Jul. 2016
Ver.6.0N
TDK Corporation
Multilayer Diplexer
For 2.4GHz W-LAN & Bluetooth / 5GHz W-LAN
DPX Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DPX165950DT-8060A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
Jul. 2016
Ver.6.0N
TDK Corporation
DPX165950DT-8060A1
■ SHAPES AND DIMENSIONS
Dimensions (mm)
L
W
T
a
b
c
d
e
1.60 0.80 0.60 0.10 0.30 0.25 0.55 0.25
+/-0.15 +/-0.15 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10
Terminal functions
GND
(1)
Common Port
(2)
GND
(3)
(4)
(5)
(6)
■ TEMPERATURE RANGE
Operating temperature Storage temperature
–40 to +90 °C
–40 to +90 °C
High-Band Port
GND
Low-Band Port
■ TERMINATION FINISH
Material
Sn plate
Jul. 2016
Ver.6.0N
TDK Corporation
DPX165950DT-8060A1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Parameter
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency (MHz)
2400
2400
4800
7200
to
to
to
to
2496
2496
5000
7500
TDK Spec
Min. Typ. Max.
0.51 0.65
10
15
32
43
15
24
Ta = +25+/-5°C
High-Band
Parameter
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency (MHz)
5150
5150
70
2400
7250
10300
15000
to 5950
to 5950
to 2000
to 2690
to 7800
to 11700
to 18000
TDK Spec
Min. Typ. Max.
0.90 1.25
10
15
30
42
30
35
9
14
28
33
10
27
Ta = +25+/-5°C
Jul. 2016
Ver.6.0N
TDK Corporation
DPX165950DT-8060A1
■ FREQUENCY CHARACTERISTICS
Insertion Loss (Low-Band)
Insertion Loss (High-Band)
Return Loss (Low-Band)
Return Loss (high-Band)
Attenuation (Low-Band)
Attenuation (High-Band)
Isolation
Common port Return Loss
Jul. 2016
Ver.6.0N
TDK Corporation
DPX165950DT-8060A1
■ RECOMMENDED LAND PATTERN
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
Jul. 2016
Ver.6.0N
TDK Corporation
DPX165950DT-8060A1
■ RECOMMENDED REFLOW PROFILE
Pb free solder
Soaking
Temp.
Time
t1
T1
T2
150°C 180°C 60 to 120sec
Working
Temp.
Time
T3
t2
230°C
more than 30sec
Soldering
Temp.
Time
T4
t3
Peak
Temp.
T5
247 to 253°C within 10sec 260°C Max.
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DPX165950DT-8060A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.08562
- 50+0.95818
- 150+0.90364
- 500+0.83549
- 2500+0.76875
