rev. page date 1 of 5
01/2011
PART NUMBER: VF-S320-XXA
DESCRIPTION: switching power supply
features
· · · · · · · power factor correction power good signal short circuit protection over load protection over voltage protection over temperature protection providing Peak Power 700W within 500uS duty · approved to UL, CUL, TUV, CE with CB scheme · high power density: 8.9 watts/inch 3
E210311 preset voltage 5V 9V 12 V 15 V 18 V 24 V 28 V 36 V 48 V 54 V output current convection 5 22 CFM 5 27.28 A 45 A 16.37 A 29.1 A 15 A 26.67 A 12 A 21.33 A 10 A 17.78 A 7.5 A 13.33 A 6.43 A 11.43 A 5A 8.89 A 3.75 A 6.67 A 3.33 A 5.93 A ripple & noise 3,4 (Vpp) 50 mV ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1%
MODEL VF-S320-05A VF-S320-09A VF-S320-12A VF-S320-15A VF-S320-18A VF-S320-24A VF-S320-28A VF-S320-36A VF-S320-48A VF-S320-54A
output 1,2 2 - 5.5 V 6 - 10 V 12 - 13.5 V 13.6 - 15 V 16 - 20 V 21 - 26 V 27 - 34 V 35 - 42 V 43 - 50 V 51 - 60 V
regulation 3 ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1%
notes: 1 Output is fully isolated. 2 Output voltage is measured at output power connector. 3 1% minimum load is required to maintain the ripple and regulation. 4 Ripple and noise is measured from 10 KHz to 20 MHz at output terminals with a 0.1 μF ceramic capacitor and a 22 μF electrolytic capacitor in parallel. 5 Maximum power is 320 W with 22 CFM airflow. 5 and 9 V units maximum current is listed. Maximum power is 180 W with convection.
CUSTOM CONFIG KEY
VF-S320- XX A- X X - CXX
Output voltage Reserved for custom configurations
Input/Output connector: “blank” = Terminal block input / Terminal block output 1 = Molex input / Molex output 2 = Molex input / Terminal block output 3 = Terminal block input / Molex output
Low leakage option: “blank” = standard specification L = low leakage (contact factory)
20050 SW 112th Ave. Tualatin, Oregon 97062 phone 503.612.2300 fa x 503.612.2383 phone fax
www.v-infinity.com
rev. page date 2 of 5
01/2011
INPUT
parameter input frequency input voltage Input current inrush current inrush current power factor conditions/description 90-132 / 180-264 auto-selectable At 100-120 V ac At 200-240 V ac Peak measured at 230 V ac at full load, cold start Peak measured at 115 V ac at full load, cold start Passive power factor correction meets EN61000-3-2 class A min 47 90 nom max 63 264 8 4 70 35 units Hz V ac A A A A
OUTPUT
parameter transient response conditions/description min Output voltage returns to within 1% in less than 2.5 ms for a 50% load change. Peak t ransient does not exceed 5%. Turn-on and turn-off overshoot shall not exceed 5 % over nominal voltage. Measured at 230 V and full load 3.3 model: 70% 5 V model: 75% 12 V model: 80% All other models: 83% At 120 V ac At 120 V ac and 80% of rated maximim load Adjustable with built-in trim pot. ±5% When green (LED1) is on the power supply is operating normally. Designated as PG on the CN1. This signal goes TTL high 100-500 ms after the output reaches regulation. I t goes low at least 1 mS before loss of regulation. 12 V dc/4G00mA for external fan nom max units
o vershoot efficiency
turn on delay hold up time adjustability L ED display power good
1 20
Wsecond ms
fan drive
PROTECTION CIRCUIT
parameter input fuse overload short circuit output over-voltage conditions/description Built-in ac fuse. A blown fuse usually indicates permanent damage to the power supply serviceable by factory only. Current limiting starts at 110-140% of the rated output current in foldback mode and recovers automatically. Short circuit can be continuous. Recovers automatically upon removal of short. Output is protected agaist overvoltage. Unit shuts down and latches when voltage at output terminals exceeds 130%. AC input needs to be r eset to restart the power supply. Power supply shuts down when temperature is in excess of 85 ºC. Auto recovery.
over temp.
