (0.2A/div.) 220μF V/OC (1V/div.) 330μF 147μF 47μF VIN=5V RL=10Ω IOUT (0.5A/div.) VIN=5V TIME(0.5ms/div.) TIME(20ms/div.) Figure 30. Inrush Current (BD2041AFJ) Figure 31. Over-Current Response Ramped Load (BD2041AFJ) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 12/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Wave Forms - continued V/OC (5V/div.) V/EN (5V/div.) VOUT (5V/div.) V/OC (5V/div.) VOUT (5V/div.) IOUT (0.5A/div.) VIN=5V IOUT (0.5A/div.) VIN=5V CL=100μF TIME(2ms/div.) TIME (2ms/div.) Figure 32. Over-Current Response Ramped Load (BD2041AFJ) Figure 33. Over-Current Response Enable to Shortcircuit (BD2041AFJ) V/OC (5V/div.) V/OC (5V/div.) VOUT (5V/div.) VOUT (5V/div.) Thermal Shutdown VIN=5V CL=100μF IOUT (0.5A/div.) IOUT (1A/div.) VIN=5V CL=100μF TIME (2ms/div.) TIME (500ms/div.) Figure 34. Over-Current Response Output 1Ω short at Enable (BD2041AFJ) Figure 35. Over-Current Response Output 1Ω short at Enable (BD2041AFJ) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 13/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Wave Forms – continued VIN (5V/div.) VIN (5V/div.) VOUT (5V/div.) VOUT (5V/div.) IOUT (0.5A/div.) IOUT (0.5A/div.) V/OC (5V/div.) RL=10Ω CL=147μF V/OC (5V/div.) RL=10Ω CL=147μF TIME (10ms/div.) TIME (10ms/div.) Figure 36. UVLO VIN Increasing (BD2041AFJ) Figure 37. UVLO VIN Decreasing (BD2041AFJ) For the output rise/fall and over-current detection characteristics of BD2051AFJ, please refer to the characteristic of BD2041AFJ. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 14/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Typical Application Circuit 5V(Typ) VBUS D+ IN Regulator OUT DGND USB Controller 10k to 100kΩ CIN GND OUT IN OUT IN OUT EN(/EN) /OC VBUS + CL - D+ DGND Application Information When excessive current flows due to output short circuit or so, ringing occurs by inductance of power source line and IC. This may cause bad effects on IC operations. In order to avoid this case, a bypass capacitor should be connected across the IN terminal and GND terminal of IC. A 1μF or higher value is recommended. Pull-up /OC output by resistance 10kΩ to 100kΩ. Set-up values for C L which satisfies the application. This application circuit does not guarantee its operation. When using the circuit with changes to the external circuit constants, it is better to have an adequate margin for the external components such as static and transient characteristics as well as dispersion of the IC. Functional Description 1. Switch Operation IN terminal and OUT terminal are connected to the drain and the source of switch MOSFET respectively. The IN terminal is also used as power source input to internal control circuit. When the switch is turned ON by EN(/EN) control input, both the IN and OUT terminals are connected by a 80mΩ bidirectional switch. Therefore, current flows from OUT terminal to IN terminal since the flow of current is from higher to lower potentials. On the other hand, when the switch is turned OFF, it is possible to prevent current from flowing reversely from OUT to IN since a parasitic diode between the drain and the source of switch MOSFET is not present. 2. Thermal Shutdown Circuit (TSD) If over-current would continue, the temperature of the IC would increase drastically. If the junction temperature goes beyond 140°C (Typ) during the condition of over-current detection, thermal shutdown circuit operates and turns the power switch OFF, causing the IC to output an error flag (/OC). Then, when the junction temperature drops lower than 120°C (Typ), the power switch is turned ON and error flag (/OC) is cancelled. This operation repeats unless the cause of the increase of chip’s temperature is removed or the output of power switch is turned OFF. The thermal shutdown circuit operates when the switch is ON (EN(/EN) signal is active). www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 15/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ 3. Over-Current Detection (OCD) The over-current detection circuit limits current (I SC ) and outputs error flag (/OC) when current flowing in each switch MOSFET exceeds a specified value. The over-current detection circuit works when the switch is ON (EN(/EN) signal is active). There are three types of response against over-current: (1) (2) (3) When the switch is turned on while the output is in short circuit status, the switch goes into current limit status immediately. When the output short circuits or high-current load is connected while the switch is ON, very large current flows until the over-current limit circuit reacts. When it exceeds the detection value, current limitation is carried out. When the output current increases gradually, current limit circuit would not operate unless the output current exceeds the over-current detection value. But when the output current increases gradually and it exceeds the detection value, current limitation is carried out. 4. Under Voltage Lockout (UVLO) UVLO circuit prevents the switch from turning on until V IN exceeds 2.3V(Typ). If V IN drops below 2.2V(Typ) while the switch is ON, then UVLO shuts off the power switch. UVLO has hysteresis of a 100mV(Typ). Under voltage lockout circuit works when the switch is on (EN(/EN) signal is active). 