Electromagnetic Buzzers
SMD Without oscillator circuit SDR series
Issue date: August 2007
• All specifications are subject to change without notice. • Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/3)
Electromagnetic Buzzers SMD Terminal SDR Series
FEATURES • Suitable for calling sound of mobile phones. • High quality parts(yoke and magnets) provide high output level of sound pressure in spite of compact size. • Provide a good frequency response and high quality sound. • Suitable for surface mount process(SMD). • Stand up to reflow process twice. APPLICATIONS Mobile phones, pagers.
SHAPES AND DIMENSIONS
The positive polarity mark
SPECIFICATIONS
Part No. SDR08540M3-01 Rated voltage Eo-p(V) 3 Operating voltage Eo-p(V) 0 to 5 Drive conditions: Rated voltage, square wave form[duty50%] Frequency(Hz) 2670 Sound pressure level(dB(A)/10cm)typ. 97 Sound pressure level(dB(A)/10cm)min. 88 Rated current(mA(ave))max. 85 DC resistance(Ω)typ. 16 Operating temperature range –40 to +85°C Storage temperature range –40 to +85°C
(Ð) 2
(+) 1
(Ð) 3 8.5 ± 0.2 (4.2)
(Ð) 4
8.5 ± 0.2
FREQUENCY CHARACTERISTICS
100 Sound pressure (dB (A) /10cm) 90 80 70 60 50
Sound release hole The positive polarity terminal: 1 The negative polarity terminal: 2=3=4 common Dimensions in mm
(1.2) 4 ± 0.2
0.5
1
RECOMMENDED PC BOARD PATTERN
8.9 1.78
1 1. 8
2 3 4 Frequency (kHz)
5
10
RECOMMENDED SOLDERING CONDITION REFLOW SOLDERING
1 10s 240 ± 5˚C
1.78
2
2. 52 8 1.1
8.9
170˚C 150˚C
3
4 4˚C Preheating 60 to 150s Time (s) 30s over 60s
• All specifications are subject to change without notice. 005-02 / 20070807 / ec211_sdr.fm
(2/3)
PACKAGING STYLE AND QUANTITIES TAPING SPECIFICATION
Cavity or embossment E D B K A H G F
Dimensions in mm
Sprocket hole ø1.55 ± 0.05
Type A B C D E F G H J K
08540 8.8±0.1 9±0.1 16±0.2 7.5±0.1 1.75±0.1 12±0.1 2±0.1 4±0.1 1.55±0.05 4.2±0.1
• Packaging quantities 1000 pieces/reel
C
(3/3)
SAFETY PRECAUTIONS FOR USING TDK ELECTROMAGNETIC BUZZER Please be sure to read the specifications of TDK Electromagnetic Buzzer(hereinafter referred to as “the buzzer”) before use. • When soldering a terminal pin, perform the soldering in clean • Please pay sufficient attentions to the warnings for safe conditions without contamination or rust in order to avoid poor designing when using the buzzer. connections. Incorrect usage may cause smoke or fire. • When performing dip soldering directly for installing on a printed • Do not make sound on the buzzer when it is close to ears. circuit board, be careful so that smoke from the flux, or other Listening to the buzzer when it is close to ears, or continuant lisforeign materials, will not get into the sound emission hole. tening to it for an extended period, may result in hearing disor• Do not clean(excluding products that can be cleaned). ders. • With regards to devices in which the consumers can touch the Thoroughly warn consumers not to turn on the sound when the buzzer, thoroughly warn consumers not to put foreign materials buzzer is close to ears. (such as needles, hairpins, garbage, etc.) into the sound • Do not exceed the rated operation voltage range when using the emission hole. buzzer. • As the buzzer uses a coil, it has an inductive load. If it is exceeded beyond the rated operation voltage, a built-in coil Protect the drive circuit by putting the diodes in parallel into the may generate heat, resulting in deterioration of the coil, which buzzer. may cause a drop in sound pressure or a change in the terminal • Do not reconfigure the buzzer. resistance value. • Sound pressure changes depending on the shape of the part to If a rare short circuit occurs due to heat generated in the built-in be installed in a device, or the installation location. coil, a large electrical current flows to the equipment used, posCheck the buzzer in the mounted condition. sibly causing it to emit smoke or fire. • The buzzer has polarities. • The buzzer is a magnetic type sounder. When installing, be careful not to make a mistake with the polarDo not use it for any other purpose than a sound generation. ities. Incorrect polarities will cause the following irregularities. • Do not use the buzzer in other than atmospheric air. • Without circuit type: Differences in sound pressure will be • Do not use the buzzer in the following environments (excluding created. cases in which countermeasures are taken). • With circuit type: No sound will be generated. • Corrosive gases (Cl2, NH3, SOx, NOx, etc.) • Frequencies other than the rated frequency will change the • Places to be exposed to dust. characteristics (sound pressure), and may cause wide • Places where rain, fog, salt water, and the like will get on the unevenness. buzzer. • As the buzzer uses a magnet, it generates a surrounding • After installing the buzzer when designing an apparatus, confirm magnetic field. that there are no abnormalities by performing a reliability When designing a device, etc., confirm that there are no irreguevaluation test. larities due to the magnetic field. • Do not exceed the rated operating temperature range when • The characteristics of the buzzer may change because of the using the buzzer. influence of an outside magnetic field. • Do not use for an extended period at relative humidity in excess Check the buzzer in the mounted condition, and take measures of 90% (maximum wet-bulb temperature of 38°C). such as shielding, etc. • When using the buzzer for a safety device or warning device, • Because of deterioration or damage, maintain in rated storage take all surest measures such as providing a safety circuit or the temperature range, avoid environments where there are sudden joint use of another sounder with equivalent characteristics in temperature changes, direct sunlight, corrosive gases and dust, order to prevent accidents. and store wrapped in order to avoid applying stresses. • The buzzer may be influenced by electromagnetic waves, voltage changes, and ripple voltage. Check the buzzer in the mounted condition, and take measures RECOMMENDED OPERATING CIRCUIT EXAMPLE such as safety circuits, shielding, etc. V CC Buzzer • If the buzzer is molded or secured by adhesives, thermal expansion stresses from the mold or adhesive agent may cause deterioration in a soldered terminal part. Before molding or securing an adhesive, consider the type, Oscillator circuit Q amount, hardening conditions, adhesive properties, etc., of the R sealing material, and confirm the reliability. • Do not apply vibrations or shocks (such as dropping) larger than the specified. • Do not bend the terminal pin when soldering to install on a circuit board. • Do not apply larger than the specified force to the terminal pin. • Do not apply force to the terminal pin at high temperatures (when soldering).
D
