The products in this catalog are not recommended for new design
R F
C o m p o n e n t s
January 2019
Multilayer Low Pass Filter
For 699-2170MHz
DEA202170LT-5071A1
2.0x1.25mm [EIA 0805]*
* Dimensions Code JIS[EIA]
RF Components
Conformity to RoHS Directive
For 699-2170MHz
DEA202170LT-5071A1
SHAPES AND DIMENSIONS
0.90±0.10
2.00±0.15
(1)
(3)
(2)
[Bottom view]
1.25±0.10
[Top view]
Marking
0.95±0.10
0.60±0.10
(1)
0.25±0.10
(2)
Terminal functions
1 Input Port
2 GND
3 Output Port
(3)
0.275±0.10
Dimensions in mm
RECOMMENDED LAND PATTERN
0.60
0.275
0.95
0.275
EVALUATION BOARD
Thru Hole
Resist
0.25
Surface Pattern
0.25
PCB material: Teflon
Dimensions in mm
Line width should be designed to match 50Ω characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details.https://product.tdk.com/info/en/environment/rohs/index.html
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20190114 / rf_lpf_dea202170lt-5071a1_en.fm
RF Components
DEA202170LT-5071A1
ELECTRICAL CHARACTERISTICS
Frequency Range
(MHz)
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
699 to 960
1710 to 1980
1980 to 2025
2025 to 2170
699 to 2170
2400 to 2500
3840 to 4050
5130 to 6075
Power Handling (W)
Characteristic Impedance ()
Min.
Typ.
Max.
9.54
15
9
15
0.11
0.28
0.32
0.65
17.2
17
50 (Nominal)
0.25
0.40
0.45
0.80
4 (Duty : 50%)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
RF Components
DEA202170LT-5071A1
FREQUENCY CHARACTERISTICS
INSERTION LOSS
ATTENUATION
10
1.0
Attenuation(dB)
Insertion Loss(dB)
0.5
1.5
2.0
30
40
2.5
3.0
500
1000
1500
Frequency (MHz)
2000
2500
1000
1500
Frequency (MHz)
2000
2500
2000
3000
4000
5000
Frequency (MHz)
6000
7000
8000
RETURN LOSS
Return Loss(dB)
10
40
50
500
RF Components
DEA202170LT-5071A1
RECOMMENDED REFLOW PROFILE
Preheating
Soldering
Peak
T4
T: Temperature
3°C/sec
or lower
6°C/sec
or lower
T3
T2
T3
t3
T1
t1
t2
t: Time
Preheating
Temp.
T1
150°C
T2
200°C
Time
t1
60 to 120sec
Soldering
Critical zone (T3 to T4)
Temp.
Time
T3
t2
217°C
60 to 120sec
Peak
Temp.
T4
240 to 260°C
Time
t3
30sec max.
t3
: Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
很抱歉,暂时无法提供与“DEA202170LT-5071A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.87001
- 10+2.72184
- 25+2.63307
- 50+2.54782
- 100+2.41527
- 250+2.02004
- 500+1.56739
- 1000+1.49237
- 国内价格
- 5+1.04382
- 50+0.85958
- 150+0.78063
- 500+0.68202
