RPM873
RPM873
Photo Link Module
IrDA Infrared Communication Module
RPM873
RPM873 is an infrared communication module for IrDA Ver. 1.2 (Low Power). The infrared LED, PIN photo diode, and
LSI are all integrated into one single package. This module is designed for low power consumption. The very small
package makes it a perfect fit for mobile devices.
zFeatures
1) Infrared LED, PIN photo diode, LED driver and built-in receiver frequency formation circuit.
2) Applied to SIR (2.4 to 115.2kbps) low power standard.
3) Supply voltage range is from VCC=2.0 to 3.6V, VLEDA=2.6 to 5.5V.
4) Surface mounting type.
5) Built-in power down function.
zApplications
Cellular phones, PDA, DVC, digital still cameras, printers, handy terminals and etc.
zAbsolute maximum ratings (Ta=25°C)
Parameter
Symbol
Supply voltage
VCC/VLEDA
Input voltage
Limits
Unit
7.0 ∗1
V
Vin(5,6,7pin)
−0.3 to VCC+0.3
V
Operation temperature
Topr
−25 to 85
°C
Storage temperature
Tstg
−30 to 100
Power dissipation
°C
100 ∗2
Pd
mW
∗1) This applies to all pins on the basis of ground pins (1,4pin).
∗2) In case of operating environment is over 25°C, 1.33mW would be reduced per each 1°C stepping up.
zRecommended operating conditions (Ta=25°C)
Parameter
Supply voltage
Symbol
Min.
Typ.
Max.
Units
VCC
2.0
3.0
3.6
V
VLEDA
2.6
3.0
5.5
V
Rev.B
1/6
RPM873
Photo Link Module
zBlock diagram and application circuit
AMP
2
1
AMP
GND
NC
VCC
AMP
3
VCC
GND
4
GND
C1
PWDOWN
PWDOWN
5
7
6
POWER
DOWN
RXD
RXD
TXD
TXD
LEDA
8
(LEDVCC)
VCC(3pin) and VLEDA(8pin) can be
used on either common power source
or different one.
zRecommended values
Part symbol
C1
Recommended
1µF, tantalum or ceramic
Ex.) TCFGA1A105M8R(ROHM)
Notice
Bigger capacitance is recommended with much noise from power supply.
Rev.B
2/6
RPM873
Photo Link Module
zTerminal description
Pin No.
Terminal
Circuiit
Funciton
1
GND
GND
2
NC
This terminal must be left open.
3
VCC
VCC
For preventing from infection, connect a capacitor
between VCC(3pin) and GND(4pin).
4
GND
GND
Power-down control terminal
H : Power down
L : Operation
CMOS logic level input
When input is H, it will stop the receiving
circuit, PIN−PD current and transmitting
LED operation.
VCC
5
PWDOWN
VCC
VCC
PWDOWN
6
300K
RXD
Receiving data output teminal
CMOS logic level output
When PWDOWN (5pin) = H, the RXD output will
be pulled up to VCC at approximately 300kΩ.
VCC
7
Transmitting data input terminal
H : LED (PWDOWN = L)
TXD
600k
Holding TXD = H status, LED will be
turned off at approximately 48µs.
LED ANODE terminal
Other power source can be used
8
LEDA
LED
difference between VLEDA and VCC.
This can be connected to battery kinds of unregulated
voltage source by internal constant current driver.
Rev.B
3/6
RPM873
Photo Link Module
zElectrical characteristics (VCC=3V, VLEDA=3V, Ta=25°C)
Parameter
Symbol
Min.
Consumption current 1
ICC1
75
99
µA
Waiting mode, At no input light
Consumption current 2
ICC2
0.01
0.2
µA
PWDOWN mode, At no input light
2.4
115.2
kbps
Transmission rate
Typ.
Max.
Unit
Conditions
PWDOWN input high voltage
VPDH
VCC−0.55
V
PWDOWN input low voltage
VPDL
V
PWDOWN input high current
IPDH
−1.0
µA
PWDOWN=VCC [V]
PWDOWN input low current
IPDL
−1.0
µA
PWDOWN=0 [V]
TXD input high voltage
VTXH
VCC−0.55
V
TXD input low voltage
VTXL
V
TXD input high current
ITXH
2.5
5
10
µA
TXD=VCC [V]
TXD=0 [V]
ITXL
−1.0
µA
ILEDA
30.5
mA
RXD output high voltage
VRXH
VCC−0.4
V
IRXH= −200µA
RXD output low voltage
VRXL
V
IRXL= 200µA
RXD output rise time
tRR
35
ns
CL=15pF
RXD output fall time
tFR
35
ns
CL=15pF
twRXD
1.5
2.3
4.2
µs
CL=15pF, 2.4 to 115.2kbps
tRT
100
200
µs
TXD input low current
LED anode current
RXD output pulse width
Receiver latency time
zOptical characteristics (VCC=3V, VLEDA=3V, Ta=25°C)
Parameter
Symbol
Min.
Typ.
Max.
Unit
λP
850
870
900
nm
Intensity 1
IE1
4
10
26
mW / Sr
Half-angle
θL / 2
±18
±30
˚C
Opticcal pulse width
TWLED
1.42
1.63
2.02
µs
TXD=1.63µs pulse input
Rise time / Fall time
Tr / Tf
100
ns
10% to 90%
25
Peak wave length
Optical over shoot
Conditions
−15° <
− θL <
− 15°
Tj
−40
40
Minimum irradiance in angular range
Eemin
6.8
µW / cm2 −15° <
− θL <
− 15°
Maximum irradiance in angular range
Eemax
500
θD / 2
±15
mW / cm2 −15° <
− θL <
− 15°
˚C
TLEDmax
10
48
120
Edge jitter
Half-angle
Maximum emitting time
ns
µs
TXD=VCC
1. This product is not designed for protection against radioactive rays.
2. This product does not include laser transmitter.
3. This product include one PIN photo diode.
4. This product dose not include optical load.
Rev.B
4/6
RPM873
Photo Link Module
zTiming chart
(Emitting side)
TXD
(7pin)
less than 48 µs
more than 48 µs
(emitting)
(emitting)
(emitting)
Internal LED
(Light output)
approximately 48 µs
(Detecting side)
Light input
less than 2.3 µs
more than 2.3 µs
RXD
(6pin)
approximately 2.3 µs
pull up to VCC at approximately
300 kΩ
PWDOWN
(5pin)
zNotes
1) VLEDA (8pin) and VCC (3pin)
•Other power source can be used difference between VLEDA and VCC.
2) Caution in designing board lay-out
To get maximum potential from RPM873, please keep in mind following instruction.
•The line of RXD (6pin) should be connected at backside via through hole close to RPM873 pin lead.
Better not to be close to photo diode side (1pin).
⇒This is to minimize feedback supplied to photo diode from RXD.
•Better to be placed more than 1.0cm in radius from photo diode (pin1 side) and also away from the parts which
generate noise, such as DC / DC converter.
•As for C1 between 3-4pin should be placed close to RPM873.
3) Notes
•Please be sure to set up the TXD (7pin) input to be “L” (under 0.55V) except transmitting data
(for
很抱歉,暂时无法提供与“RPM873-E2A”相匹配的价格&库存,您可以联系我们找货
