AS5045B-ASST
AS5045B-ASST
    AMSOSRAM(艾迈斯半导体)
    SSOP16_208MIL
    IC ENCODER PROG 12-BIT 16SSOP
AS5045B-ASST 数据手册
AS5045B 12-Bit Programmable Magnetic Position Sensor General Description The AS5045B is a contactless magnetic position sensor for accurate angular measurement over a full turn of 360 degrees. It is a system-on-chip, combining integrated Hall elements, analog front end and digital signal processing in a single device. To measure the angle, only a simple two-pole magnet, rotating over the center of the chip, is required. The magnet can be placed above or below the IC. The absolute angle measurement provides instant indication of the magnet’s angular position with a resolution of 0.0879º = 4096 positions per revolution. This digital data is available as a serial bit stream and as a PWM signal. An internal voltage regulator allows the AS5045B to operate at either 3.3V or 5V supplies. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS5045B, 12-Bit Programmable Magnetic Position Sensor are listed below: Figure 1: Added Value of Using AS5045B Benefits Features • Highest reliability and durability • Contactless high resolution rotational position encoding over a full turn of 360 degrees • Simple programming • Simple user-programmable zero position and settings • Multiple interfaces • Serial communication interface (SSI) • 10-bit pulse width modulated (PWM) output • Quadrature A/B and Index output signal • Ideal for motor applications • Rational speeds up to 30,000 rpm • Failure diagnostics • Failure detection mode for magnet placement monitoring and loss of power supply • Easy setup • Serial read-out of multiple interconnected AS5045B devices using Daisy Chain mode • Great flexibility at a huge application area • Detects movement of magnet in Z-axis (Red-Yellow-Green indicator) • Small form factor • SSOP 16 (5.3mm x 6.2mm) • Robust environmental tolerance • Wide temperature range: -40°C to 125°C ams Datasheet [v2-00] 2016-Feb-05 Page 1 Document Feedback AS5045B − General Description Applications The device is ideal for industrial applications like automatic or elevator doors, robotics, motor control and optical encoder replacement. Block Diagram The functional blocks of this device are shown below: Figure 2: Block Diagram Rotary Position Sensor IC VDD3V3 MagINCn VDD5V MagDECn LDO 3.3V PWM Interface Sin Hall Array & Frontend Amplifier Cos PWM Ang ATAN (Cordic) Mag Absolute Interface (SSI) DO CSn CLK OTP Register PDIO A AS5045B Incremental Interface B I Page 2 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Pin Assignment Pin Assignment Figure 3: Pin Diagram (Top View) 1 16 VDD5V MagDECn 2 15 VDD3V3 A 3 14 NC B 4 13 NC NC 5 12 PWM I 6 11 CSn VSS 7 10 CLK PDIO 8 9 DO AS5045B MagINCn The following SSOP16 shows the description of each pin of the standard SSOP16 package (Shrink Small Outline Package, 16 leads, body size: 5.3mm x 6.2mmm; see Figure 3. Figure 4: Pin Description Pin Name Pin Number MagINCn 1 Pin Type Digital output open drain MagDECn 2 A 3 Description Magnet Field Magnitude Increase. Active low. Indicates a distance reduction between the magnet and the device surface. (see Figure 14) Magnet Field Magnitude Decrease. Active low. Indicates a distance increase between the device and the magnet. (see Figure 14) Quadrature output A (1024 Pulses) Digital output B 4 NC 5 - I 6 Digital output VSS 7 Supply pin PDIO 8 Digital input pull-down DO 9 Digital output/ tri-state ams Datasheet [v2-00] 2016-Feb-05 Quadrature output B (1024 Pulses) Must be left unconnected Index signal for the quadrature output. Negative supply voltage (GND) OTP Programming Input and Data Input for Daisy Chain Mode. Pin has an internal pull-down resistor (74kΩ). Connect this pin to VSS if programming is not required. Data Output of Synchronous Serial Interface Page 3 Document Feedback AS5045B − Pin Assignment Pin Name Pin Number Pin Type CLK 10 Digital input, Schmitt-Trigger input Clock Input of Synchronous Serial Interface; Schmitt-Trigger input CSn 11 Digital input pull-down, Schmitt-Trigger input Chip Select. Active low. Schmitt-Trigger input, internal pull-up resistor (50kΩ) PWM 12 Digital output NC 13 - Must be left unconnected NC 14 - Must be left unconnected VDD3V3 15 Supply pin 3V-Regulator output, internally regulated from VDD5V. Connect to VDD5V for 3V supply voltage. Do not load externally. VDD5V 16 Supply pin Positive supply voltage, 3.0V to 5.5V Description Pulse Width Modulation Pin 1 and 2 are the magnetic field change indicators, MagINCn and MagDECn (magnetic field strength increase or decrease through variation of the distance between the magnet and the device). These outputs can be used to detect the valid magnetic field range. Furthermore those indicators can also be used for contactless push-button functionality. Pin 3 and 4 are used for incremental angle information in 12-bit quadrature signal format. Additional sync mode and sine/cosine mode are used with Pin3 and Pin4. Pin 6 Index output used for incremental angle information. (Zero position reference). Pins 7, 15, and 16 are supply pins, pins 5, 13, and 14 are for internal use and must not be connected. Pin 8 (PDIO) is used to program the zero-position into the OTP (see page 26). This pin is also used as digital input to shift serial data through the device in daisy chain configuration, (see page 17). Pin 11 Chip Select (CSn; active low) selects a device within a network of AS5045Bs and initiates serial data transfer. A logic high at CSn puts the data output pin (DO) to tri-state and terminates serial data transfer. This pin is also used for alignment mode (see Alignment Mode) and programming mode (see Programming the AS5045B). Pin 12 allows a single wire output of the 12-bit absolute position value. The value is encoded into a pulse width modulated signal with 1μs pulse width per step (1μs to 4096μs over a full turn). By using an external low pass filter, the digital PWM signal is converted into an analog voltage, e.g. for making a direct replacement of potentiometers possible. Page 4 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed in Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings Parameter Min Max Units Comments Electrical Parameters DC supply voltage at pin VDD5V -0.3 DC supply voltage at pin VDD3V3 7 V 5 V Input pin voltage -0.3 VDD5V +0.3 V Input current (latchup immunity) -100 100 mA Except VDD3V3 EIA/JESD78 Class II Level A Electrostatic Discharge Electrostatic discharge ±2 kV JESD22-A114E Temperature Ranges and Storage Conditions Storage temperature -55 150 Package body temperature Relative humidity non-condensing Moisture sensitivity level (MSL) ams Datasheet [v2-00] 2016-Feb-05 5 3 ºC Min -67ºF; Max 302ºF 260 ºC The reflow peak soldering temperature (body temperature) specified is in accordance with IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-Hermetic Solid State Surface Mount Devices”. The lead finish for Pb-free leaded packages is matte tin (100% Sn). 