• Suitable for use in Custom Power Supplies
• Provides high voltage DC to TDK-Lambda's
PH & PAF Power Modules
• Parallel operation on PF Series
• 12.7mm profile
Key Market Segments & Applications
Key
Test & Measurement
PF Series
Test
& Measurement
Automated
Service
Automated
Service
Factory Automation
Factory
GeneralAutomation
Purpose
General
Purpose
LED Lighting
& Display
LED Lighting & Display
Rectifier & Power Factor
Correction Modules
PF Features and Benefits
Features
Benefits
• Low profile
• Parallel
• Power Factor corrected (PF)
• Operation up to 85˚C
• Assist system integration
• For higher power or N+1 operation
• Supports Global Use
• Operates in harsh environments
Specifications
Items
AC Input Voltage range & Frequency
Input Frequency
Output Voltage
Output Power at 100/200VAC
Load Regulation
Line Regulation
Inrush Current
Efficiency (typ) at full load
Power Factor
Overcurrent Protection
Overvoltage Protection
Thermal Shutdown
Inverter Good Signal
Enable Signal
Parallel Connection
Auxiliary Output Voltage
Operating Baseplate Temperature
Storage Temperature
Cooling
Withstand Voltage
Safety Agency Approvals
Weight
Size (WxHxD)
Warranty
VAC
VDC
W
A
V
°C
°C
g
mm
yrs
PF500A-360
504/756W
85-265 wide range
47 - 63Hz
360
PF1000A-360
1008/1512W
10V
5V typical
External pins provided connection for in rush resistor
90% (100VAC), 95% (200VAC)
Meets EN61000-3-2 (0.95 typical)
Converter shutdown
390 - 400VDC, manual reset
Shuts down Inverter, manual reset
Yes, when inverter is operating correctly
Signal provided to enable "PH" DC-DC converters
Single wire current share
Yes - see installation manual
-20°C to +85°C (no derating)
-40°C to +85°C
Conduction (see installation manuals for heatsinks)
Input - Ground 3kVAC for 1 min
IEC/EN/UL/CSA60950-1, IEC/EN/UL/CSA62368-1 and CE Mark
130
200
See outline line drawings
2
Notes: (Consult Installation Manual for detailed specifications, test methods and application notes)
PF Series
1
Outline Drawing PF500A
2
PF Series
Outline Drawing PF1000A
PF Series
3
TDK-Lambda France SAS
TDK-Lambda Americas
Tel: +33 1 60 12 71 65
tlf.fr.powersolutions@tdk.com
Tel: +1 800-LAMBDA-4 or 1-800-526-2324
tla.powersolutions@tdk.com
www.us.lambda.tdk.com
www.emea.lambda.tdk.com/fr
Italy Sales Office
Tel: +39 02 61 29 38 63
tlf.it.powersolutions@tdk.com
www.emea.lambda.tdk.com/it
TDK Electronics do Brasil Ltda
Tel: +55 11 3289-9599
sales.br@tdk-electronics.tdk.com
www.tdk-electronics.tdk.com/en
Netherlands
tlf.nl.powersolutions@tdk.com
www.emea.lambda.tdk.com/nl
TDK-Lambda Germany GmbH
TDK-Lambda Corporation
Tel: +49 7841 666 0
tlg.powersolutions@tdk.com
www.emea.lambda.tdk.com/de
Tel: +81-3-6778-1113
www.jp.lambda.tdk.com
TDK-Lambda (China) Electronics Co. Ltd.
Tel: +86 21 6485-0777
tlc.powersolutions@tdk.com
www.lambda.tdk.com.cn
Austria Sales Office
Tel: +43 2256 655 84
tlg.at.powersolutions@tdk.com
TDK-Lambda Singapore Pte Ltd.
Switzerland Sales Office
Tel: +65 6251 7211
tls.marketing@tdk.com
www.sg.lambda.tdk.com
Tel: +41 44 850 53 53
tlg.ch.powersolutions@tdk.com
TDK India Private Limited, Power Supply Division
www.emea.lambda.tdk.com/at
www.emea.lambda.tdk.com/ch
Tel: +91 80 4039-0660
mathew.philip@tdk.com
Nordic Sales Office
Tel: +45 8853 8086
tlg.dk.powersolutions@tdk.com
www.emea.lambda.tdk.com/dk
TDK-Lambda UK Ltd.
Tel: +44 (0) 12 71 85 66 66
tlu.powersolutions@tdk.com
www.emea.lambda.tdk.com/uk
TDK-Lambda Ltd.
Tel: +9 723 902 4333
tli.powersolutions@tdk.com
www.emea.lambda.tdk.com/il-en
PF Sept19 v3
4
PF Series
For Additional Information, please visit
https://product.tdk.com/en/power/
很抱歉,暂时无法提供与“PF1000A-360”相匹配的价格&库存,您可以联系我们找货
