ROHM-760308MP-EVK-001 数据手册
DESIGN KIT MANUAL
Wireless Charging Solutions
Wireless Power Design Kit – Medium Power
Order Code: 760308MP, Version 1.0
Transmitter Module, Receiver Module and LED Load Module compliant to Qi v1.2.2
Abstract
ROHM Semiconductor and Würth Elektronik (WE)
offers this wireless power design kit (order code
760308MP) to demonstrate the advantages of
wireless power and to give developers the opportunity
to test and integrate a wireless power solution into
their application.
This design kit is based on the Qi specification 1.2.2
and supports the Extended Power Profile (EPP) from
the Wireless Power Consortium (WPC). Receiver and
transmitter are also backwards compatible with the
low power mode (Baseline Power Profile).
This manual describes the setup and basic usage of
this design kit.
Key Specifications
Mains power input voltage ………………100-240VAC
Regulated input voltage…..…………………….19VDC
Maximum transmitted power.................................15W
Note 1
Maximum receiver output power…….10W (15W
WPC Qi compliance………………………………v1.2.2
Features
Plug & Play Wireless Power Design Kit
Meets the Qi Standard of the Wireless Power
Consortium (WPC)
Complete solution consisting of TX, RX and LED
Load module
Flexible and modular approach for fast integration of
wireless power in your product design
Low power (baseline power profile) and Medium
power (extended power profile) operation
Visit www.rohm.com/web/eu/wirelesspowerkit
for details
Description of Featured Products
The BD57020MWV is an IC for wireless power
transmitter applications. This device is composed of
pre-driver inverters for the TX coil, Qi compliant
controller for the communication and demodulating
circuit, GPIO, XO buffer, and I2C interface. The
BD57020MWV works as an analog frontend driven by
a general-purpose microcontroller. In this design kit
the transmitter is controlled by the MCU
ML610Q772-B03, which has all necessary firmware
to be compliant with the WPC Qi ver.1.2.2 standard
and supports wireless power transmission up to 15W.
BD57015GWL is a wireless power receiver IC. The
device integrates a fully synchronous rectifier circuit
with low-impedance FETs, Qi and PMA compliant
packet controller, adjustable regulated voltage output,
and an open-drain output terminal to communicate
with the power transmitter using amplitude
modulation. The BD57015GWL is targeted at mobile
applications
implementing
wireless
charging
compliant to Qi Medium Power (including Low Power)
and PMA standard. For further details, please also
consult the relevant product datasheets at
http://www.rohm.com.
For further details about the TX and RX coils please
visit Würth Elektronik at http://www.we-online.de.
Note 1: Will need simple RX Module modification. If you require 15W get in
touch with ROHM customer support (see chapter 4).
www.rohm.com
© 2016 ROHM Co., Ltd. All rights reserved.
1/11
EUDC59-U-004 - Rev. 1.0
Wireless Power Design Kit – Medium Power – 760308MP V1.0
Design Kit Manual
Table of Contents
1.
2.
2.1
2.2
2.3
3.
3.1
3.2
3.3
3.4
3.5
3.6
4.
Cover Page...............................................................................................................................................................................1
Abstract ............................................................................................................................................................................. 1
Description of Featured Products ...................................................................................................................................... 1
Key Specifications ............................................................................................................................................................. 1
Features ............................................................................................................................................................................ 1
Introduction ............................................................................................................................................................................... 3
Hardware Description ............................................................................................................................................................... 3
Block Diagram ....................................................................................................................................................................... 3
Key components ................................................................................................................................................................... 4
Schematic, Gerber Files and Bill of Materials........................................................................................................................ 4
Design Kit Setup and Operating Instructions ............................................................................................................................ 5
Warnings ............................................................................................................................................................................... 5
Instructions for Safe Use ....................................................................................................................................................... 5
Power Supply ........................................................................................................................................................................ 5
Transmitter (TX) Module ....................................................................................................................................................... 6
Receiver (RX) Module ........................................................................................................................................................... 8
LED Load Module ................................................................................................................................................................. 9
Customer Support..................................................................................................................................................................... 9
www.rohm.com
2/11
Design Kit Manual
1. Introduction
WPC's Qi standard for medium power has attracted attention as a next-generation standard for inductive power transmission that
will enable wireless charging of tablet PCs while allowing smartphones and other mobile devices to be charged up to three times
faster than the existing low power standard (5W). In addition, an advanced Foreign Object Detection (FOD) function is included to
provide improved safety by detecting foreign metallic right before the power transfer has started to ensure the safety of sensitive
electronics and to avoid overheating of foreign metallic objects.
