Series
Programmable DC Power Supplies
200W/400W/600W/800W in 2U
Built-in USB, RS-232 & RS-485 Interface
Optional Interface:
LAN
IEEE488.2 SCPI (GPIB) Multi-Drop
Isolated Analog Programming
Features Include:
• High Power Density 200W/400W/600W/800W in 2U: 3.5 Inch (89mm) height
• Wide Range Input (85-265Vac continuous)
• Active Power Factor Correction (0.99 typical)
• Output Voltage up to 100V, Current up to 72A
• Constant Voltage (CV)/(CC) Constant Current auto-crossover
• Built-in RS-232/RS-485 Interface Standard
• Global Commands for Serial RS-232/RS-485 Interface
• Auto-Re-Start / Safe-Start: user selectable
• Last-Setting Memory
• High Resolution 16 bit ADCs & DACs
• Low Ripple & Noise
• Front Panel Lock selectable from Front Panel or Software
• Reliable Encoders for Voltage and Current adjustment
• Parallel Operation with Active Current Sharing, for up to six identical units
• Advanced Parallel Master / Slave. Total Current is programmed and measured via the Master
• External Analog Programming and Monitoring (user selectable 0-5V & 0-10V)
• Reliable Modular and SMT Design
• 19” Rack Mount Capability for ATE and OEM applications
• Optional Interfaces
Isolated Analog Programming and Monitoring Interface (0-5V/0-10V & 4-20mA)
IEEE 488.2 SCPI (GPIB) Multi-Drop
LAN
LabView® and LabWindows® drivers
• Arbitrary functions for:
Automotive or laser simulation / 4 Pre-Programmed Functions
• Fast Command Processing Time
• Output Sequencing
• Four-cell Memory Settings
• User Programmable Signal Pins
• Five Year Warranty
• Worldwide Safety Agency Approvals; CE Mark for LVD and EMC regulations
2
Front Panel Description
1.
2.
3.
4.
5.
6.
7.
AC ON/OFF Switch
Air Intake allows zero stacking for maximum system flexibility and power density.*
Reliable encoder controls Output Voltage and power supply setting.
Volt Display shows Output Voltage and directly displays and power supply settings.
Reliable encoder controls Output Current, and power supply setting.
Current Display shows Output Current and power supply setting.
Function/Status LEDs:
• Alarm
• Fine Control
• Preview Settings
• Foldback Mode
• Remote Mode
• Output On
8. Pushbuttons allow flexible user configuration
• Coarse and Fine adjustment of Output Voltage/Current and Advanced Parallel Master or Slave
• Preview settings and set Voltage/Current with Output OFF, Front Panel Lockout
• Set OVP, UVP, UVL Limits
• Set Current Foldback
• Local/Remote Mode and select Address and Baud Rate
• Output ON/OFF and Auto-Start/Safe-Start Mode
• Menu
9. Optional front panel output jacks (binding post style, Ø 4mm) for modules up to 60V: 24A Max
10. Optional front panel insulated output sockets (Ø 4mm) for modules up to 60V: 24A Max
* Zero stacking - side-by-side mounting of 6 units in a 19" Rack
3
Rear Panel Description
1.
2.
3.
4.
5.
6.
7.
Connector allows (Non-isolated) Analog Program and Monitor and other functions.
Remote/Local Output Voltage Sense Connections.
Signal Connector
RS-232/RS-485 INPUT Remote Serial Programming.
RS-485 OUTPUT to other Z Power Supplies.
USB Interface
Wide-Range Input 85-265VAC continuous, 47/63Hz with Active Power Factor Correction (0.99 typical)
AC Input Connector: IEC320 -C16.
8. Exhaust air exits at the back. Allows vertical stacking of units without any separation between units
9. Output Connections: Rugged Busbars for 6V up to 100V.
10. Optional Interface Position for LAN Interface.
11. Optional Interface Position for GPIB Interface (shown) or Isolated Analog Interface.
4
Power Benchtop Parallel and Series Configurations
Benchtop Power Supply
Parallel operation - Master/Slave:
Active current sharing allows up to six identical units to be connected in an auto-parallel
configuration for six times the output power.
