KMZ/KPZ Ferrite Bead Sample Kit
Ferrite Beads with Robust So Termina on for Signal/Power Lines
TDK’s KMZ and KPZ Series mul layer ferrite beads were designed with innova ve so
Signal/Power
termina on technology to offer high reliability under harsh condi ons ,even at high
So Termina on
temperatures up to 150°C. KMZ and KPZ series beads are qualified to AEC‐Q200 and
their compact size and robustness makes them ideal for use in demanding automo ve
AEC‐Q200
applica ons such as engine control modules (ECUs), powertrains, body controls, and
car mul media (telema cs). The external electrodes of KMZ and KPZ series beads feature a conduc ve resin layer that
offers effec ve protec on against board flexure and solder cracks due to mechanical stress during moun ng and
thermal shock during opera on. The KMZ series beads offer various impedance characteris cs with 6 materials of
different features for noise suppression in applica ons ranging from general signals to high‐speed signals. The KPZ
series beads consist of the S material type, which features impedance characteris cs similar to those of a typical ferrite
core. Impedance values within the KMZ1608‐HR series were selected for effec veness at 40 to 300MHz.
Features
Noise reduc on solu on for general signal and power lines
Has low direct current resistance for compa bility with large currents, op mal
for low power consump on
Effec ve protec on against board flexure and solder cracks
Suitable for high opera ng temperatures up to 150°C
Qualified to AEC‐Q200
So Termina on Electrode Design
Applica ons
In‐vehicle electronic control units (ECUs)
Powertrains, body controls, car mul media (telema cs)
Sample Kit Informa on
Rated Current
Size
Impedance
DC Resistance
[mm]
[Ω] @ 100MHz
[Ω] Max.
50 to 2500
30 to 1000
[mA] Max.
Series
‐55 to +85°C
+125°C
+150°C
0.1 to 0.8
200 to 800
100 to 400
100 to 400
0.015 to 0.3
800 to 5000
500 to 2000
300 to 1000
KMZ1608‐HR
(Signal Lines)
1.6 x 0.8
KPZ1608‐HR
(Power Lines)
Kit contains 240 pieces total—10 pieces each of 24 values
Digi‐Key Part Number: 445‐175078‐KIT‐ND
Rev. July 2017
Material Selec on Chart
B Material Characteris cs
This type is perfectly suited for fast digital signals. By equalizing R and X components that beads possess at a frequency
of 5MHz, B material type product is able to suppress overshoo ng, undershoo ng, and ringing of fast digital signals.
R Material Characteris cs
For wide frequency applica ons calling for broad impedance characteris cs. For digital signal line applica ons requiring
good waveform integrity. Impedance values selected for effec veness at 10 to 200MHz.
S Material Characteris cs
Standard type that features impedance characteris cs similar to those of a typical ferrite core. For signal line
applica ons in which the blocking region is near 100MHz. Impedance values selected for effec veness at 40 to
300MHz.
Y Material Characteris cs
High frequency range type intended for the 100MHz region and above. For signal line applica ons in which the signal
frequency is far from the cutoff frequency. Impedance values selected for effec veness at 80 to 400MHz.
A Material Characteris cs
This high‐impedance product is based on the impedance frequency characteris cs of our Y‐material. The product offers
excellent impedance characteris cs, which is greater than 2500Ω, in the vicinity of 100MHz range (KMZ1608AHR252B).
D Material Characteris cs
For applica ons calling for low inser on loss at low frequencies and sharply increasing impedance at high frequencies.
Designed for high impedance at high frequencies (300 MHz to 1GHz) for signal line applica ons.
Rev. July 2017
445‐175078‐KIT‐ND
TDK Part Number
Part Number Descrip on
KMZ1608BHR601CTDH5
1608, Bead, 600Ω, 25%
KMZ1608BHR102CTD25
1608, Bead, 1000Ω, 25%
KMZ1608RHR600ATD25
1608, Bead, 60Ω, 25%
KMZ1608RHR121ATD25
1608, Bead, 120Ω, 25%
KMZ1608RHR601ATD25
KMZ1608RHR102ATD25
1608 Bead, 1000Ω, 25%
KMZ1608SHR121ATD25
KMZ1608SHR601ATD25
KMZ1608SHR102ATD25
KMZ1608YHR600BTD25
KMZ1608YHR121BTD25
KMZ1608YHR301BTD25
1608, Bead, 300Ω, 25%
KMZ1608YHR601BTD25
KMZ1608YHR102BTD25
KMZ1608YHR152BTD25
1608, Bead, 1500Ω, 25%
KMZ1608AHR252BTD25
1608, Bead, 2500Ω, 25%
KMZ1608DHR500CTDH5
1608, Bead, 50Ω, 25%
KMZ1608DHR121CTDH5
KMZ1608DHR241CTD25
1608, Bead, 240Ω, 25%
KPZ1608SHR300ATDH5
1608, Power Bead, 30Ω, (+/‐10Ω)
KPZ1608SHR121ATDH5
1608, Power Bead, 120Ω, 25%
KPZ1608SHR221ATD25
1608, Power Bead, 220Ω, 25%
KPZ1608SHR601ATD25
1608, Power Bead, 600Ω, 25%
KPZ1608SHR102ATD25
1608, Power Bead, 1000, 25%
Rev. July 2017