ROHM has developed this design kit to enable engineers to faster develop wireless charging in general and explore the detailed
usage of its core components on the transmitter side with the BD57020MWV and on the receiver side with the BD57015GWL.
This manual is valid for Design Kit Version 1.0. It provides guidelines to quickly setup the hardware for fast and easy evaluation of
the wireless charging system and the featured key components. For further details and updates about the TX and RX ICs and other
ROHM products, please also consult the relevant product datasheets and general information at http://www.rohm.com.
Please also check www.rohm.com/web/eu/wirelesspowerkit for downloading the latest version of this document and additional
useful information such as application notes, Gerber files, schematics, bill of materials, etc.
2. Hardware Description
2.1 Block Diagram
The design kit consists of the following components:
TX Module
Demonstration of charging pad function using TX IC, MCU, discrete full bridge, QFOD circuit, TX coil
RX Module
Demonstration of wireless power receiver inside a mobile device using Receiver IC, RX coil
LED Shield
Wireless powered LED light using LED array + driver, MCU
Power Supply
Wide input range mains power supply with different adapters for international use
A block diagram of the design kit is depicted in Figure 1. The transmitter design corresponds to the MP-A7 as defined in the WPC Qi
specification 1.2.2. The necessary 19VDC input voltage is provided with the included mains adapter.
The key component of the Transmitter Module is the transmitter IC BD57020MWV. This IC integrates all necessary analog functions
to operate as a wireless power transmitter such as full bridge pre-driver and demodulation circuit. The digital control is realized by
the microcontroller ML610Q772-B03 which is directly supplied by one of the LDO outputs of the TX IC. The quality factor foreign
object detection (Q-FOD) circuit is realized with discrete components.
The coil area is the wireless power interface to the receiver. It is covered by a 2mm thick acryl glass plate which acts as distance
spacer and physical protection of the resonant circuit which may carry high AC voltages in certain conditions.
Figure 1: Design Kit Block Diagram
The Receiver Module integrates all necessary functions to act as a wireless power receiver such as full synchronous rectification,
power sensing, modulator, Qi/PMA packet controller and an adjustable output LDO. The key component is the BD57015GWL
receiver IC.
www.rohm.com
3/11
Design Kit Manual
The MCU on the receiver side is required for the proper configuration of the RX IC. Without the configuration the RX is not sending
the needed parameters during the negotiation/calibration phase to enable the medium power transfer mode. The I2C interface is
used to set the necessary parameters such as the LDO output voltage, the current limit, FOD and QFOD settings.
The receiver system of this design kit uses a modular approach: The Load Module is designed as stackable shield on top of the
Receiver Module. This allows easy replacement of the demonstrative LED matrix load and receiver side MCU. The user may design
a custom load/MCU shield or connect to the RX Module pin headers by jumper cables.
Interoperability between transmitter and receiver is achieved by complying with the WPC Qi standard. The Transmitter Module can
supply power to any Qi compliant receiver and equally the Receiver Module can receive power from any Qi compliant transmitter.
Also, both modules are backwards compatible with a low power (baseline power profile) counterpart.
2.2 Key components
The purpose of the EVK is the evaluation of the key components used to realize the wireless power system. Table 1 gives an
overview of the different ICs and coils. For more detailed information about these devices please follow the given hyperlinks to the
individual web pages and datasheets.
