CLV1A-FKB-CH1K1E1BB7R4S3 数据手册
Cree® PLCC4 3 in 1 SMD LED CLV1A-FKB
Data Sheet
Cree PLCC full-color LEDs offer high-intensity light output and a wide viewing angle in an industry-standard package. Designed to work in a wide array of environmental conditions, Cree PLCC full-color LEDs are suited for indoor video screen, decorative lighting and amusement applications.
FEATURES • Size (mm): 3.2 x 2.8 • Dominant Wavelength (nm): Red (619-624) Green (520-540) Blue (460-480) • Luminous Intensity (mcd) Red (355-900) Green (560-1400) Blue (180-450) • Lead-Free • Viewing Angle: 120 degree • RoHS Compliant
APPLICATIONS • Full-Color Video Screen • Decorative lighting • Amusement
LD-CT874.002 Data Sheet: C
Subject to change without notice. www.cree.com/ledlamps
1
Absolute Maximum Ratings (TA = 25°C)
Absolute Maximum Rating R 50 200 5 130 G 25 100 5 100 -40 ~ +100 -40 ~ +100 110 450 650 300 450 110 400 580 280 430 110 450 680 300 480 B 25 100 5 100
Items Forward Current
Note 1
Symbol IF
Note 2
Unit mA mA V mW °C °C °C °C/W °C/W °C/W °C/W
Peak Forward Current Reverse Voltage Power Dissipation
IFP VR PD Topr Tstg TJ RTHJA RTHJA RTHJS RTHJS
Operation Temperature Storage Temperature Junction Temperature Junction/ambient 1 chip on Junction/ambient 3 chips on Junction/solder point 1 chip on Junction/solder point 3 chips on
Note:
1. 2.
Single-color light. Pulse width ≤0.1 msec, duty ≤1/10.
Typical Electrical & Optical Characteristics (TA = 25°C)
Characteristics Wavelength at peak emission Dominant Wavelength Spectral bandwidth at 50% IREL max Viewing Angle at 50% IV Forward Voltage Condition IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA VR = 5 V Symbol λPEAK λDOM Δλ 2θ½ VF(avg) VF(max) IV(min) IV(avg) IR Values R 630 619~624 24 120 2.0 2.6 355 550 10 G 527 520~540 38 120 3.2 4.0 560 850 10 B 470 460~480 28 120 3.2 4.0 180 320 10 Unit nm nm nm deg V V mcd mcd μA
Luminous Intensity Reverse Current (max)
Copyright © 2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree and the Cree logo are registered trademarks of Cree, Inc.
2
CLD-CT874.002
Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5778 www.cree.com/ledlamps
Intensity Bin Limit (IF = 20 mA)
Red
Bin Code H J K M Min.(mcd) 355 450 560 710 Max.(mcd) 450 560 710 900
Green
Bin Code K M N P Min.(mcd) 560 710 900 1120 Max.(mcd) 710 900 1120 1400
Blue
Bin Code E F G H j Min.(mcd) 180 224 280 355 450 Max.(mcd) 224 280 355 450 505
Tolerance of measurement of luminous intensity is ±10%
Color Bin Limit (IF = 20 mA)
Red
Bin Code RB Min.(nm) 619 Max.(nm) 624
Green
Bin Code G7 G8 G9 Ga Min.(nm) 520 525 530 535 Max.(nm) 525 530 535 540
Blue
Bin Code B3 B4 B5 B6 Min.(nm) 460 465 470 475 Max.(nm) 465 470 475 480
Tolerance of measurement of dominant wavelength is ±1 nm
3
CLD-CT874.002
Order Code Table*
Luminous Intensity (mcd) Kit Number Color Red CLV1A-FKB-CHMKPEHBB7a363 Green Blue Red CLV1A-FKB-CHMKPEHBB7a463 Green Blue Red CLV1A-FKB-CH1K1E1BB7R3S3 Green Blue Red CLV1A-FKB-CH1K1E1BB7R4S3 Green Blue Red CLV1A-FKB-CJ1M1F1BB7R3S3 Green Blue Red CLV1A-FKB-CJ1M1F1BB7R4S3 Green Blue Red CLV1A-FKB-CK1N1G1BB7R4S3 Green Blue Min. 355 560 180 355 560 180 Max. 900 1400 450 900 1400 450 Dominant Wavelength (nm) Color Bin RB G7 B3 RB G7 B4 RB Min. (nm) 619 520 460 619 520 465 619 Color Bin RB Ga B6 RB Ga B6 RB Max. (nm) 624 540 480 624 540 480 624 Package Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel Reel
Any 1 Intensity bin from H(355) - K(710) Any 1 Intensity bin from K(560) - N(1120) Any 1 Intensity bin from E(180) - G(355) Any 1 Intensity bin from H(355) - K(710) Any 1 Intensity bin from K(560) - N(1120) Any 1 Intensity bin from E(180) - G(355) Any 1 Intensity bin from J(450) - M(900) Any 1 Intensity bin from M(710) - P(1400) Any 1 Intensity bin from F(224) - H(450) Any 1 Intensity bin from J(450) - M(900) Any 1 Intensity bin from M(710) - P(1400) Any 1 Intensity bin from F(224) - H(450) Any 1 Intensity bin from K(560) - M(900) Any 1 Intensity bin from N(900) - P(1400) Any 1 Intensity bin from G(280) - H(450)
Any 1 hue bin from G7(520) - Ga(540) Any 1 hue bin from B3(460) - B5(475) RB 619 RB 624
Any 1 hue bin from G7(520) - Ga(540) Any 1 hue bin from B4(465) - B6(480) RB 619 RB 624
Notes: 1. The above kit numbers represent the order codes which include multiple intensity-bin and color-bin codes. Only one intensity-bin code and one color-bin code will be shipped on each reel. Single intensity-bin code and single color-bin code will be orderable in certain quantities. For example, any 1 intensity bin from H - K means only 1 intensity bin (H or J or K) will be shipped by Cree. For example, any 1 color bin from G7 - Ga means only 1 color bin (G7 or G8 or G9 or Ga) will be shipped by Cree. 2. Please refer to the “Cree LED Lamp Reliability Test Standards” document for reliability test conditions. 3. Please refer to the “Cree LED Lamp Soldering & Handling” document for information about how to use this LED product safely.
4
CLD-CT874.002
Graphs
The above data are collected from statistical figures which do not necessarily correspond to the actual parameters of each single LED. Hence, these data will be changed without further notice.
5
CLD-CT874.002
Graphs
6
CLD-CT874.002
Mechanical Dimensions
All dimensions are in mm.
Notes
RoHS Compliance The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye.
7
CLD-CT874.002
Kit Number System
Cree LED lamps are tested and sorted into performance bins. A bin is specified by ranges of color, forward voltage, and brightness. Sorted LEDs are packaged for shipping in various convenient options. Please refer to the “Cree LED Lamp Packaging Standard” document for more information about shipping and packaging options. Cree LEDs are sold by order codes in combinations of bins called kits. Order codes are configured in the following manner:
8
CLD-CT874.002
Package
• • • • • The boxes are not water resistant and they must be kept away from water and moisture. The LEDs are packed in cardboard boxes after packaging in normal or anti-electrostatic bags. Cardboard boxes will be used to protect the LEDs from mechanical shocks during transportation. The reel pack is applied in SMD LED. Max 2000 pcs per reel.
防潮珠。不可食
9
CLD-CT874.002
