RB160LAM-40TF
Schottky Barrier Diode
(AEC-Q101 qualified)
Data sheet
● Outline
VR
40
V
Io
1
A
IFSM
50
A
● Features
● Inner Circuit
High reliability
Small power mold type
Low V F
● Application
● Packaging Specifications
Packing
Embossed Tape
Reel Size(mm)
180
Taping Width(mm)
12
Quantity(pcs)
3000
Taping Code
TR
Marking
34
General rectification
● Structure
Silicon epitaxial planar
● Absolute Maximum Ratings (Tc=25ºC unless otherwise specified)
Parameter
Symbol
Conditions
Limits
Unit
Repetitive peak reverse voltage
Reverse voltage
V RM
VR
Duty≦0.5
Reverse direct voltage
40
40
V
V
Average rectified forward current
Io
Glass epoxy mounted、
60Hz half sin waveform、resistive load、
Tc=137℃ Max.
1
A
Peak forward surge current
IFSM
60Hz half sin waveform、Non-repetitive、
one cycle、Ta=25℃
50
A
Junction temperature(1)
Storage temperature
Tj
Tstg
150
-55 ~ 150
Note(1) To avoid occurrence of thermal runaway , actual board is to be designed to fulfill dPd/dTj
很抱歉,暂时无法提供与“RB160LAM-40TFTR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+10.19398
- 25+3.78759
- 100+2.10910
- 125+1.92456
- 290+1.81910
- 国内价格 香港价格
- 1+2.938701+0.35490
- 10+2.3090010+0.27890
- 100+1.38770100+0.16760
- 500+1.28280500+0.15490
- 1000+0.907301000+0.10960
- 3000+0.897903000+0.10850