5. Error Flag (/OC) Output Error flag output is N-MOS open drain output. During detection of over-current and/or thermal shutdown, the output level is low. Over-current detection has delay filter. This delay filter prevents current detection flags from being sent during instantaneous events such as inrush current at switch on or during hot plug. If fault flag output is unused, /OC pin should be connected to open or ground line. V/EN Output Short Circuit VOUT Thermal Shutdown IOUT V/OC /OC Delay Time Figure 38. Over-Current Detection, Thermal Shutdown Timing Diagram (BD2041AFJ) VEN Output Short Circuit VOUT Thermal Shutdown IOUT V/OC /OC Delay Time Figure 39. Over-Current Detection, Thermal Shutdown Timing Diagram (BD2051AFJ) www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 16/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Power Dissipation (SOP-J8) 700 Power Dissipation : Pd[mW] POWER DISSIPATION : Pd [mW] 600 500 400 300 200 100 0 0 25 50 75 100 125 AMBIENT TEMPERATURE : Ta [℃] Ambient Temperature : Ta[°C] 150 70mm x 70mm x 1.6mm Glass Epoxy Board Figure 40. Power Dissipation Curve (Pd-Ta Curve) I/O Equivalence Circuit Symbol Pin No EN(/EN) 4 /OC 5 OUT 6,7,8 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Equivalence Circuit 17/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Operational Notes 1. Reverse Connection of Power Supply Connecting the power supply in reverse polarity can damage the IC. Take precautions against reverse polarity when connecting the power supply, such as mounting an external diode between the power supply and the IC’s power supply pins. 2. Power Supply Lines Design the PCB layout pattern to provide low impedance supply lines. Separate the ground and supply lines of the digital and analog blocks to prevent noise in the ground and supply lines of the digital block from affecting the analog block. Furthermore, connect a capacitor to ground at all power supply pins. Consider the effect of temperature and aging on the capacitance value when using electrolytic capacitors. 3. Ground Voltage Ensure that no pins are at a voltage below that of the ground pin at any time, even during transient condition. 4. Ground Wiring Pattern When using both small-signal and large-current ground traces, the two ground traces should be routed separately but connected to a single ground at the reference point of the application board to avoid fluctuations in the small-signal ground caused by large currents. Also ensure that the ground traces of external components do not cause variations on the ground voltage. The ground lines must be as short and thick as possible to reduce line impedance. 5. Thermal Consideration Should by any chance the power dissipation rating be exceeded the rise in temperature of the chip may result in deterioration of the properties of the chip. The absolute maximum rating of the Pd stated in this specification is when the IC is mounted on a 70mm x 70mm x 1.6mm glass epoxy board. In case of exceeding this absolute maximum rating, increase the board size and copper area to prevent exceeding the Pd rating. 6. Recommended Operating Conditions These conditions represent a range within which the expected characteristics of the IC can be approximately obtained. The electrical characteristics are guaranteed under the conditions of each parameter. 7. In rush Current 8. Operation Under Strong Electromagnetic Field Operating the IC in the presence of a strong electromagnetic field may cause the IC to malfunction. 9. Testing on Application Boards When testing the IC on an application board, connecting a capacitor directly to a low-impedance output pin may subject the IC to stress. Always discharge capacitors completely after each process or step. The IC’s power supply should always be turned off completely before connecting or removing it from the test setup during the inspection process. To prevent damage from static discharge, ground the IC during assembly and use similar precautions during transport and storage. When power is first supplied to the IC, it is possible that the internal logic may be unstable and inrush current may flow instantaneously due to the internal powering sequence and delays, especially if the IC has more than one power supply. Therefore, give special consideration to power coupling capacitance, power wiring, width of ground wiring, and routing of connections. 10. Inter-pin Short and Mounting Errors Ensure that the direction and position are correct when mounting the IC on the PCB. Incorrect mounting may result in damaging the IC. Avoid nearby pins being shorted to each other especially to ground, power supply and output pin. Inter-pin shorts could be due to many reasons such as metal particles, water droplets (in very humid environment) and unintentional solder bridge deposited in between pins during assembly to name a few. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 18/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Operational Notes - continued 11. Unused Input Pins Input pins of an IC are often connected to the gate of a MOS transistor. The gate has extremely high impedance and extremely low capacitance. If left unconnected, the electric field from the outside can easily charge it. The small charge acquired in this way is enough to produce a significant effect on the conduction through the transistor and cause unexpected operation of the IC. So unless otherwise specified, unused input pins should be connected to the power supply or ground line. 12. Regarding the Input Pin of the IC This monolithic IC contains P+ isolation and P substrate layers between adjacent elements in order to keep them isolated. P-N junctions are formed at the intersection of the P layers with the N layers of other elements, creating a parasitic diode or transistor. For example (refer to figure below): When GND > Pin A and