In Advanced Parallel Master/Slave Mode, total current is programmed and reported by the
Master, Up to six supplies act as one.
Series operation
Up to two units may be connected in series to increase the output voltage or to provide
bipolar output.
Remote Programming via Built-in USB, RS-232 & RS-485 Interface
Standard Serial Interface allows daisy chain control of up to 31 power supplies on the same
bus with built-in RS-232 & RS-485 Interface.
Optional Interface:
LAN & IEEE488.2 SCPI (GPIB)
Multi-Drop
Allows LAN/IEEE Master to control up to 31 slaves over RS-485 daisy-chain
Only the Master needs be equipped with LAN/IEEE Interface
USB
RS-232
RS-485
LAN
IEEE
RS-485
5
RS-485
Applications
Z series power supplies have been designed to meet the demands of a wide variety of applications.
Test and Measurement
Built-in Last-Setting memory based on Flash Memory
no battery or capacitor backup. Simplifies test
design and requirements.
Built-in RS-232/RS-485 gives maximum system
flexibility along with 0-5V and 0-10V, selectable analog
programming.
Wide range of available inputs allows testing of many
different devices.
Semiconductor Burn-in
Safe-Start mode ENABLED - to re-start at Output OFF
to protect load.
Wide range input (85-265Vac) with Active Power Factor
correction rides through input transients easily.
Component Test
High power density, zero stacking and single wire
parallel operation, give maximum system flexibility.
Laser Diode
OVP is directly set on Voltage Display, assuring accurate
protection settings.
Fast Constant Current response, no over shoot.
Current Limit Fold Back assures load is protected from
current surges.
Heater Supplies
Smooth, reliable encoders enhance front panel control.
Remote analog programming is user selectable 0-5V or 0-10V.
RF Amplifiers and Magnets
Robust design assures stable operation under a wide
variety of loads. High linearity in Voltage & Current mode.
Z+ Series Sequence Programming Applications
Basic Voltage Profile
A
A
C
t1
t2
t3
t4
t5
Reset behaviour at voltage drop
Discontinuities in supply voltage
Momentary drop in supply voltage
6
Options: (200W/400W/600W/800W)
Front Panel Output
Up to 60V Output Module
P/N: Z_ _ - _ _ - L
P/N: Z_ _ - _ _ - L2
Optional front panel output jacks (binding post style, (Ø 4mm) for modules up to 60V: 24A Max
Z+ Assemblies
Dual Output Housing (for 105mm) 200W/400W/600W/800W
Triple Output Housing (for 70mm) 200W/400W/600W/800W
P/N: Z-NL200 (same p/n for both Dual & Triple Output Housing)
19" Rack Mounted to 4.8kW
Six units (70mm) can be assembled into 19-Inch rack/2U high
Four units (105mm) can be assembled into 19-Inch rack/2U high
to meet your configuration requirements.
In cases where the entire rack is not occupied with power units,
P/N: Z-BP for 70mm, P/N: Z-WBP for 105mm blank panels can be installed:
P/N: Z-NL100
Power Modules Table
Module Type
0~10V
0~20V
0~36V
0~60V
0~100V
19" rack width
19" rack width
200W
400W
600W
800W
20A
40A
60A
72A
10A
20A
30A
40A
6A
12A
18A
24A
3.5A
7A
10A
14A
2A
4A
6A
8A
1/6 width 1/6 width 1/6 width 1/6 width
1/4 width 1/4 width 1/4 width 1/4 width
7
1/6 width
1/4 width
-L
-L2
Programming Options (Factory Installed)
Digital Programming via IEEE Interface
P/N: IEEE
• IEEE 488.2 SCPI Compliant
• Program Voltage
• Program Current
• Measure Current
• Measure Voltage
• Current Foldback shutdown
• Over Voltage setting and shutdown
• Error and Status Messages
• Multi-Drop
• Allows IEEE Master to control up to 31 slaves over RS-485 daisy-chain
• Only the Master needs be equipped with IEEE Interface
Four Channels to Program and Monitor Voltage and Current.
