RPM882-H12E4
RPM882-H12E4
    ROHM(罗姆)
    MODULE IRDA 115.2KBPS 8SMD
RPM882-H12E4 数据手册
RPM882-H12 RPM882-H12 Photo Link Module IrDA Infrared Communication Module RPM882-H12 RPM882-H12 is an infrared communication module for IrDA Ver. 1.2 (Low Power). The infrared LED, PIN photo diode, LSI are all integrated into a single package. This module is designed with power down function and low current consumption at stand-by mode. The ultra small package makes it a perfect fit for mobile devices. zFeatures 1) Infrared LED, PIN photo diode, LED driver & Receiver frequency formation circuit built in. Improvement of EMI noise protection because of Shield Case. 2) Applied to SIR (2.4 to 115.2kbps) 3) Surface mount type. 4) Power down function built in. 5) Low voltage operation as 1.5V of interface terminals to controller (TXD, RXD, PWDOWN, TX-RC). 6) Infrared remote control transmission driver built-in. zApplications Mobile phone, PDA, DVC, Digital Still Camera, Printer, Handy Terminal etc. zAbsolute maximum ratings (Ta=25°C) Parameter Symbol Limits Unit Vmax 7.0∗1 V Vin (4, 5, 6, 7pin) −0.3 to VIO+0.3 V Operation temperature Topr −25 to +85 °C Storage temperature Tstg −30 to +100 °C LED peak current IFP 300∗2 mA Power dissipation Pd 300∗3 mW Supply voltage Input voltage ∗1 This applies to all pins basis ground pins (1pin) ∗2 LED Peak Current< 90µs, On duty 50% ∗3 When glass-epoxy board (70 70 1.6mm) mounted. In case operating environment is over 25°C, 4mW would be reduced per each 1°C stepping up. zRecommended operating conditions (Ta=25°C) Parameter Symbol Min. Typ. Supply voltage VCC 2.4 Interface supply voltage VIO 1.5 VLEDVCC 2.6 LED supply voltage Max. Unit 3.0 3.6 V 3.0 VCC V 3.0 5.5 V 1/9 RPM882-H12 Photo Link Module zBlock diagram and application circuit C1 AMP 2 1 AMP GND GND + VIO VIO VCC AMP 3 VCC TX-RC 4 TX-RC PWDOWN / LED Mode RXD RXD TXD TXD LEDA (LEDVCC) 8 sw PWDOWN / LED Mode 5 7 6 POWER DOWN R1 VCC (3pin) ,VIO (2pin) and LEDVCC (8pin) can be used on either common power source or different one 2/9 RPM882-H12 Photo Link Module zTerminal description Circuit Function Pin No Terminal 1 GND 2 VIO Supply voltage for I/O pins. (TX-RC, PWDOWN, RXD, TXD) VCC Power Supply Terminal For preventing from infection, connect a capacitor between VCC (3pin) and GND (1pin). 3 Ground VIO 4 RC Transmitting Data Input Terminal H : LED Emitting CMOS Logic Level Input Holding TX-RC='H' status, LED will be turn off approximately 48µs. TX-RC 200k Power-down Control and LED Intensity switching Terminal H : POWERDOWN (RC transmitting Mode) L : OPERATION CMOS Logic Level Input When input is 'H', it will stop the receiving circuit and Pin-PD current. VIO 5 PWDOWN / LED Mode VIO PWDOWN 6 VIO 300k RXD Transmitting Data Input Terminal IrDA TXD input at PWDOWN=L (Remote control transmitting input at PWDOWN=H). VIO 7 TXD 200k 8 LEDA − Shield Case Receiving Data Output Terminal CMOS Logic Level Output When PWDOWN (5pin)= 'H', the RXD output will be pulled up to VIO at approximately 300kΩ. LED H : LED Emitting CMOS Logic Level Input Holding TXD="H" status, LED will be turn off approximately 48µs. LED ANODE Terminal Other power source can be used difference between LEDVCC and VCC. LED current depends on LED load resistance value at RC mode. Connect to Ground. 