CUSTOMER:
DATE:
APPROVAL SPECIFICATION
PRODUCT NAME: SMD power inductor
CUSTOMER PART NO.:
OUR PART NO.: MPIT4030 Series
RECEPTION
THE SPECIFICATION HAS BEEN ACCEPTED.
DATE:
COMPANY:
CFMD
CHKD
RCVD
MANUFACTURING NAME
深圳市麦捷微电子科技股份有限公司
SHENZHEN MICROGATE TECHNOLOGY CO.,LTD
Address: Yuxing road, Golf Street, Guanlan Town
Bao’an District Shenzhen P.R.C
Postcode :518110
TEL:86-755-28085000
FAX:86-755-28085605
CFMD.
CHKD.
DSGD.
目录 CATALOG
规格书版本控制 Component SPEC Version Record……………………………….. .. ..
2
1
适用范围 Scope.
. 3
2
品名构成 Product Identification.
. 3
3
形状、
. 3
形状、尺寸和材料 Appearance, Dimensions and Material.
4
测试条件 Testing Conditions.
4
5
电气特性 Electrical Characteristics.
4
6
工作条件 Condition of work.
. 5
7
信赖性试验 Reliable Performance.
8
焊接条件 Recommended Soldering Conditions.
. 8
9
包装 Packaging.
. 9
5-7
10 产品外观检查标准 Visual inspection standard of product.
. 10
11 存贮条件 Products Storage.
. 10
深圳市麦捷微电子科技股份有限公司
地址:深圳市宝安区观澜镇高尔夫大道裕新路
电话(Tel):0755-28085000
传真(Fax):0755-28085605
邮编(Postcode):518110
Rev.
Effective Date
Changed Contents
Change Reasons
Approved By
01
Dec. 10.2012
New released
Charles
2
SHENZHEN MICROGATE TECHNOLOGY CO.,LTD.
Add:Yuxing Road,Golf Street,Guanlan Town,Bao’an District,Shenzhen
Tel:+86-755-28085000
Fax:+86-755-28085605
Postcode:518110
1. Scope
This specification applies to the MPIT4030 series of SMD power inductor.
2. Product Identification
MPIT
①
4030 –
6R8
③
②
M - LF
④
⑤
Product Symbol (T type SMD power inductor)
Product dimensions (4.0×4.0×3.0mm)
Inductance Value: (4R7: 4.7uH 100: 10uH; 101: 100uH)
Induc tance Tolerance:(M: ±20% ; N: ±30%)
Lead free product.
3. Appearance, Dimensions and Material
3.1 Appearance and dimensions
220
h
S
F
Recommended Pattern
NOTE: S=Start F=Finish
Model
MPIT4030
A
4.00±0.20
B
4.00±0.20
Dimensions in mm
C
D
E
3.00Max. 2.00±0.20 1.00±0.20
f
1.90 Typ.
g
4.10 Typ.
h
3.40 Typ.
3.2 Material List
No.
1
2
3
4
Item
Ferrite Core
Wire
Terminal Electrode
Magnetic Glue
Material
Ni-Zn Ferrite
Enameled Copper Wire
Ag/Ni/Sn/Cu
Epoxy resin and magnetic powder
4.Testing Conditions
Unless otherwise specified
Temperature : Ordinary Temperature
( 5 to 35℃)
Humidity : Ordinary Humidity
(25 to 85% RH)
Atmospheric Pressure : 86 to 106 kPa
In case of doubt
Temperature : 20±2℃
Humidity : 60 to 75% RH
3
Postcode:518110
5. Electrical Characteristics And Test Instruments
1
Irms
(A)
2
DCR
(Ω) ±30%
MPIT4030-R91N-LF
0.91±30%
0.022
7.00
3.15
100
MPIT4030-1R2N-LF
1.2±30%
0.025
5.90
2.96
80
MPIT4030-1R5N-LF
1.5±30%
0.030
5.40
2.92
62
MPIT4030-1R8N-LF
1.8±30%
0.030
4.40
2.92
60
Customer Part No.