Isolation allows operation with floating references in harsh electrical environments.
Choose between programming with Voltage or Current.
Connection via removable terminal block: Phoenix MC1,5/8-ST-3.81.
P/N: IS510
• Voltage Programming, user-selectable 0-5V or 0-10V signal.
Power Supply Voltage and Current Programming Accuracy ±1%
Power Supply Voltage and Current Monitoring Accuracy ±1.5%
P/N: IS420
• Current Programming with 4-20mA signal.
LAN Interface
• VISA & SCPI Compatible
• Address Viewable on Front Panel
• Fixed and Dynamic Addressing
• Compatible with most standard Networks
P/N: LAN
• TCP / UDP Socket Programming
• LAN Fault Indicators
• Auto-detects LAN Cross-over Cable
• Fast Startup
AC Cord
Region
Output Power
AC Cords
Wall Plug
Power Supply
Connector
Europe
850W
10A/250Vac L=2m
INT'L 7/VII
IEC320-C15
Japan
850W
15A/125Vac L=2m
JIS C8303
IEC320-C15
Part Number
P/N: Z-E
P/N: Z-J
North America
Israel
850W
850W
13A/125Vac L=2m 10A/250Vac L=2m
NEMA 5-15P
SI-32
IEC320-C15
IEC320-C15
P/N : Z-U
P/N: Z-I
Communication Cable
RS-232/RS-485 Cable is used to connect the power supply to the PC Controller
Mode
RS-485
RS-232
PC Connector
DB-9F
DB-9F
Communication Cable
Shield Ground L=2m
Shield Ground L=2m
Power Supply Connector
EIA/TIA-568A (RJ-45)
P/N
Z/485-9
Z/232-9
Serial Link Cable*
Daisy-chain up to 31 Z Series power supplies.
Mode
RS-485
* Included with power supply
8
Communication Cable
P/N
Shield Ground
Z/RJ45
Power Supply Identification / Accessories
How to order
Z
10 -
Series
Name
40-
Output Voltage Output Current
(0~10V)
(0~40A)
Factory option
Factory
Options:
IEEE
LAN
IS510
IS420
Output
Jacks
Z10-20
Z10-40
Z10-60
Z10-72
Z20-10
Z20-20
Z20-30
Z20-40
Z36-6
Z36-12
Z36-18
Z36-24
Z60-3.5
Z60-7
Z60-10
Z60-14
Z100-2
Z100-4
Z100-6
Z100-8
L2
P/N
USB Interface built-in Standard
RS-232/RS-485 Interface built-in Standard
GPIB Interface
IEEE
Voltage Programming Isolated Analog Interface
IS510
Current Programming Isolated Analog Interface
IS420
LAN Interface
LAN
Front panel output jacks (binding post style, Ø 4mm)
for modules up to 60V or 24A Max
Front panel insulated output sockets (Ø 4mm)
Model
L
Output
Voltage
(VDC)
0~10 VDC
0~20 VDC
0~36 VDC
0~60 VDC
0~100VDC
Output
Current
(A)
0~20
0~40
0~60
0~72
0~10
0~20
0~30
0~40
0~6
0~12
0~18
0~24
0~3.5
0~7
0~10
0~14
0~2
0~4
0~6
0~8
L
L2
Output
Power
(W)
200
400
600
720
200
400
600
800
216
432
648
864
210
420
600
840
200
400
600
800
9
AC cord Options:
Region :
E - Europe
J - Japan
U - North America
I - Middle East
C - China
2.1 Z+200 Series Specifications
MODEL
1. Rated output voltage(*1)
2. Rated output current (*2)
3. Rated output power
CONSTANT VOLTAGE MODE
1. Max. Line regulation (*6)
2. Max. Load regulation (*7)
3. Ripple and noise (p-p, 20MHz) (*8)
4. Ripple r.m.s. 5Hz~1MHz
5. Temperature coefficient
6. Temperature stability
7. Warm-up drift
8. Remote sense compensation/wire
9. Up-prog. Response time, 0~Vomax.(*9)
10. Down-prog. response time:
Full load (*9)
Time delay (*17)
No load (*10) (*15)(*17)
No load (*10) (*16)(*17)
Z
V
A
W
10-20
10
20-10
200
Z
----mV
mV
PPM/°C
----V
mS
10-20
20-10
10-20
20-10
mS
36-6
36
6
216
60-3.5
60
3.5
210
100-2
100
2
200
36-6
60-3.5
100-2
0.01% of rated output voltage+2mV
50
50
50
50
80
5
6
6
7
8
30PPM/°C from rated output voltage, following 30 minutes warm-up.