3/9 RPM882-H12 Photo Link Module zElectrical characteristics (Unless otherwise noted, VCC= VIO=3.0V, VLEDVCC=3.0V, Ta=25°C) Parameter Symbol Min. Typ. Max. Unit Consumption current1 ICC1 − 80 104 µA PWDOWN=0V At no input light Consumption current2 ICC2 PWDOWN=VIO At no input light Data rate PWDOWN input high voltage VPDH − 0.01 0.2 µA 2.4 − 115.2 kbps 2/3∗VIO − VIO V 1/3∗VIO 1.2 Conditions VIO=1.8 to 3.6V VIO=1.5 to 1.8V VIO=1.8 to 3.6V PWDOWN input low voltage VPDL 0 − PWDOWN input high current IPDH −1.0 0 1.0 µA PWDOWN=VIO PWDOWN input low current IPDL −1.0 0 1.0 µA PWDOWN=0V 2/3∗VIO − VIO V 1/3∗VIO VIO−1.2 V VIO=1.5 to 1.8V TXD/TX-RC input high voltage VTXH 1.2 TXD/TX-RC input low voltage VTXL 0 − TXD/TX-RC input high current ITXH 7.5 15 30 TXD/TX-RC input low current ITXL −1.0 0 VIO−1.2 V VIO=1.8 to 3.6V VIO=1.5 to 1.8V VIO=1.8 to 3.6V VIO=1.5 to 1.8V µA TXD=VIO or TX-RC=VIO 1.0 µA TXD=0V or TX-RC=0V TXD=VIO, R1=4.7Ω, PWDOWN=0V TX-RC=VIO, R1=4.7Ω, PWDOWN=VIO LED anode current (IrDA Mode) ILEDA1 28 40 52 mA LED anode current (RC Mode) ILEDA2 150 200 245 mA RXD output high voltage VRXH VCC−0.4 − VIO V IRXH= −200µA RXD output low voltage VRXL 0 − 0.4 V IRXL=200µA tRR − 35 − ns CL=15pF RXD output rise Time RXD output fall Time RXD output pulse width Receiver latency time tFR − 35 − ns CL=15pF twRXD 1.5 2.3 4.2 µs CL=15pF, 2.4 to 115.2kbps tRT − 100 200 µs zOptical characteristics (Unless otherwise noted, VCC= VIO=3.0V, VLEDVCC=3.0V, Ta=25°C) Parameter Symbol Min. Typ. Max. Unit 880 890 892 nm ILED=50mA, Duty20% ILED=50mA, Duty20%, −20 to 60°C Conditions Peak wave length1 (IrDA Mode) λP1 850 − 900 nm Peak wave length2 (RC Mode) λP2 880 890 920 nm Intensity1 (IrDA Mode) IE1 4 13 28 mW/sr −15° θL 15° R1=4.7Ω 130 mW/sr −15° θL 15° R1=4.7Ω Intensity2 (RC Mode) IE2 30 65 ILED=200mA, Duty20% θL/2 ±15 ±22 − deg Optical pulse width1 (IrDA Mode) TWLED1 1.42 1.63 2.02 µs TXD=1.63µs pulse input R1=4.7Ω Optical pulse width2 (RC Mode) TWLED2 9.5 10 10.5 µs TX-RC=10µs pulse input R1=4.7Ω Tr/Tf − 60 120 ns 10% to 90% − − 25 % Half-angle Rise time / Fall time Optical over shoot Tj −40 − 40 ns Minimum Irradiance in angular Eemin − 3.6 6.8 µW/cm2 −15° θL +15° Maximum Irradiance in angular Eemax 500 − − mW/cm2 −15° θL +15° θD/2 ±15 − − deg TLEDmax 20.5 48 120 µs Edge jitter Input half-angle Maximum emitting time TXD=0 VIO or TX-RC=0 VIO 1. This product is not designed for protection against radioactive rays. 2. This product dose not include laser transmitter. 3. This product includes one PIN photo diode. 4. This product dose not include optical load. 4/9 RPM882-H12 Photo Link Module zLED Operation Mode Table PWDOWN (5pin) TX-RC (4pin) TXD (7pin) LED Emitting Mode IrDA Receiver Operation Condition L L L OFF ON L L IrDA ON L H L H L L RC ON L OFF OFF RC OFF RC OFF L H Notes) Please be sure to set up the TX-RC (4pin) and the TXD (7pin) input to be ''L'' (under 0.3V) except transmitting data (for < 90µs. ON Duty 50%). of TX-RC (4pin) and TXD (7pin) in the table above is supposed to be the pulse input. When either TX-RC (4pin) input TXD (7pin) input keeps the state of ''H'' (more than appproximately 48µs), LED will be turned off due to LED pulse width limiting circuit if the pulse is input from the other terminal. Therefore, don't use as the normal transmitting is impossible. Please input the pulse when both TX-RC (4pin) and TXD (7pin) are ''L''. zInterface operating timing (Emitting side) (1) When TXD output for IrDA and TXD output for remote controller is 1 line. 1 GND VIO VIO VCC VCC Input TX-RC PWDOWN Condition PWDOWN TXD LED Mode Recriver circuit L L OFF ON L IrDA / RC RXD H L IrDA ON OFF OFF RC OFF Controller H TXD LEDA 8 LEDVCC ( "L" ) TX-RC (4pin) Min 1µs Min 1µs Min 1µs Min 1µs TXD (7pin) PWDOWN (5pin) LED Emitting Emitting Mode IrDA RC RC IrDA ∗If TX-RC or TXD input pulse width is wider than 48µs, output LED emitting pulse will be turn off approximately 48µs. 5/9 RPM882-H12 Photo Link Module (2) When TXD output for IrDA and TXD output for controller are different lines. GND 1 VIO VIO VCC RC Transmitting VCC Controller (BU787X etc) TX-RC PWDOWN IrDA / RC RXD Controller TXD LEDA LEDVCC 8 (2-a) RC transmitting mode at IrDA receiver active condition. Input Condition PWDOWN TX-RC TXD LED Mode Recriver circuit L L L OFF ON IrDA ON L L L H L TX-RC (4pin) Min 1µs L RC ON L OFF OFF Min 1µs TXD (7pin) PWDOWN (5pin) LED Emitting Emitting Mode RC IrDA IrDA RC ∗If TX-RC or TXD input pulse width is wider than 48µs, output LED emitting pulse will be turn off approximately 48µs. 6/9 RPM882-H12 Photo Link Module (2-b) RC transmit mode at IrDA receiver power down condition. Input Condition PWDOWN TX-RC TXD LED Mode Recriver circuit L L L OFF ON L L H H L IrDA ON L RC OFF L OFF OFF Min 1µs TX-RC (4pin) Min 1µs Min 1µs Min 1µs TXD (7pin) PWDOWN (5pin) LED Emitting Emitting Mode IrDA RC RC IrDA ∗If TX-RC or TXD input pulse width is wider than 48µs, output LED emitting pulse will be turn off approximately 48µs. (Receiving side) Light input Min 200µs PWDOWN RXD (5pin) RXD (6pin) Pull up to VIO at approximately 300kΩ ∗RXD output width is fixed approximately 2.3µs. Note RXD output become stable after 200µs since PWDOWN is changed from H to L. RXD output could be unstable at H to L within 200µs. 7/9 RPM882-H12 Photo Link Module zAttached components Recommended values Part symbol Recommended value Notice C1 1µF, tantalum or ceramic Ex.) TCFGA1A105M8R (ROHM) Bigger capacitance is recommended with much noise from power supply R1 4.7Ω±5%, 1/8W (VLEDVCC=3V) At LED Emitting Duty=20% [LED current set-up method for Remote control mode] In case of using R1 with different condition from the above, formula is as follows : LED resistance value : R1[Ω], LED average consumption current : ILED[mA], Supply voltage : VLEDVCC[V], minimum necessary of irradiant intensity le1 [mW / sr] (Including LED’s distribution within ±15deg) R1=166 × (VLEDVCC−1.28) / le1−5.0 ILED=Duty × (VLEDVCC−1.28) / (R1+3.5) Duty : LED duty at emitting ∗ Please set up to be ILED / Duty < 250[mA] (Duty ≤ 50%) ∗ At IrDA Mode, LED current is constantly approximately 40mA. (Reference) In case of using R1, typical intensity (le1typ) and maximum intensity (le1max) on axis are described as below. le1typ=300 × (VLEDVCC−1.28) / (R1+3.5) le1max=600 × (VLEDVCC−1.28) / (R1+3.5) zNotes 1) LEDVCC (8pin), VCC (3pin) and VIO (2pin) • Other power source can be used difference between LEDVCC and VCC and VIO. (VIO < VCC + 0.3V) 2) Caution in designing board lay-out To get maximum potential from RPM882-H12, please keep in mind following instruction. • The line of RXD (6pin) should be connected at backside via through hole close to RPM882-H12 pin lead. Better not to be close to photo diode side (1pin). ⇒This is to minimize feedback supplied to photo diode from RXD. • As for C1 between 1-3 pin should be placed close to RPM882-H12. • Better to be placed more than 1.0cm in radius from photo diode (pin1 side) and also away from the parts which generates noise, such as DC / DC converter. 