85 % Represents a maximum floor time of 168h Page 5 Document Feedback AS5045B − Electrical Characteristics Electrical Characteristics TAMB = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation), unless otherwise noted. Figure 6: Electrical Characteristics Symbol Parameter Condition Min Typ Max Units 125 °C 16 21 mA 5.0 5.5 Operating Conditions TAMB Ambient temperature Isupp Supply current VDD5V Supply voltage at pin VDD5V VDD3V3 Voltage regulator output voltage at pin VDD3V3 VDD5V Supply voltage at pin VDD5V VDD3V3 Supply voltage at pin VDD3V3 VON Power-on reset thresholds On voltage; 300mV typ. hysteresis Voff Power-on reset thresholds Off voltage; 300mV typ. hysteresis -40°F to 257°F -40 4.5 5V operation 3.3V operation (pin VDD5V and VDD3V3 connected) V 3.0 3.3 3.6 3.0 3.3 3.6 V 3.0 3.3 3.6 1,37 2.2 2.9 DC supply voltage 3.3V (VDD3V3) V 1.08 1.9 2.6 Programming Conditions VPROG Programming voltage Voltage applied during programming 3.3 3.6 V VProgOff Programming voltage off level Line must be discharged to this level 0 1 V IPROG Programming current Current during programming 100 mA Programmed fuse resistance (log 1) 10μA max. current @ 100mV 10k ∞ Ω Unprogrammed fuse resistance (log 0) 2mA max. current @ 100mV 50 100 Ω Rprogrammed Runprogrammed Page 6 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Electrical Characteristics Symbol Parameter Condition Min Typ Max Units DC Characteristics CMOS Schmitt-Trigger Inputs: CLK, CSn (CSn = Internal Pull-Up) VIH High level input voltage VIL Low level input voltage VIon- VIoff Normal operation 0.7 * VDD5V V 0.3 * VDD5V Schmitt trigger hysteresis 1 V V ILEAK Input leakage current CLK only -1 1 IiL Pull-up low level input current CSn only, VDD5V: 5.0V -30 -100 μA DC Characteristics CMOS / Program Input: PDIO VIH High level input voltage VPROG(1) High level input voltage VIL Low level input voltage IIH High level input current During programming VDD5V: 5.5V 0.7 * VDD5V VDD5V V 3.3 3.6 V 0.3 * VDD5V V 100 μA 1 μA VSS + 0.4 V 30 DC Characteristics CMOS Output Open Drain: MagINCn, MagDECn IOZ Open drain leakage current VOL Low level output voltage IO VDD5V: 4.5V 4 VDD5V: 3V 2 Output current mA DC Characteristics CMOS Output: PWM VOH High level output voltage VOL Low level output voltage IO ams Datasheet [v2-00] 2016-Feb-05 VDD5V – 0.5 V VSS +0.4 VDD5V: 4.5V 4 VDD5V: 3V 2 Output current V mA Page 7 Document Feedback AS5045B − Electrical Characteristics Symbol Parameter Condition Min Typ Max Units DC Characteristics CMOS Output: A, B, Index VOH High level output voltage VOL Low level output voltage IO VDD5V – 0.5 V VSS +0.4 VDD5V: 4.5V 4 VDD5V: 3V 2 Output current V mA DC Characteristics Tri-state CMOS Output: DO VOH High level output voltage VOL Low level output voltage IO IOZ VDD5V – 0.5 V VSS +0.4 VDD5V: 4.5V 4 VDD5V: 3V 2 Output current Tri-state leakage current V mA 1 μA Note(s): 1. Either with 3.3V or 5V supply. Page 8 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Electrical Characteristics Magnetic Input Specification TAMB = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Two-pole cylindrical diametrically magnetized source: Figure 7: Magnetic Input Specification Symbol Parameter dmag Diameter tmag Thickness Condition Recommended magnet: Ø 6mm x 2.5mm for cylindrical magnets Bpk Magnetic input field amplitude Required vertical component of the magnetic field strength on the die’s surface, measured along a concentric circle with a radius of 1.1mm Boff Magnetic offset fmag_abs Min Typ 4 6 Max Unit mm 2.5 mm 75 mT Constant magnetic stray field ± 10 mT Input frequency (rotational speed of magnet) 153 rpm @ 4096 positions/rev 2.54 Hz Disp Displacement radius Max. offset between defined device center and magnet axis (see Figure 32) 0.25 mm Ecc Eccentricity Eccentricity of magnet center to rotational axis 100 μm Recommended magnet material and temperature drift ams Datasheet [v2-00] 2016-Feb-05 45 NdFeB (Neodymium Iron Boron) -0.12 SmCo (Samarium Cobalt) -0.035 %/K Page 9 Document Feedback AS5045B − Electrical Characteristics System Specifications TAMB = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 8: Input Specification Symbol RES Parameter Condition Min Typ Max Unit 12 bit Resolution 0.088 deg Integral non-linearity (optimum) Maximum error with respect to the best line fit. Centered magnet without calibration, TAMB =25 ºC. ± 0.5 deg Integral non-linearity (optimum) Maximum error with respect to the best line fit. Centered magnet without calibration, TAMB = -40ºC to 125ºC ± 0.9 deg INL Integral non-linearity Best line fit = (Errmax – Errmin) / 2 Over displacement tolerance with 6mm diameter magnet, without calibration, TAMB = -40ºC to 125ºC ± 1.4 deg DNL Differential non-linearity 12-bit, no missing codes ± 0.044 deg TN Transition noise 1 sigma 0.06 deg RMS tPwrUp Power-up time Until status bit OCF = 1 20 ms tdelay System propagation delay absolute output : delay of ADC, DSP and absolute interface 96 μs tdelayINC System propagation delay incremental output 192 μs fS Internal sampling rate for absolute output 11.46 kHz 1 MHz INLopt INLtemp CLK/SEL Read-out frequency Page 10 Document Feedback 9.38 Max. clock frequency to read out serial data 10.42 ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Electrical Characteristics Figure 9: Integral and Differential Non-Linearity Example 4095 α 12bit code 4095 Actual curve 2 TN DNL+1LSB 1 0 2048 Ideal curve INL 0.09° 2048 0 0° 180° 360 ° α [degrees] Integral Non-Linearity (INL) is the maximum deviation between actual position and indicated position. Differential Non-Linearity (DNL) is the maximum deviation of the step length from one position to the next. Transition Noise (TN) is the repeatability of an indicated position. ams Datasheet [v2-00] 2016-Feb-05 Page 11 Document Feedback AS5045B − Timing Characteristics Timing Characteristics TAMB = -40°C to 125°C, VDD5V = 3.0V to 3.6V (3V operation) VDD5V = 4.5V to 5.5V (5V operation) unless otherwise noted. Figure 10: Timing Characteristics Symbol Parameter Conditions Min Typ Max Units 100 ns Synchronous Serial Interface (SSI) Data output activated (logic high) Time between falling edge of CSn and data output activated tCLKFE First data shifted to output register Time between falling edge of CSn and first falling edge of CLK 500 ns TCLK/2 Start of data output Rising edge of CLK shifts out one bit at a time 500 ns tDOvalid Data output valid Time between rising edge of CLK and data output valid 413 ns Data output tri-state After the last bit DO changes back to “tri-state” 100 ns tCSn Pulse width of CSn CSn =high; To initiate read-out of next angular position 500 fCLK Read-out frequency Clock frequency to read out serial data >0 tDOactive tDOtristate ns 1 MHz Pulse Width Modulation Output PWM frequency Signal period = 4098μs ±10% at TAMB = -40ºC to 125ºC 220 244 268 Hz PWMIN Minimum pulse width Position 0d; angle 0 degree 0.90 1 1.10 μs PWMAX Maximum pulse width Position 4098d; angle 359.91 degrees 3686 4096 4506 μs 20 μs fPWM Programming Conditions tPROG Programming time per bit Time to prog. a single fuse bit 10 Refresh time per bit Time to charge the cap after tPROG 1 fLOAD