Manufacturer
Rohm Semiconductor
Rohm Semiconductor
Rohm Semiconductor
Rohm Semiconductor (Lapis)
Product
Wireless Power Transmitter IC
Step-Down Switching Regulator
Wireless Power Receiver IC
Microcontroller
Part Number
BD57020MWV
BD9E151NUX
BD57015GWL
ML610Q772-B03
Used in
TX Module
TX Module
RX Module
TX Module
Rohm Semiconductor
Würth Elektronik eiSos
Microcontroller
LED driver 8ch
Transmitter Coil
Receiver Coil
ML610Q112
BD6142AMUV
760 308 110
760 308 102 207
LED Module
LED Module
TX Module
RX Module
Table 1: Key components used in the design kit
2.3 Schematic, Gerber Files and Bill of Materials
Please visit www.rohm.com/web/eu/wirelesspowerkit for downloading the latest production data consisting of the schematics,
assembly data, Gerber files and Bill of Materials (BOMs) for all three modules of this design kit.
www.rohm.com
4/11
Design Kit Manual
3. Design Kit Setup and Operating Instructions
3.1 Warnings
This design kit must only be operated by trained professionals.
This design kit should be operated in a well ventilated environment and, if used inside a case, the case should not be
covered.
This design kit should be placed on a stable, flat, non-conductive surface in use and should not be contacted by conductive
items.
All peripherals used with the design kit should comply with relevant standards for the country of use and be marked
accordingly to ensure that safety and performance requirements are met.
Where peripherals are connected that do not include the cable or connector, the cable or connector used must offer
adequate insulation and operation in order that the requirements of the relevant performance and safety are met.
The connection of incompatible devices to the design kit may affect compliance or result in damage to the unit and
invalidate the warranty.
WARNING
The AC voltage in the resonant tank may reach voltage up to 250Vpp under
certain conditions. Therefore, it is covered by acryl glass to ensure human
safety. Nevertheless take care not to touch the PCB by bare hand and use
the required level of isolation when probing test points on the PCB.
3.2 Instructions for Safe Use
Do not expose the design kit to water, moisture or place on a conductive surface whilst in operation.
Take care whilst handling to avoid mechanical or electrical damage to the printed circuit board and components.
Avoid handling the printed circuit board while it is powered. Only handle by the edges to minimize the risk of electrostatic
discharge damage.
Do not short any outputs to each other, to the supply or to GND.
Do not operate the design kit outside its specified ratings.
Take care to monitor the PCB and IC temperatures in particular when operating with high power loads and do not exceed
the absolute maximum ratings of all components.
3.3 Power Supply
Apply one of the included mains plugs (North America / Japan, Great Britain, Central Europe) with the power supply and connect the
AC plug to mains. Connect the DC plug of the mains adapter to CONN1 of the Transmitter Module.
In case another power supply is used please make sure to comply with the electrical characteristics as the provided mains adapter
(see Table 2). Take care not to reverse polarize the applied voltage.
Parameter
Input voltage
Output voltage
Output current rating
Specification
100-240V AC, 50/60Hz
19V DC 5%
2A
Table 2: Mains adapter specification
Figure 2: Included power supply with 3 different mains adapter plugs
www.rohm.com
5/11
Design Kit Manual
3.4 Transmitter (TX) Module
When power is provided to the TX Module at CONN1, LED1 will light green to indicate presence of the 19V input voltage.
Additionally LED2 will light green when the 5V DC/DC converter has started up. The Transmitter Module is now in low power “idle”
mode where it is periodically pinging on the wireless interface to detect presence of a receiver device.
The stacked RX+LED Modules (or any other Qi compliant receiver) can now be placed anywhere on the Coil Area (as shown in
Figure 3) and the wireless power transmission will start. In low power mode (WPC baseline power profile) the LED LP will light green
to indicate successful and ongoing power transfer. In addition the LED MP will also light in medium power mode (WPC extended
power profile).
There is a red color LED FL to indicate failure modes. Slow blinking means the power transfer is still established but Field Strength
Limitation (FSL) is active. This is usually caused when the receiver has slightly moved out of alignment and safe power transfer is
not guaranteed. In this case the ROHM Receiver Module will communicate to stop power transfer if the system will not have
recovered from this failure mode within ~3s. This condition is indicated by fast blinking failure mode LED. Other reasons for stopped
power transfer can be Foreign Object Detection (FOD), Under Voltage Lockout (UVLO) or “End of Power Transfer” (EPT) requested
by the receiver. The system can only recover from this failure mode if the receiver is removed from the coil area. The transmitter will
then go to idle mode.
