R F
C o m p o n e n t s
July 2015
Thin-film Diplexer
For 2400-2496MHz / 4900-5950MHz
TFSD10055950-5102A2
1.0x0.5mm [EIA 0402]*
* Dimensions Code JIS[EIA]
RF Components
Thin-film Diplexer
Conformity to RoHS Directive
TFSD10055950-5102A2
SHAPES AND DIMENSIONS
0.30±0.05
1.00±0.10
[Top view]
(3)
[Bottom view]
0.03±0.03
0.30±0.04
0.30±0.04
(2)
(1)
Marking
(3)
(4)
0.74±0.04
Terminal functions
1 Low-band
2 Common
3 High-band
4 GND
0.24±0.04
(2)
0.03±0.03
(1)
0.50±0.10
(4)
Dimensions in mm
0.10±0.04
0.63
0.30
0.23
RECOMMENDED LAND PATTERN
0.30
0.73
1.13
Dimensions in mm
The recommended distance to the PCB ground plane is 0.2mm.
Line width should be designed to match 50: characteristic impedance,
depending on PCB material and thickness.
RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/
• All specifications are subject to change without notice.
• Before using these products, be sure to request the delivery specifications.
20150701 / tfs_dpx_tfsd10055950-5102a2_en.fm
RF Components
TFSD10055950-5102A2
ELECTRICAL CHARACTERISTICS
LOW-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
Frequency Range
(MHz)
Min.
Typ.
Max.
2400 to 2496
2400 to 2496
2400 to 2500
4900 to 5950
7200 to 7488
10
18.0
24.6
27.3
50 (Nominal)
0.50
0.65 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
4900 to 5950
4900 to 5950
4900 to 5950
500 to 2700
9800 to 11900
10
26
15
0.74
14.8
30.8
20.5
50 (Nominal)
1.20
1.40 (–40 to +85°C)
Frequency Range
(MHz)
Min.
Typ.
Max.
500 to 2700
4900 to 5950
2400 to 2500
4900 to 5950
26
10
30.8
24.2
21.2
15.2
50 (Nominal)
Characteristic Impedance (:)
・Ta: +25°C
HIGH-BAND
Item
Insertion Loss (dB)
Return Loss (dB)
Attenuation (dB)
・Ta: +25°C
COMMON
Item
Isolation (dB)
Return Loss (dB)
・Ta: +25±5°C
TEMPERATURE RANGE
Operating temperature
(°C)
–40 to +85
Storage temperature
(°C)
–40 to +85
MSL
Moisture Sensitivity Level
(MSL)
1
RF Components
TFSD10055950-5102A2
FREQUENCY CHARACTERISTICS
HIGH-BAND
Insertion Loss
0.0
0.0
0.5
0.5
1.0
1.0
Insertion Loss (dB)
Insertion Loss (dB)
LOW-BAND
Insertion Loss
1.5
2.0
1000
1500
2000
Frequency (MHz)
2500
3000
10
1000
1500
2000
Frequency (MHz)
2500
3000
6000
6500
5000
5500
Frequency (MHz)
6000
6500
6000
8000
Frequency (MHz)
10000
50
4500
3500
Attenuation
Attenuation
10
Attenuation(dB)
40
50
5500
Frequency (MHz)
40
40
50
500
5000
Return Loss
Return Loss(dB)
Return Loss(dB)
3.0
4500
3500
Return Loss
Attenuation(dB)
2.0
2.5
2.5
3.0
500
1.5
40
4000
6000
8000
Frequency (MHz)
10000
12000
50
4000
12000
RF Components
TFSD10055950-5102A2
Isolation
10
Isolation(dB)
Return Loss(dB)
COMMON
Return Loss
30
40
50
30
40
4000
6000
8000
Frequency (MHz)
10000
12000
50
4000
6000
8000
Frequency (MHz)
10000
12000
RF Components
TFSD10055950-5102A2
RECOMMENDED REFLOW PROFILE
Soaking
Working
Soldering
Peak
T: Temperature
T5
T6
T5
T4
T4
T3
T2
T1
T3
t4
t3
t1
t2
t: Time
Soaking
Temp.
T1
T2
150°C
180°C
Time
t1
60 to 120s
Working
Temp.
T3
217°C
Time
t2
60 to 150s
Temp.
T4
230°C
Time
t3
more than 45s
Soldering
Temp.
T5
247 to 253°C
Time
t4
within 10s
Peak
Temp.
T6
260°C max.
RF Components
REMINDERS FOR USING THESE PRODUCTS
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment,
home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality
require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person
or property.
Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below
or for any other use exceeding the range or conditions set forth in this catalog.
(1) Aerospace/Aviation equipment
(2) Transportation equipment (cars, electric trains, ships, etc.)
(3) Medical equipment
(4) Power-generation control equipment
(5) Atomic energy-related equipment
(6) Seabed equipment
(7) Transportation control equipment
(8) Public information-processing equipment
(9) Military equipment
(10) Electric heating apparatus, burning equipment
(11) Disaster prevention/crime prevention equipment
(12) Safety equipment
(13) Other applications that are not considered general-purpose
applications
When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/
equipment or providing backup circuits, etc., to ensure higher safety.
TFSD10055950-5102A2 价格&库存
很抱歉,暂时无法提供与“TFSD10055950-5102A2”相匹配的价格&库存,您可以联系我们找货