LOAD frequency Data can be loaded at n x 2μs 500 kHz fREAD READ frequency Read the data from the latch 2.5 MHz fWRITE WRITE frequency Write the data to the latch 2.5 MHz tCHARGE Page 12 Document Feedback μs ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Detailed Description Detailed Description The AS5045B is manufactured in a CMOS standard process and uses a spinning current Hall technology for sensing the magnetic field distribution across the surface of the chip. The integrated Hall elements are placed around the center of the device and deliver a voltage representation of the magnetic field at the surface of the IC. Through Sigma-Delta Analog / Digital Conversion and Digital Signal-Processing (DSP) algorithms, the AS5045B provides accurate high-resolution absolute angular position information. For this purpose a Coordinate Rotation Digital Computer (CORDIC) calculates the angle and the magnitude of the Hall array signals. The DSP is also used to provide digital information at the outputs MagINCn and MagDECn that indicate movements of the used magnet towards or away from the device’s surface. A small low cost diametrically magnetized (two-pole) standard magnet provides the angular position information (see Figure 31). The AS5045B senses the orientation of the magnetic field and calculates a 12-bit binary code. This code can be accessed via a Synchronous Serial Interface (SSI). In addition, an absolute angular representation is given by a Pulse Width Modulated signal at pin 12 (PWM). This PWM signal output also allows the generation of a direct proportional analog voltage, by using an external Low-Pass-Filter. The AS5045B is tolerant to magnet misalignment and magnetic stray fields due to differential measurement technique and Hall sensor conditioning circuitry. Figure 11: Typical Arrangement of AS5045B and Magnet ams Datasheet [v2-00] 2016-Feb-05 Page 13 Document Feedback AS5045B − Detailed Description Synchronous Serial Interface (SSI) Figure 12: Synchronous Serial Interface with Absolute Angular Position Data TCLK/2 CSn tCSn tCLK FE 1 CLK D11 DO D10 D9 D8 D7 D6 D5 1 18 8 D4 D3 D2 D1 D0 OCF COF LIN tCLK FE Mag Mag Even INC DEC PAR D11 tDO valid tDO active Angular Position Data Status Bits tDO Tristate If CSn changes to logic low, Data Out (DO) will change from high impedance (tri-state) to logic high and the read-out will be initiated. • After a minimum time tCLK FE, data is latched into the output shift register with the first falling edge of CLK. • Each subsequent rising CLK edge shifts out one bit of data. • The serial word contains 18 bits, the first 12 bits are the angular information D[11:0], the subsequent 6 bits contain system information, about the validity of data such as OCF, COF, LIN, Parity and Magnetic Field status (increase/decrease). • A subsequent measurement is initiated by a “high” pulse at CSn with a minimum duration of t CSn. Page 14 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Detailed Description Data Content D11:D0 absolute angular position data (MSB is clocked out first) OCF (Offset Compensation Finished), logic high indicates the finished Offset Compensation Algorithm COF (CORDIC Overflow), logic high indicates an out of range error in the CORDIC part. When this bit is set, the data at D11:D0 is invalid. The absolute output maintains the last valid angular value. This alarm can be resolved by bringing the magnet within the X-Y-Z tolerance limits. LIN (Linearity Alarm), logic high indicates that the input field generates a critical output linearity. When this bit is set, the data at D11:D0 can still be used, but can contain invalid data. This warning can be resolved by bringing the magnet within the X-Y-Z tolerance limits. Even Parity bit for transmission error detection of bits 1 to 17 (D11 to D0, OCF, COF, LIN, MagINC, MagDEC) Placing the magnet above the chip, angular values increase in clockwise direction by default. Data D11:D0 is valid, when the status bits have the following configurations: Figure 13: Status Bit Outputs OCF 1 COF 0 LIN Mag INC Mag DEC 0 0 0 1 1 0 1 1 0 Parity Even checksum of bits 1:15 Note(s): 1. MagInc=MagDec=1 is only recommended in YELLOW mode (see Figure 14). ams Datasheet [v2-00] 2016-Feb-05 Page 15 Document Feedback AS5045B − Detailed Description Z-Axis Range Indication (Push Button Feature, Red/Yellow/Green Indicator). The AS5045B provides several options of detecting movement and distance of the magnet in the Z-direction. Signal indicators MagINCn and MagDECn are available both as hardware pins (pins #1 and 2) and as status bits in the serial data stream (see Figure 12). In the default state, the status bits MagINC, MagDec and pins MagINCn, MagDECn have the following function. Figure 14: Magnetic Field Strength Red-Yellow-Green Indicator Hardware Pins Status Bits OTP: Mag CompEn = 1 (Red-Yellow-Green) Mac INC Mag DEC LIN Mac INCn Mag DECn 0 0 0 Off Off No distance change Magnetic input field OK (GREEN range, ~45mT to 75mT) 1 1 0 On Off YELLOW range: magnetic field is ~ 25mT to 45mT or ~75mT to 135mT. The AS5045B can still be operated in this range, but with slightly reduced accuracy. 1 1 1 On On RED range: magnetic field is ~~135mT. It is still possible to operate the AS5045B in the red range, but not recommended. All other combinations n/a n/a Not available Description Note(s): 1. Pin 1 (MagINCn) and pin 2 (MagDECn) are active low via open drain output and require an external pull-up resistor. If the magnetic field is in range, both outputs are turned off. The two pins can also be combined with a single pull-up resistor. In this case, the signal is high when the magnetic field is in range. It is low in all other cases (see Figure 14). Page 16 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Detailed Description Incremental Mode The AS5045B has an internal interpolator block. This function is used if the input magnetic field is to fast and a code position is missing. In this case an interpolation is done. With the OTP bits OutputMd0 and OutputMd1 a specific mode can be selected. For the available pre-programmed incremental versions (10-bit and 12-bit), these bits are set during test at ams. These settings are permanent and can not be recovered. A change of the incremental mode (WRITE command) during operation could cause problems. A power-on-reset in between is recommended. Figure 15: Incremental Mode_Table Mode Default mode 10-bit Incremental mode (low DNL) 12-bit Incremental mode (high DNL) Sync mode Description AS5145 function DTEST1_A and DTEST2_B are not used. The Mode_Index pin is used for selection of the decimation rate (low speed/high speed). DTEST1_A and DTEST2_B are used as A and B signal. In this mode the Mode_Index Pin is switched from input to output and will be the Index Pin. The decimation rate is set to 64 (fast mode) and cannot be changed from external. In this mode a control signal is switched to DTEST1_A and DTEST2_B. ams Datasheet [v2-00] 2016-Feb-05 Output Md1 Output Md0 0 0 0 1 Resolution Dtest1_A and DTest2_B Pulses 10 256 Index Width 