The different operating modes and status LED indications are summarized in Table 3. Please check
Figure 4 for the local positions of described LEDs, inputs and outputs.
Figure 3: Stacked RX+LED Module placed on coil area of TX Module
LED Name
LP
MP
FL
Operating Mode Description
Off
Off
Off
Idle mode with periodic pings for receiver detection. Very low power consumption.
On
Off
Off
LP mode (WPC baseline power profile) with up to 5W load power.
On
On
Off
MP mode (WPC extended power profile) with up to 10W (15W) load power.
On
On
or
Off
Slowly
Blinking
Power transfer is still established but Field Strength Limitation (FSL) is active. (see
above).
Off
Off
Fast
Blinking
Power transfer has been stopped due to Foreign Object Detection (FOD), EPT or
Under Voltage Lockout (UVLO). The system can only recover from this failure mode if
the receiver is removed from the coil area. The transmitter will then go to idle mode.
Table 3: Operating Modes indicated by status LEDs on the Transmitter Module
www.rohm.com
6/11
Design Kit Manual
Figure 4: Transmitter Board with indication of inputs, outputs and status LEDs
Parameter
Input voltage
Maximum output AC power
Qi compliance
Transmitter Type
Specification
19V DC 5%
15W
1.2.2
MP-A7
Table 4: Transmitter Module specification
Basic electrical specifications of the Transmitter Module are summarized in Table 4. The AC output power of the transmitter is high
enough so that a receiver can deliver 15W maximum to its load.
www.rohm.com
7/11
Design Kit Manual
3.5 Receiver (RX) Module
When the wireless transmitted power reaches the Receiver Module, LED1 will light green to indicate a “power good” function. Also
LED2 and LED3 are lit white and shine into the acryl glass cube. The push button TST1 can be used to reset the receiver if
necessary. See Figure 5 for LED and push button positions.
Figure 5: Receiver Module, top view
The basic electrical specifications of the Receiver Module are summarized in Table 5. Please note the maximum receiver load power
must not exceed 10W with the version 1.0 of the design kit. If a load power of 15W is really required please get in contact with ROHM
customer support for help on necessary hardware and software modifications.
Parameter
Output voltage delivered to load
Maximum power delivered to load
(at 20°C ambient temperature)
Qi compliance
Specification
10V DC
10W (RX IC case temperature ~ 60°C)
1
15W (RX IC case temperature ~ 85°C)
1.2.2
Note 1: Will need simple RX Module modification. If you require 15W get in touch with ROHM customer support (see
chapter 4).
Table 5: Receiver Module specification
www.rohm.com
8/11
Design Kit Manual
3.6 LED Load Module
When the LED Load Module is powered by the RX Module via the VOUT pin the LED69 on the bottom side (see Figure 6) will light
white. When Sw1 is turned on (default setting) the LED driver is enabled and the LED matrix on the top side will light. Turning Sw2
off will disable the LED matrix load. In this case a user defined load may be attached between VOUT and GND as indicated in Figure
7. Please take care not to exceed the maximum specified RX load power.
Figure 6: LED Module, bottom view
Figure 7: LED Module, top view
Slide switch on LED Module
Sw1: LED
1
Sw2: uC
On
On
Off
On
Don’t care
Off
Configured Mode
1
Default Mode. The MCU is enabled and uses the I2C interface to configure the
RX IC BD57015 in Medium Power Mode. The LED driver is enabled, thus the
LED matrix load is lit as a demonstrative load.
The MCU is enabled and uses the I2C interface to configure the RX IC
BD57015 in Medium Power Mode. The load to the receiver is disabled. A user
defined load may be attached to the VOUT pad on the LED Module.
The MCU is disabled so the RX IC BD57015 works in Low Power Mode by
default. The LED loads are turned off independent from Sw1 setting. The user
may attach a custom MCU to the 2.85V supply pin and a load to the VOUT pad
of the LED module. In case the 2.85V supply is not needed the LED Module
can be removed, and the user may stack a customized MCU/load shield.
