PAH450S48-28
PAH450S48-28
    TDK(东电化)
    DIP9 模块,1/2砖
    隔离模块 直流转换器 1 输出 28V 16A 36V - 76V 输入
PAH450S48-28 数据手册
PAH300-450 Series https://product.tdk.com/en/power/pah www.emea.lambda.tdk.com/pah 300-450W Half Brick DC-DC Converters The PAH300, PAH350 and PAH450 series of isolated half brick DC-DC converters operate from a 24V or 48V nominal dc input and are rated at 300W to 450W. Output voltages are 12V, 28V or 48V and can be adjusted over a wide range using the trim terminal by up to -40% to +18%. Remote sense and remote on/off are included as standard. The power modules can be conduction cooled to a cold plate or fitted with an optional heatsink. These efficient converters are well suited for distributed power architectures and power systems. Features Benefits • Wide Range Inputs • Operates From Batteries or DC Power Systems • Baseplate Cooled • Can be Conduction or Convection Cooled with a Heatsink • -40 to +100°C Baseplate Temperature • Operates in Harsh Environments • Up to 92% Efficient • Easier To Cool In the End System • Fixed Switching Frequency • Predictable Switching Noise Model Selector Model Input Voltage (V) Output Voltage (V) Adjustment Range (V) Maximum Current (A) Maximum Power (W) Input Current (A) nominal input, 100% load Efficiency (%) nominal input, 100% load Overvoltage Protection (%) PAH300S24-12 PAH300S48-12 PAH350S48-12 PAH300S24-28 PAH350S24-28 PAH300S48-28 PAH350S48-28 PAH450S48-28 PAH350S24-48 PAH450S48-48 18 - 36 36 - 76 36 - 76 18 - 36 18 - 36 36 - 76 36 - 76 36 - 76 18 - 36 36 - 76 12 12 12 28 28 28 28 28 48 48 7.2 - 13.2 7.2 - 13.2 7.2 - 13.2 16.8 - 33.0 16.8 - 33.0 16.8 - 33.0 16.8 - 33.0 16.8 - 33.0 28.8 - 52.8 28.8 - 57.6 25 25 29.2 11 12.5 11 12.5 16 7.3 9.4 300 300 350 308 350 308 350 448 350 451 14.71 7.02 8.25 15.1 17.36 7.21 8.24 10.3 17.36 10.4 87 90 89 88 88 90 89 92 87 92 115 - 135 115 - 135 115 - 135 125 - 140 125 - 140 125 - 140 125 - 140 125 - 145 115 - 140 125 - 145 PAH Series 450 S Output Power (W) 300, 350, 450 Simple Function 24 - 28 Nominal Input 24 = 24V 48 = 48V * Contact factory for availability on other models Output Voltage 12, 28, 48 /T Options Suffix Description Blank M3 tapped mounting inserts /T 3.3mm non-threaded inserts /P Positive logic remote On/Off (Not on PAH450S)* Related Products DC-DC Converters DC-DC Converters DC-DC Converters Heatsink Heatsink Heatsink Part Number PAF600F24-48 PH50A280 to PH600A280 i7A HAH-10L HAH-10T HAH-15L Description 600W, 24 & 48V Input Full Brick DC-DC Converters 50W to 600W, 200 to 425V Input DC-DC Converters 500 to 700W, Non-isolated Step Down DC-DC Converters Half brick 25mm longitudinal fins Half brick 25mm transverse fins Half brick 38.1mm longitudinal fins PAH300-450 Series 1 Specifications Model Input Input Voltage range - Input Current - Efficiency - Conducted & Radiated EMI - Immunity - Safety Certifications and Markings - PAH300-450 See model selector See model selector See model selector EN55011/EN55032-A, FCC Class A, VCCI-A (External components are required, consult Instruction manual on website) IEC61000-4-2, -3, -4, -5, -6 (External component are required, consult Immunity Data on website) IEC/UL/CSA/EN62368-1, 60950-1, CE Mark and UKCA Mark Immunity Test Standard Test Level Criteria ESD EN61000-4-2 Air ±10kV and contact ±5kV A 80M -1GHz: 10V/m Radiated Susceptibility EN61000-4-3 1.4 - 2.0GHz: 3V/m A 2.0 - 2.7GHz: 1V/m Electrical Fast Transient Burst EN61000-4-4 ±2.4kV A Surge EN61000-4-5 Common, Normal ± 600V A Conducted Susceptibility EN61000-4-6 10Vrms A Notes External components are required (Consult Immunity Data on website) Specifications Model PAH300-450 