WT545490-11K2-FS
WT545490-11K2-FS
    TDK(东电化)
    1 线圈,2 层 8.9µH 无线充电线圈 发射器 60 毫欧
WT545490-11K2-FS 数据手册
TDK P/N: : WT545490-11K2-FS Black PET tape Ferrite sheet White PET tape Wireless charging Coil thickness Coil+Resin Adhesive Tape PET Tape Main sheet PET Tape Total Max. 1.15 1.15 0.03 0.05 0.90 0.05 3.33 1.35 1.35 0.03 0.05 0.99 0.05 3.83 Unit:mm Typ. Max. 1.15 0.03 0.05 0.90 0.05 2.18 1.35 0.03 0.05 0.99 0.05 2.48 Top view 54,0 Typ. 37,0 Typ. 10,0 Typ. 54,0 Typ. Adhesive tape or Glue Typ. Solder coat Side view 3,33 Typ. Air Coil Wireless charging Coil thickness (Include I/O) Coil+Resin Coil+Resin Adhesive Tape PET Tape Main sheet PET Tape Total Unit:mm 13,0 Typ. 2,18 Typ. Bottom view Sheet material : FK2 Sheet thickness : 0.90mm Wire Type : 0.06mm x 180 Ts : 11 Ls [uH] : 8.9 typ @100kHz Rs [ohm] : 0.06 typ @100kHz Q : 104.0 typ @100kHz Rdc [ohm]: 0.05 typ 54,0 Typ. 54,0 Typ. Wireless Charging TDK Confidential © TDK Corporation 2014 Oct
WT545490-11K2-FS 价格&库存
很抱歉,暂时无法提供与“WT545490-11K2-FS”相匹配的价格&库存,您可以联系我们找货
