USR UNR 4-T220 4-T220B 4-T221 USS UNS 4-T220
• Near Temperature Independent • Lowest Tolerances • Low Capacitance and Inductance • High Power • Available also 2-pin version
SPECIFICATIONS ELEKTRICAL
Resistance range Nominal power : :
• Highest Stability
USR 4-T220
0R2...80R
UNR 4-T220 note1)
0R2...80R
Thermal Resistance Rthj-c : Tolerances : from 0R5 : from 10R : from 50R : Stability : Temperature coefficient :
1.5 W (70°C) without heatsink 10 W* 15 W* * with heatsink 10.8 K/W 6.8 K/W 0.1%, 0.25%, 0.5%, 1% 0.05%, 0.1%, 0.25%, 0.5%, 1% 0.01%, 0.02%, 0.05%, 0.1%, 0.25%, 0.5%, 1% 0.01% max. ±5 ppm/K (-55...155)°C typ. ±3 ppm/K (-55...125)°C upon request ±1 ppm/K (0...60)°C 1 kVDC < 1 µV/K
Voltage Proof Thermal EMF
ENVIRONMENTAL
Operating Temperature Range : -55°C...155°C MECHANICAL Resistor Material : NiCr-Foil AlN Substrate : Al2O3 Housing : Epoxy + heatsink Cu nickel plated Connector Material : Cu, tinned, 4-pin Max. torque backplate : 1.0 Nm note1): Specially designed for applications with fast changing electrical load.
TEMPERATURE COEFFICIENT
600 400 -5 ppm/K 200 0 +2,2 ppm/K -200 -400 - 600 -50 -25 0 25 50 Tem perature (°C) 75 100 125 +5 ppm/K
dR/R (ppm )
No minal-Spread
-1,8 ppm/K +/-2,3 ppm/K
No minal-dR/R No minal-Spread +/-2,3 ppm/K
Willow Technologies Ltd. Shawlands Court, Newchapel Road, Lingfield, Surrey, RH7 6BL, UK Tel. + 44 (0) 1342 835234, Fax. + 44 (0) 1342 834306, e-mail sales@willow.co.uk web www.willow.co.uk
USR UNR USS UNS
DERATING CURVE
Power ( % from nominal power)
4-T220 4-T220B 4-T221 4-T220
120 100 80 60 40 20 0 25 50 85 100 115 130 145 155 Temperature of the backplate (°C)
DIMENSIONS
USR 4-T220 UNR 4-T220
Housing for special demands and small quantities
USR 4-T220B / UNR 4-T220B
USR 4-T221 / UNR 4-T221
USS 4-T220 / UNS 4-T220
Dimensions in mm
HOW TO ORDER USR 4-T220 0R5 D 0.25% TK5 UNR 4-T220B 50R D 0.1% TK1
很抱歉,暂时无法提供与“USR4-T221”相匹配的价格&库存,您可以联系我们找货