www.v-infinity.com
rev. page date 3 of 5
01/2011
GENERAL AND SAFTEY
parameter operating temp. storage temp. operating humid. storage humid. EMI safety leakage current vibration isolation voltage (HI-POT) conditions/description 0 to 70ºC ambient, de-rating at 2.5% per degree from 50ºC to 70ºC. min 0 nom max 50 85 90% 95% units ºC ºC RH RH
grounding test
warranty MTBF burn-in cooling
-20 Non-condensing 5% Non-condensing 5% Pass FCC Part 15, CISPR 22 class B, Conducted UL60950-1, CSA C22.2 No. 60950-1-03, TUV EN60950-1, CE Mark (LVD) E N61000-3-(2,3) & IEC61000-4 Series regulations and CB at 240 V ac Acceleration ± 7.35 M/(SxS), on X, Y and Z Axis 5 Applied for 3 seconds at 10 mA Primary to secondary: 3,000 Primary to transformer core: 1,500 Primary to earth chassis: 1,500 Allowable resistance measured when 25 A current is applied from the ground pin of the three prong plug t o the farthest earthed connection point. Standard warranty length According to MIL-HDBK-217 at 30 ºC 100,000 Full load, at 45 ± 5 ºC, 230 V ac Built-in DC fan speed control.
1.5 50
mA Hz V ac V ac V ac Ω
0.1
2 1
years hours hours
MECHANICAL
parameter weight enclosure conditions/description 6(L) x 4(W) x 1.5(H) min nom max 600 units grams inches
L OGIC SIGNAL CONNECTOR - (CN1)
parameter CN1 conditions/description JST B2B-XH-4 or equivalent (CHYAO SHIUNN JS-1001-03) Suggested mating connector: J ST XHP-3 or equivalent (CHYAO SHIUNN JS-2001-03)
FAN DRIVER CONNECTOR - (FAN2)
parameter FAN2 conditions/description Suggested mating connector: J ST XHP-2 (2 pins 0.98 pitch) or equivalent (CHYAO SHIUNN JS-2001-02)
www.v-infinity.com
rev. page date 4 of 5
01/2011
INPUT / OUTPUT CONNECTOR - (CN2)
parameter option 1 conditions/description AC INPUT JST VH series (5 pin with pins 2 and 4 removed) or equivalent (Chyao Shiunn JS-1120-05) Suggested mating plug: J ST VHR-5N (5 pin) or equivalent (Chyao Shiunn JS-1121-05) contact: JST SVH series or similar DC OUTPUT JST VH series (10 pin) or equivalent (Chyao Shiunn JS-1120-10) Suggested mating plug: J ST VHR-10N (10 pin) or equivalent (Chyao Shiunn JS-1121-10) contact: JST SVH series or similar Howder Terminal block Part No. HB-95-7P (7 pin, M3.5 Screw) 9.5mm spacing Suggested mating connector: M olex 19198-0045 or similar
option 2
www.v-infinity.com
REV. A 152.40 6.000
DESCRIPTION NEW DRAWING
DATE 6/26/2008
38.10 1.500
FAN2
CN1 FF RTN
PG
101.60 4.000 (2 PLCS)
connector part no. JS-1120-05 (5 pins, 3 used)
L N L N G VO-
DETAIL A SCALE 2 : 1
76.20 3.000 (2 PLCS)
G
VO-
101.60 4.000
VO+ VO+
UNC 8-32 (6 PLCS)
A
terminal block option M3.5 screw 7pins 9.5mm center connector part no. JS-1120-10 (10 pins) SCALE: 1:3 TOLERANCE: ±0.3mm UNLESS OTHERWISE SPECIFIED
RoHS
25.40 1.000 (2 PLCS) 101.60 4.000 25.40 1.000 20050 SW 112th Ave. Tualatin, OR 97062 Phone: 503-612-2300 800-275-4899 Fax: 503-612-2383 Website: www.cui.com
NOTE: MOUNTING HOLE MAX DEPTH 4.00mm
TITLE:
SWITCHING POWER SUPPLY VF-S320-XXA Series
APPROVED BY: UNITS:
REV:
A
PART NO.
MM [INCHES]
SCALE:
PC FILE NAME:
DRAWN BY:
VF-S320-XXA Series
COPYRIGHT 2008 BY CUI INC.
ZRJ
1:2
很抱歉,暂时无法提供与“VF-S320-05A”相匹配的价格&库存,您可以联系我们找货
