RPI-121_05
RPI-121_05
    ROHM(罗姆)
    RPI-121_05 - Photointerrupter, Ultraminiature type - Rohm
RPI-121_05 数据手册
RPI-121 Photointerrupter, Ultraminiature type External dimensions (Unit : mm) 3.6 Through hole 2.65 Input(LED) Forward current Reverse voltage Power dissipation Collector-emitter voltage Emitter-collector voltage Collector current Collector power dissipation Operating temperature Storage temperature IF VR PD VCEO VECO IC PC Topr Tstg 50 5 80 30 4.5 30 80 −25 to +85 −40 to +100 mA V mW V V mA mW Optical control equipment Cameras Floppy disk drives Gap 1 0.8 Cross-section A-A 0.4 C 0. 7 4-φ 0.8 (photo- ) transistor Output Features 1) Ultra-small. 2) Minimal influence from stray light. 3) Low collector-emitter saturation voltage. 3.3 1.5 A Optical axis center (0.5) °C °C Electrical and optical characteristics (Ta=25°C) Min.2 2.3 Parameter Output Input charac- characteristics teristics Forward voltage Reverse current Dark current Peak sensitivity wavelength Collector current Collector-emitter saturation voltage Response time Infrared light emitter diode Symbol VF IR ICEO λP Min. − − − − Typ. 1.3 − − Max. 1.6 10 0.5 − − − Unit V µA µA nm mA mA V µs MHz nm µs nm Conditions IF = 50mA VR = 5V VCE = 10V − A 2-R0.1 2-R0.3 4-0.5 800 − − − 4-0.2 (2.65) (2) 4-0.4 IC1 IC2 VCE(sat) tr fC 0.7 0.2 − − − − VCE = 5V, IF = 20mA VCE = 5V, IF = 5m IF = 20mA, IC = 0.3mA VCC = 5V, IF = 20mA, RL =100 Ω IF=50mA ∗ Non-coherent Infrared light emitting diode used. Transfer characteristics 0.3 − − − − − tf 10 1 950 10 800 Anode Collector Cut-off frequency Peak light emitting wavelength Response time Maximum sensitivity wavelength 2 Cathode Emitter Parameter Symbol Limits Unit Applications 2.6 Absolute maximum ratings (Ta=25°C) λP Photo transistor tr λP tf − − VCC=5V, IC=1mA, RL=100Ω ∗ This product is not designed to be protected against electromagnetic wave. − Notes: 1. Unspecified tolerance shall be ± 0.2 . 2. Dimension in parenthesis are show for reference. Electrical and optical characteristics curves RELATIVE COLLECTOR CURRENT : IC (%) 125 FORWARD CURRENT : IF (mA) 50 40 30 20 10 0 FORWARD CURRENT : IF (mA) −25˚C 0˚C 25˚C 50˚C 75˚C COLLECTOR CURRENT : IC (mA) 50 100 d 5 100 1000 RESPONSE TIME : tr (µs) 4 DARK CURRENT : ICEO (nA) 40 100 VCE=30V VCE=20V VCE=10V RL=1kΩ 10 RL=500Ω 75 3 30 10 50 20 2 1 RL=100Ω 25 10 0 0.2 1 0.1 0 0 1 0.05 0.1 −25 0 0 0.5 1.0 1.5 2.0 2.5 −20 0 20 40 60 80 100 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 10 20 30 40 50 1 10 0 25 50 75 100 DISTANCE : d (mm) AMBIENT TEMPERATURE : Ta (˚C) FORWARD VOLTAGE : VF (V) FORWARD CURRENT : IF (mA) COLLECTOR CURRENT : IC (mA) AMBIENT TEMPERATURE : Ta (˚C) Fig.1 Relative output current vs. distance ( ) RELATIVE COLLECTOR CURRENT : IC (%) POWER DISSIPATION / COLLECTOR POWER DISSIPTION : PD/PC (mW) 125 d Fig.2 Forward current falloff RELATIVE COLLECTOR CURRENT : IC (%) 160 Fig.3 Forward current vs. forward voltage Fig.7 Collector current vs. forward current Input COLLECTOR CURRENT : IC (mA) 10 IF=50mA 40mA 6 30mA 20mA Fig.8 Response time vs. collector current Fig.9 Dark current vs. ambient temperature 120 100 P D PC 80 60 40 20 0 VCC 140 120 100 80 60 40 20 0 −40 −20 0 20 40 60 80 100 100 8 75 Input Output RL 90% 10% 50 4 Output td tr td : Delay time tf 25 2 10mA t r : Rise time (time for output current to rise from 0 0 2 4 6 8 10 0 0 0.5 1.0 1.5 2.0 2.5 −20 0 20 40 60 80 100 10% to 90% of peak current) t f : Fall time (time for output current to fall from 90% DISTANCE : d (mm) AMBIENT TEMPERATURE : Ta (˚C) AMBIENT TEMPERATURE : Ta (˚C) COLLECTOR TO EMITTER VOLTAGE: VCE (V) to 10% of peak current) Fig.4 Relative output current vs. distance ( ) Fig.5 Power dissipation / collector power dissipation vs. ambient temperature Fig.6 Relative output vs. ambient temperature Fig.10 Output characteristics Fig.11 Response time measurement circuit Appendix Notes No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design. The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction. Appendix1-Rev1.1
RPI-121_05 价格&库存
很抱歉,暂时无法提供与“RPI-121_05”相匹配的价格&库存,您可以联系我们找货