0.02% of rated Vout over 8hrs. interval following 30 minutes warm-up. Constant line, load & temp.
Less than 0.05% of rated output voltage+2mV over 30 minutes following power on.
1
1
2
3
5
15
30
30
50
50
12
25
30
40
50
210
250
320
380
1200
40
65
85
100
250
200
200
290
310
1100
Time for output voltage to recover within 0.5% of its rated output for a load change 10~90% of rated output
current. Output set-point: 10~100%, Local sense. Less than 1mS, for models up to and including 100V
15mSec Typical.
16mSec Typical.
11. Transient response time
mS
12. Hold-up time (*19)
CONSTANT CURRENT MODE
2. Max. Load regulation (*11)
3. Load regulation thermal drift
4. Ripple r.m.s. 5Hz~1MHz (*12)
7. Warm-up drift
Z
------mA
PPM/°C
36-6
60-3.5
100-2
0.01% of rated output current+2mA
0.01% of rated output current+5mA
Less than 0.05% of rated output current over 30 minutes following load change.
25
15
8
4
3
100PPM/°C from rated output current, following 30 minutes warm-up.
0.05% of rated Iout over 8hrs. interval following 30 minutes warm-up. Constant line, load & temperature.
Less than +/-0.1% of rated output current over 30 minutes following power on.
PROTECTIVE FUNCTIONS
Z
1. Foldback protection
2. Over-voltage protection (OVP)
3. Over -voltage trip point
4. Output under voltage limit (UVL)
V
5. Output under voltage protection (UVP)
6. Over temperature protection
10-20
20-10
36-6
60-3.5
100-2
Output shut-down when power supply change mode from CV to CC or CC to CV. User presetable.
Reset by AC input recycle in autostart mode or by OUTPUT button or by rear panel ENABLE, or by communication port.
Inverter Shut down method. Reset by AC input recycle in autostart mode or by OUTPUT button or by
0.5~12
1~24
2~40
5~66
5~110
Preset by front panel or communication port. Prevents from adjusting Vout below limit. Does not affect in analog programming.
Output shut-down when power supply output voltage goes below UVP programming. User presetable.
User selectable, latched or non latched.
ANALOG PROGRAMMING AND MONITORING
1. Vout voltage programming
2. Iout voltage programming (*13)
3. Vout resistor programming
4. Iout resistor programming (*13)
5. Shut Off (SO) control
6. Output current monitor (*13)
7. Output voltage monitor
8. Power supply OK signal
9. Parallel operation (*20)
10. Series operation
11. CV/CC indicator
12. Interlock (ILC) control
13. Local/Remote mode Control
14. Local/Remote mode Indicator
15.Trigger out
16.Trigger in
17. Programmed signal 1
18. Programmed signal 2
0~100%, 0~5V or 0~10V, user selectable. Accuracy and linearity: +/-0.5% of rated Vout.
0~100%, 0~5V or 0~10V, user selectable. Accuracy and linearity: +/-1% of rated Iout.
0~100%, 0~5/10Kohm full scale, user selectable. Accuracy and linearity: +/-1% of rated Vout.
0~100%, 0~5/10Kohm full scale, user selectable. Accuracy and linearity: +/-1.5% of rated Iout.
By electrical Voltage: 0~0.6V/4~15V or dry contact, user selectable logic.
0~5V or 0~10V, user selectable. Accuracy: +/-1%.
4~5V-OK, 0V-Fail. 500ohm series resistance.
Possible, up to 6 units in master/slave mode with single wire current balance connection.
2 identical units (with external diodes).
