SLI-570Y2T3F
SLI-570Y2T3F
    ROHM(罗姆)
    径向
    黄色 LED 指示 - 分立 2.1V 径向
SLI-570Y2T3F 数据手册
SLI-570x/SLA-570x Series ■Features • Viewing angle 2θ 1/2 : 20° (SLI-570 Series) • Viewing angle 2θ 1/2 : 25° (SLA-570 Series) • High brightness Color Type Data Sheet ■Outline U U2 D Y Y2 M ■Dimensions ■Recommended Solder Pattern Tolerance : ±0.2 (unit : mm) (unit : mm) ■Specifications Absolute Maximum Ratings (Ta=25ºC) Emitting Part No. Power Forward Peak Forward Electrical and Optical Characteristics (Ta=25ºC) Reverse Forward Voltage VF Reverse Current IR Peak Wavelength λP Color Dissipation Current Current Voltage PD(mW) IF(mA) IFP(mA) VR(V) Typ. Topr(ºC) Tstg(ºC) (V) IF (mA) Max. (µA) VR Typ. (V) (nm) IF Red SLI-570DT AlGaInP Orange 50 200*2 9 1.9 -30〜+85 -40〜+100 SLA-570MT 20 100 9 611 20 Yellow 591 2.1 GaP Yellowish green 75 25 60* 1 4 -25〜+85 -30〜+100 2.3 IF 2200 4000 SLI-570YT SLI-570Y2T Typ. 900 3000 630 125 Min. (mA) (mcd) (mcd) (mA) SLI-570UT SLI-570U2T Luminous Intensity IV Operating Temp. Storage Temp. Chip Structure 900 3000 20 610 2500 2200 5200 20 10 4 563 200 470 *1 : Duty1/5, 200Hz, *2 :Duty1/10 1kHz ________________________________________________________ www.rohm.com 1/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series] [Data Sheet]      ■Electrical Characteristics Curves Reference Fig.2 Luminous Intensity      Atmosphere Temperature 1000 FORWARD CURRENT : IF [mA] Ta=25ºC 100 10 SLI-570DT 1 1.5 2.0 2.5 RELATIVE LUMINOUS INTENSITY [a.u.] Fig.1 Forward Current - Forward Voltages FORWARD VOLTAGE : VF [V] 1 0.1 0.01 FORWARD CURRENT : IF [mA] 100 MAXIMUM FORWARD CURRENT : [mA] RELATIVE LUMINOUS INTENSITY Ta=25ºC 10 1.2 1.0 0.8 0.6 SLI-570DT 0.4 -40 -20 0 20 40 60 80 100 Fig.4 Derating 10 1 IF=20mA 1.4 ATMOSPHERE TEMPERATURE : Ta [ºC] Fig.3 Luminous Intensity - Forward Current SLI-570DT 1.6 SLI-570DT 50 40 30 20 10 0 -40 -20 0 20 40 60 80 100 AMBIENT TEMPERATURE : Ta [ºC] ________________________________________________________ www.rohm.com 2/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series] [Data Sheet]      ■Electrical Characteristics Curves Reference Fig.2 Luminous Intensity      Atmosphere Temperature FORWARD CURRENT : IF [mA] 50 Ta=25ºC 20 10 5.0 SLA-570MT 2.0 1.0 1.5 2.0 2.5 3.0 RELATIVE LUMINOUS INTENSITY [a.u.] Fig.1 Forward Current - Forward Voltages RELATIVE LUMINOUS INTENSITY 5 Ta=25ºC 1 0.1 SLA-570MT 10 FORWARD CURRENT : IF [mA] 1.2 1.0 0.8 0.6 SLA-570MT 0.4 -40 -20 0 20 40 60 80 100 Fig.4 Derating 100 MAXIMUM FORWARD CURRENT : [mA] Fig.3 Luminous Intensity - Forward Current 1 IF=20mA ATMOSPHERE TEMPERATURE : Ta [ºC] FORWARD VOLTAGE : VF [V] 0.01 1.4 40 30 20 10 SLA-570MT 0 -40 -20 0 20 40 60 80 100 AMBIENT TEMPERATURE : Ta [ºC] ________________________________________________________ www.rohm.com 3/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series] [Data Sheet]      ■Electrical Characteristics Curves Reference Fig.2 Luminous Intensity      Atmosphere Temperature 100 FORWARD CURRENT : IF [mA] Ta=25ºC 10 SLI-570UT SLI-570U2T SLI-570YT SLI-570Y2T 1 1.0 1.5 2.0 2.5 3.0 RELATIVE LUMINOUS INTENSITY [a.u.] Fig.1 Forward Current - Forward Voltages FORWARD VOLTAGE : VF [V] 2 1 SLI-570UT SLI-570U2T SLI-570YT SLI-570Y2T 0 0 10 20 30 40 50 FORWARD CURRENT : IF [mA] 1.4 1.2 1.0 0.8 SLI-570UT SLI-570U2T SLI-570YT SLI-570Y2T 0.6 0.4 -40 -20 0 20 40 60 80 100 Fig.4 Derating MAXIMUM FORWARD CURRENT : [mA] RELATIVE LUMINOUS INTENSITY Ta=25ºC IF=20mA ATMOSPHERE TEMPERATURE : Ta [ºC] Fig.3 Luminous Intensity - Forward Current 3 1.6 60 50 40 30 20 10 0 -40 SLI-570UT SLI-570U2T SLI-570YT SLI-570Y2T -20 0 20 40 60 80 100 AMBIENT TEMPERATURE : Ta [ºC] ________________________________________________________ www.rohm.com 4/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series] [Data Sheet]      ■Viewing Angle Reference SCANNING ANGLE (deg) SCANNING ANGLE (deg) 0 10 10 20 20 ■SLI-570U2T SLI-570Y2T 30 30 40 40 60 60 70 70 80 80 90 100 ■SLI-570U/D/YT 50 50 50 0 50 90 100 RELATIVE INTENSITY (%) RELATIVE INTENSITY (%) SCANNING ANGLE (deg) ■SLA-570MT RELATIVE INTENSITY (%) ________________________________________________________ www.rohm.com 5/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series] [Data Sheet]      ■Rank Reference of Brightness* Red(U) Rank Iv (mcd) SLI-570UT SLI-570U2T Orange(D) Rank Iv (mcd) SLI-570DT Yellow (Y) Rank Iv (mcd) SLI-570YT SLI-570Y2T (Ta=25ºC, IF=20mA) XE 47〜 XF XG XH XJ XK XL XM 68 68〜 100 100〜150 150〜220 220〜330 330〜470 470〜680 680〜1000 XN XP 1000〜1500 1500〜2200 XQ XR XS XT XU 2200〜 3300 3300〜4700 4700〜6800 6800〜10000 10000〜15000 (Ta=25ºC, IF=20mA) XE 47〜 XF XG XH XJ XK XL XM 68 68〜 100 100〜150 150〜220 220〜330 330〜470 470〜680 680〜1000 XN XP 1000〜1500 1500〜2200 XQ XR XS XT XU 2200〜 3300 3300〜4700 4700〜6800 6800〜10000 10000〜15000 (Ta=25ºC, IF=20mA) XE 47〜 XF XE 47〜 XG XH XJ XK XL XM 68 68〜 100 100〜150 150〜220 220〜330 330〜470 470〜680 680〜1000 Yellowish Green(M) Rank Iv (mcd) SLA-570MT *Measurement tolerance:±10% XN XP 1000〜1500 1500〜2200 XQ XR XS XT XU 2200〜 3300 3300〜4700 4700〜6800 6800〜10000 10000〜15000 (Ta=25ºC, IF=20mA) XF XG XH XJ XK XL XM 68 68〜 100 100〜150 150〜220 220〜330 330〜470 470〜680 680〜1000 XN XP 1000〜1500 1500〜2200 XQ XR XS XT XU 2200〜 3300 3300〜4700 4700〜6800 6800〜10000 10000〜15000 ________________________________________________________ www.rohm.com 6/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series] [Data Sheet]      ■Part No. Construction *"-"will be taken out for emitting color Special Code will be applied for Chromaticity rank Rank sign WB/B/E series. Emitting color WB/B/E series. (for white LED) (Brightness Rank)* S L Series name I - 5 7 0 Package type U 2 Emitting Color T T Resin Color 3 1-Die Circular Type High Brightness LED Lamps V Red R DiffusedColored SLI 1-Die Circular Type Low Current High Brightness LED Lamps U Red U DiffusedColored SLR 1-Die Circular Type LED Lamps U2 Red Y DiffusedColored SLD 1-Die Oval Type High Brightness LED Lamps D Orange G DiffusedColored Y Yellow C Y2 Yellow RC P Green E Green B Blue WB White XS Taping Specification SLA M Yellowish green 2 3F 1-Element straight bulk T□□ See Taping specifications Transparent Colored T Transparent Coloreless *Concerning the Brightness rank. *Please refer to the rank chart above for luminous intensity classification. *Part name is individual for each rank. *When shipped as sample,the part name will be a representative part name. General products are free of ranks. Please contact sales if rank appointment is needed. ________________________________________________________ www.rohm.com 7/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series] [Data Sheet]      ■ATTENTION POINTS IN HANDLING Visual light emitting diode does not contain reinforcement materials such as glass fillers. Therefore if sudden thermal and mechanical shock are given, destruction or inferiority of luminous intensity may occur. Please take care of the handling. ■FIXATION METHOD 1.ATTENTION POINTS  (1) Please do not give excessive heat over storage temperature to resin.   In case that the product has to be heated in oven for the glue fixing of surface mount parts,   this LED should be mounted after the glue fixing.  (2) Please avoid stress to resin at high temperature. 2. TERMINATION PROCESSING  (1) In case of termination processing, please fix the   termination  (2) Processing position, and process the reverse side   of LED body.   If stress is given during processing, It may cause   non-lighting failure.  (3) Please process before soldering. <No good> <Good> To be fixed To be fixed 3. ASSEMBLY ON PC BOARD  (1) In case of soldering on PCB, If the operation is done with stress, it may cause non-lighting   failure during soldering or using. Please design the through-holes of PCB suitable for lead pins   space or lead pins space after forming to avoid the physical stress on resin. <Good> <No good> <Good> <2 lead pins type> <3 lead pins type>  (2) Using spacer between LEDʼs body and PCB is recommended.   In case of direct mount on PCB(SLR/SLI-343 series), please take care about clinch of LED pins   to avoid the remained stress and solder heat stress.   Enough evaluation is requested before deciding assembly and soldering conditions. Please consult with us if any problems in the evaluation stage. <3 lead pin type> <2 lead pin type> Min.15° Die bonding side Min.45° Min.15° Min.45 Min.45° Die bonding side ________________________________________________________ www.rohm.com 8/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series] [Data Sheet]      4.SOLDERING(Sn-3Ag-0.5Cu)  (1) Please make soldering rapidly under the following temperature and time conditions.  (2) Please avoid stress to LED lamp during soldering.  (3) In case of double peak flow soldering, the temperature gap during 1st and 2nd soldering to be   less than 100 degree C. <Recommendable soldering conditions> SOLDERINGTEMP OPERATION TIME ARTIICLE Pre-heat Max. 100℃ 60sec Max. Soldering Dip Soldering Bath Soldering Iron Max. 265℃ 5sec Max. Max. 400℃ 3sec Max. Remarks - In case of double peak flow soldering, the operation time is counted from the beginning of 1st peak to the end of 2nd peak. The iron should not touch the LEDʼs body. 5.CLEANING  In case of cleaning, some solvents may cause damage of resin or cause non-lighting failure,  so please check the solvent before actual use.  The recommendable cleaning solvent is alcoholic one such as isopropyl alcohol. <RECOMMENDABLE CLEANING CONDITIONS> METHOD CONDITIONS Temperature of solvent :Max. 45℃ Cleaning by solvent Immersion time :Max. 3min Ultrasonic out :Max. 15W/Liter Cleaning by solvent Cleaning time :Max. 3min 6.RECOMMENDABLE ROUND PATTERN   Round pattern depends on the material PCB, density and circuit arrangement.   Our recommendation is as follow : <3 lead pin type/2.0mm pitch> ±0.1 ±0.1 ±0.1 1.5 2.0 2.0 2.5 or 5.0 1.0 1.0 1.0 2.0 2.5 *Unit : mm *Lead types : □0.4mm □0.5mm 2.0 2.5 φ2.0 ■ATTENTION ON STORAGING  Storage in dry box is most desirable, but if it is not possible, we recommend following conditions. <RECOMMENDABLE STORAGE CONDITIONS> Temperature Humidity ARTICLE Expiration Date CONDITIONS 5〜30℃ Max.60%RH Within 1 year Poor storage conditions may cause some failure as bellow.  (1) Lead pins may corrode if it is stored in the environment of high temperature and humidity   and lead to defective soldering.  (2) In case of soldering after LEDʼs body absorb moisture highly, destruction or inferiority of   luminous intensity may occur. ________________________________________________________ www.rohm.com 9/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 [SLI-570x/SLA-570x series]      [Data Sheet] ■APPLICATION METHOD 1.Precaution for Drive System and Off Mode    ・Design the circuit without the electric load exceeding the ABSOLUTE MAXIMUM RATING that    applies on the products.    ・If drive by constant voltage, it may cause current deviation of the LED and result in deviation of    luminous intensity, so we recommend to drive by constant current. (Deviation of VF Value will    cause deviation of current in LED.) ・Furthermore, for off mode, please do not apply voltage neither forward nor reverse. Especially, for the products with the Ag-paste used in the die bonding, thereʼs high possibility to cause electro migration and result in function failure. 2. Operation Life Span    Thereʼs possibility for intensity of light drop according to working conditions and environments     (applied current, surrounding temperature and humidity, corrosive gases ), please call our Sales    staffs for inquiries about the concerned application below.    (1) Longtime intensity of light life    (2) On mode all the time 3. Usage    The Product is LED. We are not responsible for the usage as the diode such as Protection Chip, Rectifier, Switching and so on. ■OTHERS 1. Surrounding Gas    Notice that if it is stored under the condition of acid gas (chlorine gas, sulfured gas) or alkali gas     (ammonia), it may result in low soldering ability (caused by the change in quality of the plating    surface ) or optical characteristics changes (light intensity, chrominance) and change in quality of    die bonding (Ag-paste) materials. All of the above will cause function failure of the products.    Therefore, please pay attention to the storage environment for mounted product (concern the    generated gas of the surrounding parts of the products and the atmospheric environment). 2. Electrostatic Damage    The product is part of semiconductor and electrostatic sensitive, thereʼs high possibility to be    damaged by the electrostatic discharge.    Please take appropriate measures to avoid the static electricity from human body and earthing   setting of production equipment. The resistance values of electrostatic discharge (actual values)   are different varies with products, therefore, please call our Sales staffs for inquiries. 