4303.0002
    SCHURTERINC.
    PWR ENT MOD RCPT IEC320-C14 PNL
4303.0002 数据手册
Power entry modules without line filter www.schurter.com/pg05 IEC Appliance Inlet C14 with Fuseholder 1- or 2-pole and Voltage Selector KEC Standard or Medical Fuse drawer Fuse drawer must be ordered separately (see accessories). Fuse drawer must be ordered separately (see accessories). C14 70° C Description - Panel Mount: Screw-on version from front or rear side, snap-in version from front side - 3 Functions: Appliance Inlet Protection class I, Fuseholder with interchangeable fuse drawer for Fuse-links 5 x 20 mm or 6.3 x 32 mm 1- or 2-pole, with or without voltage selector (step switch) - Quick connect terminals 4.8 x 0.8 mm - Alternative: version with line filter KFC Characteristics - Available with or without internal connections - The fuse drawer "Fingergrip" can be removed by hand For added safety "Extra-Safe" fuse drawers are available Fuse drawer meets requirements of medical standard IEC/EN 60601-1 The fuse drawer can only be opened with the aid of a tool The fuseholder is accessible from the equipment front - Qualified for use in equipment according IEC/EN 60950 Other versions on request References Weblinks Approvals - Fuse drawer with other voltage values - For protection class II General Product Information Approvals, RoHS, CHINA-RoHS, Mating Connectors, e-Store, Distributor-Stock-Check, Accessories - VDE License Number: 40012271 - UL License Number: E93617 - CSA License Number: 38456 Technical Data Ratings IEC Ratings UL/CSA Dielectric Strength 10 A / 250 VAC; 50 Hz 13 A / 125 VAC; 60 Hz ¹⁾ > 3 kVAC between L-N > 4 kVAC between L/N-PE (1 min/50 Hz) -25 °C to 70 °C from front side IP 40 acc. to IEC 60529 Suitable for appliances with protection class 1 acc. to IEC 61140 Quick connect terminals 4.8 x 0.8 mm Screw: max 8 mm Mounting screw torque max 0.5 Nm Snap-in: 1.5/2/2.5 mm Thermoplastic, black, UL 94V-0 Appliance Inlet C14 acc. to IEC/EN 60320-1, UL 498, CSA C22.2 no. 42 (for cold conditions) pin-temperature 70 °C, 10 A, Protection Class 1 1 or 2 pole, Shocksafe category PC2 acc. to IEC 60127-6, for fuse-links 5 x 20 or 6.3 x 32 mm 5 x 20: 2.5 W (1 pole)/ 2 W (2-pole) per pole 6.3 x 32: 3.15 W (1 pole)/ 2.5 W (2-pole) per pole Admissible power acceptance at higher ambient temperature see derating curves optional, step, 2-4 digits Fuseholder Allowable Operation Temp. Degree of Protection Protection Class Terminal Panel Thickness s Rated Power Acceptance @ Ta 23 °C Power Acceptance @ Ta > 23°C Voltage Selectors Material: Housing 1) UL/CSA: 1-pole version 13 A, 2-pole version 10 A Dimensions Screw on PCB mounting 30 R6 R 4.5 ø 3.2 4.8x0.8 55 M3/ø 3.6 Snap-in mounting 30 ø 6.3x90˚ 58 mm 55 R 4.5 4.8x0.8 S ±0.1 230 50 ±0.15 +0.2 0 43.5 230 40.7 41 40.7 58 50 R 3 -0.2 18 27.5 2 2.2 27.5 +0.2 0 0 R 3 -0.2 18 27.2 R 3.1 27.5 2 2.2 27.5 0 R 3.1 27.2 +0.2 0 Connectors 41 +0.2 0  KEC www.schurter.com/pg05 Diagrams without internal connections Voltage selector 4-positions, 1-pole without internal connections Voltage selector 4-positions, 2-pole with internal connections Voltage selector 4-positions, 1-pole Power entry modules without line filter with internal connections Voltage selector 4-positions, 2-pole Voltage selector 3-positions 1-pole Voltage selector 3-positions 2-pole Voltage selector 2-positions 1-pole Voltage selector 2-positions 2-pole without voltage selector 1-pole without voltage selector 2-pole Derating Curves Fuses 5 x 20 mm (1-pole) 2.5 Fuses 5 x 20 mm (2-pole, per pole) 2.0 Admissible power acceptance in Watt 2.0 1.5 1.0 0.5 0.0 0 20 40 60 80 100 I = 1.0 In I = 0.7 In I = < < In Admissible power acceptance in Watt