Open collector. CC mode: On, CV mode: Off. Maximum voltage: 30V, maximum sink current: 10mA
Enables/Disables the PS output by dry contact (Short: On, Open: Off, Source current: less than 0.5mA). Ena/Dis is activated by front panel.
By electrical signal or Open/Short: 0~0.6V or short: Remote, 2~15V or open: Local
Open collector (shunted by 36V zener). On (0~0.6V, 10mA sink current max.)-Remote. Off-Local (30V max.).
Maximum low level output =0.8V, Minimum high level output =3.8V, Maximum high level output =5V,
Maximum source current =16mA, pulse =20μs Typical.
Maximum low level input =1.2V, Minimum high level input =3.5V, Maximum high level input =5V,
Maximum sink current =16mA, positive edge, trigger: tw =10μs minimum, Tr/Tf =1μs maximum.
Open collector, maximum voltage 25V,maximum sink current 100mA. (Shunted by 27V zener)
Multiple options with 2 Encoders
Vout/Iout manual adjust
OVP/UVL/UVP manual adjust
Protection Functions - OVP, UVL,UVP, Foldback, OCP, INT, SO
Communication Functions - Selection of LAN,IEEE,RS232,RS485,USB
Communication Functions - Selection of Baud Rate, Address
Analog Control Functions - Selection Voltage/resistive programming, 5V/10V, 5K/10K programming
Analog Control Functions - Selection of Voltage/Current Monitoring 5V/10V, Output ON/OFF, Front Panel Lock.
Vout: 4 digits, accuracy: 0.5% of rated output voltage+/-1 count.
Iout: 4 digits, accuracy: 0.5% of rated output current+/-1 count.
GREEN LEDs: FINE, MENU, PREV, PROT, REM, OUTPUT, CV, CC
RED LED: PROT (OVP, UVP, OTP, FOLD, AC FAIL).
FRONT PANEL
1. Control functions
2. Display
3. Indications
4. Function buttons
10
PROGRAMMING AND READBACK (RS232/485,USB, Optional: IEEE, LAN)
1. Vout programming accuracy
--2. Iout programming accuracy (*13)
--3. Vout programming resolution
--4. Iout programming resolution
--5. Vout readback accuracy
--6. Iout readback accuracy (*13)
--7. Vout readback resolution
--8. Iout readback resolution
--INPUT CHARACTERISTICS
1. Input voltage/freq. (*3)
2. Maximum Input current 100/200VAC (*4) (*18)
3. Power Factor (Typ)
4. Efficiency (Typ) 100/200VAC (*4) (*18)
5. Inrush current 100/200VAC (*5)
ENVIRONMENTAL CONDITIONS
1. Operating temperature
2. Storage temperature
3. Operating humidity
4. Storage humidity
Z
5. Altitude
SAFETY/EMC
0.1% of actual +0.1% of rated output current
0.012% of full scale
0.1% of actual +0.3% of rated output current
10-20
20-10
36-6
60-3.5
85~265Vac continuous, 47~63Hz, single phase
2.62/1.29
2.76/1.37
2.69/1.33
>0.99 at 100Vac, >0.98 at 200Vac,100% load
77/79
79/80.5
79/80.5
Less than 15A/30A
2.65/1.31
76/77.5
100-2
2.55/1.26
79/81
0~50°C, 100% load.
-20~85°C
20~90% RH (no condensation).
10~95% RH (no condensation).
Maximum 3000m. Derate ambient temp above 2000m.
Operating: Maximum ambient temperature, From 2000m up to 3000m Ambient temperature 40°C.
2. Withstand voltage
3. Insulation resistance
4. Conducted emission
5. Radiated emission
UL61010-1, EN61010-1, IEC61010-1. Design to meet UL60950-1, EN60950-1
10V≤Vout≤60V: Output,J1,J2,J3,J4,USB,LAN,IEEE/ISOLATED Analog are Non Hazardous
Vout=100V:Output,J1,J2 are Hazardous J3,J4,USB, IEEE/ISOLATED Analog ,LAN are Non Hazardous
IEC/EN61326-1 (Built to meet EN55022/EN55024)
10≤Vout≤36V models: Input-Output&J1,J2,J3,J4,USB,LAN/IEEE/ISOLATED ANALOG: 4242VDC/1min;
Input-Ground: 2828VDC/1min.