1/3 LSB 1 0 1 1 12 1024 Page 17 Document Feedback AS5045B − Detailed Description Incremental Power-Up Lock Option After power-up, the incremental outputs can optionally be locked or unlocked, depending on the status of the CSn pin: • CSn = low at power-up: CSn has an internal pull-up resistor and must be externally pulled low ( R ext ≤ 5kΩ ). If Csn is low at power-up, the incremental outputs (A, B, Index) will be high until the internal offset compensation is finished. This unique state (A=B=Index = high) can be used as an indicator for the external controller to shorten the waiting time at power-up. Instead of waiting for the specified maximum power up-time (0), the controller can start requesting data from the AS5045B as soon as the state (A=B=Index = high) is cleared. • CSn = high or open at power-up: In this mode, the incremental outputs (A, B, Index) will remain at logic high state, until CSn goes low or a low pulse is applied at CSn. This mode allows intentional disabling of the incremental outputs until, for example the system microcontroller is ready to receive data. Figure 16: Incremental Output ClockWise Programmed Zero Position Counter ClockWise A B 1 LSB I 3 LSB The hysteresis trimming is done at the final test (factory trimming) and set to 4 LSB, related to a 12-bit number. Incremental Output Hysteresis To avoid flickering incremental outputs at a stationary magnet position, a hysteresis is introduced. In case of a rotational direction change, the incremental outputs have a hysteresis of 4 LSB. Regardless of the programmed incremental resolution, the hysteresis of 4 LSB always corresponds to the highest resolution of 12-bit. In absolute terms, the hysteresis is set to 0.35 degrees for all resolutions. For constant rotational directions, every magnet position change is indicated at the incremental outputs (see Figure 17). For example, if the magnet turns clockwise from position “x+3“ to “x+4“, the incremental output would also indicate this position accordingly. Page 18 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Detailed Description A change of the magnet’s rotational direction back to position “x+3“ means that the incremental output still remains unchanged for the duration of 4 LSB, until position “x+2“is reached. Following this direction, the incremental outputs will again be updated with every change of the magnet position. Figure 17: Hysteresis Window for Incremental Outputs Incremental Output Indication Hysteresis : 0.35° X +6 X +5 X +4 X +3 X +2 X +1 X X X +1 X +2 X +3 X +4 X +5 X +6 Magnet Position Clockwise Direction Counterclockwise Direction Incremental Output Validity During power on the incremental output is kept stable high until the offset compensation is finished and the CSn is low (internal Pull Up) the first time. In quadrature mode A = B = Index = high indicates an invalid output. If the interpolator recognizes a difference larger than 128 steps between two samples it holds the last valid state. The interpolator synchronizes up again with the next valid difference. This avoids undefined output burst, e.g. if no magnet is present. ams Datasheet [v2-00] 2016-Feb-05 Page 19 Document Feedback AS5045B − Detailed Description Sync Mode This mode is used to synchronize the external electronic with the AS5045B. In this mode two signals are provided at the pins DTEST1_A and DTEST2_B. By setting Bit 48 in the OTP register, the Sync Mode will be activated. Figure 18: Dtest1_A and DTest2_B Every rising edge at DTEST1_A indicates that new data in the device is available. With this signal it is possible to trigger an external customer Microcontroller (interrupt) and start the SSI readout. DTEST2_B indicates the phase of available data. Sine/Cosine Mode This mode can be enabled by setting the OTP Factory-bit FS2. If this mode is activated the 16 bit sine and 16 bit cosine digital data of both channels will be switched out. Due to the high resolution of 16 bits of the data stream an accurate calculation can be done externally. In this mode the open drain outputs of DTEST1_A and DTEST2_B are switched to push-pull mode. At pin MagDECn the clock impulse, at pin MagINCn the Enable pulse will be switched out. The pin PWM indicates, which phase of signal is being presented. The mode is not available in the default mode. Daisy Chain Mode The daisy chain mode allows connection of several AS5045Bs in series, while still keeping just one digital input for data transfer (see “Data IN” in Figure 19). This mode is accomplished by connecting the data output (DO; pin 9) to the data input (PDIO; pin 8) of the subsequent device. The serial data of all connected devices is read from the DO pin of the first device in the chain. The length of the serial bit stream increases with every connected device, it is n * (18+1) bits: n= number of devices. e.g. 38 bit for two devices, 57 bit for three devices, etc. The last data bit of the first device (Parity) is followed by a dummy bit and the first data bit of the second device (D11), etc. (see Figure 20). Page 20 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Detailed Description Figure 19: Daisy Chain Hardware Configuration AS5045B 2nd Device AS5045B 1st Device µC Data IN PDIO DO DO PDIO CSn CLK CSn AS5045B last Device DO CLK PDIO CSn CLK CLK CSn Figure 20: Daisy Chain Mode Data Transfer CSn tCLK FE TCLK/2 1 CLK D11 DO tDO active tDO valid D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 OCF COF LIN Mag Mag Even INC DEC PAR Status Bits Angular Position Data 1st Device ams Datasheet [v2-00] 2016-Feb-05 D 18 8 1 2 3 D11 D10 D9 Angular Position Data 2nd Device Page 21 Document Feedback AS5045B − Detailed Description Pulse Width Modulation (PWM) Output The AS5045B provides a pulse width modulated output (PWM), whose duty cycle is proportional to the measured angle. For angle position 0 to 4094 (EQ1) t ⋅ 4098 ( t on + t off ) on -–1 Position = ------------------------- Examples: 1. An angle position of 180° will generate a pulse width ton = 2049μs and a pause toff of 2049 μs resulting in Position = 2048 after the calculation: 2049 * 4098 / (2049 + 2049) -1 = 2048 2. An angle position of 359.8° will generate a pulse width ton = 4095μs and a pause toff of 3 μs resulting in Position = 4094 after the calculation: 4095 * 4098 / (4095 + 3) -1 = 4094 Exception: 1. An angle position of 359.9° will generate a pulse width ton = 4097μs and a pause toff of 1 μs resulting in Position = 4096 after the calculation: 4097 * 4098 / (4097 + 1) -1 = 4096 The PWM frequency is internally trimmed to an accuracy of ±5% (±10% over full temperature range). This tolerance can be cancelled by measuring the complete duty cycle as shown above. Figure 21: PWM Output Signal Angle PWMIN 0 deg (Pos 0) 1µs 4098µs PWMAX 359.91 deg (Pos 4095) 4097µs 1/fPWM Page 22 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Detailed Description Changing the PWM Frequency The PWM frequency of the AS5045B can be divided by two by setting a bit (PWMhalfEN) in the OTP register (see Programming the AS5045B). With PWMhalfEN = 0 the