The products in this catalog are not recommended for new design
RF Components
Isolator
SMD
Pb
RoHS
Lead
Free
CU4S0508 Series
PART NUMBER CONSTRUCTION
CU4S0508
Series name
Direction
A
B
T
Center Frequency
(MHz)
CW
CCW
Control Number
cut off after the decimal point
DIRECTION OF CIRCULATION
ClockWise(CW): A
CounterClockWise(CCW): B
Marking
Marking
OUT
IN
IN
OUT
ELECTRICAL CHARACTERISTICS
Frequency
range
Center
frequency
Isolation
Insertion
loss
V.S.W.R.
Zo=50
Handling
power
Reflection
power
(MHz)
(MHz)
(dB)
min.
10
10
(dB)
max.
1.00
1.00
max.
1.8
1.8
(W)
max.
5
5
(W) 4
max.
2
2
3300 to 3600
3500 to 3700
3450
3600
Part Number
ClockWise
CU4S0508AT-3450-00
CU4S0508AT-3600-00
CounterClockWise
CU4S0508BT-3450-00
CU4S0508BT-3600-00
Characteristic Impedance () : 50(Nominal)
4 To be kept below +105deg.C at the bottom surface
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +105
Storage temperature
(°C)
–40 to +105
Please be sure to request delivery specifications that provide further details on the features and specifications of the products for proper and safe use.
Please note that the contents may change without any prior notice due to reasons such as upgrading.
20200416
rf_isolator_cu4s0508_en.fm
RF Components
CU4S0508 Series
RECOMMENDED REFLOW PROFILE
SHAPES AND DIMENSIONS
5.0±0.3
2.5±0.2
(4)
(2)
(5)
(1)
(6)
Working
Soldering
Peak
260°C max.
250°C
250°C
Terminal (Au plating)
Metal parts other than a terminal.
(GND electric potential)
T: Temperature
(3)
Soaking
5.0±0.3
[Top view]
230°C
230°C
180°C
within 10s
150°C
Tolerance unless otherwise specified: ±0.2
Coplanarity : 0.1max.
[Bottom view]
60 to 120s
5.2±0.3
30 to 60s
3.0
0.8
1.6
0.8
1.6
0.8
Terminal functions
1
OUT
2
GROUND
3
GROUND
4
GROUND
5
GROUND
6
IN
Rotation Clockwise
IN
GROUND
GROUND
GROUND
GROUND
OUT
Counter
Clockwise
t: Time
PACKAGING STYLE
REEL DIMENSIONS
Dimensions in mm
0.4
0.4
[Marking]
ClockWise(CW): A
(3)
(4)
(3)
(4)
(2)
(5)
(2)
(5)
(1)
(6)
(1)
(6)
Marking
Marking
330
Dimensions in mm
RECOMMENDED LAND PATTERN
Pulling side
1.1
4.2
1.1
Dimensions in mm
RECOMMENDED PC BOARD PATTERN
GND
5.6±0.1
GND
GND
I/O
Isolator Outline
GND
GND
I/O
3.2±0.1
5.6±0.1
12.0±0.1
1.0
1.6
1.5+0.1/–0 2.0±0.1 4.0±0.1
7.5±0.1 1.75±0.1
1.0
1.6
Reel side
16.0+0.3/–0.1
1.0
TAPE DIMENSIONS
0.3±0.05
Dimensions in mm
4.2
0.6min.
PACKAGE QUANTITY
1.6
Standard package quantity
1000 pieces/reel
I/O
0.6min.
(1.0)
Connect to
50Ω Stripline
With I/O land.
I/O
(1.1) 1min.
Dimensions in mm
20200416
RF Components
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
Please do not bring the magnet close to the product (Recommending is separating to 50cm or more). An electric
characteristic might be deteriorated.
The magnetic field of 5mT or more must not go into the product when you make the magnet approach.
Moreover, please do not touch a soft magnetic material such as iron (Recommending is separating to 10mm or
more). An electric characteristic might be deteriorated. An electric characteristic changes when bringing it close
within 10mm(reversible change).
There is a leakage of some magnetism (0.3T or less) from the product.
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
20200416
很抱歉,暂时无法提供与“CU4S0508BT-3600-00”相匹配的价格&库存,您可以联系我们找货
