rev. page date 1 of 3
09/2009
PART NUMBER: VWRBS2
DESCRIPTION: dc-dc converter
Description
Designed to convert a wide input voltage range into an isolated regulated voltage, the VWRBS2-SIP series is well suited for providing board-mount local supplies in a wide range of applications, including mixed analog/digital circuits, test & measurement equip., process/machine controls, datacom/telecom fields, etc... Model Number VWRBS2-D5-S3.3-SIP VWRBS2-D5-S5-SIP VWRBS2-D5-S9-SIP VWRBS2-D5-S12-SIP VWRBS2-D5-S15-SIP VWRBS2-D5-S24-SIP VWRBS2-D12-S3.3-SIP VWRBS2-D12-S5-SIP VWRBS2-D12-S9-SIP VWRBS2-D12-S12-SIP VWRBS2-D12-S15-SIP VWRBS2-D12-S24-SIP VWRBS2-D24-S3.3-SIP VWRBS2-D24-S5-SIP VWRBS2-D24-S9-SIP VWRBS2-D24-S12-SIP VWRBS2-D24-S15-SIP VWRBS2-D24-S24-SIP VWRBS2-D48-S3.3-SIP VWRBS2-D48-S5-SIP VWRBS2-D48-S9-SIP VWRBS2-D48-S12-SIP VWRBS2-D48-S15-SIP VWRBS2-D48-S24-SIP Note: Nominal 5 Vdc 5 Vdc 5 Vdc 5 Vdc 5 Vdc 5 Vdc 12 Vdc 12 Vdc 12 Vdc 12 Vdc 12 Vdc 12 Vdc 24 Vdc 24 Vdc 24 Vdc 24 Vdc 24 Vdc 24 Vdc 48 Vdc 48 Vdc 48 Vdc 48 Vdc 48 Vdc 48 Vdc
F eatures
·Wide (2:1) input range ·High efficiency to 82% ·Regulated ·Single voltage output ·I/O Isolation 1500VDC ·No heatsink required ·Short circuit protection ·Remote on/off ·MTBF >1,000,000 hrs ·Temperature range: -40°C~+85°C Input Voltage Range 4.5~9.0 Vdc 4.5~9.0 Vdc 4.5~9.0 Vdc 4.5~9.0 Vdc 4.5~9.0 Vdc 4.5~9.0 Vdc 9.0~18.0 Vdc 9.0~18.0 Vdc 9.0~18.0 Vdc 9.0~18.0 Vdc 9.0~18.0 Vdc 9.0~18.0 Vdc 18.0~36.0 Vdc 18.0~36.0 Vdc 18.0~36.0 Vdc 18.0~36.0 Vdc 18.0~36.0 Vdc 18.0~36.0 Vdc 36.0~72.0 Vdc 36.0~72.0 Vdc 36.0~72.0 Vdc 36.0~72.0 Vdc 36.0~72.0 Vdc 36.0~72.0 Vdc Output Voltage 3.3 Vdc 5 Vdc 9 Vdc 12 Vdc 15 Vdc 24 Vdc 3.3 Vdc 5 Vdc 9 Vdc 12 Vdc 15 Vdc 24 Vdc 3.3 Vdc 5 Vdc 9 Vdc 12 Vdc 15 Vdc 24 Vdc 3.3 Vdc 5 Vdc 9 Vdc 12 Vdc 15 Vdc 24 Vdc Output Current Max. Min. 500 mA 400 mA 222 mA 167 mA 133 mA 80 mA 500 mA 400 mA 222 mA 167 mA 133 mA 80 mA 500 mA 400 mA 222 mA 167 mA 133 mA 80 mA 500 mA 400 mA 222 mA 167 mA 133 mA 80 mA 50 mA 40 mA 22 mA 16 mA 13 mA 8 mA 50 mA 40 mA 22 mA 16 mA 13 mA 8 mA 50 mA 40 mA 22 mA 16 mA 13 mA 8 mA 50 mA 40 mA 22 mA 16 mA 13 mA 8 mA Package Style SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP SIP
Max. 11 Vdc 11 Vdc 11 Vdc 11 Vdc 11 Vdc 11 Vdc 22 Vdc 22 Vdc 22 Vdc 22 Vdc 22 Vdc 22 Vdc 40 Vdc 40 Vdc 40 Vdc 40 Vdc 40 Vdc 40 Vdc 80 Vdc 80 Vdc 80 Vdc 80 Vdc 80 Vdc 80 Vdc
Efficiency 65% 68% 72% 73% 72% 73% 72% 77% 79% 81% 80% 80% 72% 77% 79% 81% 80% 80% 71% 75% 79% 80% 79% 80%
1. All specifications measured at TA=25°C, humidity
很抱歉,暂时无法提供与“VWRBS2-D48-S5-SIP”相匹配的价格&库存,您可以联系我们找货