PWM timing is as shown in Figure 22. Figure 22: PWM Signal Parameters (Default Mode) Symbol Parameter Typ Unit Note fPWM PWM frequency 244 Hz PWMIN MIN pulse width 1 μs • Position 0d • Angle 0 deg PWMAX MAX pulse width 4097 μs • Position 4095d • Angle 359.91 deg Signal period: 4097μs When PWMhalfEN = 1, the PWM timing is as shown in Figure 23. Figure 23: PWM Signal Parameters with Half Frequency (OTP Option) Symbol Parameter Typ Unit fPWM PWM frequency 122 Hz PWMIN MIN pulse width 2 μs • Position 0d • Angle 0 deg PWMAX MAX pulse width 8194 μs • Position 4095d • Angle 359.91 deg ams Datasheet [v2-00] 2016-Feb-05 Note Signal period: 8194μs Page 23 Document Feedback AS5045B − Detailed Description Analog Output An analog output can be generated by averaging the PWM signal, using an external active or passive low pass filter. The analog output voltage is proportional to the angle: 0º= 0V; 360º = VDD5V. Using this method, the AS5045B can be used as direct replacement of potentiometers. Figure 24: Simple 2nd Order Passive RC Low Pass Filter Pin12 R2 R1 analog out PWM VDD C1 C2 0V Pin7 0º 360º VSS Figure 21 shows an example of a simple passive low pass filter to generate the analog output. (EQ2) R1,R2 ≥ 10k Ω C1,C2 ≥ 2.2μF / 6V R1 should be greater than or equal to 4k7 to avoid loading of the PWM output. Larger values of Rx and Cx will provide better filtering and less ripple, but will also slow down the response time. Page 24 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Application Information Application Information The benefits of AS5045B are as follows: • Complete system-on-chip • Flexible system solution provides absolute and PWM outputs simultaneously • Ideal for applications in harsh environments due to contactless position sensing • No calibration required • No temperature compensation necessary Programming the AS5045B After power-on, programming the AS5045B is enabled with the rising edge of CSn with PDIO = high and CLK = low. The AS5045B programming is a one-time-programming (OTP) method, based on poly silicon fuses. The advantage of this method is that a programming voltage of only 3.3V to 3.6V is required for programming (either with 3.3V or 5V supply). The OTP consists of 52 bits, of which 21 bits are available for user programming. The remaining 31 bits contain factory settings and a unique chip identifier (Chip-ID). A single OTP cell can be programmed only once. Per default, the cell is “0”; a programmed cell will contain a “1”. While it is not possible to reset a programmed bit from “1” to “0”, multiple OTP writes are possible, as long as only unprogrammed “0”-bits are programmed to “1”. Independent of the OTP programming, it is possible to overwrite the OTP register temporarily with an OTP write command at any time. This setting will be cleared and overwritten with the hard programmed OTP settings at each power-up sequence or by a LOAD operation. Use application note AN514X_10 to get more information about the programming options. The OTP memory can be accessed in the following ways: • Load Operation: The Load operation reads the OTP fuses and loads the contents into the OTP register. A Load operation is automatically executed after each power-on-reset. • Write Operation: The Write operation allows a temporary modification of the OTP register. It does not program the OTP. This operation can be invoked multiple times and will remain set while the chip is supplied with power and while the OTP register is not modified with another Write or Load operation. ams Datasheet [v2-00] 2016-Feb-05 Page 25 Document Feedback AS5045B − Application Information • Read Operation: The Read operation reads the contents of the OTP register, for example to verify a Write command or to read the OTP memory after a Load command. • Program Operation: The Program operation writes the contents of the OTP register permanently into the OTP ROM. • Analog Readback Operation: The Analog Readback operation allows a quantifiable verification of the programming. For each programmed or unprogrammed bit, there is a representative analog value (in essence, a resistor value) that is read to verify whether a bit has been successfully programmed or not. Zero Position Programming Zero position programming is an OTP option that simplifies assembly of a system, as the magnet does not need to be manually adjusted to the mechanical zero position. Once the assembly is completed, the mechanical and electrical zero positions can be matched by software. Any position within a full turn can be defined as the permanent new zero position. For zero position programming, the magnet is turned to the mechanical zero position (e.g. the “off”-position of a rotary switch) and the actual angular value is read. This value is written into the OTP register bits Z35:Z46(see Figure 27). Note(s): The zero position value can also be modified before programming, e.g. to program an electrical zero position that is 180º (half turn) from the mechanical zero position, just add 2048 to the value read at the mechanical zero position and program the new value into the OTP register. Page 26 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Application Information OTP Memory Assignment Figure 25: OTP Bit Assignment Symbol Factory Bit 1 PMW frequency Index pulse width 51 PWMhalfEN_Index width 50 MagCompEn 49 pwmDIS Disable PWM 48 Reserved 47 Reserved 12 bit inc. (programmed by ams) bit 47 to 1, bit 48 to 0 46 Z0 : : 35 Z11 34 CCW 33 RA0 : : 29 RA4 28 FS 0 27 FS 1 26 FS 2 25 FS 3 24 FS 4 23 FS 5 : : 20 FS 8 19 FS 9 18 FS 10 Alarm mode (programmed by ams to 1) 12-bit Zero Position Direction Redundancy Address Factory Bit ams Datasheet [v2-00] 2016-Feb-05 Customer Section mbit1 Function Factory Section Bit Page 27 Document Feedback AS5045B − Application Information Symbol 17 ChipID0 16 ChipID1 : : 0 ChipID17 Function ID Section Bit 18-bit Chip ID mbit0 Factory Bit 0 User Selectable Settings The AS5045B allows programming of the following user selectable options: • PWMhalfEN_Indexwidth: Setting this bit, the PWM pulse will be divided by 2, in case of quadrature incremental mode A/B/Index setting of index impulse width from 1 LSB to 3LSB • Z [11:0]: Programmable Zero / Index Position • CCW: Counter Clockwise Bit ccw=0 – angular value increases in clockwise direction ccw=1 – angular value increases in counterclockwise direction • RA [4:0]: Redundant Address: an OTP bit location addressed by this address is always set to “1” independent of the corresponding original OTP bit setting OTP Default Setting The AS5045B can also be operated without programming. The default, un-programmed setting is: • Z0 to Z11: 00 = no programmed zero position • CCW: 0 = clockwise operation • RA4 to RA0:0 = no OTP bit is selected • MagCompEN: 1 = The green/yellow Mode is enabled Redundancy For a better programming reliability a redundancy is implemented. In case when the programming of one bit failed this function can be used. With an address RA(4:0) one bit can be selected and programmed. Page 28 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Application