May. 2021 Ver.5.0
TDK Corporation
Multilayer Band Pass Filter
For N77
DEA Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DEA163750BT-3059A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
May. 2021 Ver.5.0
TDK Corporation
DEA163750BT-3059A1
■ SHAPES AND DIMENSIONS
[Top View]
[Bottom View]
(4)
(1)
(4)
(3)
(3)
(2)
(1)
(2)
Dimensions (mm)
L
W
T
a
b
c
d
e
f
1.60 0.80 0.65 0.225 0.30 0.40 0.65 0.22 0.21
+/-0.10 +/-0.10
Max
+/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05
Terminal functions
Input / Output Port
(1)
GND
(2)
(3)
(4)
Output / Input Port
GND
■ TERMINATION FINISH
Material
Au plate
May. 2021 Ver.5.0
TDK Corporation
DEA163750BT-3059A1
■ ELECTRICAL CHARACTERISTICS
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +85 °C )
VSWR (Input Port)
VSWR (Output Port)
Attenuation (dB)
3300 to
3300 to
TDK Spec
Min. Typ. Max.
4200 0.69 0.85
4200 1.20
3300
3300
1710
5150
4200
4200
2690
5850
( Measurement )
Frequency (MHz)
Characteristic Impedance (ohm)
Ta = +25+/-5°C
to
to
to
to
1.43 1.92
1.37 1.92
14
16
10
18
50 (Nominal)
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W) *1
Human Body Model : HBM
Machine Model : MM
Charged Device Model : CDM
TDK Spec
Conditions
–40 to +85 °C
–40 to +85 °C
Frequency (MHz)
CW
1
3300 to 4200
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
@Each Port (V)
+/-500
Humidity : 60%RH max
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
May. 2021 Ver.5.0
TDK Corporation
DEA163750BT-3059A1
■ FREQUENCY CHARACTERISTICS
Attenuation
Insertion Loss
2690
5150
5850
15.87
18.54
17.85
26.43
0.0
dB
dB
dB
dB
0.5
0.69 dB
0.57 dB
3300 MHz
4200 MHz
1.24
1.09
1.0
30
2.0
40
2.5
50
3.0
60
4000
6000
8000
3000
10000
3500
Frequency[MHz]
4000
4500
Frequency[MHz]
Common Port Return Loss
VSWR
3.0
3300 MHz
4200 MHz
19.50
26.91
dB
dB
VSWR
10
Return Loss[dB]
3300 MHz
4200 MHz
Insertion Loss[dB]
Attenuation[dB]
10
MHz
MHz
MHz
MHz
2.5
30
1.5
1.0
40
3000
3500
4000
Frequency[MHz]
4500
3000
3200
3400
3600
3800
4000
4200
4400
Frequency[MHz]
May. 2021 Ver.5.0
TDK Corporation
DEA163750BT-3059A1
■ RECOMMENDED LAND PATTERN
Unit : [mm]
■ EVALUATION BOARD
05
Material & Layer
Copper Surface Pattern
FR-4
Inner GND
FR-4
Copper Bottom GND
Thickness
0.035 mm
0.10 mm
0.018 mm
0.30 mm
0.035 mm
unit : mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
May. 2021 Ver.5.0
TDK Corporation
DEA163750BT-3059A1
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
May. 2021 Ver.5.0
TDK Corporation
DEA163750BT-3059A1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Sprocket hole
K
Loading Direction
E
J
C
D
A
B
B
t
H
Dimensions (mm)
A
B
C
0.97 1.8 8.0
+/-0.05 +/-0.05
+/-0.2
G
F
D
3.5
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
K
0.8
t
0.25
+/-0.05
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DEA163750BT-3059A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.46157
- 50+1.20118
- 150+1.08962
- 500+0.95040
- 2500+0.88852
