MS05-1A87-75DHR
MS05-1A87-75DHR
    STANDEX-MEDER(斯丹麦德)
    RELAY_15.2X3.81MM_TM
    Reed Relay SPST-NO (1 Form A) Through Hole
MS05-1A87-75DHR 数据手册
MS Series MICRO SIL Reed Relays MEDER electronic DESCRIPTION MICRO SIL is a compact version of SIL Reed Relay Serie using only 15.2 x 3.81 mm of board space which is half the standard SIL requirement. APPLICATIONS • ATE systems • Measurement equipment • Telecommunications • Security systems • • • • • FEATURES Contact Form 1A and 2A Internal magnetic shield New rugged molded design Diode option available High coil resistance option All dimensions in mm [inches] Form 1A max 3.81 [0.150"] DIMENSIONS View from top of component PIN OUT Form 2A 15.11 [0.595"] Form 1A Pitch grid: 3.81 mm [0.15”] Pin #2 must be positive when internal diode protection is present. 0.51 [0.020"] Form 2A Pitch grid: 2.54 mm [0.1”] Pin #3 must be positive when internal diode protection is present. 8.76 [0.345"] 3.17 [0.125"] ø0.51 [0.020] 2.54 [0.100"] 12.7 [0.500"] 75 78 1 • Notch in case denotes pin #1 ORDER INFORMATION Relay Series MS MS Options Nominal Voltage XX XX 05, 12 Contact Form 1A 2A Switch Model 87 87 Pin Out 75 78 Options X X L, D HR High Resistance Version XX Part Number Example MS12 - 1A87 - 75L 12 is the nominal voltage 87 is the switch model L is the option OPTIONS L = No diode (with internal shield) D = With diode and internal magnetic shield HR = High resistance version (5 Volt option only) www.meder.com 172 MEDER electronic MS Series MICRO SIL Reed Relays RELAY DATA All Data at 20° C Contact Ratings Switching Power Switch Model → Contact Form → Conditions Any DC combination of V & A not to exceed their individual max.‘s DC or peak AC DC or peak AC DC or peak AC w/ 0.5 V & 50mA Measured w/ 0.5 V & 50mA , 1.5 ms after closure Across Contact Coil - Contact Across Contact Coil - Contact Switch 87 Form A Min. Typ. Max. Units 10 W Switching Voltage Switching Current Carry Current Static Contact Resistance Dynamic Contact Resistance Insulation Resistance across Contacts Breakdown Voltage across Contact Operation Time incl. Bounce Release Time Capacitance Life Expectance Switch Voltage 5V - 10 mA 200 0.5 1.0 150 200 1010 1013 225 1500 0.5 0.1 0.2 2.0 1012 1014 V A A mΩ mΩ Ω VDC ms ms pF Nominal voltage with no coil suppression Across Contact Coil - Contact DC
MS05-1A87-75DHR 价格&库存
很抱歉,暂时无法提供与“MS05-1A87-75DHR”相匹配的价格&库存,您可以联系我们找货