3. Electromagnetic Wave Applications with strong electromagnetic wave such as, IH cooker, will influence the reliability of LED, therefore please evaluate before using it. ________________________________________________________ www.rohm.com 10/10 ©2016 ROHM Co., Ltd. All rights reserved 2017.9 - Rev.004 Notice Notes 1) The information contained herein is subject to change without notice. 2) Before you use our Products, please contact our sales representative and verify the latest specifications : 3) Although ROHM is continuously working to improve product reliability and quality, semiconductors can break down and malfunction due to various factors. Therefore, in order to prevent personal injury or fire arising from failure, please take safety measures such as complying with the derating characteristics, implementing redundant and fire prevention designs, and utilizing backups and fail-safe procedures. ROHM shall have no responsibility for any damages arising out of the use of our Poducts beyond the rating specified by ROHM. 4) Examples of application circuits, circuit constants and any other information contained herein are provided only to illustrate the standard usage and operations of the Products. The peripheral conditions must be taken into account when designing circuits for mass production. 5) The technical information specified herein is intended only to show the typical functions of and examples of application circuits for the Products. ROHM does not grant you, explicitly or implicitly, any license to use or exercise intellectual property or other rights held by ROHM or any other parties. ROHM shall have no responsibility whatsoever for any dispute arising out of the use of such technical information. 6) The Products are intended for use in general electronic equipment (i.e. AV/OA devices, communication, consumer systems, gaming/entertainment sets) as well as the applications indicated in this document. 7) The Products specified in this document are not designed to be radiation tolerant. 8) For use of our Products in applications requiring a high degree of reliability (as exemplified below), please contact and consult with a ROHM representative : transportation equipment (i.e. cars, ships, trains), primary communication equipment, traffic lights, fire/crime prevention, safety equipment, medical systems, servers, solar cells, and power transmission systems. 9) Do not use our Products in applications requiring extremely high reliability, such as aerospace equipment, nuclear power control systems, and submarine repeaters. 10) ROHM shall have no responsibility for any damages or injury arising from non-compliance with the recommended usage conditions and specifications contained herein. 11) ROHM has used reasonable care to ensur the accuracy of the information contained in this document. However, ROHM does not warrants that such information is error-free, and ROHM shall have no responsibility for any damages arising from any inaccuracy or misprint of such information. 12) Please use the Products in accordance with any applicable environmental laws and regulations, such as the RoHS Directive. For more details, including RoHS compatibility, please contact a ROHM sales office. ROHM shall have no responsibility for any damages or losses resulting non-compliance with any applicable laws or regulations. 13) When providing our Products and technologies contained in this document to other countries, you must abide by the procedures and provisions stipulated in all applicable export laws and regulations, including without limitation the US Export Administration Regulations and the Foreign Exchange and Foreign Trade Act. 14) This document, in part or in whole, may not be reprinted or reproduced without prior consent of ROHM. Thank you for your accessing to ROHM product informations. More detail product informations and catalogs are available, please contact us. ROHM Customer Support System http://www.rohm.com/contact/ www.rohm.com © 201 ROHM Co., Ltd. All rights reserved. R1102A
SLI-570Y2T3F 价格&库存
很抱歉,暂时无法提供与“SLI-570Y2T3F”相匹配的价格&库存,您可以联系我们找货
SLI-570Y2T3F
    • 1+1.543311+0.18718
    • 10+1.2928310+0.15680
    • 50+1.1473850+0.13916
    • 100+1.01810100+0.12348
    • 500+1.02618500+0.12446
    • 1000+1.018101000+0.12348
    • 2000+1.010022000+0.12250
    • 4000+1.010024000+0.12250
    库存:2940