Information 0 0 00001 1 0 0 00010 0 1 00011 0 00100 Z0 Z1 Z2 Z3 Z4 Z5 Z6 Z7 Z8 Z9 Z10 Z11 CCW pwmDIS 0 Reserved MagCompEN 00000 Reserved Address PWMhalfEN_Indexwidth Figure 26: Redundancy Addressing 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 00101 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 00110 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 00111 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 01000 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 01001 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 01010 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 01011 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 01100 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 01101 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 01110 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 01111 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 10000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 10001 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 10010 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 10101 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ams Datasheet [v2-00] 2016-Feb-05 Page 29 Document Feedback AS5045B − Application Information Redundant Programming Option In addition to the regular programming, a redundant programming option is available. This option allows that one selectable OTP bit can be set to “1” (programmed state) by writing the location of that bit into a 5-bit address decoder. This address can be stored in bits RA4...RA0 in the OTP user settings. Example: setting RA4…0 to “00001” will select bit 51 = PWhalfEN_Indexwidth, “00010” selects bit 50 = MagCompEN, “10010” selects bit 34 =CCW, etc. OTP Register Entry and Exit Condition For timing options, refer to Programming the AS5045B. Figure 27: OTP Access Timing Diagram OTP Access Setup Condition CSn PDIO CLK Operation Mode Selection Exit Condition To avoid accidental modification of the OTP during normal operation, each OTP access (Load, Write, Read, Program) requires a defined entry and exit procedure, using the CSn, PDIO and CLK signals as shown in Figure 27. Page 30 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Application Information Alignment Mode The alignment mode simplifies centering the magnet over the center of the chip to gain maximum accuracy. Alignment mode can be enabled with the falling edge of CSn while PDIO = logic high (see Figure 28). The Data bits D11-D0 of the SSI change to a 12-bit displacement amplitude output. A high value indicates large X or Y displacement, but also higher absolute magnetic field strength. The magnet is properly aligned, when the difference between highest and lowest value over one full turn is at a minimum. Under normal conditions, a properly aligned magnet will result in a reading of less than 128 over a full turn. The MagINCn and MagDECn indicators will be = 1 when the alignment mode reading is < 128. At the same time, both hardware pins MagINCn (#1) and MagDECn (#2) will be pulled to VSS. A properly aligned magnet will therefore produce a MagINCn = MagDECn = 1 signal throughout a full 360º turn of the magnet. Stronger magnets or short gaps between magnet and IC will show values larger than 128. These magnets are still properly aligned as long as the difference between highest and lowest value over one full turn is at a minimum. The Alignment mode can be reset to normal operation by a power-on-reset (disconnect / re-connect power supply) or by a falling edge on CSn with PDIO = low. Figure 28: Enabling the Alignment Mode PDIO CSn 2µs min. AlignMode enable Read-out via SSI exit AlignMode Read-out via SSI 2µs min. Figure 29: Exiting Alignment Mode PDIO CSn ams Datasheet [v2-00] 2016-Feb-05 Page 31 Document Feedback AS5045B − Application Information 3.3V / 5V Operation The AS5045B operates either at 3.3V ±10% or at 5V ±10%. This is made possible by an internal 3.3V Low-Dropout (LDO) Voltage regulator. The internal supply voltage is always taken from the output of the LDO, meaning that the internal blocks are always operating at 3.3V. For 3.3V operation, the LDO must be bypassed by connecting VDD3V3 with VDD5V (see Figure 30). For 5V operation, the 5V supply is connected to pin VDD5V, while VDD3V3 (LDO output) must be buffered by a 1...10μF capacitor, which is supposed to be placed close to the supply pin (see Figure 30) with recommended 2.2μF. Note(s): The VDD3V3 output is intended for internal use only It must not be loaded with an external load. The output voltage of the digital interface I/O’s corresponds to the voltage at pin VDD5V, as the I/O buffers are supplied from this pin. Figure 30: Connections for 5V / 3.3V Supply Voltages 5V Operation 3.3V Operation 2.2 ... 10µF VDD3V3 VDD3V3 100nF VDD5V 100nF LDO Internal VDD VDD5V LDO Internal VDD DO DO PWM 4.5 - 5.5V VSS Page 32 Document Feedback I N T E R F A C E CLK CSn + - - + 3.0 - 3.6V PDIO VSS I N T E R F A C E PWM CLK CSn PDIO ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Application Information A buffer capacitor of 100nF is recommended in both cases close to pin VDD 5V. Note that pin VDD 3V3 must always be buffered by a capacitor. It must not be left floating, as this may cause an instable internal 3.3V supply voltage which can lead to larger than normal jitter of the measured angle. Selecting Proper Magnet Typically the magnet is 6mm in diameter and 2.5mm in height. Magnetic materials such as rare earth AlNiCo/SmCo5 or NdFeB are recommended. The magnetic field strength perpendicular to the die surface has to be in the range of ±45mT to ±75mT (peak). The magnet’s field strength is verified using a gauss-meter. The magnetic field Bv at a given distance, along a concentric circle with a radius of 1.1mm (R1) is in the range of ±45mT to ±75mT (see Figure 31). Figure 31: Typical Magnet (6x3mm) and Magnetic Field Distribution typ. 6mm diameter N S Magnet axis R1 Magnet axis Vertical field component R1 concentric circle; radius 1.1mm Vertical field component Bv (45…75mT) 0 360 360 ams Datasheet [v2-00] 2016-Feb-05 Page 33 Document Feedback AS5045B − Application Information Physical Placement of the Magnet The best linearity can be achieved by placing the center of the magnet exactly over the defined center of the chip as shown in the drawing below: Figure 32: Defined Chip Center and Magnet Displacement Radius 3.9mm 3.9mm 2.4325mm 1 Defined center 2.4325mm Rd Area of recommended maximum magnet misalignment Magnet Placement The magnet’s center axis must be aligned within a displacement radius Rd of 0.25mm from the defined center of the IC. The magnet can be placed below or above the device. The distance can be chosen such that the magnetic field on the die surface is within the specified limits (see Figure 32). The typical distance “z” between the magnet and the package surface is 0.5mm to 1.5mm, provided the use of the recommended magnet material and dimensions (6mm x 3mm). Larger distances are possible, as long as the required magnetic field strength