VLM10555T-1R2M100-3H
    TDK(东电化)
    非标准
    FIXED IND 1.2UH 10A 3.2 MOHM SMD
VLM10555T-1R2M100-3H 数据手册
I N D U C T O R S November 2013 Inductors for Power Circuits Wound Ferrite VLMseries VLM10555-2H VLM10555-3H VLM13580-D1 (For automobiles) (2/17) I N D U C T O R S REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The storage period is less than 6 months. Be sure to follow the storage conditions (Temperature: 5 to 30°C, Humidity: 10 to 75% RH or less). If the storage period elapses, the soldering of the terminal electrodes may deteriorate. Do not use or store in locations where there are conditions such as gas corrosion (salt, acid, alkali, etc.). Before soldering, be sure to preheat components. The preheating temperature should be set so that the temperature difference between the solder temperature and chip temperature does not exceed 150°C. Soldering corrections after mounting should be within the range of the conditions determined in the specifications. If overheated, a short circuit, performance deterioration, or lifespan shortening may occur. When embedding a printed circuit board where a chip is mounted to a set, be sure that residual stress is not given to the chip due to the overall distortion of the printed circuit board and partial distortion such as at screw tightening portions. Self heating (temperature increase) occurs when the power is turned ON, so the tolerance should be sufficient for the set thermal design. Carefully lay out the coil for the circuit board design of the non-magnetic shield type. A malfunction may occur due to magnetic interference. Use a wrist band to discharge static electricity in your body through the grounding wire. Do not expose the products to magnets or magnetic fields. Do not use for a purpose outside of the contents regulated in the delivery specifications. The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. If you intend to use the products in the applications listed below or if you have special requirements exceeding the range or conditions set forth in the each catalog, please contact us. (1) Aerospace/Aviation equipment (2) Transportation equipment (electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When designing your equipment even for general-purpose applications, you are kindly requested to take into consideration securing protection circuit/device or providing backup circuits in your equipment. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (3/17) I N D U C T O R S Inductors for Power Circuits Product compatible with RoHS directive Compatible with lead-free solders AEC-Q200 Wound Ferrite Overview of the VLM Series FEATURES Low Rdc design using a rectangular wire. Design with low core loss, large current capability design Mn-Zn core, and compatible with low loss and high current. Compatible with vehicle-related equipment. APPLICATION Equipment used for automobiles (ECM, HID, EPS, etc.) Vehicle accessory equipment (Vehicle AV equipment, car navigation, automobile air conditioners, etc.) PART NUMBER CONSTRUCTION VLM Series name 10555 L×W×H Dimensions (mm) 10555 10.5×10.6×5.4 13580 13.5×12.2×7.8 T Packaging style T Taping - 1R8 M 8R8 Inductance (μH) 1R8 1.8 100 10 Inductance tolerance M ±20% Rated current (A) 8R8 8.8 100 10 - 2H Internal code OPERATING TEMPERATURE RANGE, PACKAGE QUANTITY, PRODUCT WEIGHT Temperature range Package quantity Operating Storage temperature temperature (pieces/reel) (°C) (°C) VLM10555-2H –40 to +125 –40 to +125 500 VLM10555-3H –40 to +125 –40 to +125 500 VLM13580-D1 –40 to +150 –40 to +150 400 Operating temperature range includes self-temperature rise. The