• Limited Lifetime Warranty
• UL508 Approved
• SEMI F47 Compliant (high line AC)
• Universal Input (85 - 265VAC)
• High Efficiency
• RoHS Compliant Design
Key Market Segments & Applications
HWS300-1500 Series
Factory Automation
Test & Measurement
Automated Service
Single Output Industrial
Power Supplies
HWS300-1500 Features and Benefits
Features
• High Efficiency
• Wide Range AC Input
• Lower Cost of Ownership
• Easier System Cooling
• Supports Global Use
Specifications
MODEL
ITEMS
Input Voltage range (47-63Hz)
Input Current (Typ)
(1)
A
Inrush Current
(1)
Power Factor
Temperature Coefficient
Overcurrent Protection
Overvoltage Protection
Hold Up Time (Typ)
Leakage Curr. (at 240VAC, 60Hz)
Remote Sense
Indicator
Remote on/off
Parallel operation
DC Good
Remote Adjust (PV)
Operating Temperature
Storage Temperature
Humidity (non condensing)
Cooling
Withstand Voltage
(4)
Isolation Resistance
Vibration (non operating)
Shock
Safety Agency Approvals (5)
Line Dip
Conducted & Radiated EMI
Recommended EMI Filter
Immunity
Weight (Typ)
Size
MTBF (6)
Warranty
Benefits
A
V
ms
mA
°C
°C
g
mm
hrs
yrs
HWS300
HWS600
HWS1000
HWS1500
85 - 265VAC or 120 - 330VDC
5V: 7.5/3.6;
3.3V: 9.6/5.0;
3.3V: 15/8
12-48V: 8.1/3.9
5-60V: 13.5/7.0
5-60V: 19/10
20 / 40
Meets EN61000-3-2
105% (>101% of peak current for peak current capable models)
See table on page 2 (Recycle AC or remote on/off to reset)
20 (HWS1500-7 - 16ms)
很抱歉,暂时无法提供与“HWS150A-5/HD”相匹配的价格&库存,您可以联系我们找货
