R F
C o m p o n e n t s
Balun transformers
Wound SMD
ATB series
RoHS
REACH
SVHC-Free
Cl
Br
Pb
Halogen
Free
Lead
Free
ATB3225 type
FEATURES
The ATB3225 case size is L3.2×W2.5×H2.3mm.
The case size is smaller than conventional Baluns.
The frequency band width for ATB3225-75011CT is 5 to 200MHz, for ATB3225-75032CT is 5 to 100MHz, for ATB3225-75034CT is 1 to
100MHz, and for ATB3225-50011CT is 5 to 100MHz.
Low insertion loss and good balance parameters.
APPLICATION
Cable modem
PART NUMBER CONSTRUCTION
ATB
3225
Series name
L×W×H
dimensions
(mm)
3.2×2.5×2.3
750
Impedance
() at 100MHz
750
75
500
50
11
CT
Impedance ratio
Type
11
32
34
1:1
3:2
3:4
CT
T
001
Packaging style
Internal code
Center tap
T
ø180mm reel
Amplitude
unbalance
(dB)max.
0.1
0.5
1
0.1
0.1
0.5
Phase
difference
(deg.)
180±2
180±5
180±10
180±10
180±2
180±5
CHARACTERISTICS SPECIFICATION TABLE
DC
resistance
( )max.
Frequency
Insertion loss
range
(MHz)
(dB)max.
5 to 65
0.8
0.7
1:1 (75 :75 )
5 to 200
1.5
0.7
3:2 (75 :50 )
5 to 100
2
0.7
3:4 (75 :100 )
1 to 100
2
5
0.8
0.7
1:1(50 : 50 )
100
1.5
Temperature derating was considered for the rated current.
Return loss
Impedance ratio
(dB)min.
15
10
5
5
15
10
Part No.
ATB3225-75011CT-T001
ATB3225-75032CT-T001
ATB3225-75034CT-T000
ATB3225-50011CT-T000
Measurement equipment
Measurement item
Product No.
Insertion loss
E5071B
Return loss
E5071B
Amplitude unbalance
E5071B
Phase difference
E5071B
* Equivalent measurement equipment may be used.
Manufacturer
Keysight Technologies
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
(1/5)
20220119
rf_balun_atb3225_en.fm
R F
C o m p o n e n t s
ATB3225 type
FREQUENCY CHARACTERISTICS
INSERTION LOSS
Return loss (dB)
Insertion loss (dB)
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
RETURN LOSS
100
150
Frequency (MHz)
5
10
15
200
100
150
Frequency (MHz)
190
188
186
184
182
180
178
176
174
172
170
Phase unbalance (dB)
PHASE UNBALANCE
1.0
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
0.0
Amplitude unbalance (dB)
AMPLITUDE UNBALANCE
100
150
Frequency (MHz)
200
100
150
Frequency (MHz)
200
200
0.0
0.5
1.0
1.5
2.0
2.5
3.0
3.5
4.0
4.5
5.0
RETURN LOSS
Return loss (dB)
Insertion loss (dB)
INSERTION LOSS
100
150
Frequency (MHz)
200
100
150
Frequency (MHz)
100
150
Frequency (MHz)
200
PHASE BALANCE
Phase balance (dB)
Amplitude balance (dB)
15
25
AMPLITUDE BALANCE
5.0
4.5
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
0.0
5
10
200
190
188
186
184
182
180
178
176
174
172
170
100
150
Frequency (MHz)
200
(2/5)
20220119
R F
C o m p o n e n t s
ATB3225 type
2
3
4
5
6
7
8
9
10
RETURN LOSS
Return loss (dB)
Insertion loss (dB)
INSERTION LOSS
15
1
10
Frequency (MHz)
1
1
10
Frequency (MHz)
100
PHASE BALANCE
Phase balance (dB)
5.0
4.5
4.0
3.5
3.0
2.5
2.0
1.5
1.0
0.5
0.0
30
100
AMPLITUDE IMBALANCE
5
10
10
Frequency (MHz)
100
185
184
183
182
181
180
179
178
177
176
175
1
10
Frequency (MHz)
100
INSERTION LOSS
RETURN LOSS
Return loss (dB)
Insertion loss (dB)
0.0
1.0
1.5
2.0
2.5
3.0
60
Frequency (MHz)
80
100
60
Frequency (MHz)
60
Frequency (MHz)
80
100
PHASE BALANCE
Phase balance (dB)
15
25
AMPLITUDE IMBALANCE
1.0
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
0.0
5
10
80
100
190
188
186
184
182
180
178
176
174
172
170
60
Frequency (MHz)
80
100
(3/5)
20220119
R F
C o m p o n e n t s
ATB3225 type
SHAPE & DIMENSIONS
PACKAGING STYLE
REEL DIMENSIONS
3.2±0.2
2.5±0.2
2.0±0.5
3
4
2
5
1
6
6
2
60 +1
–0
(0.9)
(0.18)
(0.45)
(0.45)
1
(0.4)
(0.9)
(1.8)
2.3±0.1
Mark for direction
9 +1
–0
ø13.0±0.2
(ø21)
5
13±1.4
ø180+0/–3
3
4
Dimensions in mm
Dimensions in mm
Sprocket
hole
0.3±0.1
ø1.5 +0.1
–0
4±0.1
1.75±0.1
2.0
ø1.1±0.1
Cavity
2.0±0.05
8±0.2
B
0.3
2.25
0.55
1.0
3.5±0.05
TAPE DIMENSIONS
RECOMMENDED LAND PATTERN
4.0
4±0.1
A
K
Dimensions in mm
Dimensions in mm
CIRCUIT DIAGRAM
Unbalance port
1
Type
ATB3225
Balance port
3
5
2
A
(2.9)
GND
or
Vcc
K
(2.5)
500 to 560min.
160min.
6
B
(3.6)
Taping
440min.
4
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Drawing direction
Dimensions in mm
Natural
cooling
Peak
PACKAGE QUANTITY
245°C
Package quantity
Temperature
230°C
1000 pcs/reel
230°C
TEMPERATURE RANGE, INDIVIDUAL WEIGHT
180°C
5s max.
150°C
60 to 120s
10 to 30s
Operating
Storage
temperature range
temperature range
–40 to +85°C
–40 to +85°C
The storage temperature range is for after the assembly.
Individual
weight
75 mg
Time
(4/5)
20220119
R F
C o m p o n e n t s
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using this products.
REMINDERS
The storage period is within 6 months. Be sure to follow the storage conditions (temperature: 5 to 40°C, humidity: 10 to 75% RH or
less).
If the storage period elapses, the soldering of the terminal electrodes may deteriorate.
Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.).
Soldering corrections after mounting should be within the range of the conditions determined in the specifications.
If overheated, a short circuit, performance deterioration, or lifespan shortening may occur.
When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to
the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions.
Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal
design.
Carefully lay out the coil for the circuit board design of the non-magnetic shield type.
A malfunction may occur due to magnetic interference.
Use a wrist band to discharge static electricity in your body through the grounding wire.
Do not expose the products to magnets or magnetic fields.
Do not use for a purpose outside of the contents regulated in the delivery specifications.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society,
person or property.
If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions
set forth in the each catalog, please contact us.
(1) Aerospace/aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment.
(5/5)
20220119
很抱歉,暂时无法提供与“ATB3225-75034CT”相匹配的价格&库存,您可以联系我们找货
