IF E99B
156 Mbps Plastic Fiber Optic Red LED
4/2/12
Description
The IF-E99B is a very high-speed red LED housed in a “connector-less” style plastic fiber
optic package. The output spectrum of the IF-E99B is produced by a GaAIAs die that peaks
at a wavelength of 650 nm, one of the optimal transmission windows of PMMA plastic
optical fiber. The device package features an internal micro-lens, and a precision-molded
PBT housing ensures efficient optical coupling with standard 1000 µm core plastic
fiber cable.
Application Highlights
The fast transition times of the IF-E99B make it suitable for high-speed digital data links.
Link distances in excess of 75 meters at data rates of 156 Mbps are possible using standard
1000 µm core plastic fiber and an IF-D98 photologic detector. The wide analog bandwidth
permits direct modulation at RF frequencies exceeding 70MHz. Drive circuit design for the
IF-E99B requires good RF and digital design techniques, but is much simpler than required
for laser diodes, making it a good low-cost solution in a variety of high frequency POF
analog and digital applications.
Applications
➤ PC-to-Peripheral Data Links
➤ Motor Controller Triggering
➤ Ethernet LANs
Features
➤ Medical Instruments
◆ No Optical Design Required
➤ Automotive Electronics
◆ Mates with Standard 1000 µm Core Jacketed Plastic Fiber Cable
➤ Digitized Video and HDTV
◆ Internal Micro-lens for Efficient Coupling
➤ Sonet/SDH Transmitters
➤ Robotics Communications
◆ Inexpensive Plastic Connector Housing
➤ Isolation from Lightning and
Voltage Transients
◆ Connector-Less Fiber Termination and Insertion
◆ Interference-Free Transmission from Light-Tight Housing
◆ Excellent Linearity
◆ Visible Light Output
◆ RoHS compliant
Maximum Ratings
(TA =25°C)
Operating Temperature Range
(TOP)...........................-0°to 60°C
Storage Temperature Range
(TSTG)......................-40° to 85°C
Junction Temperature (TJ).........75°C
Soldering Temperature
(2mm from case bottom)
(TS) t ≤ 5 s..........................240°C
Reverse Voltage (VR)....................3 V
Characteristics (TA =25°C)
Parameter
Peak Wavelength
Spectral Bandwidth (50% of IMAX)
Output Power Coupled into Plastic Fiber
(1 mm core diameter). Lens to Fiber
distance ≤ .1 mm, 1m SH4001 fiber,
IF =per circuit (50% Duty Cycle)
IF=20 mA DC
Switching Times (10% to 90% and
90% to 10%) (RL =47Ω, IF =10 mA)
Power Dissipation
(PTOT) TA =25°C...........130 mW
Capacitance (VF=0, F=1 MHz)
De-rate Above 25°C.......1.7 mW/°C
Cut off frequency
Forward Current, DC (IF)......50 mA
De-rate Above 25°C......0.57 mA/°C
Forward Voltage (IF =30 mA)
Symbol
Min.
Typ.
Max.
Unit
∆λ
10
nm
PEAK
Φ
640
650
660
nm
355
-4.5
630
-2.0
1120
+0.5
µW
dBm
449
796
1415
µW
tr, tf
C0
3
6.5
ns
fc
60
1.9
70
2.4
Vf
pF
MHz
CAUTION: The IF E99B is Class 1B ESD sensitive per testing using the HBM: 1.5k Ohm; 100 pF; +/- 1000V.
To minimize risk of damage observe appropriate precautions during handling and processing.
I ndustrial F iber O ptics , I nc . • www.i-fiberoptics.com
V
Relative fiber-coupled optical output power (%)
IF E99B
(Typ. Ta=25 ˚C, IF=20 mA)
120
100
80
60
40
620
660
640
680
700
Wavelength (nm)
Figure 1. Relative intensity versus wavelength.
Figure 3. Typical interface circuit.
(Measured with the recommended driver circuit)
140
Fiber Termination Instructions
120
1. Cut off the ends of the optical fiber with a singleedge razor blade or sharp knife. Try to obtain a
precise 90-degree angle (square).
100
80
2. Insert the fiber through the locking nut and into
the connector until the core tip seats against the
internal micro-lens.
60
40
3. Screw the connector locking nut down to a snug fit,
locking the fiber in place.
-20
60
80
Ambient temperature (ºC)
Figure 2. Optical power output versus temperature (IF=20mA)
NOTE: To avoid degraded device life due to package stress, do not bend or form leads outside the orientation shown on drawing.
Figure 4. Case outline.
Specifications are believed to be accurate but are subject to change. Industrial Fiber Optics assumes no
responsibility for the consequences of using the information provided beyond replacement warranty for
products not meeting stated specifications. Industrial Fiber Optics products are not authorized for use in
life support applications without written approval from the President of Industrial Fiber Optics Corporation.
很抱歉,暂时无法提供与“IF-E99B”相匹配的价格&库存,您可以联系我们找货