3) Notes • Please be sure to set up the TX-RC (4pin) and the TXD (7pin) input to be “L” (under 0.3V) except transmitting data (for < 90µs, ON duty ≤ 50%). • Power down current might increase if exposed by strong light (ex. direct sunlight) at powerdown mode. • Please use by the signal format at IrDA operating mode which is specified by IrDA Ver1.2 (2.4k to 115.2kbps). There might be on error if used by different signal format. • Please pay attention to the lens carefully. Dusts of scratch on the lens may effect the characteristics of product. Please handle it with care. 8/9 RPM882-H12 Photo Link Module 4) Eye safe IEC60825-1 (IEC60825-1 amendment2), Class 1 Eye Safe. • 5) LED current derating and amdient temperature The relation between LED peak current and maximum ambient temperature is shown below. We recommend you to use within the range as indicated in below. MAXIMUM LED PEAK CURRENT : Iledp (mA) When glass-epoxy board (70×70×1.6mm) mounted. 300 Duty:10% 250 Duty:50% 200 Duty:40% Duty:30% 150 Duty:20% 100 50 0 −20 0 20 40 60 80 100 AMBIENT TEMPERATURE : Ta (°C) zExternal dimensions (Unit : mm) 0.84±0.1 1.75 LED PinPD 0.15±0.1 2.0 2.4 3.0 0.6 3.0 8.0 5.6 2.49 0.56 8 A Part Size (Shield Case underside size) 0.37±0.1 0.75 1 P0.95×7=6.65 7.6 3.0 0.6±0.1 0.68±0.1 NOTE 0.6±0.1 2.72 2.8 A TOLERANCE : ±0.2mm COPLANARITY : 0.1mmMAX UNIT : mm ETH450 9/9 Appendix Notes No technical content pages of this document may be reproduced in any form or transmitted by any means without prior permission of ROHM CO.,LTD. The contents described herein are subject to change without notice. The specifications for the product described in this document are for reference only. Upon actual use, therefore, please request that specifications to be separately delivered. Application circuit diagrams and circuit constants contained herein are shown as examples of standard use and operation. Please pay careful attention to the peripheral conditions when designing circuits and deciding upon circuit constants in the set. Any data, including, but not limited to application circuit diagrams information, described herein are intended only as illustrations of such devices and not as the specifications for such devices. ROHM CO.,LTD. disclaims any warranty that any use of such devices shall be free from infringement of any third party's intellectual property rights or other proprietary rights, and further, assumes no liability of whatsoever nature in the event of any such infringement, or arising from or connected with or related to the use of such devices. Upon the sale of any such devices, other than for buyer's right to use such devices itself, resell or otherwise dispose of the same, no express or implied right or license to practice or commercially exploit any intellectual property rights or other proprietary rights owned or controlled by ROHM CO., LTD. is granted to any such buyer. Products listed in this document are no antiradiation design. The products listed in this document are designed to be used with ordinary electronic equipment or devices (such as audio visual equipment, office-automation equipment, communications devices, electrical appliances and electronic toys). Should you intend to use these products with equipment or devices which require an extremely high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), please be sure to consult with our sales representative in advance. About Export Control Order in Japan Products described herein are the objects of controlled goods in Annex 1 (Item 16) of Export Trade Control Order in Japan. In case of export from Japan, please confirm if it applies to "objective" criteria or an "informed" (by MITI clause) on the basis of "catch all controls for Non-Proliferation of Weapons of Mass Destruction. Appendix1-Rev1.1
RPM882-H12E4 价格&库存
很抱歉,暂时无法提供与“RPM882-H12E4”相匹配的价格&库存,您可以联系我们找货