stays within the defined limits. A magnetic field outside the specified range still can be detected by the chip. But the out-of-range condition will be indicated by MagINCn (pin 1) and MagDECn (pin 2), (see Figure 4). Page 34 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Application Information Failure Diagnostics The AS5045B also offers several diagnostic and failure detection features: Magnetic Field Strength Diagnosis By software: the MagINC and MagDEC status bits will both be high when the magnetic field is out of range. By hardware: Pins #1 (MagINCn) and #2 (MagDECn) are open-drain outputs and will both be turned on (= low with external pull-up resistor) when the magnetic field is out of range. If only one of the outputs are low, the magnet is either moving towards the chip (MagINCn) or away from the chip (MagDECn). Power Supply Failure Detection By software: If the power supply to the AS5045B is interrupted, the digital data read by the SSI will be all “0”s. Data is only valid, when bit OCF is high, hence a data stream with all “0”s is invalid. To ensure adequate low levels in the failure case, a pull-down resistor (~10kΩ) must be added between pin DIO and VSS at the receiving side. By hardware: The MagINCn and MagDECn pins are open drain outputs and require external pull-up resistors. In normal operation, these pins are high ohmic and the outputs are high (see Figure 14). In a failure case, either when the magnetic field is out of range of the power supply is missing, these outputs will become low. To ensure adequate low levels in case of a broken power supply to the AS5045B, the pull-up resistors (~10kΩ) from each pin must be connected to the positive supply at pin 16 (VDD5V). By hardware: PWM output: The PWM output is a constant stream of pulses with 1kHz repetition frequency. In case of power loss, these pulses are missing. ams Datasheet [v2-00] 2016-Feb-05 Page 35 Document Feedback AS5045B − Application Information Angular Output Tolerances Accuracy Accuracy is defined as the error between measured angle and actual angle. It is influenced by several factors: • The non-linearity of the analog-digital converters • Internal gain and mismatch errors • Non-linearity due to misalignment of the magnet As a sum of all these errors, the accuracy with centered magnet = (Errmax – Errmin)/2 is specified as better than ±0.5 degrees @ 25ºC (see Figure 34). Misalignment of the magnet further reduces the accuracy. (see Figure 33) shows an example of a 3D-graph displaying non-linearity over XY-misalignment. The center of the square XY-area corresponds to a centered magnet (see dot in the center of the graph). The X- and Y- axis extends to a misalignment of ±1mm in both directions. The total misalignment area of the graph covers a square of 2x2mm (79x79mil) with a step size of 100μm. For each misalignment step, the measurement as shown in Figure 34 is repeated and the accuracy (Errmax – Errmin)/2 (e.g. 0.25º in Figure 34) is entered as the Z-axis in the 3D-graph. Figure 33: Example of Linearity Error Over XY Misalignment 6 5 4 ° 3 800 500 2 200 1 -100 -800 -1000 -1000 -600 -400 0 -700 -200 200 600 y Page 36 Document Feedback x -400 400 1000 800 0 ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Application Information The maximum non-linearity error on this example is better than ±1 degree (inner circle) over a misalignment radius of ~0.7mm. For volume production, the placement tolerance of the IC within the package (±0.235mm) must also be taken into account. The total nonlinearity error over process tolerances, temperature and a misalignment circle radius of 0.25mm is specified better than ±1.4 degrees. The magnet used for this measurement was a cylindrical NdFeB (Bomatec® BMN-35H) magnet with 6mm diameter and 2.5mm in height. Figure 34: Example of Linearity Error Over 360º 0.5 0.4 0.3 0.2 transition noise 0.1 Err max 0 -0.1 1 55 109 163 217 271 325 379 433 487 541 595 649 703 757 811 865 919 973 Err min -0.2 -0.3 -0.4 -0.5 Transition Noise Transition noise is defined as the jitter in the transition between two steps. Due to the nature of the measurement principle (Hall sensors + Preamplifier + ADC), there is always a certain degree of noise involved. This transition noise voltage results in an angular transition noise at the outputs. It is specified as 0.06 degrees rms (1 sigma)x1. This is the repeatability of an indicated angle at a given mechanical position. The transition noise has different implications on the type of output that is used: • PWM interface: If the PWM interface is used as an analog output by adding a low pass filter, the transition noise can be reduced by lowering the cutoff frequency of the filter. If the PWM interface is used as a digital interface with a counter at the receiving side, the transition noise can be further reduced by averaging of readings. • Incremental mode: In incremental mode, the transition noise influences the period, width and phase shift of the output signals A, B and Index. However, the algorithm used to generate the incremental outputs guarantees no missing or additional pulses even at high speeds (up to 15,000 rpm and higher). ams Datasheet [v2-00] 2016-Feb-05 Page 37 Document Feedback AS5045B − Application Information Note(s): Statistically, 1 sigma represents 68.27% of readings and 3 sigma represents 99.73% of readings. High Speed Operation • Sampling Rate: The AS5045B samples the angular value at a rate of 10.42k samples per second. Consequently, the absolute outputs are updated each 96μs. At a stationary position of the magnet, the sampling rate creates no additional error. • Absolute Mode: At a sampling rate of 10.4kHz, the number of samples (n) per turn for a magnet rotating at high speed can be calculated by (EQ3) n= 60 -------------------------rmp ⋅ 96μs The upper speed limit is ~30,000 rpm. The only restriction at high speed is that there will be fewer samples per revolution as the speed increases (see Figure 13). Regardless of the rotational speed, the absolute angular value is always sampled at the highest resolution of 12-bit. • Incremental Mode: Incremental encoders are usually required to produce no missing pulses up to several thousand rpm. Therefore, the AS5045B has a built-in interpolator, which ensures that there are no missing pulses at the incremental outputs for rotational speeds of up to 15,000 rpm, even at the highest resolution of 12 bits (4096 pulses per revolution). Propagation Delays The propagation delay is the delay between the time that the sample is taken until it is converted and available as angular data. This delay is 96μs. Using the SSI interface for absolute data transmission, an additional delay must be considered, caused by the asynchronous sampling (0 … 1/fsample) and the time it takes the external control unit to read and process the angular data from the chip (maximum clock rate = 1MHz, number of bits per reading = 18). Angular Error Caused by Propagation Delay A rotating magnet will cause an angular error caused by the output propagation delay. This