Output&J1,J2,J3,J4,USB,LAN/IEEE/ISOLATED ANALOG-Ground: 707VDC/1min.
60V,100V models: Input-Output&J1,J2: 4242VDC/1min; Input-J3,J4,USB,LAN/IEEE/ISOLATED Analog:
4242VDC/1min; Input-Ground: 2828VDC/1min.
Output&J1,J2- J3,J4,USB,LAN/IEEE/ISOLATED ANALOG :1910VDC/1min; Output&J1,J2-Ground:
1380VDC/1min.
J3, J4, USB/LAN/IEEE/ISOLATED ANALOG - Ground: 707VDC/1min;
More than 100Mohm at 25°C, 70%RH.
IEC/EN61326-1 Industrial Location - B, FCC part 15-B, VCCI-B
IEC/EN61326-1 Industrial Location - A, FCC part 15-A, VCCI-A
1. Cooling
--Kg
Kg
mm
mm
Forced air cooling by internal fan.
Less than 1.9Kg.
Less than 2.4Kg. Wide body with Isolated analog or Binding post or IEEE.
H: 83, W: 70, D: 350 (excluding bus bars, handles…). (Refer to Outline drawing).
H: 83, W: 105, D: 350 (excluding bus bars, handles…). (Refer to Outline drawing).
According to: IEC60068-2-64
Less than 20G, half sine, 11mS. Unit is unpacked. According to: IEC60068-2-27
1. Applicable standards:
Safety
EMC
MECHANICAL
2. Weight
3. Dimensions (WxHxD)
4. Vibration
5. Shock
STANDARD
WIDE BODY
STANDARD
WIDE BODY
NOTES:
*1: Minimum voltage is guaranteed to maximum 0.1% of rated output voltage.
*2: Minimum current is guaranteed to maximum 0.2% of rated output current.
*3: For cases where conformance to various safety standards (UL, IEC, etc…) is required, to be described as 100-240Vac (50/60Hz).
*4: Ta=25°C with rated output power.
*5: Not including EMI filter inrush current, less than 0.2mSec at cold start Ta=25°C
*6: At 85~132Vac or 170~265VAC, constant load.
*7: From No-Load to Full-Load, constant input voltage. Measured at the sensing point in Remote Sense.
*8: Measured with JEITA RC-9131A (1:1) probe.
*9: From 10% to 90% or 90% to 10% of Rated Output Voltage, with rated resistive load.
*10: From 90% to 10% of Rated Output Voltage.
*11: For load voltage change, equal to the unit voltage rating, constant input voltage.
*12: For 10V model the ripple is measured at 2V to rated output voltage and rated output current. For other models, the ripple is measured
at 10~100%
of rated output voltage and rated output current.
*13: The Constant Current programming, readback and monitoring accuracy do not include the warm-up and Load regulation thermal drift.
*14: Measured with JEITA RC-9131A (1:1) probe.
*15: For cases where the time interval between each down programming is longer than Td (time delay).
*16: For cases where the time interval between each down programming is shorter than Td (time delay).
*17: Td typical Minimum time between consecutive down programming cycles.
*18: PS with Lan, IEEE, models decrease efficiency by 0.5% and increase input current by 0.5%.
PS with Isolated analog option decreases efficiency by 1.5% and increases input current by 1.5%.
*19: At rated output power.
*20: For Parallel operation more than 2 units 5% of total output current is requierd.
11
2.2 Z+400 Series Specifications
MODEL
7. Warm-up drift
Full load (*9)
Time delay (*17)
No load (*10) (*15) (*17)
No load (*10) (*16) (*17)
Z
V
A
W
10-40
10
40
400
20-20
Z
----mV
mV
PPM/°C
----V
mS
10-40
20-20
10-40
20-20
mS
36-12
36
12
432
60-7
60
7
420
100-4
100
4
400
36-12
60-7
100-4
50
50
50
50
80
5
6
6
7
8
1
1
2
3
5
15
30
30
50
50
10
10
15
30
50
210
250
320
380
1200
40
65
85
100
250
200
200
290
310
1100
15mSec Typical.
