Common Mode Filters
For ultra high-speed differential signal line
(Thunderbolt, SerialATA, USB3.0, etc.)
TCM series
Type:
TCM0806T
[0302 inch]*
* Dimensions Code [EIA]
Issue date:
August 2012
• All specifications are subject to change without notice.
• Conformity to RoHS Directive: This means that, in conformity with EU Directive 2002/95/EC, lead, cadmium, mercury, hexavalent chromium, and specific
bromine-based flame retardants, PBB and PBDE, have not been used, except for exempted applications.
(1/2)
Common Mode Filters
For Ultra High-speed Differential Signal Line
TCM Series TCM0806T
FEATURES
• Thin-film common mode filter with a wide bandwidth for highspeed differential signal interfaces such as Thunderbolt,
SerialATA and USB 3.0 .
• The series suppresses radiation noise due to common mode
noise, without affecting the transmission of high-speed
differential signals by realizing a higher cutoff frequency.
• This product contains no lead and supports lead-free soldering.
APPLICATIONS
• High speed interface(Thunderbolt, SerialATA and USB3.0, etc.)
in electronics devices.
PRODUCT IDENTIFICATION
TCM
(1)
0806 T - 060 - 2P - T
(2) (3)
(4)
(5)
(6)
(1) Series name
(2) Dimensions LW
(3) Product identification number
(4) Impedance[at 100MHz]
060: 06
(5) Number of line
2P: 2-line
(6) Packaging style
T: ø180mm reel taping
TEMPERATURE RANGES
Operating
Storage(After mount)
RECOMMENDED SOLDERING CONDITIONS
RECOMMENDED TEMPERATURE PROFILE
FOR LEAD-FREE SOLDER
–25 to +85°C
–25 to +85°C
PACKAGING STYLE AND QUANTITIES
Packaging style
Taping
Quantity
10000 pieces/reel
Peak 245˚C max.
Natural
cooling
230˚C
SHAPES AND DIMENSIONS/CIRCUIT DIAGRAM
0.4±0.05 0.65±0.05
0.85±0.05
180˚C
4
3
150˚C
60 to 120s
0.03typ.
1
1
0.27±0.1
Time (s)
REFLOW PROFILE FOR SOLDER HEAT RESISTANCE
Peak 260˚C max.
Natural
cooling
230˚C
Weight: 0.001g
2
2
・No polarity
0.2 +0.05
–0.1
0.5±0.1
4
3
10 to 30s
Dimensions in mm
180˚C
150˚C
RECOMMENDED PC BOARD PATTERN
60 to 120s
40s max.
4
Time (s)
0.9
3
0.3
0.3
2
0.5
1
Dimensions in mm
001-01 / 20120821 / e9712_tcm_t
(2/2)
ELECTRICAL CHARACTERISTICS
Common mode
impedance
( )typ.[at 100MHz]
6
Part No.
TCM0806T-060-2P
DC resistance
( )typ.
[1 line]
1.4
TYPICAL ELECTRICAL CHARACTERISTICS
IMPEDANCE vs. FREQUENCY CHARACTERISTICS
Cutoff
frequency
(GHz)typ.
10
Rated current
Idc
(A)max.
0.1
Rated voltage
Edc
(V)max.
10
Insulation
resistance
(M )min.
10
INSERTION LOSS vs. FREQUENCY CHARACTERISTICS
1000
–5
100
Differential mode
10
Insertion loss(dB)
Impedance(Ω)
Differential mode
–10
Common mode
–15
Common mode
–20
–25
–30
–35
1
1
10
100
Frequency (MHz)
1000
10000
–40
1
10
100
Frequency(MHz)
1000
10000
很抱歉,暂时无法提供与“TCM0806T-060-2P”相匹配的价格&库存,您可以联系我们找货