error increases linearly with speed: (EQ4) e sampling = rpm * 6 * prop.delay Where: esampling = angular error [º] rpm = rotating speed [rpm] prop.delay = propagation delay [seconds] Note(s): Since the propagation delay is known, it can be automatically compensated by the control unit processing the data from the AS5045B. Page 38 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Application Information Internal Timing Tolerance The AS5045B does not require an external ceramic resonator or quartz. All internal clock timings for the AS5045B are generated by an on-chip RC oscillator. This oscillator is factory trimmed to ±5% accuracy at room temperature (±10% over full temperature range). This tolerance influences the ADC sampling rate and the pulse width of the PWM output: Absolute output; SSI interface: A new angular value is updated every 96μs (typ). PWM output: A new angular value is updated every 96μs (typ). The PWM pulse timings Ton and Toff also have the same tolerance as the internal oscillator. If only the PWM pulse width Ton is used to measure the angle, the resulting value also has this timing tolerance. However, this tolerance can be cancelled by measuring both Ton and Toff and calculating the angle from the duty cycle (see Pulse Width Modulation (PWM) Output). Temperature Magnetic Temperature Coefficient One of the major benefits of the AS5045B compared to linear Hall sensors is that it is much less sensitive to temperature. While linear Hall sensors require a compensation of the magnet’s temperature coefficients, the AS5045B automatically compensates for the varying magnetic field strength over temperature. The magnet’s temperature drift does not need to be considered, as the AS5045B operates with magnetic field strengths from ±45…±75mT. Example: A NdFeB magnet has a field strength of 75mT @ –40ºC and a temperature coefficient of -0.12% per Kelvin. The temperature change is from -40ºC to 125ºC = 165K.The magnetic field change is: 165 x -0.12% = -19.8%, which corresponds to 75mT at -40ºC and 60mT at 125ºC. The AS5045B can compensate for this temperature related field strength change automatically, no user adjustment is required. Accuracy over Temperature The influence of temperature in the absolute accuracy is very low. While the accuracy is less than or equal to ±0.5º at room temperature, it can increase to less than or equal to ±0.9º due to increasing noise at high temperatures. Timing Tolerance over Temperature The internal RC oscillator is factory trimmed to ±5%. Over temperature, this tolerance can increase to ±10%. Generally, the timing tolerance has no influence in the accuracy or resolution of the system, as it is used mainly for internal clock generation. The only concern to the user is the width of the PWM output pulse, which relates directly to the timing tolerance of the internal oscillator. This influence however can be cancelled by measuring the complete PWM duty cycle instead of just the PWM pulse. ams Datasheet [v2-00] 2016-Feb-05 Page 39 Document Feedback AS5045B − Package Drawings & Markings Package Drawings & Markings The device is available in SSOP 16 (5.3mm x 6.2mm). Figure 35: Package Drawings and Dimensions RoHS Green Symbol Min Nom Max A A1 A2 b c D E E1 e L L1 L2 R Q N 1.73 0.05 1.68 0.22 0.09 5.90 7.40 5.00 0.55 0.09 0º 1.86 0.13 1.73 0.315 0.17 6.20 7.80 5.30 0.65 BSC 0.75 1.25 REF 0.25 BSC 4º 16 1.99 0.21 1.78 0.38 0.25 6.50 8.20 5.60 0.95 8º YYWWMZZ @ AS5045B Note(s): 1. Dimensions and tolerancing conform to ASME Y14.5M-1994. 2. All dimensions are in millimeters. Angles are in degrees. Figure 36: Package Code: YYWWMZZ YY WW M ZZ @ Last two digits of the manufacturing year Manufacturing week Plant identifier Assembly traceability code Sublot identifier Page 40 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Package Drawings & Markings Figure 37: Vertical Cross Section of SSOP-16 Note(s): 1. All dimensions in mm. ams Datasheet [v2-00] 2016-Feb-05 Page 41 Document Feedback AS5045B − Package Drawings & Markings Recommended PCB Footprint Figure 38: PCB Footprint Recommended Footprint Data Symbol mm A B C D E Page 42 Document Feedback 9.02 6.16 0.46 0.65 5.01 ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Ordering & Contact Information Ordering & Contact Information The devices are available as the standard products shown in Figure 39. Figure 39: Ordering Information Ordering Code Package AS5045B-ASST SSOP 16 (5.3mm x 6.2mm) AS5045B-ASSM Description Delivery Form Delivery Quantity Pre-programmed 12-bit incremental (125 °C) Tape&Reel (13”) 2000 pcs/reel Pre-programmed 12-bit incremental (125 °C) Tape&Reel (7”) 500 pcs/reel Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbaderstrasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v2-00] 2016-Feb-05 Page 43 Document Feedback AS5045B − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 44 Document Feedback ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v2-00] 2016-Feb-05 Page 45 Document Feedback AS5045B − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 46 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Revision Information Revision Information Changes from 1.1 (2014-Sep-16) to current revision 2-00 (2016-Feb-05) Page Content was updated to the latest ams design Added benefits to the Figure 1 1 Updated Figure 6 6 Updated text above Figure 7 9 Updated text above Figure 8 10 Updated text above Figure 10 12 Updated Figure 36 40 Updated Figure 39 43 Note(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. ams Datasheet [v2-00] 2016-Feb-05 Page 47 Document Feedback AS5045B − Content Guide Content Guide Page 48 Document Feedback 1 1 2 2 General Description Key Benefits & Features Applications Block Diagram 3 5 Pin Assignment Absolute Maximum Ratings 6 9 10 Electrical Characteristics Magnetic Input Specification System Specifications 12 Timing Characteristics 13 14 17 20 20 20 22 23 24 Detailed Description Synchronous Serial Interface (SSI) Incremental Mode Sync Mode Sin/Cosine Mode Daisy Chain Mode Pulse Width Modulation (PWM) Output Changing the PWM Frequency Analog Output 25 25 26 27 28 28 28 30 30 31 32 33 34 34 35 35 35 36 36 37 38 38 39 39 39 Application Information Programming the AS5045B Zero Position Programming OTP Memory Assignment User Selectable Settings OTP Default Setting Redundancy Redundant Programming Option OTP Register Entry and Exit Condition Alignment Mode 3.3V / 5V Operation Selecting Proper Magnet Physical Placement of the Magnet Magnet Placement Failure Diagnostics Magnetic Field Strength Diagnosis Power Supply Failure Detection Angular Output Tolerances Accuracy Transition Noise High Speed Operation Propagation Delays Internal Timing Tolerance Temperature Accuracy over Temperature ams Datasheet [v2-00] 2016-Feb-05 AS5045B − Content Guide ams Datasheet [v2-00] 2016-Feb-05 40 42 Package Drawings & Markings Recommended PCB Footprint 43 44 45 46 47 Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information Page 49 Document Feedback
AS5045B-ASST 价格&库存
很抱歉,暂时无法提供与“AS5045B-ASST”相匹配的价格&库存,您可以联系我们找货