per pole 1.5 I = 1.0 In 1.0 I = 0.7 In I = < < In 0.5 0.0 0 20 40 60 80 100 Ambient air temperature Ta °C Ambient air temperature Ta °C Fuses 6.3 x 32 mm (1-pole) 3.15 Fuses 6.3 x 32 mm (2-pole, per pole) 2.5 Admissible power acceptance in Watt Admissible power acceptance in Watt per pole 2.5 2.0 1.5 1.0 0.5 0.0 0 20 40 60 80 100 2.0 1.5 1.0 0.5 0.0 0 20 40 60 80 100 I = 1.0 In I = 0.7 In I = < < In I = 1.0 In I = 0.7 In I = < < In Ambient air temperature Ta °C Ambient air temperature Ta °C  Connectors Power entry modules without line filter www.schurter.com/pg05 Variants Fuse drawer must be ordered separately (see accessories). Fingergrip and Extra-Safe Panel mounting Screw Screw Screw Screw Screw Screw Screw Screw Screw Screw Screw Screw Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Snap-in Panel Thickness s [mm] 1.5 1.5 1.5 2 2 2 2.5 2.5 2.5 1.5 1.5 1.5 2 2 2 2.5 2.5 2.5 1.5 1.5 1.5 2 2 2 2.5 2.5 2.5 1.5 1.5 1.5 2 2 2 2.5 2.5 2.5 Fuseholder 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 1-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole 2-pole Voltage Selectors without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. without 3/4 digits 2 pos. l l l l l l l l l l l l l l l l l l l l l Internally wired l l l Order Number 4303.0031 4303.0091 4303.0211 4303.1031 4303.1091 4303.1211 4303.0001 4303.0061 4303.0181 4303.1001 4303.1061 4303.1181 4303.0032 4303.0092 4303.0212 4303.0033 4303.0093 4303.0213 4303.0034 4303.0094 4303.0214 4303.1032 4303.1092 4303.1212 4303.1033 4303.1093 4303.1213 4303.1034 4303.1094 4303.1214 4303.0002 4303.0062 4303.0182 4303.0003 4303.0063 4303.0183 4303.0004 4303.0064 4303.0184 4303.1002 4303.1062 4303.1182 4303.1003 4303.1063 4303.1183 4303.1004 4303.1064 4303.1184 KEC Packaging unit 50 Pcs Connectors  KEC www.schurter.com/pg05 Required Accessory Description Fusedrawer 3 Fusedrawer for Fuse Links 5x20mm resp.. 6.3x32mm Fingergrip, 5 x 20, 2-pole, Voltage Selectors Fingergrip, 5 x 20, 2-pole, Voltage Selectors, 100, 120, 220, 240 Fingergrip, 5 x 20, 2-pole, Voltage Selectors, 110, 150, 220 Fingergrip, 5 x 20, 2-pole, Voltage Selectors, 110, 220 Power entry modules without line filter 4303.2014.00 4303.2014.01 4303.2014.02 4303.2014.03 ... Accessories Assorted Covers Rear Cover 0859.0072 Cord retaining kits Cord retaining strain relief Flat head, A 4700.0001 Mating Outlets/Connectors Category / Description Appliance Outlet Overview complete IEC Appliance Outlet F, Screw-on Mounting, Front Side, Solder or Quick-connect Terminal IEC Appliance Outlet F, Snap-in Mounting, Front Side, Solder or Quick-connect Terminal IEC Appliance Outlet F or H, Screw-on Mounting, Front Side, Solder, PCB or Quick-connect Terminal IEC Appliance Outlet F or H, Screw-on Mounting, Front Side, Solder or Quick-connect Terminal Appliance Outlet further types to KEC Connector Overview complete IEC Connector C15, Rewireable, Straight IEC Connector C15A, Rewireable, Straight IEC Connector C15A, Rewireable, Straight IEC Connector C15A, Rewireable, Angled IEC Connector C13, Rewireable, Angled Connector further types to KEC Power Cord Overview complete Power Cord with IEC Connector C13, Angled Power Cord with IEC Connector C13, Angled Power Cord with IEC Connector C13, Angled Power Cord with IEC Connector C13, Angled Power Cord with IEC Connector C13 Power Cord further types to KEC 0311 3011 3012 3013 3020 ... 0101 0102 0102-G 0112 4012 ... 4787 4788 5091 5092  The specifications, descriptions and illustrations indicated in this document are based on Connectors current information. All content is subject to modifications and amendments.
4303.0002 价格&库存
很抱歉,暂时无法提供与“4303.0002”相匹配的价格&库存,您可以联系我们找货