Storage temperature range is for after the circuit board is mounted. Type Individual weight (g) 1.7 1.7 3.9 RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://www.tdk.co.jp/rohs/ • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (4/17) I N D U C T O R S Overview of the VLM Series RECOMMENDED REFLOW PROFILE Preheating Soldering Natural cooling Peak T: Temperature T4 T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 T2 150°C 180°C Time t1 60 to 120s Soldering Temp. Time T3 t2 230°C 30s Peak Temp. T4 250°C Time t3 5s • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (5/17) I N D U C T O R S VLM series VLM10555-2H Type SHAPE & DIMENSIONS 5.4±0.2 1.3±0.1 1.2±0.1 1.3±0.2 1R8M 10.6±0.2 2.2±0.2 1.3±0.2 10.5max. Dimensions in mm 2.6 3.4 1.8 2.6 RECOMMENDED LAND PATTERN 3.0 6.1 1.9 Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (6/17) I N D U C T O R S VLM series VLM10555-2H Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE L (μH) 1.8 2.5 3.3 4.3  Tolerance ±20% ±20% ±20% ±20% Measuring frequency (kHz) 100 100 100 100 DC resistance (m ) 5.6 6.7 8.3 8.3 (%) ±15 ±15 ±15 ±15 Rated current(A) max. Idc1 18 15 12 9 typ. Idc2 8.8 8 7.2 7.2 Part No. VLM10555T-1R8M8R8-2H VLM10555T-2R5M8R0-2H VLM10555T-3R3M7R2-2H VLM10555T-4R3M7R2-2H Rated current: smaller value of either Idc1 or Idc2. Idc1: When based on the inductance change rate (25% below the initial value) Idc2: When based on the temperature increase (Temperature increase of 40°C by self heating) ○ Measurement equipment Measurement item Product No. Manufacturer L 4194A Agilent Technologies DC resistance 3220 HIOKI Rated current Idc1 3260B+3265B Wayne Kerr Electronics * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (7/17) I N D U C T O R S VLM series VLM10555-2H Type ELECTRICAL CHARACTERISTICS L FREQUENCY CHARACTERISTICS GRAPH 6 5 Inductance(μH) 4 4R3M 3R3M 3 2R5M 2 1R8M 1 0 10 100 1000 Frequency(kHz) 10000 100000 ○ Measurement equipment Product No. Manufacturer 4294A Agilent Technologies * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (8/17) I N D U C T O R S VLM series VLM10555-2H Type ELECTRICAL CHARACTERISTICS INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH 8 7 Inductance(μH) 6 5 4R3M 4 3R3M 3 2R5M 2 1R8M 1 0 0 5 10 DC current(A) 15 20 ○ Measurement equipment Product No. Manufacturer 3260B+3265B Wayne Kerr Electronics * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (9/17) I N D U C T O R S VLM series VLM10555-3H Type SHAPE & DIMENSIONS 5.4±0.2 1.3±0.1 1.8±0.2 1.2±0.1 R45M 10.6±0.2 2.2±0.2 1.8±0.2 10.5max. Dimensions in mm 2.6 3.4 1.8 2.6 RECOMMENDED LAND PATTERN 3.0 6.1 1.9 Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (10/17) I N D U C T O R S VLM series VLM10555-3H Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE L (nH) 330 450 560 700 1200  Tolerance ±20% ±20% ±20% ±20% ±20% Measuring frequency (kHz) 100 100 100 100 100 DC resistance (m ) max. typ. 1.2 0.95 2.6 2.2 2.5 2.1 2.5 2.1 3.2 2.7 Rated current* (A) max. typ. Idc1 Idc2 34 18 40 11 34 12 26 12 18 10 Part No. VLM10555T-R33M180-3H VLM10555T-R45M110-3H VLM10555T-R56M120-3H VLM10555T-R70M120-3H VLM10555T-1R2M100-3H Rated current: smaller value of either Idc1 or Idc2. Idc1: When based on the inductance change rate (25% below the initial value) Idc2: When based on the temperature increase (Temperature increase of 40°C by self heating) ○ Measurement equipment Measurement item Product No. L 4194A DC resistance 3220 Rated current Idc1 3260B+3265B * Equivalent measurement equipment may be used. Manufacturer Agilent Technologies HIOKI Wayne Kerr Electronics • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (11/17) I