LS03/GZ-1A66-PA-500W 数据手册
A Global Leader in the Design, Development, and
Manufacture of Sensor and Magnetic Components
www.standexmeder.com
Series Datasheet – LS03 Level Sensors
LS03 Series
Level Sensors
Features: Single Level Horizontal Mount, High Power Switch Option, Other Cables & Connectors
Applications: Level Control, Detection and Monitoring
Markets: Automotive, Appliance, HVAC/R, Test & Measurement
LS-03 0X00-XX-000X
Part-Description:
Contact QTY
Contact Form
Switch Model
Material
Cable Length
(mm)
Cable
Termination
01
A (SPST-NO)
B (SPST-NC)
66, 85
PA, PP
500
W = Stripped
and Tinned
Customer Options
Contact Data
66
85
Rated Power (max.)
10
100
W
200
400
V
0.5
1.0
A
1.25
2.5
A
150
150
mOhm
Switch Model
Any DC combination of V&A not to exceed their individual max.’s
Switching Voltage (max.)
DC or peak AC
Switching Current (max.)
DC or peak AC
Carry Current (max.)
DC or peak AC
Contact Resistance (max.)
@ 0.5V & 10mA
Glossary Contact Form
Unit
Glossary Material
Form A
NO = Normally Open Contacts
SPST = Single Pole Single Throw
PP: Polypropylene
Form B
NC = Normally Closed Contacts
Form C
Changeover
SPDT = Single Pole Double Throw
PA: Polyamide
NBR: Nitrile
Butadiene Rubber
For water applications
and dilute acids
For oil
For oil, gasoline & in
high temperatures
SS: Stainless Steel
For high temp. (< 160° C)
USA:
Europe:
Asia:
+1.866.782.6339
+49.7731.8399.0
+86.21.37820625
│ salesusa@standexmeder.com
│ info@standexmeder.com
│ salesasia@standexmeder.com
Modifications in the sense of technical progress are reserved.
Version 01
27.01.2015
General Sensor Data
LS03 Versions
Materials
Standard-Version
GZ-Version
DK-Version
DL-Version
Stem, Nut
PA
PP
Float
PA
PP
Seal
Nitrile Rubber
Low voltage
Nitrile Rubber
High voltage
(Switch Model 66)
(Switch Model 66)
Cross Section (mm²)
0.14
0.25
Cable material
PVC
Packing
Bulk
Cable spec
Environmental Data
Unit
Shock Resistance (max.)
50
G
G
-20 to 80
°C
-5 to 80
°C
-30 to70
°C
1/2 sine wave duration 11ms
Vibration Resistance (max.)
Operating Temperature
Cable not moved
Cable moved
Storage Temperature
Tank wall
Tank wall
LS03 Level Sensor
Handling & Assembly Instructions
Standard
Mounting from inside,
thread M16 x 2.0
Insertion hole: Ø 16.5mm
GZ-Type
Mounting from outside,
tapered thread ½“
(no sealing necessary)
Sealing from inside,
with O-ring
DK-Type
Insertion hole: 1/2“ thread
thread M16 x 2.0
thread M16 x 2.0
Life Test Data
Insertion hole: Ø 22mm
Insertion hole: Ø 22–24 mm
*Load increase reduces life expectancy of Reed Switches
DL-Type
5mm narrow sealing, suitable 12mm wide sealing, suitable
for high filling Pressure
for low filling Pressure
Wall thickness min. 4mm
Wall thickness max. 5mm
USA:
Europe:
Asia:
+1.866.782.6339
+49.7731.8399.0
+86.21.37820625
Version 01
27.01.2015
LS03/GZ-1A66-PA-500W 价格&库存
很抱歉,暂时无法提供与“LS03/GZ-1A66-PA-500W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+235.26995
- 2+221.22399
- 3+208.93377
- 25+129.04733