GND > Pin B, the P-N junction operates as a parasitic diode. When GND > Pin B, the P-N junction operates as a parasitic transistor. Parasitic diodes inevitably occur in the structure of the IC. The operation of parasitic diodes can result in mutual interference among circuits, operational faults, or physical damage. Therefore, conditions that cause these diodes to operate, such as applying a voltage lower than the GND voltage to an input pin (and thus to the P substrate) should be avoided. Resistor Transistor (NPN) Pin A Pin B C Pin A N P+ N P N P+ N Parasitic Elements N P+ GND E N P N P+ B N C E Parasitic Elements P Substrate P Substrate Parasitic Elements Pin B B Parasitic Elements GND GND Figure 41. Example of monolithic IC structure N Region close-by GND 13. Ceramic Capacitor When using a ceramic capacitor, determine the dielectric constant considering the change of capacitance with temperature and the decrease in nominal capacitance due to DC bias and others. 14. Thermal Shutdown Circuit(TSD) This IC has a built-in thermal shutdown circuit that prevents heat damage to the IC. Normal operation should always be within the IC’s power dissipation rating. If however the rating is exceeded for a continued period, the junction temperature (Tj) will rise which will activate the TSD circuit that will turn OFF all output pins. When the Tj falls below the TSD threshold, the circuits are automatically restored to normal operation. Note that the TSD circuit operates in a situation that exceeds the absolute maximum ratings and therefore, under no circumstances, should the TSD circuit be used in a set design or for any purpose other than protecting the IC from heat damage. 15. Thermal design Perform thermal design in which there are adequate margins by taking into account the power dissipation (Pd) in actual states of use. www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 19/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Ordering Information B D 2 0 4 1 A Part Number B D F J - Package FJ: SOP-J8 2 0 5 1 A Part Number F J Package FJ: SOP-J8 E2 Packaging and forming specification E2: Embossed tape and reel - E2 Packaging and forming specification E2: Embossed tape and reel Marking Diagram SOP-J8 (TOP VIEW) Part Number Marking LOT Number 1PIN MARK Part Number Part Number Marking BD2041AFJ D041A BD2051AFJ D051A www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 20/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Physical Dimension, Tape and Reel Information Package Name www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 SOP-J8 21/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 BD2041AFJ BD2051AFJ Revision History Date 08.Mar.2013 21.Aug.2014 Revision 001 002 www.rohm.com © 2013 ROHM Co., Ltd. All rights reserved. TSZ22111・15・001 Changes New Release Applied the ROHM Standard Style and improved understandability. 22/22 TSZ02201-0E3E0H300290-1-2 21.Aug.2014 Rev.002 Datasheet Notice Precaution on using ROHM Products 1. Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you (Note 1) , transport intend to use our Products in devices requiring extremely high reliability (such as medical equipment equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ 2. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation (Pd) depending on Ambient temperature (Ta). When used in sealed area, confirm the actual ambient temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used; if flow soldering method is preferred, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice – GE © 2013 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet Precautions Regarding Application Examples and External Circuits 1. If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label QR code printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since our Products might fall under controlled goods prescribed by the applicable foreign exchange and foreign trade act, please consult with ROHM representative in case of export. Precaution Regarding Intellectual Property Rights 1. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. ROHM shall not be in any way responsible or liable for infringement of any intellectual property rights or other damages arising from use of such information or data.: 2. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the information contained in this document. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice – GE © 2013 ROHM Co., Ltd. All rights reserved. Rev.002 Datasheet General Precaution 1. Before you use our Pro ducts, you are requested to care fully read this document and fully understand its contents. ROHM shall n ot be in an y way responsible or liabl e for fa ilure, malfunction or acci dent arising from the use of a ny ROHM’s Products against warning, caution or note contained in this document. 2. All information contained in this docume nt is current as of the issuing date and subj ect to change without any prior notice. Before purchasing or using ROHM’s Products, please confirm the la test information with a ROHM sale s representative. 3. The information contained in this doc ument is provi ded on an “as is” basis and ROHM does not warrant that all information contained in this document is accurate an d/or error-free. ROHM shall not be in an y way responsible or liable for an y damages, expenses or losses incurred b y you or third parties resulting from inaccur acy or errors of or concerning such information. Notice – WE © 2014 ROHM Co., Ltd. All rights reserved. Rev.001
BD2041AFJ-E2 价格&库存
很抱歉,暂时无法提供与“BD2041AFJ-E2”相匹配的价格&库存,您可以联系我们找货