N D U C T O R S VLM series VLM10555-3H Type ELECTRICAL CHARACTERISTICS L FREQUENCY CHARACTERISTICS GRAPH 10000 R56M R45M 1R2M Inductance(nH) 1000 R70M R33M 100 10 1 10 100 1000 Frequency(kHz) 10000 100000 ○ Measurement equipment Product No. Manufacturer 4294A Agilent Technologies * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (12/17) I N D U C T O R S VLM series VLM10555-3H Type ELECTRICAL CHARACTERISTICS INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH 2000 1800 1600 Inductance(nH) 1400 1R2M 1200 1000 800 R70M 600 R56M R45M 400 R33M 200 0 0 5 10 15 20 25 DC current(A) 30 35 40 45 50 ○ Measurement equipment Product No. Manufacturer 3260B+3265B Wayne Kerr Electronics * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (13/17) I N D U C T O R S VLM series VLM13580-D1 Type SHAPE & DIMENSIONS 1.9±0.2 2R2 13.5±0.5 2.6±0.4 2.8±0.2 2.5±0.1 7.8±0.5 1.9±0.2 12.2±0.5 Dimensions in mm 2.45 3 5.4 2.45 RECOMMENDED LAND PATTERN 3.4 6 3.3 Dimensions in mm • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (14/17) I N D U C T O R S VLM series VLM13580-D1 Type ELECTRICAL CHARACTERISTICS CHARACTERISTICS SPECIFICATION TABLE L (μH) Tolerance(%) Measuring frequency (kHz) 0.82 1.5 2.2 3.3 ±20 ±20 ±20 ±20 100 100 100 100  DC resistance (m ) Rated current(A) max. max. typ. Idc1 2 2.5 3.9 4.5 1.7 2.1 3.3 3.8 36 26 20 18 typ. Idc2 Self heating 20°C 12.6 11.3 10.5 8.4 Part No. VLM13580T-R82M-D1 VLM13580T-1R5M-D1 VLM13580T-2R2M-D1 VLM13580T-3R3M-D1 Rated current: smaller value of either Idc1 or Idc2. Idc1: When based on the inductance change rate (30% below the nominal value) Idc2: When based on the temperature increase (Temperature increase of 40°C by self heating) ○ Measurement equipment Measurement item Product No. L 4194A DC resistance VP-2941A Rated current Idc1 4284A+42841A+42842C * Equivalent measurement equipment may be used. Manufacturer Agilent Technologies Panasonic Agilent Technologies • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (15/17) I N D U C T O R S VLM series VLM13580-D1 Type ELECTRICAL CHARACTERISTICS L FREQUENCY CHARACTERISTICS GRAPH 5000 4000 Inductance(nH) 3R3M 3000 2R2M 2000 1R5M 1000 R82M 0 10 100 1000 Frequency(kHz) 10000 100000 ○ Measurement equipment Product No. Manufacturer 4294A Agilent Technologies * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (16/17) I N D U C T O R S VLM series VLM13580-D1 Type ELECTRICAL CHARACTERISTICS INDUCTANCE VS. DC BIAS CHARACTERISTICS GRAPH 6000 5000 Inductance(nH) 4000 3000 3R3M 2000 2R2M 1R5M 1000 R82M 0 0 5 10 15 20 DC current(A) 25 30 35 40 ○ Measurement equipment Product No. Manufacturer 4284A+42841A+42842C Agilent Technologies * Equivalent measurement equipment may be used. • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm (17/17) I N D U C T O R S VLM series Packaging Style REEL DIMENSIONS 2.0±0.5 E Type VLM10555-2H VLM10555-3H VLM13580-D1 A ø330 ø330 ø330 W1 25.5 25.5 25.5 W2 30.4 30.4 30.4 N ø100 ø100 ø100 E 2 2 2 N * These values are typical values. (1.0) ø13.0±0.5 W1 ø21.0±0.8 W2 A Dimensions in mm TAPE DIMENSIONS P2 P0 K P1 t A Type VLM10555-2H VLM10555-3H VLM13580-D1 A 11.5 11.5 13.5 B 11.5 11.5 13.5 B W F E øD0 øD0 1.5+0.1/-0 1.5+0.1/-0 1.5+0.1/-0 Dimensions in mm E F P0 P1 P2 W 1.75±0.1 11.5±0.1 4.0±0.1 16.0±0.1 2.0±0.1 24.0±0.3 1.75±0.1 11.5±0.1 4.0±0.1 16.0±0.1 2.0±0.1 24.0±0.3 1.75±0.1 11.5±0.1 4.0±0.1 16.0±0.1 2.0±0.1 24.0±0.3 K 6.2 6.2 8.3 t 0.4 0.4 0.5 • All specifications are subject to change without notice. 001-01 / 20131101 / inductor_automotive_power_vlm_en.fm
VLM10555T-1R2M100-3H 价格&库存
很抱歉,暂时无法提供与“VLM10555T-1R2M100-3H”相匹配的价格&库存,您可以联系我们找货