Note 1: Please change the position of these switches only when the stacked RX+LED Load Module are unpowered
Table 6: Mode configuration by slide switches of LED Module
4. Customer Support
If any further technical support is required when operating with the design kit please contact ROHM Semiconductor or Würth
Elektronik with your enquiry.
ROHM Semiconductor
wirelesspower@de.rohmeurope.com
Würth Elektronik
wirelesspower@we-online.com
www.rohm.com
9/11
Design Kit Manual
Notes
This EVK is
only to be used as device under test for research and development purposes.
only to be operated by trained professionals.
not to be assembled into a final product.
Additional Terms, warnings, restrictions and disclaimers of the Würth Elektronik and
ROHM Semiconductor Wireless Power Design Kit (later defined as DESIGN KIT)
Würth Elektronik (later defined as WE) and ROHM Semiconductor (later defined as ROHM)
provide the enclosed DESIGN KIT under the following conditions: The user has to bear all
responsibility and liability for the proper and safe handling with regard to this DESIGN KIT. The
user shall indemnify WE and ROHM from all claims arising from the handling or utilization of the
DESIGN KIT. In the case this DESIGN KIT does not comply with the specifications indicated in
the Quick Start Guide and Manual, the DESIGN KIT may be returned within 30 days from the
date of delivery for a full reimbursement of the purchase price.
THE FOREGOING LIMITED WARRANTY IS THE EXCLUSIVE WARRANTY MADE BY WE and
ROHM TO THE USER AND IS IN LIEU OF ALL OTHER WARRANTIES, EXPRESSED,
IMPLIED, OR STATUTORY, INCLUDING ANY WARRANTY OF MERCHANTABILITY OR
FITNESS FOR ANY PARTICULAR PURPOSE. EXCEPT TO THE EXTENT OF THE INDEMNITY
SET FORTH ABOVE, NEITHER PARTY SHALL BE LIABLE TO THE OTHER FOR ANY
INDIRECT, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES.
Please read the Quick Start Guide and Manual carefully prior to handling the DESIGN KIT.
This Guide contains essential safety information regarding temperatures and voltages.
No license is granted under any patent right or other intellectual property rights of WE or ROHM
covering or relating to any machine, process and procedure, or combination in which such the
DESIGN KIT or services might be or are used. Our arrangement with the user is not exclusive as
WE and ROHM are currently working with a large number of customers for DESIGN KITs. WE
and ROHM bear no liability for applications assistance, customer product design, software
performance, or infringement of patents or services described in the Quick Start Guide and
Manual.
Code of federal regulations
As noted in the DESIGN KIT Quick Start Guide and Manual, this DESIGN KIT and/or
accompanying hardware may or may not be subject to and compliant with the Code of Federal
Regulations, Title 47, Part 15. For DESIGN KITs annotated to comply with the Code of Federal
Regulations, Title 47, Part 15. Operation is subject to the following two conditions:
(1) This DESIGN KIT may not cause harmful interference, and (2) this DESIGN KIT must accept
any interference received, including interference that may cause undesired operation. Changes
or modifications not expressly approved by the party responsible for compliance could void the
user‘s authority to operate the equipment. This DESIGN KIT as a Class A digital apparatus
complies with Canadian ICES-003. Changes or modifications not expressly approved by the
party responsible for compliance could void the users’ authority to operate the equipment.
For DESIGN KITs annotated as not subject to or compliant with the Code of Federal Regulations,
Title 47, Part 15. This DESIGN KIT is intended for use for ENGINEERING DEVELOPMENT,
DESIGNSTRATION, OR EVALUATION PURPOSES ONLY and is not considered by WE and
ROHM to be a finished end product fit for general consumer use. It generates, uses, and can
radiate radio frequency energy and has not been tested for compliance with the limits of
computing devices pursuant to the Code of Federal Regulations, Title 47, Part 15, which are
designed to provide reasonable protection against radio frequency interference. Operation of the
equipment may cause interference with radio communications, in which case the user at its own
expense will be required to take whatever measures may be required to correct this interference.