16mSec Typical.
mS
7. Warm-up drift
Z
------mA
PPM/°C
36-12
60-7
100-4
70
40
15
8
3
Z
10-40
20-20
36-12
60-7
100-4
0.5~12
1~24
2~40
5~66
5~110
User Selectable. Latched or non latched
3. Over - voltage trip point
V
9. Parallel operation (*21)
11. CV/CC indicator
15.Trigger out
16.Trigger in
Open collector, maximum voltage 25V, maximum sink current 100mA. (Shunted by 27V zener)
OVP/UVL /UVP manual adjust
Protection Functions - OVP, UVL, UVP, Foldback, OCP, INT, SO
Communication Functions - Selection of LAN,IEEE (*20), RS232,RS485,USB
FRONT PANEL
2. Display
3. Indications
4. Function buttons
12
PROGRAMMING AND READBACK (RS232/485,USB, Optional: IEEE(*20), LAN)
5. Inrush current (*5)
4. Storage humidity
Z
5. Altitude
10-40
20-20
36-12
60-7
4.98/2.45
5.25/2.57
5.10/2.50
0.99 at 100/200Vac, 100% load
81/83
83/85
83/85
Less than 25A
5.05/2.47
80/82
100-4
4.80/2.37
84/86
0~50°C, 100% load.
-20~85°C
SAFETY/EMC
1380VDC/1min.
1. Cooling
--Kg
Kg
mm
mm
Less than 1.9Kg.
Safety
EMC
MECHANICAL
2. Weight
4. Vibration
5. Shock
STANDARD
WIDE BODY
STANDARD
WIDE BODY
NOTES:
*5: Not including EMI filter inrush current, less than 0.2mSec.
at 10~100%
*16: For cases where the time interval between each down programming is shorter than Td (Time delay).
*18: PS with Lan, IEEE, models decrease efficiency by 0.25% and increase input current by 0.25%.
PS with Isolated analog option decreases efficiency by 0.75% and increases input current by 0.75%.
*20: Max. ambient temperature for using IEEE is 45°C
*21: For Parallel operation more than 2 units 5% of total output current is requierd.
13
2.3 Z+600 Series Specifications
MODEL
7. Warm-up drift
Full load (*9)
Time delay (*17)
Z
V
A
W
10-60
10
60
600
20-30
600
Z
----mV
mV
PPM/°C
----V
mS
10-60
20-30
10-60
20-30
mS
mS
12. Hold-up time (*18)
Z
------mA
PPM/°C
7. Warm-up drift
Z
V
11. CV/CC indicator
15.Trigger out
16.Trigger in
36-18
36
18
648
60-10
60
10
600
100-6
100
6
600
36-18
60-10
100-6
50
50
50
50
80
5
5
5
12
15
0.05% of rated Vout over 8hrs. interval following 30 minutes warm-up. Constant line, load & temp.
1
1
2
3
5
50
50
50
50
100
25
25
25
25
80
285
425
450
570
1370
65
110
155
175
375
280
470
470
500
1200
15mSec Typical.
20mSec Typical.
36-18
60-10
100-6
Less than 0.15% of rated output current over 30 minutes following load change.
150
75
25
8
5
10V Model: Less than +/-0.3% of rated output current over 30 minutes following power on.
20V, 36V Model: Less than +/-0.15% of rated output current over 30 minutes following power on.
60V, 100V Models: Less than +/-0.1% of rated output current over 30 minutes following power on.
10-60
20-30
36-18
60-10
100-6
0.5~12
1~24
2~40
5~66
5~110
User Selectable. Latched or non latched.
14
FRONT PANEL
2. Display
3. Indications
4. Function buttons
Communication Functions - Selection of LAN,IEEE (*19), RS232,RS485,USB
PROGRAMMING AND READBACK (RS232/485,USB, Optional: IEEE(*19), LAN)
4. Storage humidity
10-72
5. Altitude
20-40
36-24
60-14
9.60/4.70
9.40/4.60
10.00/4.90
84/86
85/87
85/87
Less than 25A
8.9/4.40
81/83
100-8
9.05/4.60
85/87
0~50°C, 100% load.
