RSEV
RSEV
SERIES
Compact Single-Phase EMC Filter That Offers Improved Wiring Workability
EMC
filter
■ FEATURES
RSEV
■ SAFETY STANDARDS
Easy to install, all screws are self-up structure
UL1283
Terminal block screw and product cover are unified
The attachment for DIN rail is available (optional accessory)
Part number: DIN-RSEV
CSA C22.2 No.8 (cUL)
EN60939-3 (ENEC15)
■ PRODUCT IDENTIFICATION
RSEV ‒2 006
Rated current
Number indicating the rated voltage
Series name
■ CONFORMITY TO RoHS Directive
■ CIRCUIT DIAGRAM
FG
1
4
2
3
FG
web231206
f_42
・All specifications are subject to change without notice.
RSEV
■ ELECTRICAL CHARACTERISTICS
Rated
Rated
voltage
current
(AC/DC)
(AC/DC)
Part No.
RSEV-2006
Withstand
Insulation
Leakage
voltage
resistance
current
6A
RSEV-2010
10A
RSEV-2016
250V
AC.2500V
16A
RSEV-2020
20A
RSEV-2030
30A
60s
[line - earth]
With
DC
derating
resistance
Common mode
Differential mode
range
over
(mΩ)
at 25dB
at 25dB
0.1 to 30
0.2 to 30
110 max.
100MΩ
min.
1mA max.
[DC500V/
[250V/60Hz]
Attenuation frequency range (MHz)
Operating
temperature
-25 to +85℃
1min]
+55℃
Weight
(g)
150
40 max.
0.2 to 30
0.2 to 30
150
20 max.
0.6 to 30
0.3 to 30
150
10 max.
0.8 to 30
0.4 to 30
150
6 max.
2 to 30
0.5 to 30
150
EMC
filter
■ DERATING GRAPH
120
Rated current(%)
100
80
60
40
–25
–10
10 20 30 40 50 60
Ambient temperature Ta(°C)
70
80
90
RSEV
■ MECHANICAL
Dimensions in mm
f_43
RSEV
■ ATTENUATION vs. FREQUENCY CHARACTERISTICS
EMC
filter
RSEV-2010
–10
–10
–20
–20
–30
–30
–40
Attenuation(dB)
Attenuation(dB)
RSEV-2006
Common mode
–50
–60
–70
–70
–80
–90
1
Frequency(MHz)
10
100
RSEV-2016
–100
–10
–10
–20
–20
–30
–40
Common mode
–50
–60
–70
–80
Differential mode
0.1
1
–30
Frequency(MHz)
10
100
Common mode
–40
–50
–60
–70
Differential mode
–80
–90
–90
–100
–100
0.1
Differential mode
RSEV-2020
Attenuation(dB)
Attenuation(dB)
–60
–90 Differential mode
0.1
Common mode
–50
–80
–100
RSEV
–40
1
Frequency(MHz)
10
100
0.1
1
Frequency(MHz)
10
100
RSEV-2030
–10
Attenuation(dB)
–20
–30
Common mode
–40
–50
–60
–70
Differential mode
–80
–90
–100
f_44
0.1
1
Frequency(MHz)
10
100
很抱歉,暂时无法提供与“DIN-RSEV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+45.377481+5.50025
- 10+43.5912410+5.28374
- 25+39.0340325+4.73136
- 50+36.6523750+4.44267