For Feasibility Evaluation Only, in Laboratory/Development Environments. The DESIGN
KIT is not a complete product. It is intended exclusively for preliminary feasibility evaluation in
laboratory/development environments by technically qualified electronics experts. Those experts
mandatory have to be familiar with the dangers and application risks in connection with handling
electrical mechanical components, systems and subsystems. It should not be used as an end
product or as a part of an end product.
www.rohm.com
10/11
Design Kit Manual
Your Sole Responsibility and Risk. You acknowledge, represent and agree that:
a) You have unique awareness of the Federal, State and local regulatory requirements (including
but not limited to Food and Drug Administration regulations, if applicable) which affects your
products and which refers to your use (and/or the use of your employees, affiliates, contractors or
designees) of the DESIGN KIT for evaluation, testing and other purposes.
b) You are unlimited and exclusive responsible for the safety of your DESIGN KIT and for the
compliance with all relevant laws and other applicable regulatory requirements. Further you have
to assure the safety of any activities to be conducted by you and/or your employees, affiliates,
contractors or designees, using the DESIGN KIT. You are also responsible to ensure that any
interfaces (electronic and/or mechanical) between the DESIGN KIT and any human body are
designed with suitable isolation and means to safely limit the accessible leakage currents to
minimize the risk of electrical shock hazard.
c) Since the DESIGN KIT is not a completed product, it may not meet all applicable regulatory
and safety compliance standards (such as UL, CSA, VDE, CE, RoHS and WEEE) which may
normally be associated with similar completed products. You assume full responsibility to
determine and/ or assure compliance with any such standards and related certifications as may
be applicable. You have to use reasonable safeguards to ensure
that your use of the DESIGN KIT will not result in any property damage, injury or death, even if
the DESIGN KIT should fail to perform as specified or expected.
Certain Instructions. It is important to handle this DESIGN KIT within WE‘s and ROHM’s
recommended specifications and environmental considerations as described in the Quick Start
Guide and Manual. Surpassing the specified DESIGN KIT classifications (including but not
limited to input and output voltage, current, power, and environmental ranges) may cause
property damage, personal injury or death. If there are questions concerning these classifications
please contact a WE external sales representative before connecting interface electronics
including input power and intended loads. Any loads applied beyond the specified output range
may result in unintended and/or inexact operation and/or possible lasting damage to the DESIGN
KIT and/or interface electronics. Please consult the DESIGN KIT Quick Start Guide and Manual
prior to connecting any load to the DESIGN KIT output. If there is uncertainty regarding the load
specification, please contact a WE or ROHM external sales representative. During normal
operation, some circuit components may have case temperatures greater than 60°C as long as
the input and output are maintained at a normal ambient operating temperature. These
components include but are not limited to linear regulators, switching transistors, pass
transistors, and current sense resistors which can be identified by using the DESIGN KIT
schematic published in the DESIGN KIT Quick Start Guide and Manual.
Please be aware that the devices of the DESIGN KIT may be very warm in case of placing the
measurement test setup close to the DESIGN KIT during normal procedure. Please ensure that
only qualified personnel educated in electronic measurement and diagnostics usually found in
development environments should use these DESIGN KITs.
Agreement to Defend, Indemnify and Hold Harmless. You agree to defend, indemnify and
hold WE, ROHM, its licensors and their representatives harmless from and against any and all
claims, damages, losses, expenses, costs and liabilities (collectively, „Claims“) arising out of or in
connection with any use of the DESIGN KIT that is not in accordance with the terms of the
agreement. This obligation shall apply whether Claims arise under law of tort or contract or any
other legal theory, and even if the DESIGN KIT fails to perform as specified or expected.
Safety-Critical or Life-Critical Applications. If you intend to evaluate the components for
possible use in safety critical applications (such as life support) where a failure of the WE or
ROHM product would reasonably be expected to cause severe personal injury or death, such as
devices which are classified as FDA Class Ill or similar classification,
Thank you for your accessing to ROHM product information.
More detailed product information and catalogs are available, please contact us.
ROHM Customer Support System
http://www.rohm.com/contact/
www.rohm.com
11/11