SRF
(MHz)
MPIT4030-2R2N-LF
2.2±30%
0.035
4.30
2.57
52
MPIT4030-3R3M-LF
3.3±20%
0.040
3.30
2.40
38
MPIT4030-4R3M-LF
4.3±20%
0.051
2.95
2.13
37
MPIT4030-4R7M-LF
4.7±20%
0.060
2.90
2.00
31
MPIT4030-5R6M-LF
5.6±20%
0.065
2.60
1.95
30
MPIT4030-6R2M-LF
6.2±20%
0.070
2.50
1.85
29
MPIT4030-6R8M-LF
6.8±20%
0.084
2.60
1.65
24
MPIT4030-7R5M-LF
7.5±20%
0.084
2.20
1.65
26
MPIT4030-8R2M-LF
8.2±20%
0.090
2.10
1.60
26
MPIT4030-9R1M-LF
9.1±20%
0.095
2.00
1.55
23
MPIT4030-100M-LF
10±20%
0.096
1.95
1.52
21
MPIT4030-120M-LF
12±20%
0.131
1.70
1.30
18
MPIT4030-150M-LF
15±20%
0.189
1.65
1.11
16
MPIT4030-180M-LF
18±20%
0.200
1.40
1.10
10
MPIT4030-220M-LF
22±20%
0.225
1.30
1.00
10
MPIT4030-330M-LF
33±20%
0.320
1.10
0.85
10
MPIT4030-360M-LF
36±20%
0.335
1.05
0.83
9.8
MPIT4030-390M-LF
39±20%
0.345
1.03
0.80
10
MPIT4030-430M-LF
43±20%
0.440
1.00
0.73
9.2
MPIT4030-470M-LF
47±20%
0.445
0.95
0.72
8.4
MPIT4030-510M-LF
51±20%
0.470
0.90
0.70
8.4
MPIT4030-560M-LF
56±20%
0.555
0.85
0.65
8.4
MPIT4030-620M-LF
62±20%
0.829
0.80
0.53
7.0
MPIT4030-680M-LF
68±20%
0.868
0.75
0.52
7.0
MPIT4030-750M-LF
75±20%
0.920
0.70
0.50
6.3
MPIT4030-820M-LF
82±20%
0.970
0.66
0.48
5.6
MPIT4030-910M-LF
91±20%
1.070
0.62
0.46
5.6
MPIT4030-101M-LF
100±20%
1.110
0.60
0.45
5.6
MPIT4030-121M-LF
120±20%
1.250
0.53
0.43
5.4
T-I characteristic curve
L-I characteristic curve
80
60
100µH
50
10µH
4.7µH
40
30
100µH
100
Inductance(µH)
Indictance(uH)
1000
70
Temperature rise ( ℃ )
Temperature rise(℃)
Isat
(A)
Inductance
(uH)
Microgate Part No.
10
1
10µH
4.7µH
10
0.5
1.0
1.5
DC.Current (A)
2.0
2.5
3.0
0.01
0.1
10
4
1
DC.Current(A)
DC.Current(A)
DC. Current(A)
Postcode:518110
Test instruments and remarks
* CHROMA 3302 meter for L and DCR./CHROMA 3302 and 1320 meter for IDC.
* L test condition: 100KHz&1V at 20℃ambient;
* Rated current:Isat or Irms,whichever is smaller:
1
:Isat: direct current at which the inductance drops approximate 30% from its value without current.
2
:Irms: direct current when the temperature of the product rise (△T =40°C) from 20°C ambient
6. Condition of work
1. The part normal work be allowed ambient temperature: -25℃ ~ +85℃.
2 .The part must be allowed high temperature: +125℃.
3. The part normal work be allowed temperature dependent: 40℃
4. Ambient temperature of the part is allowed storage temperature: -25℃ ~ +85℃.
5. Storage life: half a year
6 .The part be allowed work ambient frequency: 0.1MHz ~ 1MHz
7. Reliability and Test Condition
Item
Required Characteristics
Test Method/Condition
Temperature: 125±2℃
Time : 1000 hours
Tested not less than 1 hours, nor more than 2 hours
at room temperature.
High temperature
resistance
125
1000H
Temperature : -40±2℃
Time : 1000 hours
Tested not less than 1 hour, nor more than 2 hours at room
temperature.
Low temperature
resistance
1. No case deformation or change in
appearance.
2. |∆L|/L≤10%
1000H
-40℃
1.
2.
3.
Exposure : Temperature:60±2℃, Humidity : 93±3%
RH Time : 1000 hours.
Tested while the specimens are still in the chamber.
room temperature.
Humidity test
1000
5
Postcode:518110
Item
First -40℃ for T time, last 125℃ T time as 1 cycle. Go
through 100 cycles.
1.
Thermal
test
shock
2.
in appearance.
|∆L|/L≤10%
125℃
30 min.
30 min.
Ambient
Temperature
-40℃
30 min.
20sec. (max.)
Solderability test
Terminal area must have 90% min.
solder coverage.
Heat endurance
of
reflow
soldering
Dip pads in flux then dip in solder pot at 245±5℃ for
0.1mm. NG.
AQL=0.65
l
L
l >L/6 or w >W/6, NG.
H
11.Products Storage
⑴ Storage period
Products which inspected in MICROGATE over 6 months ago should be examined and used, which
can be confirmed with inspection No. marked on the container. Solderability should be checked if this
period is exceeded.
⑵ Storage conditions
Products should be storage in the warehouse on the following conditions:
Temperature: -10 ~+ 40℃
Humidity
: Less than 80% relative and humidity
No rapid change on temperature and humidity
⑶ Don’t keep products in corrosive gases such as sulfur, chlorine gas or acid, or it may cause oxidization of
electrode, resulting in poor solderability.
⑷ Products should be storage on the palette for the prevention of the influence from humidity, dust and so on.
⑸ Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
⑹ Products should be storage under the airtight packaged condition.
10
Postcode:518110
很抱歉,暂时无法提供与“MPIT4030-1R0M-LF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31540
- 100+0.28690
- 500+0.25840
- 1000+0.22990
- 2000+0.21090
- 4000+0.20520