Output Output Voltage Tolerance % ±1 Output Voltage Adjustment - See model selector Switching Frequency kHz PAH300-350S24: 330, PAH300-350S48: 370, PAH450S48-28 400, PAH450S48-48: 460 Line Regulation mV 12V: 24, 28V: 56, 48V: 96 Load Regulation mV 12V: 24, 28V: 56, 48V: 96 External Load Capacitance - Contact Technical Sales Ripple & Noise mV 12V: 200; 28V: 280 (240 for PAH300 ), 48V: 480 Temperature Coefficient %/°C 0.02 Minimum Load - No minimum load required Overcurrent Protection % 105 - 140, constant current with automatic recovery Overvoltage Protection - See model selector, cycle input or remote on/off to reset Overtemperature Protection °C 105 - 130 base-plate Remote Sense - Yes Remote On/Off - Yes; Low = ON, High = OFF Parallel Operation - Not possible Environmental Operating Temperature (Baseplate) °C -40 to +100. PAH350S24-28 & -48: derate linearly to 85% load from 90 to 100 Storage Temperature °C -40 to +100 Humidity (non condensing) %RH Operating and storage: 5 - 95 Cooling - Conduction. (See Instruction Manual for heatsink selection) Altitude m 3,000 Withstand Voltage (For 1 minute) Vdc Input to Base-plate: 1,500; Input to Output 1,500; Output to Baseplate: 500 Isolation Resistance MΩ >100 at 25°C, 70%RH & 500Vdc Vibration - Non Operating, 10-55Hz (sweep for 1 min.) Amplitude 0.825mm constant (Max 49 m/s2) X,Y,Z 1 hour each Shock - 196.1m/s2 2 PAH300-450 Series Specifications Model PAH300-450 Other Weight (Typ) g PAH300: 90, PAH350-450: 100 Size (LxWxH) mm 61 x 57.9 x 12.7 Size (LxWxH) Inches 2.4 x 2.28 x 0.5 MTBF - Telcordia SR-332 issue 3* Hours PAH300: 5,133,191, PAH350: 5,181,681, PAH450: 1,733,846 Warranty Years 2 Notes See website for detailed specifications, test methods and installation manual *Ground Benign 25°C Basic Connection Circuit * PAH300-450 Series 3 Outline Drawing * 4 PAH300-450 Series TDK-Lambda France SAS TDK-Lambda Americas Tel: +33 1 60 12 71 65 france@fr.tdk-lambda.com Tel: +1 800-LAMBDA-4 or 1-800-526-2324 powersolutions@us.tdk-lambda.com www.us.lambda.tdk.com www.emea.lambda.tdk.com/fr Italy Sales Office Tel: +39 02 61 29 38 63 info.italia@it.tdk-lambda.com www.emea.lambda.tdk.com/it TDK Electronics do Brasil Ltda Tel: +55 11 3289-9599 sales.br@tdk-electronics.tdk.com www.tdk-electronics.tdk.com/en Netherlands info@nl.tdk-lambda.com www.emea.lambda.tdk.com/nl TDK-Lambda Germany GmbH Tel: +49 7841 666 0 info@de.tdk-lambda.com www.emea.lambda.tdk.com/de TDK-Lambda Corporation Tel: +81-3-6778-1113 www.jp.lambda.tdk.com TDK-Lambda (China) Electronics Co. Ltd. Tel: +86 21 6485-0777 powersolutions@cn.tdk-lambda.com www.lambda.tdk.com.cn TDK-Lambda Singapore Pte Ltd. Tel: +65 6251 7211 tls.mkt@sg.tdk-lambda.com www.sg.lambda.tdk.com Austria Sales Office Tel: +43 2256 655 84 info@at.tdk-lambda.com www.emea.lambda.tdk.com/at TDK India Private Limited, Power Supply Division Switzerland Sales Office Tel: +91 80 4039-0660 mathew.philip@in.tdk-lambda.com www.sg.lambda.tdk.com Tel: +41 44 850 53 53 info@ch.tdk-lambda.com www.emea.lambda.tdk.com/ch Nordic Sales Office Tel: +45 8853 8086 info@dk.tdk-lambda.com www.emea.lambda.tdk.com/dk TDK-Lambda UK Ltd. Tel: +44 (0) 12 71 85 66 66 info@uk.tdk-lambda.com www.emea.lambda.tdk.com/uk TDK-Lambda Ltd. Tel: +9 723 902 4333 info@tdk-lambda.co.il www.emea.lambda.tdk.com/il C.I.S. Commercial Support: Tel: +7 (495) 665 2627 Technical Support: Tel: +7 (812) 658 0463 info@tdk-lambda.ru www.emea.lambda.tdk.com/ru For Additional Information, please visit https://product.tdk.com/en/power/ PAH300-450_260898_May 13th, 2022 V1 PAH300-450 Series 5
PAH450S48-28 价格&库存
很抱歉,暂时无法提供与“PAH450S48-28”相匹配的价格&库存,您可以联系我们找货