-20~85°C
SAFETY/EMC
EMC
MECHANICAL
1. Cooling
2. Weight
4. Vibration
5. Shock
Safety
--STANDARD
WIDE BODY
STANDARD
WIDE BODY
Kg
mm
IEC61326-1 (Built to meet EN55022/EN55024)
10≤Vout≤36V models: Input-Output&J1,J2,J3,J4,USB,LAN/IEEE/ISOLATED ANALOG: 4242VDC/1min; Input-Ground: 2828VDC/1min.
Output&J1,J2,J3,J4,USB,LAN/IEEE/ISOLATED ANALOG-Ground: 1000VDC/1min.
60V,100V models: Input-Output&J1,J2: 4242VDC/1min; Input-J3,J4,USB,LAN/IEEE/ISOLATED Analog: 4242VDC/1min; Input-Ground: 2828VDC/1min.
Output&J1,J2- J3,J4,USB,LAN/IEEE/ISOLATED ANALOG :1910VDC/1min; Output&J1,J2-Ground: 1380VDC/1min.
J3, J4, USB/LAN/IEEE/ISOLATED ANALOG - Ground: 1000VDC/1min;
EN55022B, FCC part 15-B, VCCI-B
Less than 2.5Kg.
Less than 3.0Kg. Wide body with Isolated analog or Binding post or IEEE.
According to:IEC60068-2-64
Less than 20G, half sine, 11mS. Unit is unpacked. According to: IEC600068-2-27
NOTES:
*12: For 10V model the ripple is measured at 2V to rated output voltage and rated output current. For other models, the ripple is measured at 10~100%
*17: Td typical (±20%) Minimum time between consecutive down programming cycles.
*18: PS with isolated analog option decreases efficiency by 0.5% and increases input current by 0.5%
*19: For Parallel operation more than 2 units 5% of toatal output current is requierd.
15
2.4 Z+800 Series Specifications
MODEL
Vin ≥ 100Vac, Ta ≤ 50°C
2. Rated output
85Vac ≤ Vin < 100Vac, Ta ≤ 40°C
current (*2)(*21)
85Vac ≤ Vin < 100Vac, 40°C < Ta ≤ 50°C
3. Rated output
power
7. Warm-up drift
Full load (*9)
Time delay (*17)
Z
V
A
A
A
W
W
W
10-72
10
72
72
66
720
720
660
20-40
40
36
800
800
720
Z
----mV
mV
PPM/°C
----V
mS
10-72
20-40
10-72
20-40
mS
mS
Z
mA
PPM/°C
7. Warm-up drift
Z
V
11. CV/CC indicator
36-24
36
24
24
864
720
60-14
60
14
14
12.5
840
840
750
100-8
100
8
8
7.5
800
800
750
36-24
60-14
100-8
50
50
50
60
80
5
5
5
12
15
1
1
2
3
5
50
50
50
50
100
25
25
25
25
80
285
425
450
570
1370
65
110
155
175
375
280
470
470
500
1200
10mSec Typical. Rated output power.
36-24
60-14
100-8
For 10V: Less than 0.15% of rated output current over 30 minutes following load change.
For 20V ~ 100V: Less than 0.1% of rated output current over 30 minutes following load change.
180
100
31
28
12
10V model: Less than +/-0.3%, 20V model: Less than +/-0.15%, 36V~100 models: Less than +/-0.1% of
10-72
20-40
36-24
60-14
100-8
0.5~12
1~24
2~40
5~66
5~110
15.Trigger out
16.Trigger in
Communication Functions - Selection of LAN,IEEE (*19) ,RS232,RS485,USB
FRONT PANEL
16
FRONT PANEL
2. Display
3. Indications
4. Function buttons
4. Storage humidity
Z
5. Altitude
Rated output current at 100≤Vin≤265Vac
Rated output current at 85≤Vin
