May. 2021 Ver.3.0
TDK Corporation
Multilayer Band Pass Filter
For 5GHz W-LAN
DEA Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DEA165538BT-2208F1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
May. 2021 Ver.3.0
TDK Corporation
DEA165538BT-2208F1
■ SHAPES AND DIMENSIONS
[Top View]
[Bottom View]
(4)
(4)
(1)
(3)
(2)
(1)
(3)
(2)
Dimensions (mm)
L
W
T
a
b
c
d
e
f
1.60 0.80 0.65 0.23 0.65 0.40 0.30 0.21 0.22
+/-0.15 +/-0.10
Max
+/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05
Terminal functions
Input Port
(1)
GND
(2)
Output Port
(3)
GND
(4)
■ TERMINATION FINISH
Material
Ag
May. 2021 Ver.3.0
TDK Corporation
DEA165538BT-2208F1
■ ELECTRICAL CHARACTERISTICS
Parameter
( Measurement )
TDK Spec
Min. Typ. Max.
5925 0.68 0.95
5925 1.15
Frequency (MHz)
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
VSWR
Attenuation (dB)
5150 to
5150 to
to
5150 to 5925 1.2 1.6
699 to
960 45 56.1
960 to 1710 40 44.9
1710 to 2690 37 38.5
2690 to 3550 20 38.5
3400 to 3600 32 38.7
3600 to 3800 22 28.2
3550 to 4000 12 20.8
4400
6.15 9.0
4000 to 4500 6.5
6500 to 7000 1.7
6850 to 7000 6.3
7000 to 7400 3
9.2
7400 to 9750 10 16.7
9750 to 10300 20 59.7
10300 to 12750 35 46.7
15450 to 17550 35 44.9
50 (Nominal)
Characteristic Impedance (ohm)
Ta = +25+/-5°C
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W) *1
Human Body Model : HBM
Machine Model : MM
Charged Device Model : CDM
TDK Spec
Conditions
–40 to +90 °C
–40 to +90 °C
Frequency (MHz)
2
5150 to 5925
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
@Each Port (V)
+/-500
Humidity : 60%RH max
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
May. 2021 Ver.3.0
TDK Corporation
DEA165538BT-2208F1
■ FREQUENCY CHARACTERISTICS
Insertion Loss
VSWR
May. 2021 Ver.3.0
TDK Corporation
DEA165538BT-2208F1
Attenuation
May. 2021 Ver.3.0
TDK Corporation
DEA165538BT-2208F1
■ RECOMMENDED LAND PATTERN
Unit[mm]
■ EVALUATION BOARD
unit : mm
Material & Layer
Copper Surface Pattern
FR-4
Inner GND
FR-4
Copper Bottom GND
Thickness
0.035 mm
0.10 mm
0.018 mm
0.30 mm
0.035 mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
May. 2021 Ver.3.0
TDK Corporation
DEA165538BT-2208F1
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
May. 2021 Ver.3.0
TDK Corporation
DEA165538BT-2208F1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Sprocket hole
K
Loading Direction
E
J
C
D
A
B
B
t
H
Dimensions (mm)
A
B
C
0.97 1.8 8.0
+/-0.05 +/-0.05
+/-0.2
G
F
D
3.5
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
K
0.8
t
0.25
+/-0.05
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DEA165538BT-2208F1”相匹配的价格&库存,您可以联系我们找货
