Advance Data Sheet: iCG Series – Non-isolated SMT Power Module
iCG Series DC/DC Power Modules
4.5-14V Input, 6A Output
Surface Mount Power Module
iCG power modules perform local voltage conversion from either a
5V or 12V bus. The iCG12006A007V utilizes a low component
count that results in both a low cost structure and a high level of
performance. The open-frame, compact, surface mountable
design features a low profile and weight as well as additional edge
plated pads that allow for extremely flexible and robust
manufacturing processes.
Features
• Size – 12.2mm x 12.2 mm x 8.5 mm
(0.48 in. x 0.48 in. x 0.335 in.)
• DOSA Compatible Footprint
• Edge plated castellations for forming
inspectable solder joints
• Surface mountable
• Maximum weight 3g (0.106 oz)
• Up to 33W of output power in high
ambient temperature, low airflow
environments with no power derating
• Positive logic on/off
• Flexible Output Voltage Sequencing
• Starts with pre-biased output
• Output voltage adjustment – industry
standard
• Outstanding transient response
without the need for external loop
tuning components
• Constant switching frequency
• Remote Sense
• Power Good
• Full, auto-recovery protection:
o Input under voltage
o Short circuit
o Thermal limit
• ISO Certified manufacturing facilities
• Patent pending
Optional Features
• Negative logic on/off
• No output voltage sequencing
• Solder bumping for enhanced
solderability on the EPC footprint
℡ 1-800-526-2324
©2015 TDK - Lambda Americas Inc.
iCG12_Full_Datasheet_100312_rev 1.2.doc rev. 1.2 1/18/2017
1/16
This page intentionally left blank
℡ 1-800-526-2324
2/16
Mechanical Specification:
Dimensions are in mm [in]. Unless otherwise specified tolerances are: x.x ± 0.5 [0.02], x.xx ± 0.25 [0.010]
-A-
-A-
See ordering information
for solder bumping
options
A
A
Pin Locations: (bottom view)
DOSA PINS
EPC PINS
Pin Assignment:
PIN
FUNCTION
PIN
FUNCTION
1
2
ON/OFF
VIN
6
7
TRIM
GND
3
GND
8
NC
4
VOUT
9
SEQ
5
SENSE
10
PW GOOD
℡ 1-800-526-2324
3/16
Recommended Footprint (top view):
FOR DOSA STANDARD PADS
℡ 1-800-526-2324
FOR EPC PADS
4/16
Absolute Maximum Ratings:
Stress in excess of Absolute Maximum Ratings may cause permanent damage to the device.
Characteristic
Min
Continuous Input Voltage
Max
Unit
-0.25
15
Vdc
Storage Temperature
-55
125
˚C
Operating Temperature Range (Tc)
-40
115*
˚C
Notes & Conditions
Measured at the location specified in the thermal
measurement figure; maximum temperature varies
with output current – see curve in the thermal
performance section of the data sheet.
* Engineering estimate
Input Characteristics:
Unless otherwise specified, specifications apply over all rated Input Voltage, Resistive Load, and Temperature conditions.
Characteristic
Min
Typ
Max
Unit
Operating Input Voltage
4.5
Maximum Input Current
Startup Delay Time from application of input voltage
Notes & Conditions
14
Vdc
6.5
A
Vin=2.4 to Vin,max; Io=Io,max
5
mS
Vo=0 to 0.1*Vo,set; on/off=on,
Io=Io,max, Tc=25˚C
Startup Delay Time from on/off
5
mS
Vo=0 to 0.1*Vo,set; Vin=Vi,nom,
Io=Io,max,Tc=25˚C
Output Voltage Rise Time
4
mS
Io=Io,max,Tc=25˚C, Vo=0.1 to
0.9*Vo,set
Input Reflected Ripple
30*
mApp
Input Ripple Rejection
40*
dB
Turn on input voltage
4.2
V
Turn off input voltage
*Engineering Estimate
3.5
V
See input/output ripple measurement
figure; BW=20 MHz
@ 120 Hz
Caution: The power modules are not internally fused. An external input line normal blow fuse with a
maximum value of 10A is required, see the Safety Considerations section of the data sheet.
℡ 1-800-526-2324
5/16
Electrical Data:
Characteristic
Unit
Notes & Conditions
Output Voltage Initial Setpoint
-2
+2
Vo=3.3Vsetting, Vin=Vin,nom; Io=Io,max;
Tc = 25˚C
Output Voltage Tolerance
-3
+3
Over all rated input voltage, load, and
temperature conditions to end of life
84
86
88
92
94
Vin=5V; Io=Io,max; Tc=25˚C
Line Regulation
3
mV
Vin=Vin,min to Vin,max
Load Regulation
6
mV
Io=Io,min to Io,max
Output Current
A
Output Current Limiting Threshold
10
A
Vo = 0.9*Vo,nom, Tc
ICG12006A007V-007-R 价格&库存
很抱歉,暂时无法提供与“ICG12006A007V-007-R”相匹配的价格&库存,您可以联系我们找货
