RLT
RLT
    C-TON
    RAINFALL TRANSMITTER
RLT 数据手册
Rainfall Transmitter Model RLT DESCRIPTION & FEATURES Track mounted transmitter The RLT converts the output of a tipping bucket rain gauge to a 4-20 mA signal. The RLT rain gauge is fabricated of heavy duty PVC, aluminum and stainless steel. It consists of an outer funnel, screen, inner funnel and tipping bucket. Precipitation entering the collection orifice fills the calibrated tipping bucket assembly. When the bucket fills to the calibrated amount, the bucket tips. Another bucket is brought into place and the precipitation sample is discharged through the dump tubes to the ground below. This produces a switch closure which is detected by the electronics in the separate transmitter. The 4-20 mA transmitter board is track mounted and powered by the milliamp loop. Each tip of the bucket causes the output signal to increase 1% of full scale. The rain gauge range is 0-1.00” over the 4-20 mA output. The transmitter will reset after 100 bucket tips or 1” of precipitation. ORDERING INFO PART NUMBER RLT.............................................. Rainfall Gauge with 20’ 2 conductor cable and 4-20 mA transmitter ACCESSORIES SA2W..........................................Wall mount 2 wire Surge/Lightning Arrestor SA4W..........................................Wall mount 4 wire Surge/Lightning Arrestor DK191..............................................................Loop Powered Display Series DK190F...................................................................... Loop Powered Display DK807/907.......................................................Loop Powered Display Series Rain Guage BDR-924/999............................................4-20 mA Controlled Display Series PW1.0.....................................................................................Power Supply PW1.5.....................................................................................Power Supply PW2-24...................................................................................Power Supply SPECIFICATIONS CVC................................................................................ 4-20 mA Calibrator Range: Electronics Accuracy: Rain Gauge Accuracy: Transmitter Dimensions: Rain Gauge Dimensions: Shipping Weight: Operating Temperature: 0-1.00” = 4-20 mA output +/-1% +/-4% Track Mount 2.5”W x 6.25”L x 1.5”H 8.4” Diameter x 12.0”H 8 lbs. Rain Gauge -40 to 60° C Transmitter 0 to 60° C Transmitter Connections: Screw terminals for 12AWG or smaller Transmitter Power: Powered by the 4-20 mA loop current Rain Gauge Mounting: 3 equally spaced legs with 1/4” bolt holes on 9.5” diameter bolt circle Accessories: Surge/Lightning Arrestors C-TON Industries • PO Box 11746 • Memphis, TN 38111 • USA (603) 471-0158 • email: info@ctonindustries.com
很抱歉,暂时无法提供与“RLT”相匹配的价格&库存,您可以联系我们找货
